cigarette lighter fuse replacement - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > Z Series > E89 Z4 (2009 - current)
Old 01-30-2019, 10:26 AM
jdsisley jdsisley is offline
Mein Auto: 2007 530Xi..2012 s35i Z4
I have a 2012 35is and can anyone direct me as to which fuse in the fuse box ties into the cigarette lighter socket in the armrest? Evidently it is blown as it will not provide juice to anything I try plugging into it. The manual instructions are rather vague and frustrating to say the least!
Thanx...JDS
"It's so choice...if you have the means I highly recommend you picking one up"....F. Bueller
Old 01-30-2019, 10:29 AM
Doug Huffman's Avatar
Doug Huffman Doug Huffman is online now
Nuclear engineer
WwwlNewTIS.info. Enter with your VIN-7, browse / search.
Many BMW lighter circuits are off while the car is off to protect the battery.
Old 01-30-2019, 10:39 AM
Thanx so much for the prompt response Doug but I am aware that the plug will not operate until the engine has been fired up. I have never had a problem with it before as I utilize it to charge my phone while driving.
JDS
Old 01-30-2019, 08:01 PM
Ziggy328xi Ziggy328xi is offline
Ziggy.
Mein Auto: 11 328xi N51
think its probably fuse 54 a 20A fuse if its similar to half the other bmws out there. there should be a little paper diagram inside the fuse panel though the symbol for power points is a little thing with a + and - symbol
Old 01-31-2019, 04:58 AM
Thanx Ziggy...and you are somewhat correct as I was told through another Z4 forum that it was indeed the graphic you had mentioned and it is socket #8 using a 20 AMP fuse. Unfortunately I could not locate the diagram in the fuse area so I was flying blindfolded
Old 02-02-2019, 08:03 AM
Squiddie's Avatar
Squiddie Squiddie is offline
BMW Snow Plow User
Mein Auto: e89 Z4, e46 330Ci vert
The fuse box access in the e89 is atrocious. Good luck.
Someday somebody will total one of these cars over a blown fuse
HTML code is Off
Similar Threads
Cigarette lighter (on dash) fuse number for 2007 e60 turkiye E60 / E61 (2004 - 2010) 4 12-26-2018 07:21 AM
Cigarette lighter fuse eusjro F06 Gran Coupe (2013 - 2018) 2 11-03-2018 10:39 AM
DIY. Replacing cigarette lighter receptacle without taking apart half your interior EconoBox E39 (1997 - 2003) 9 09-17-2018 04:19 AM
DIY. Replacing cigarette lighter receptacle without taking apart half your interior EconoBox E46 (1999 - 2006) 0 09-14-2018 07:24 PM
Cigarette lighter inoperable ZIGGURAT89 3 Series & 4 Series 7 01-14-2003 07:31 PM
