Need help: Error code 400641 in ISTA....Parking gear Incorrectly Enegaged..2009 750li - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series & 8 Series > 7 Series - F01 / F02 / F03 / F04 (2008 - 2015)
The 5th generation F01/F02/F03/F04 BMW 7 Series flagship forum. The redesigned 7 series leads off the BMW Fxx chassis code, offering an 8 speed automatic transmission and all turbocharged engine options.
Old 04-15-2019, 06:20 PM
inbmwwetrust inbmwwetrust is offline
DoingAllright
Mein Auto: 2014 75OLI
Hi guys: Installed ISTA and read code which came back to code: 400461....Parking gear incorrectly engaged.
Symptoms are: Car will not move nor go into gear. Every time i move the shifter to any gear it defaults back to Park: My car is a 2009 750li XDrive with 130,200 miles on it.
Does anyone have good experience with this and or can shed a little light on what may be causing-this, thanks guys.
Replaced so far: rear trunk latch and actuator along with cable, front driver side window regulator, reprogrammed key fob, front trunk hood cables, front head light and fog lights, valve cover seals and gaskets plus timing cover gaskets
Old 04-15-2019, 06:40 PM
isstatu1's Avatar
isstatu1 isstatu1 is online now
Mein Auto: 2010 750Li
Check the coolant level, it might need to be topped off. Mine would default back to park when the coolant was low.
Old 04-15-2019, 08:54 PM
DoingAllright
Coolant is all good!
Old 04-16-2019, 08:22 PM
DoingAllright
Anyone else?
Old 07-25-2019, 07:54 PM
hgarcia hgarcia is offline
Mein Auto: 750Li
Originally Posted by inbmwwetrust View Post
Anyone else?
Just wondering, did you ever get the issue fixed?
Mine has currently been doing this as of late. I start the vehicle up, wait about 2 minutes, Shift to Drive (D) and it will take a few seconds and go back to Park (P). After that first try, I do it again and it I can pull off after about 5 seconds.
Old 07-31-2019, 03:43 PM
Prezzi Prezzi is offline
Mein Auto: 7 SERIES F01
Your gonna have to change the soleniod in the transmission. While your in there might aswell change the filter, fluid, and other plastic grommets. Well for now I would try resetting the transmission and engine adaptions in ista. Look under service functions.
Similar Threads
DIY - Convert X3 NA model front turn lights to EU requirements phuksi X3 E83 (2004 - 2010) 8 08-09-2017 03:21 AM
BMW Service Codes 00000000 through 09999999 mksu19 General BMW Questions 7 02-22-2013 06:07 PM
BMW Auto Lease Rates - November 2008 LeaseCompare Ask-A-BMW-Dealer 17 12-03-2008 09:26 AM
BMW Lease Rates - October 2008 **REVISED** LeaseCompare Ask-A-BMW-Dealer 12 11-08-2008 12:26 AM
BMW Lease Rates - October 2008 LeaseCompare Ask-A-BMW-Dealer 9 10-07-2008 11:45 AM
