Aux Help - Bimmerfest - BMW Forums
Old 07-29-2019, 07:17 AM
ginomachino ginomachino is offline
Mein Auto:
Aux Help
Hello everyone. I recently purchased an 06 650i and have been trying to get the auxiliary input to work. I have done some research, purchased an inpa cable and downloaded and installed ncs expert. following guides online, i was able to successfully code the CCC, or so i thought. here is what is happening... if nothing is plugged into the input, i can select the aux input and go back to radio, no problem. If my phone is plugged in, as soon as i select the aux, the radio freezes and reboots.
During coding, i was able to add +NAUX to the vehicle order, changed AUX_CONFIG to mounted in CAPPL, and set CAUDI INPUT_SCALING_SUB2 to wert_02.
Thanks in advance!
Old 07-30-2019, 03:55 AM
Hsurf's Avatar
Hsurf Hsurf is offline
Super Moderator
Mein Auto: E63 645ci
I don't remember having to change the input_scaling when I did mine, since you've added +NAUX to the VO have you tried default coding the 4 modules associated with the CCC, some cars need this and some don't, just depends on their setup.
Neal.
_________________
E63 645Ci
Toyota Hilux Surf 3.0
Honda CBR1100XX
_________________
Old 07-30-2019, 06:14 AM
Mein Auto:
Oh nevermind. this was a total newb error on my part. I installed the pins on the wrong connector - idiot. to my defense, the connector i took the pins out of on the cable was white, so i installed the pins back into the white connector at the back of the radio, which is the driver's side one, and is of course wrong lol. Thanks for trying to help!
Old 07-30-2019, 06:25 AM
Hsurf's Avatar
Super Moderator
At least you found the problem relatively quickly and painlessly .
Neal.
_________________
E63 645Ci
Honda CBR1100XX
_________________
