2006 650I aux input retrofit through cd changer - Bimmerfest - BMW Forums
Old 01-09-2013, 04:28 PM
tk123 tk123 is offline
Mein Auto: 650 ic
has anyone done this retrofit?
Old 01-09-2013, 05:23 PM
I don't know of any simple adapter that allows you to replace the replace the CD and end up with just an Aux input. You can have an Ipod (Iphone) adapter, they run $350 or so. There is a Dension Gateway that I believe has Aux along with Ipod functionality, it runs $450 or more. The problem is that the CD Changer is connector to the MOST bus which is Fiber Optic signal. So you have to have an Analog to Fiber Optic Digital converter of some type.
To add Aux input to your car and you are good with a DIY you could buy the Aux Input kit from BMW, take apart your center console to connect the wires, then pay the dealer to code it to your car (or learn how to code yourself). From memory the Aux In kit runs around $80, then the dealer programming runs $150 to $250, all depends on your dealer.
Link to a previous post:
https://www.bimmerfest.com/forums/sho...42#post6959042
Link to detailed install instructions:
https://www.bimmerfest.com/forums/sho...d.php?t=124742
Old 01-09-2013, 06:37 PM
Mein Auto: 650 ic
I once saw a post that read : unplug changer and plug in aux in place of changer but u still need to have dealer to reprogram. I am trying to find that thread again. Thanks
Old 07-22-2019, 05:30 PM
Brandovibe Brandovibe is offline
Mein Auto: 650I
Did you ever figure this out? I bought the cable and had a shop take my dash apart and plug in the aux cable in place of the cd changer, but it didn't work. I saw some stuff about having to reprogram or code the computer for it to work but i'm wondering if that was with this cd changer swap thing?
Old 07-22-2019, 08:21 PM
HerbP HerbP is offline
Super Moderator
Mein Auto: 05 645Ci, 14 750 M-Sport
You re replying to post that are 6 years old, most members are still not around. It would be much easier to start your on thread. If you searched the sticky at the top of the page to the DIY section, you will find what you are looking for. The CD changer is only removed to use an IPod to replace the CD player. All of this has to be coded, which is not that hard with the proper tools. The AUX input needs to be coded in the IDrive settings, then the cable needs to be configured. It is not that hard to do, & quite cheap. There is not a way to stream music by way of Bluetooth, with your current configuration. You will need a copy of BMW Standard Tools, using NCSExpert to make the coding change. You will also need a OBD2 cable that is correctly configured to work with the software. All of this can be download online for free. Go to the Coding Forum to find what you need. The coding guys can be quite rude at times if you do not put your time in searching for a solution, so please don't insult them. There is plenty of info on the web to help!
Old 07-22-2019, 08:29 PM
Super Moderator
I deleted your 2 other threads where all questions can be kept to one thread. This will help you get all of your answers in one place.
Old 07-22-2019, 08:30 PM
Mein Auto: 650I
Thank you. Forgive me for my ignorance, I do not know what a sticky is. I will go to the DIY section and see if i can find it.
Old 07-22-2019, 09:00 PM
Super Moderator
Look at the top of the page in the 1st 5 threads, they will have Sticky on them. They are there to help members with common info that is needed.
https://www.bimmerfest.com/forums/sh....php?t=1309251
Old 07-24-2019, 08:44 AM
AusieE46 AusieE46 is offline
Mein Auto: 2007 650i convertible
Yep. https://www.ebay.com.au/itm/Bluetoot....c100013.m1986 Works great. https://www.bimmerfest.com/forums/sh....php?t=1248954
BMW 650i Individual Convertible
Porsche 911 Wide Body Sport Edition Convertible
Mercedes Benz Custom Convertible
Volvo S60 T6 AWD
