DIY: Maintenance/Modifications/Repairs - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series & 8 Series > 7 Series - F01 / F02 / F03 / F04 (2008 - 2015)
The 5th generation F01/F02/F03/F04 BMW 7 Series flagship forum. The redesigned 7 series leads off the BMW Fxx chassis code, offering an 8 speed automatic transmission and all turbocharged engine options.
Closed Thread
Old 01-19-2016, 05:00 PM
aom aom is offline
Super Moderator
Mein Auto: 750i 740i 330ci
This thread has been created to gather all helpful DIY maintenance and repair threads. To be included, please post the reasons or symptoms for the repair (if applicable), part numbers used, where the parts was sourced from (including cost), a step by step guide with photos (preferred) and any other thoughts, observations, tips/tricks/warnings and gotchas.
Please post all questions and comments relating to the DIY in the specific posts, not on here. As the number of DIY entries grows, I will organize them by category or section.
All DIY threads are for your reference only, should you choose to follow any advice on these threads, you assume any and all responsibility for any risks, damage or other unexpected or unintentional consequences.
DIY REPAIR
Battery Replacement
Engine Air Filter Replacement
Changing Turbo Oil Lines
Changing Turbo Coolant Lines
Rear Door Sunshade Disassembly
Remove Front Bumper to Replace Headlights
Low Pressure Fuel Sensor
Front Brakes (Rotors and Pads)
AC Blower Motor (performance maintenance or replace filter) Noise due to debris
N63 Valve Seal Replacement DIY
BMW F01 Night Vision Retrofit DIY
REFERENCE
Wheel Bolt Torque Values
MODS
Top/Surround View Camera Retrofit
F01 750i Dark Graphite Metallic M-Sport Packages: Driver Assistance | ARS | Luxury Seating | Camera | Convenience | Premium Sound | 20" 303M Wheels | Ceramic Controls
BMS Stage 1 Tune | Pedal Box | M-Sport Paddle Shift Steering Wheel | 5000k HID | Tint | Mtec Angel Eyes LED | Rear Tinted Taillights | Coded
E38 740i Black Sport Packages: PDC | Convenience | Sunshade
Paddle Shift Retrofit | Brushed Aluminum Gauge Ring | Modified M-Sport Steering Wheel | Tint | MKIV NAV | 4500K HID | 3M DiNOC Carbon Fiber Trim | Heated Seats | Refinished M-Parallel Wheels | Celis Tails
My PedalBox Stealth Install: https://www.bimmerfest.com/forums/sh...d.php?t=725889
Closed Thread
