2006 BMW 650i coupe x5 chrome 21 inch 5 spoke - Bimmerfest - BMW Forums
Old 07-30-2019, 03:55 PM
Mikeuno583 Mikeuno583 is offline
Mein Auto:
X5 21 inch chrome 5 star rim chrome what size tires can I fit on these 245/35/21 front 275/30/21 rear there wide 21x10
Front and 21x11.5 rear will these fit with these tires size
Old 07-30-2019, 07:50 PM
HerbP HerbP is offline
Super Moderator
Mein Auto: 05 645Ci, 14 750 M-Sport
Look in the DIY section & you will find a tire size chart, & a BMW wheel spec sheet. The offset will have to be accounted for with spacers, so pay close attention to the difference in offset difference in the rims.
Old 07-31-2019, 12:49 PM
Mein Auto:
Do you know what spacers will i need front rims are 10 and the rear 11.5 I think
Old 07-31-2019, 06:45 PM
Super Moderator
Look at the charts in the DIY. You need to input your set of wheels, then the size that will work without causing problems with the DME. I would not consider installing big spacers, since it can cause safety problems with the car.
https://www.bimmerfest.com/forums/sh....php?t=1309251
