7 Series - F01 / F02 (2009 - 2015) - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series & 8 Series > 7 Series - F01 / F02 / F03 / F04 (2008 - 2015)
The 5th generation F01/F02/F03/F04 BMW 7 Series flagship forum. The redesigned 7 series leads off the BMW Fxx chassis code, offering an 8 speed automatic transmission and all turbocharged engine options.
Old 07-26-2019, 03:08 AM
iosman123 iosman123 is offline
Mein Auto:
Hello,
I took my car to the dealership for the dreaded Drivetrain malfunction and I had a loud rattle under my car that needed to be diagnosed. The rattle was a bolt that was loose underneath my car which I attributed to not being tightened when they replaced engine a few months ago. found out that I need this sensor that is located behind the manifold and you need to remove a good portion of stuff to get to and its labor intensive. Part is a 174.00 and total bill will be 762.00 to fix. The mechanic said not to worry too much and I can take my time fixing it, I will just notice a difference in my gas mileage.
thanks
iosman
Old 08-22-2019, 12:44 AM
Mein Auto:
Originally Posted by iosman123 View Post
Hello,
I took my car to the dealership for the dreaded Drivetrain malfunction and I had a loud rattle under my car that needed to be diagnosed. California air tools 10020c The rattle was a bolt that was loose underneath my car which I attributed to not being tightened when they replaced engine a few months ago. found out that I need this sensor that is located behind the manifold and you need to remove a good portion of stuff to get to and its labor intensive. Part is a 174.00 and total bill will be 762.00 to fix. The mechanic said not to worry too much and I can take my time fixing it, I will just notice a difference in my gas mileage.
thanks
iosman
thanks my issue has been fixed.
Old 08-22-2019, 07:24 AM
hgarcia hgarcia is online now
Mein Auto: 750Li
how much did they end up charging you
