General Information Pre LCI 630i/645Ci/650i. LCI 630i/650i/635d - Bimmerfest - BMW Forums
Old 12-01-2017, 01:40 PM
Hsurf's Avatar
Hsurf Hsurf is offline
Super Moderator
Mein Auto: E63 645ci
Included both Pre and Post LCI Owners manuals for Coupe and Convertible PDF's below
__________________________________________________ __________________________________________________ __________________________________________________ __________________________________________________ ____________________________________________
Fuse Layouts and Wiring
See the DIY section under E63/64 - Engine or E63-64 - Vehicle Electrical System
The Technical PDF for the Pre LCI models below.
I've tried to double check these figures in the PDF below against at least two different sources but if anyone notices anything significantly out of place please give me a shout so I can amend them, also if you feel there is some general info that hasn't been put in and should be again feel free to let me know .
The Technical PDF for the LCI models below.
Component Parts Lists (Every part in the car)
https://www.realoem.com/bmw/en/select
http://bmwfans.info/parts-catalog
Good link for the BMW colour charts
https://www.uniquecarsandparts.com.a..._reference_bmw
Pre LCI 650i Factory Options list PDF added below.
Suspension Spring Part Numbers
BMW E6x 630i, 635d, 645Ci and 650i Pre and Post LCI listed in the PDF below.
Wiring Colour Codes PDF added below
BMW Acronyms PDF added below
Engine Overviews
Engine overviews for 630i (N52TU engine), 645Ci (N62B44 engine), 650i N62B48 engine), 635d (M57D30 TU2 engine) PDF's added below.
Transmission Overview
ZF 6HP26Z Overview PDF added below
BMW Wheels List
http://www.bmwstylewheels.com/
Basic datasheets for the 2010 E63/4 LCI models just before the F series took over.
VIDS
File Type: pdf E63-4 2004 645Ci Coupe & Convertible Owners manual.pdf (3.46 MB, 134 views)
File Type: pdf E63-4 2008 LCI 650i Coupe & Convertible Owners manual.pdf (9.07 MB, 107 views)
File Type: pdf Suspension Spring Part Numbers for E6x 1.pdf (363.4 KB, 79 views)
File Type: pdf E63-64 630i N52 Engine Introduction.pdf (134.5 KB, 43 views)
File Type: pdf E63-64 650i N62TU Engine Introduction.pdf (255.8 KB, 42 views)
File Type: pdf GA6HP26Z Auto Transmission Overview.pdf (701.9 KB, 47 views)
File Type: pdf BMW E63 630i-645Ci-650i-Alpina Technical Specifications.pdf (288.5 KB, 20 views)
File Type: pdf BMW E63 LCI 630i-635d-650i-Alpina Technical Specifications.pdf (160.5 KB, 13 views)
Neal.
_________________
E63 645Ci
Toyota Hilux Surf 3.0
Honda CBR1100XX
_________________
Old 12-02-2017, 02:17 PM
roseng's Avatar
roseng roseng is offline
Mein Auto: 2016 528i + 2007 650 Vert
Originally Posted by Hsurf View Post
I've tried to double check these figures against at least two different sources but if anyone notices anything significantly out of place please give me a shout so I can amend them, also if you feel there is some general info that hasn't been put in and should be again feel free to let me know .
Impressive detail.
I Love LA. It lets me ride in the winter with the top down.
07' E64/Black....14' F10/M-Sport White
Old 12-24-2017, 10:26 PM
Desmocedici Desmocedici is offline
Mein Auto: 650ci
You outta work for Google.
Old 03-01-2018, 11:39 PM
Hsurf's Avatar
Super Moderator
Added ride height details under "Dimensions and Weight" for those doing front control arms etc.
Neal.
_________________
E63 645Ci
Honda CBR1100XX
_________________
Old 05-06-2018, 03:27 AM
Hsurf's Avatar
Super Moderator
Added Suspension Spring Part Numbers and rough (UK only I'm afraid) prices.
Neal.
_________________
E63 645Ci
Honda CBR1100XX
_________________
Old 05-16-2018, 06:34 AM
Hsurf's Avatar
Super Moderator
Ok, this spring table is turning into a monster, it should be noted these are based on UK cars so once I've got the various models and combinations completed I'll add in any US differences (if there are any), depending on how big this gets I may convert it to a PDF and add it to the others at the bottom.
Neal.
_________________
E63 645Ci
Honda CBR1100XX
_________________
Old 05-16-2018, 05:42 PM
HerbP HerbP is offline
Super Moderator
Mein Auto: 05 645Ci, 14 750 M-Sport
Good info!
Old 06-19-2018, 01:34 AM
Hsurf's Avatar
Super Moderator
Suspension part numbers are pretty much complete, if anyone comes across anything different then please shout out so I can amend it or add it as necessary.
It turned out much bigger than I thought it was going to so I am going to change it a PDF and add it to the bottom of post 1 when I get the time.
Neal.
