Car Shudders at 1500 rpm - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series & 8 Series > 7 Series - F01 / F02 / F03 / F04 (2008 - 2015)
The 5th generation F01/F02/F03/F04 BMW 7 Series flagship forum. The redesigned 7 series leads off the BMW Fxx chassis code, offering an 8 speed automatic transmission and all turbocharged engine options.
Old 06-25-2019, 05:58 PM
isstatu1 isstatu1 is offline
Mein Auto: 2010 750Li
My 2010 750li often shudders and shakes when it gets to 1500 rpm. At firat I thought it was the tranny, but after I shifted in manual it does it on the 2nd as well as 1st gear. It doesn't do it when I step on the gas, or when I'm really easy on it. So basically it does it when accelerating normally. When it gets to speed it doesn't do it anymore, just when starting to move. No codes or any lights on the dash. Any ideas?
Old 06-25-2019, 08:03 PM
HerbP HerbP is offline
Super Moderator
Mein Auto: 05 645Ci, 14 750 M-Sport
It could possibly be the transmission is low on fluid, it will not signal a code. The fluid usually gets cooked from heat, then it starts getting low on fluid. The fluid should be changed at 50k mile intervals. Usually you will get a transmission warning when the fluid pressure gets low, due to the Mechatronic Adapter Sleeve gets hard, & does not seal properly.
Old 06-26-2019, 05:00 AM
Should I change anything else in the transmission while I'm in there?
Old 06-26-2019, 07:12 AM
rafiqi rafiqi is offline
Mein Auto: 2006 e65
Might be a ignition coil about to go out. Try getting a scan.
Old 07-02-2019, 07:29 PM
Did the spark plugs and ignition coils. Nothing changed. Will try to do the tranny flush next.
Old 07-02-2019, 08:55 PM
Robin750 Robin750 is offline
Mein Auto: 2013 750i and 2015 740i
Drain and fill, do not flush. Make sure to change the pan when you get this done and that the shop knows the procedure (and has the diagnostic equipment) to fill the fluid at the right temperature.
2015 BMW 740i and 2013 BMW 750i (current)
2011 BMW 750i (previous)
2002 BMW 745i (previous)
2001 Lexus LS430 (previous)
delete pls 8K
*NEW* delete pls 8K
Old 07-03-2019, 03:03 AM
Got it, thank you!
Old 07-05-2019, 08:58 AM
Is there anything else besides the pan that should be changed while the fluid is being changed?
Old 07-05-2019, 09:16 AM
As Herb mentioned, the mechatronics sleeve and adapter seals can also be a source of problems, though those usually cause more serious problems or trigger fault codes due to low fluid pressure.
The mechatronics has to be removed to replace these seals so there will be some more labor involved, but if you've got around 100K miles, it might not be a bad idea to replace these as a preventative measure since you've already got the fluid drained and pan off. Make sure the shop is familiar with these transmissions as reinstalling it incorrectly can cause serious problems or damage.
Here's a relevant thread about these seals:
https://www.bimmerfest.com/forums/sh...d.php?t=995002
delete pls 8K
*NEW* delete pls 8K
Old 07-25-2019, 06:09 PM
Did the service for the transmission. The shop said the fluid was low, but it still shudders at 1500rpm. Any more ideas?
Old 07-25-2019, 10:37 PM
Did they reset the valve body adaptations? If so, the transmission should shift rough for a couple hundred miles.
delete pls 8K
*NEW* delete pls 8K
Old 07-26-2019, 05:20 AM
It's possible they did not. Is there a specific driving procedure after the adaptation, or is it just a button click in ISTA? I found instructions for an older Exx model that has instructions of a particular acceleration procedure after a reset that has to be repeated 9 times, but nothing for the F02 model.
Old 07-26-2019, 09:10 AM
It's in the EGS ECU functions. There is no special driving procedure needed, just drive the car normally at varying speeds so it can determine the adaptations.
delete pls 8K
*NEW* delete pls 8K
Old 07-29-2019, 03:34 PM
Did the adaptation. I don't notice any changes so far. Still shudders, but it feels like it gets pretty high in the RPM range to do the shift.. It feels like it's hesitating a little bit. I'm adding a screencap from ISTA before the adaptation.
Old 10-17-2019, 01:18 PM
Turns out it was a failed transfer case mount. Replaced it. Still does a very small shudder, but way better. And crazy vibrations when accelerating are barely noticeable now.
Has anyone replaced their transfer case? Do they have any electrical components or are they purely mechanical?
If I need to replace it, should I get a new one or a used one should do?
Old 10-17-2019, 02:57 PM
Carbonblack12 Carbonblack12 is offline
Mein Auto: 2012 750i xDrive
Any updates on this? Mine does something similar. Mine does it if I drive a little aggressive. If I'm driving normal, it simmers down a bit, but may still sporadically do this. I really don't want to raise my car just to check the tranny fluid either. Although, I would rather do that than change anything out. lol
Nevermind, I missed your recent post.
Old 10-17-2019, 03:02 PM
I wouldn't wait to fix it. It's only going to get worse. How many miles do you have on your 7? It could be low on transmission fluid. Try going to a parking lot and basically turning your wheel to one side and another and go. Does it ahudder then? Mine didn't when I did that which made me think that's not a transmission issue.
Old 10-17-2019, 03:10 PM
paprmkr's Avatar
paprmkr paprmkr is offline
Mein Auto: 2010 BMW 750Li
I got transmission replaced at about 75K miles haven't done service. currently at 168K since I didn't do it at 50K is it too late no issues guess reason I thought I shouldn't touch it
Old 10-17-2019, 06:44 PM
Super Moderator
That is sounding a COP problem at that speed under load. I would pull the COP's out to inspect them, to make sure they are not shorting out?
Old 10-17-2019, 06:46 PM
What's a COP?
Old 10-18-2019, 04:05 PM
Super Moderator
The COP is the coil pack on the spark plug.
Old 10-18-2019, 04:07 PM
Those were replaced and nothing changed.
Old 10-19-2019, 04:59 PM
Super Moderator
I would then verify that the grounds on the valve cover are attached for the coils, there will be 2 wires on each valve cover. I would then do a smoke test to see if there is a vacuum leak somewhere?
Old 10-19-2019, 05:21 PM
When I'm at a red light and I make a turn it doesn't do it. Could that still be a COP issue?
Old 10-21-2019, 05:34 AM
Also very rarely it throws a chassis stability malfunction light with the little 4x4 symbol. I turn the car off and back on and it disappears. It happens maybe once or twice a month.
