Brake Booster Hose Intake Valve, Grommet - Bimmerfest - BMW Forums
Old 08-13-2019, 03:24 PM
lucas979 lucas979 is offline
Mein Auto: E39, E38
Hi,
I was replacing the valley pan gasket in my M60-powered E38, and unfortunately broke the plastic valve that goes into the intake manifold and plugs into the vacuum hose that goes to the brake booster. I got a suitable replacement part (not the original), but when I was installing that, I accidentally tore the rubber grommet that the valve fits into (in the intake manifold). Thus, I decided to buy both parts and replace both. However, I can't find them on RealOEM, and am not sure what part numbers they are. Could somebody shed some light on that? Thanks in advance!
Old 08-13-2019, 04:48 PM
Mein Auto: E39, E38
Resolved:
Part numbers found:
Gasket (I mistakenly called it a grommet): 34331158929 (95% sure this is the right part)
T-Connector (called valve): 34331158930
Hope this helps somebody!
