M550 668M Wheels - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > G30 (2017 - Current)
The next generation 5 Series, chassis code G30, arrives at dealers in February 2017. Looking like a scaled down 7 Series and riding on the CLAR platform, the new 5 Series will have a focus on lightweight and sporty performance. Engines options will come from BMW's new B family for the 530 and 540 and a turbocharged V8 for the M550i. Read more about the 2017 5 Series
Old 08-14-2019, 07:36 PM
jagu's Avatar
jagu jagu is offline
Mein Auto: 2018 M550I. XDrive
M550 668M Wheels
Is it possible to put tires with taller sidewalls on these wheels and if so, what size? I have had 8 blowouts in one year and I don't want the 19 inch wheels.
2018 M550I XDrive, Sapphire Black/Mocha Nappa Leather/Dynamic Handling/Executive/Leather Dashboard/Dynamic Digital Cluster/Driver Assistant/Cold Weather/Parking Assistance/Luxury.
Old 08-14-2019, 08:02 PM
rraisley rraisley is offline
Mein Auto:
What size wheels do you have now? Realize that taller sidewalls, even by 10%, will increase your tire's outside diameter by about 2", making speedometer off by about 7%, 7% less torque to the road, possible clearance issues, etc. You normally have to go to a smaller wheel diameter: each 1" in diameter allowing you to add 5% to the profile ratio, without changing diameter much.
Old 08-14-2019, 08:41 PM
gigantor gigantor is offline
Mein Auto: 18 M550
It's possible but not recommended. Going from 30 to 35 rears and 35 to 40 fronts not going to prevent blowouts. Do you have RFT's?
You can compare sizes here: https://tiresize.com/calculator/
18 - M550
15 - 550ix (gone)
12 - 550ix (gone)
09 - 550i (gone)
"Never argue with an idiot. They will only bring you down to their level and beat you with experience."
George Carlin
Old 08-14-2019, 08:54 PM
jagu's Avatar
Thank you. I have the very low profile 20 inch wheels now. I might have to look for some blacked out 19 inch wheels.
Old 08-15-2019, 09:01 AM
Mein Auto:
LOVE the calculator; thanks for the post. I was using a spreadsheet I made up.
I won't disagree with the difference going from 30 to 35, and 35 to 40, yet that small change is the right change for going from 20" wheels to 19". Cars designed for low profile tires are just going to end up with low profile tires. OP could go to 40 front and 45 rears with 18" tires, but I'm not sure he'll like the look of the result. We're all atuned to these new low profile tires, which look and handle fantastic, but ride and durability are something else.
Old 08-15-2019, 01:29 PM
Mein Auto: 18 M550
Nooooo, no way OP swaps those 20" beauties for 18"s. Plus I'm no sure there are many 18" which will fit over sports brakes on 550.
18 - M550
15 - 550ix (gone)
12 - 550ix (gone)
09 - 550i (gone)
George Carlin
Old 08-16-2019, 07:49 AM
bymep2 bymep2 is offline
Mein Auto:
lot of discussion about this on the other forum...
search "Am I okay running 245/40/20 and 275/35/20"
Old 08-16-2019, 08:11 AM
Warp Ten's Avatar
Warp Ten Warp Ten is offline
Mein Auto: 2019 540xi, 2016 Z06
You might talk with some folks at Tire Rack. They are usually very helpful to customers with all kinds of questions, and may well have experience with other customers asking the some questions. Smaller wheels and taller tires would help and if done right could keep the rolling diameter the same as your stock sizes. It is done all the time with snow tire/wheel packages. Note that formula One cars use small wheels and tall tires to be an active part of the suspension, which is otherwise very stiff. From F1 when the increase tire widths in 2017:
So the new sizes for slick tyres will be 305/670-13 at the front and 405/670-13 at the rear (the total diameter will go from the current 660mm to 670mm). Wheel rim diameter remains unchanged at 13 inches. Note: 13 in wheels and a 670 aspect ratio! --Bob
2019 540xi M Sport, Carbon Black/Cognac, 2014 328xi, 2016 Corvette Z06; Previous:2010 BMW 535xi M Sport, Carbon BLack/Natural Brown, 2008 335xi, 1998 M3 Sedan,1980 530i, 1977 320i, 1976 2002 BMWCCA Member
Old 08-16-2019, 10:16 AM
Mein Auto:
For anyone else who, like me, did not understand this tire description (where tire size is /usually/ WWW/RR-DD where WWW is width in mm, RR is aspect ratio in %, and DD is wheel diameter in inches, these F1 tires are WWW/OOO-DD where WWW is width in mm, OOO is OUTSIDE DIAMETER in mm (NOT aspect ratio), and DD is wheel diameter in inches. For reference, the calculated aspect ratios for each would be:
(670 mm - 13 x 25.4 mm) / 2 = 169.9mm section height / 305 width = 56 aspect ratio front.
{670 mm - 13 x 25.4 mm) / 2 - 169.9mm section height / 405 width - 42 aspect ratio rear.
I was a little surprised that the rear tires are the same diameter as the front. Somehow, they looked larger to me (in addition to being wider).
