Streaming music to early 2006 BMW 650i - Bimmerfest - BMW Forums
Old 07-11-2015, 04:50 PM
Themoosieman Themoosieman is offline
Mein Auto: BMW 650i
Looking to improve the audio set up now that I've some new subs on my 2006 650i.
I have the Logic 7 upgrade/
While I can pair my phone, the bluetooth doesn't seem to support music streaming from my iPhone, is there really nothing that can be done to allow music to be streamed and not only call audio?
If that doesn't work, is there any way to either get a 3.5mm jack aux in? Either from abandoning the DVD or CD player?
Or is the only solution a FM transmitter attached to my iPhone and tuning in via radio?
Old 07-11-2015, 06:17 PM
HerbP HerbP is offline
Super Moderator
Mein Auto: 05 645Ci, 14 750 M-Sport
I found an App the other day called BTmono, but it is only mono. You can purchase an adapter to remove the CD changer in the glove box, & install the IPhone adapter. There are some threads on the 7 Series forum in a sticky, that should help you out.
Old 07-11-2015, 11:07 PM
Other than the cool mono-bluetooth streaming that Herb mentions there is no option. Keep in mind that your 2006 has old technology that was created in the late 90's early 2000's. Stereo streaming is not an OEM option on your 6 and there is no OEM retrofit.
As far as Aux In kit, search and you will find many threads on the subject. There is an OEM retrofit option, I am not sure how good you are at tearing apart the trim of your dash, but for as little as $25 you can get an ebay aftermarket kit that will provide the hardware. Then you would have to have the car programmed to recognize the new hardware, this you can do yourself if you are familiar with BMW coding. If not, you would need to pay someone, or a dealer, to do it for you (up to $150).
Old 07-11-2015, 11:50 PM
rawdog805 rawdog805 is offline
Mein Auto: 05 645Ci
Aux in kit and Bluetooth dongle will get you wireless streaming. I have it set up in my car.
2005 645 Ci (Sold)
8000K HID Bulbs + 7W Ebay Halos & Fog Lights + 21" 128 Style Wheels + K&N Air Filter + Replica CSR Front Lip + Triple Resonator Delete with X-Pipe + Aux Input with Bluetooth Dongle +
2002 745 LI (Sold)
2006 X5 (Sold)
Old 07-12-2015, 08:33 AM
Mein Auto: BMW 650i
Thanks, do you have a link to a particular Aux In and Bluetooth kit? How much was it to instal?
Old 07-12-2015, 07:54 PM
Super Moderator
Look at the 7 Series forum for E65 & E66 sticky.
Old 07-12-2015, 08:08 PM
Mein Auto: 05 645Ci
The aux in that I purchased was from ebay seller roskinc.. Check the link below..
http://www.ebay.com/itm/301640735859...859%26_rdc%3D1
2005 645 Ci (Sold)
2002 745 LI (Sold)
2006 X5 (Sold)
Old 07-13-2015, 10:21 AM
RooK77 RooK77 is offline
Mein Auto: 645i
This cable works really well.
Old 08-12-2015, 06:00 PM
guty59 guty59 is offline
Mein Auto: 2003 525i
Do you have to reprogram by dealer?
Old 08-12-2015, 06:09 PM
Super Moderator
Someone will need to code in the Aux port.
Old 08-13-2015, 05:08 AM
Mein Auto: 645i
You can check this video:
Old 08-13-2015, 08:31 AM
Thanks RooK77
Old 08-17-2015, 09:35 AM
StikiGreenZ StikiGreenZ is offline
Mein Auto: BMW 645i
Just ordered that cable, gonna hook it up to a Bluetooth dongle and have bluetooth audio finally!
BMW 645i - Black on Red
Range Rover Sport - Black on Black
Old 07-22-2019, 04:42 PM
Brandovibe Brandovibe is offline
Mein Auto: 650I
Where does it plug into the car though?
Old 07-23-2019, 04:38 AM
Mein Auto: 645i
OBDII port
Old 07-23-2019, 10:16 AM
Mein Auto: 650I
Originally Posted by RooK77 View Post
OBDII port
Thanks, but i meant the actual cable, not where you plug in to program it.
Old 07-23-2019, 08:51 PM
Super Moderator
Look up under the dash on the drivers side, down by the left foot area. There will be a small flap that pulls down, & that will be the OBD2 port. The cable is BMW specific to work with the BMW software, so just not any cable will work.
Old 07-24-2019, 12:29 AM
Hsurf's Avatar
Hsurf Hsurf is offline
Super Moderator
Mein Auto: E63 645ci
OBDII port
There's a complete guide to fitting this via the two YouTube vids at the bottom of the page in the DIY section, E63/64 Audio, Navigation and Electronic Systems ***x1f44d;.
Neal.
_________________
E63 645Ci
Toyota Hilux Surf 3.0
Honda CBR1100XX
_________________
Old 07-24-2019, 01:59 PM
Mein Auto: 650I
Thanks, but im not talking about the OBD port. IM saying once you buy the cable that you use for the AUX input to plug into, where does that go into the car? I have the cable hooked up to i believe the input where the cd changer used to go. I was told that would work when i bought the cable but it didn't. WOndering if its plugged into the right spot or not.
Old 07-24-2019, 02:00 PM
Mein Auto: 650I
Great! Thanks so much for the guidance
