Strange no starting issue with 645 anybody have any ideas please? - Bimmerfest - BMW Forums
Old 04-29-2019, 01:40 PM
wizzi07 wizzi07 is offline
Mein Auto: bmw 645ci e63
Hi, the last few months Iíve been having random no start problems, itís always when the car is warm after a drive this could be a 15minute drive or a couple of hours, i then turn off the car and try and start it again and it doesnít crank. I get all lights radio etc everything as normal it just doesnít turn over. I can hear a very faint click from the steering collum.. after leaving for around 15/20 normally it will fire right back up like there was never a issue. Iíve scanned it and there are no fault codes.
Anybody have any information that could help me or point me in the right direction would be greatly appreciated
Thanks in advance!
Sent from my iPhone using Bimmerfest mobile app
Old 04-29-2019, 01:47 PM
Doug Huffman's Avatar
Nuclear engineer
Charge your battery. The delay in starting is recovery of the surface charge.
Old 04-29-2019, 02:39 PM
Thanks for your rent! The battery is a brand new Bosch silver s5015 110a which was coded/registered when fitted,, i did wonder about the battery so I gave it a full charge overnight with a smart charger and it still happened the next day
Old 04-29-2019, 05:51 PM
HerbP HerbP is offline
Super Moderator
Mein Auto: 05 645Ci, 14 750 M-Sport
Most likely a bad IVM module.
Old 04-29-2019, 08:26 PM
The Thomas J The Thomas J is offline
Living the dream.
Mein Auto: 2004 645 convertible
Bad IVM. It's a simple DIY.
This is how I roll
Old 04-29-2019, 09:54 PM
+1 on IVM.
Sent from my iPad using Bimmerfest
Current:
2018 540ix
2015 428i convertible
2013 Cooper S
2007 650i - 6 speed
Past:
2012 X5 Diesel
2006 Cooper S - 6 speed
2006 330i - 6 speed
1997 328is - 5 speed
1991 318is - 5 speed
1988 635csi - 5 speed
Old 04-30-2019, 01:01 AM
Thanks guys! Any tests I can do to confirm itís the ivm? And anybody attempted repairing it or is it better to just replace it?.. hopefully Iíll have some time to remove it today and see if thereís anything obviously wrong with it, Iíll post pictures of it when it do.. thanks again!
Old 04-30-2019, 04:06 AM
Iíve ordered a new one from sytners to collect later today for £88.. Iíve removed the old ones thereís some slight corrosion but I wouldnít say it looked terrible? Click image for larger version
ID:	850047Click image for larger version
Old 04-30-2019, 07:00 PM
Super Moderator
You should be able to search IVM repair on the forum, there is usually a cold solder joint that fails. Since it controls everything on the engine & tranny, I just change it out.
Old 05-01-2019, 01:42 AM
Ok, Iíll change it tomorrow. hopefully thatís the end of the starting issue... thanks for your all of your advice!
Old 07-23-2019, 11:17 AM
Itís abit late but Iíve got a update... the problem still exists ( I swapped out the ivm with a brand new one from Bmw and Iíve just been out for a drive and made a short stop at a shop and when I got back in it wouldnít start again! After waiting around 25 minutes it started up just fine. Iíve got no error codes again and battery is fully charged. It seems to happen on hot days and when the car is hot after longish journeys.. itís really annoying now because I canít trust when it going to start when I use it.
@HerbP do you have any more tips or ideas of what else it could be? Iím pretty sure itís something to do with heat but I could be wrong.
Or does anybody else have any experience of this issue and could help out?
It would be a huuuge help and very appreciated I love the car but this is taking all the fun out of using it
Old 07-23-2019, 12:21 PM
Living the dream.
You could have gotten a lemon replacement IVM.
Sent from my SM-N960U using Tapatalk
This is how I roll
Old 07-23-2019, 02:29 PM
[QUOTE=The Thomas J;13061557]You could have gotten a lemon replacement IVM.
QUOTE]
Although itís possible I think itís very unlikely I would have got a faulty unit with the exact same fault but no others. It was a brand new unit from Sytners (main dealer in UK)
I donít think it is the IVM now, I just donít know where else to start to look
Old 07-23-2019, 03:09 PM
zod zod is online now
Mein Auto: 1987 BMW 535is 2008 E64
Sounds like a heat related short. Whatever relay activates the starter isn't.
I chased something like this on a 69 Corvette, so I know the feeling.
Old 08-03-2019, 02:20 PM
If anybody else has the same issue I seem to have cured mine.. after changing the ivm I still had no crank problems so I carried on investigating and I noticed on ISTA the IBS was showing no information for current charge state or the last 5 days so I disconnected it (both the blue and red connected) and then re connected and then I could read the current charge level on ISTA and fingers crossed since then I havenít had a no crank issue so Iím hoping it was down to the ibs. Iím not sure how ďintelligentĒ the ibs is and wether it simply kind of crashed and just need a power cycle or wether itís actually faulty or maybe one of the connections was just loose but It seems to be working now and seems to have solved my problem I was having
Old 08-03-2019, 06:40 PM
Super Moderator
Glad you found the problem, even though it got expensive changing parts. ISTA is a very good tool, you just have to learn how to use it, then work thru the steps.
Old 08-04-2019, 12:42 PM
It was worth it, I can enjoy driving it again now and changing the ivm wouldnít have done any harm Iíll just think of it as preventative maintenance .. ISTA is a great tool! im still finding my way around it but even with my limited experience it far surpasses inpa and dis57 which I was using before and without it I never would have suspected the IBS. After googling IBS and no crank it seems like itís fairly common even though here in the uk mine was recalled and replaced with the newer version it still must be pretty unreliable.
So if anybody is reading this with the same symptoms itís definitely worth checking your IBS, I believe if itís faulty and the cause of a crank state just disconnecting it will allow you to start the car before replacing it
thanks again for the help HerbP! I wouldnít have got ISTA if it wasnít for you recommending it when I asked about coding a new key in another thread and without ista I would have never suspected the IBS so thankyou! I really appreciate your help!
Similar Threads
Strange starting/lighting issue :s LAMYpbrz E46 (1999 - 2006) 3 11-25-2018 04:44 PM
Strange electrical issue StickyDonkey X3 E83 (2004 - 2010) 14 03-02-2015 07:43 AM
Strange Audio Issue Needsdecaf F10 / F11 (2011 - 2016) 1 02-28-2012 07:08 AM
2005 X3 strange problem starting X3_husband X3 E83 (2004 - 2010) 5 01-26-2012 08:32 AM
E36 wont start. strange issue Bystrov E36 (1991 - 1999) 22 01-10-2011 08:58 PM