Old 08-16-2019, 11:54 AM
Warp Ten's Avatar
Apologies; you are right on the aspect ratio. I wasn't thinking fast enough and didn't bother to check the number. The rears do look larger; probably just the section width that creates that illusion. When they do slow motion shots of cars going over the curbs you can really see how much flex they have, both up and down and side to side. --Bob
Old 08-16-2019, 01:43 PM
jjsC6 jjsC6 is online now
Mein Auto: See Sig
I find it hard to believe that taller sidewalls will not help reduce the chances of blowouts. You have more sidewall to absorb the impact.
2017 BMW 540 M-Sport Carbon Black/Ivory
2016 Lexus GX 460---Wife's car
Bikes...2017 Yamaha FJR1300---2017 KTM 1290 Superduke GT---2012 Ducati Panigale
Previous BMW: 2012 550 M-Sport
Old 08-16-2019, 02:59 PM
Mein Auto:
I agree, it has to HELP. Put it this way, any impact that will blow a 40 aspect ratio will certainly blow a 35 AR. But probably not every impact that will blow a 35, will blow a 40. We never know what impact we'll get, or what the actual result will be. I hit a curb at high speed in my GTI, with 40 AR low profile tires, and while it didn't blow, and luckily didn't bend the wheel, it messed up the sidewall and ended up with a hell of a big blister on the side, requiring replacement. Sometimes just a little improvement is all we need.
Old 08-17-2019, 04:47 PM
jagu's Avatar
Correct. I rented a Macan turbo from Turo and it had 21 inch wheels which plowed through the same potholes that took my car out.
Old 08-18-2019, 09:46 AM
aceman67 aceman67 is offline
Mein Auto: MB E500 4matic
Question - I know JAG doesn't want 19's, but aren't the 668's out now on some other BMW models in 19" flavor - would they fit on the 5er?
And for you tire guys - are the blowouts b/c they are run flats with the stiff sidewall? If he switches to non runflats will that make a measurable difference?
Aceman
2012 550iX Alpine White, M-Sport, CW PKG, SAT, HUD, PREM SOUND, SUR VIEW CAMERAS
Mods: OEM Spoiler, 35% tint, Front/Rear Mud guards
Old 08-18-2019, 10:01 AM
jagu's Avatar
Aceman
It’s the ultra low profile tires. In fact I get people trying to tell me that my tires are flat when they’re not.
Old 08-18-2019, 10:42 AM
Mein Auto: See Sig
Aceman
I have 19 inch "7" series wheels on my car. They are 1/2" wider. I also went up one tire size - 255/40-19 on front and 285/35-19 on back. Mine are "647 M" wheels.They fit great and do a better job of filling out the wheel well without looking goofy. They look like they should come from the factory.
The new 3 series has a similar looking 19" wheel option, but its going to be too small for a 5.
Old 08-18-2019, 11:31 AM
And btw, the change in diameter messing up the speedometer shouldn't be a factor given BMW's are off from the factory!
JJSC6 - may be worth exploring using the 7's...
Old 08-18-2019, 03:15 PM
Mein Auto: See Sig
Here are a couple of pics. None of the pics show them very well.
ID:	861555   Click image for larger version
ID:	861557   Click image for larger version
ID:	861559   Click image for larger version
Old 08-27-2019, 11:56 AM
280BlackPearl 280BlackPearl is offline
Mein Auto: 2018 BMW M550
I ordered an '18 M550 with these exact wheels. They are quite possibly the best looking wheels BMW currently has on any of their cars. But after 4 blowouts in 8 months, two on the highway in the rain, I had had enough. I downsized to 19" wheels and slightly larger tires. Not one problem since. Good luck!
Old 08-28-2019, 04:01 PM
jagu's Avatar
Thank you. I have had another bubble since I started this thread. Thankfully Discount Tires honor their road hazard plan every time and I 'm amazed that they haven't kicked me out of the plan yet.
Old 08-29-2019, 12:06 AM
Sophisto Sophisto is offline
Mein Auto: E46 330ci / G32 630d
Ther is a hole in the bucket dear Liza, dear Liza
Ther is a hole in the bucket dear liza a hole.
Well fix it.
Old 11-08-2019, 10:53 AM
drtbar drtbar is offline
Mein Auto: M550
I'm in this same predicament. I think I'd like to downsize as well. Can you tell me what wheels and tires you went with? Were you able to sell your other wheels?
Old 11-08-2019, 11:10 AM
I now have 19" Pilot Sport A/S3+. The wheels were supplied by BMW. Not sure of model number but attached is a picture. I've had zero problems since going to this new wheel/tire package.
Good luck!
Old 11-11-2019, 03:19 PM
DLF750's Avatar
DLF750 DLF750 is offline
Mein Auto: 2019 540iX
Yep, when I had my last 750, I had either 20s or 21s (probably 20s) and low profile tires. Not only did I constantly get blow out - more often then not, I would get two AT ONCE! Lots of flatbeds. Finally dropped back down to the RFT 19s...
2019 540iX M Package, M Blue Brakes, bunch of other stuff...
Old 11-12-2019, 04:58 AM
Mein Auto: M550
Good luck!
I found that those are the 664m wheels which is what I'm considering. I haven't had any bubbles or blow outs, but from the number of problems people have had, it seems it's essentially inevitable.