_________________
E63 645Ci
Honda CBR1100XX
_________________
Old 10-18-2018, 11:06 PM
Hsurf's Avatar
Super Moderator
Factory Options for the pre LCI 650i have been added.
Neal.
_________________
E63 645Ci
Honda CBR1100XX
_________________
Old 10-19-2018, 04:51 PM
Super Moderator
You must have gotten bored this week!
Good Job!
Old 10-20-2018, 12:30 AM
Hsurf's Avatar
Super Moderator
Good Job!
Stumbled across it purely by accident while searching other things , I'm not quite sure how google managed to link that to a Toyota Surf but there we go .
Neal.
_________________
E63 645Ci
Honda CBR1100XX
_________________
Old 10-21-2018, 03:24 PM
FredoinSF FredoinSF is offline
Mein Auto: 4 BMWs, 1 Mini, 1 Vespa
I had seen most of this over the years, but never aggregated like this. Thanks for pulling it all together.
Old 12-05-2018, 10:41 PM
Hsurf's Avatar
Super Moderator
BMW wiring colour codes PDF now added.
Neal.
_________________
E63 645Ci
Honda CBR1100XX
_________________
Old 02-06-2019, 06:22 AM
Hsurf's Avatar
Super Moderator
Technical PDF added for LCI models along with Alpina B6 S, B6 also added to the pre LCI PDF, I'll try to update with convertibles when time allows.
Neal.
_________________
E63 645Ci
Honda CBR1100XX
_________________
Old 02-18-2019, 01:40 AM
Hsurf's Avatar
Super Moderator
A good link for general BMW colour charts added.
Neal.
_________________
E63 645Ci
Honda CBR1100XX
_________________
Old 03-20-2019, 12:12 AM
Hsurf's Avatar
Super Moderator
Various Engine overviews added to post 1.
Neal.
_________________
E63 645Ci
Honda CBR1100XX
_________________
Old 04-26-2019, 11:57 AM
Hsurf's Avatar
Super Moderator
BMW Acronyms PDF added to post 1 for all those abbreviations no one understands .
If anyone notices any that aren't listed please feel free to post them so I can add them in .
Neal.
_________________
E63 645Ci
Honda CBR1100XX
_________________
Old 05-10-2019, 10:38 PM
Hsurf's Avatar
Super Moderator
General overview of the 6hp26 Auto gearbox added.
Neal.
_________________
E63 645Ci
Honda CBR1100XX
_________________
Old 08-02-2019, 01:03 PM
terrapinsmdb terrapinsmdb is offline
Mein Auto: 2009 BMW 650i
Hey my 2009 E63 56k miles is blowing bluish smoke when idling for a while when hot. Has anyone else experience this? Itís random and the car was never beaten
Old 08-02-2019, 01:07 PM
I also picked up a set of 5 Beyern Multispokes which have an ET of 40. Is this a cause for concern?
Old 08-03-2019, 12:08 AM
Hsurf's Avatar
Super Moderator
Check your CCV's for any tears, check all around for any oil or vacuum leaks (a smoke test can work well for this), if they are all fine then it's probably the valve stem seals. Unfortunately it doesn't matter too much how the car was treated, it's the BMW oil change intervals that cause this as they are way too long between changes, when these cars were first bought no one knew any better, they all took BMW at their word.
Neal.
_________________
E63 645Ci
Honda CBR1100XX
_________________
Old 08-03-2019, 12:11 AM
Hsurf's Avatar
Super Moderator
If you take a look in the DIY section under "E63/64 - Chassis/Wheels" there are a number of various wheel and tyre calculators for this .
Neal.
_________________
E63 645Ci
Honda CBR1100XX
_________________
Old 08-03-2019, 12:16 AM
Thanks yea my mechanic said it's probably those pcv pipes on top and praying that's the problem. Is that expensive to fix? And I found the type of wheels. Although it recommends et 20 and I have 20" etc 40, don't know what that et means. But thanks for the info
Old 08-03-2019, 12:51 AM
Hsurf's Avatar
Super Moderator
The pipes can crack and cause this problem but usually it will be the CCV's themselves as they are rubber and tend to tear after a while due to the stresses put on them, dirt cheap and super easy to replace, take a look here under "Cylinder Head Cover".
The ET stands for Einpresstiefe or insertion depth in English , it's the measurement of the wheels offset, the number being the measurement of the mounting surface to the center of the wheel, it's not easy trying to explain it on a forum so take a look at this vid, he's talking about his particular car so don't worry about him mentioning 35 - 40 offsets being ridiculous but he explains it quite well if your struggling with what it all means, the calculators I mentioned will mean a lot more to you once you've got the basics in your head.
Neal.
_________________
E63 645Ci
Honda CBR1100XX
_________________
Old 08-03-2019, 12:55 AM
Hsurf's Avatar
Super Moderator
By the way, if you don't know the OEM ET I'm pretty sure I put them in the Technical PDF in post 1, you'll want that to compare against what you have now, that is if you don't still have the OEM wheels, it'll also be stamped on them .
Neal.
_________________
E63 645Ci
Honda CBR1100XX
_________________
