Service notice for software update to ensure minimum oil level warning is displayed - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series & 8 Series > 7 Series - F01 / F02 / F03 / F04 (2008 - 2015)
The 5th generation F01/F02/F03/F04 BMW 7 Series flagship forum. The redesigned 7 series leads off the BMW Fxx chassis code, offering an 8 speed automatic transmission and all turbocharged engine options.
Old 06-27-2019, 12:19 AM
Robin750 Robin750 is offline
Mein Auto: 2013 750i and 2015 740i
Did anyone else get this notice for their 750i/750Li? I got it a couple weeks ago and the wording as follows:
"During a recent quality analysis, it was determined that the minimum oil level warning may not display."
"To correct this issue, the control unit in your vehicle needs to be reprogrammed so the oil service interval is corrected and displays minimum oil level warning."
I wondered if they actually changed the way the oil measurement worked, but this doesn't seem likely. The dealer upgraded the I-Level from F001-18-11-539 to F001-19-03-530 and my 740i is not affected by this issue, so maybe this was necessary because they discovered a bug in F001-18-11-539.
Patch Tuesday for my car it seems...
2015 BMW 740i and 2013 BMW 750i (current)
2011 BMW 750i (previous)
2002 BMW 745i (previous)
2001 Lexus LS430 (previous)
delete pls 8K
*NEW* delete pls 8K
Old 06-27-2019, 07:00 AM
sampatel1's Avatar
sampatel1 sampatel1 is offline
Mein Auto: BMW 2013 - 750Li
Was this notice in the mail? OR did it appear on your display screen?
Old 06-27-2019, 09:00 AM
In the mail.
delete pls 8K
*NEW* delete pls 8K
Old 06-30-2019, 05:32 AM
That 7 Guy That 7 Guy is offline
Mein Auto: 750i
I got mine about three weeks ago. Havenít gotten around to making the appointment yet.
Old 06-30-2019, 12:02 PM
What year is yours? Do you know if the software had been upgraded before?
delete pls 8K
*NEW* delete pls 8K
Old 06-30-2019, 12:22 PM
Mein Auto: 750i
Mine is a 2013. 2/2013 build. Off the top of my head I canít remember an update having been done.
Old 07-17-2019, 07:49 PM
ICECOLD ICECOLD is offline
Mein Auto: 2013 BMW 750Li
I received the letter also. I dropped my car off July 3rd. They reprogrammed mine then took my car for a test drive and the SRM module fail and I lost oil pressure. They called me last Friday, they did not have one in stock so they have to order it from Germany. At that point, the part wouldn't be here till the end of August. I received a call yesterday saying it will be available the 20th of this month but still has to be shipped here. They will continue to give me updates.
Oh well, nothing I can do. As long as I'm not paying for it.
Old 07-17-2019, 08:05 PM
The FRM module? Hopefully they gave you a decent loaner. I had an X3 M40i and the exhaust (in sport mode) makes the car much more fun to drive than a compact SUV should be...
delete pls 8K
*NEW* delete pls 8K
Old 07-17-2019, 08:18 PM
Thanks for the correction. FRM module. They gave me a 2019 X3 xDrive 30i. I do put it in sports mode and you are right its fun. lol. For a small SUV its kind of roomy for its size. Shocked me.
Old 07-25-2019, 12:02 PM
pilione pilione is offline
Mein Auto: 740il
Hey the same problem happened to me. I was to drop of mine 4th of July weekend, got bumped to 10th July and have'nt seen my car since. I also got a brand new x3 to drive around because my FRM module failed.
Old 07-25-2019, 04:29 PM
andreroper77 andreroper77 is offline
Mein Auto: 2012 BMW 750LI
Was it a recall? I have a 2012 750LI and I havenít heard or seen anything.
Old 07-25-2019, 08:04 PM
I think a service notice is not quite up to the severity of a recall, but this seems to affect 2013 models based on the responses here.
delete pls 8K
*NEW* delete pls 8K
Old 08-06-2019, 07:59 AM
Mein Auto: 740il
Slight update on my situation. Dealer called me last week to say they are still waiting for a back ordered FRM module and i should expect to get my car back mid august. I work in the automotive industry so i think they have to manufacture new ones and go through QA before they mass release them but i could be wrong. Anyway they took back the loaded X3 loaner that i had because they sold it but and brought me a brand new one.
Same time last year my extended warranty company was different but they covered my Upper Head Gasket leak repair which would have set me back $2,600 in labor and parts. I had a loaner and only paid the diagnostic fee of $115.
Now This Year
Dealer had me bring the car in for the oil level reprogramming campaign But they also gave me a list of the following recommended repairs. Which extended warranty doesn't cover (Warranty company contract was sold to Fortegra).
With dealer discount i would be out about $3000 to cover all of these below.
Below is my list of approved repairs. (I have a comfort access issue in the front passenger door handle)
CUSTOMER STATES THE PASS FRONT DOOR HANDLE WILL NOT UNLOCK OR LOCK VIA COMFORT ACCESS. CHECK AND ADVISE. CUSTOMER HAS EXT WARRANTY. $0.00 X
DIAG TIME USED. (OUTSIDE DOOR HANDLE FAULTY.) Fail $118.80 X REPLACE OUTSIDE DOOR HANDLE. (OUTSIDE DOOR HANDLE FAULTY.) Fail $563.24
Below is list of non approved so far
REPLACE CRANK CASE LINES. (CRANK CASE LINES LEAKING.) x Fail $1,054.90
REPLACE TURBO COOLANT LINES. (TURBO COOLANT LINES LEAKING.) x Fail $1,004.90
I'm starting to get worried i may never get my car back any time soon
Old 08-06-2019, 08:58 AM
hgarcia hgarcia is offline
Mein Auto: 750Li
The dealer did mine for around $750 but that was because they were doing the valve stem seal replacement.
I have seen others have it done for about half that while doing their valve stem seals.
What exactly is wrong with your doors?
In the Bmw software I get: PTC Rear left/right: PWM signal line, short circuit to ground or open circuit
FKA_01
801009
80100B
Old 08-06-2019, 11:19 AM
Mein Auto: 740il
The door started acting weird. It would not unlock via comfort access. So i would have to manually pull up the handle. Or it only unlocks via the unlock button. I suspected the cooler and turbo lines quote was higher than normal. Maybe i should use my alternate german repair shop for that job.
Old 08-06-2019, 06:15 PM
isstatu1 isstatu1 is offline
Mein Auto: 2010 750Li
Sounds like the handle is the issue. I've had the same issue with my both rear doors. Ordered used ones in the same color as the car from ebay for $100 each and replaced them in about 15minutes total. It's just one screw that's holding them in place. That's a very easy DIY job and could save you some money.
Does it lock via comfort access?
Old 08-15-2019, 06:22 AM
Mein Auto: 740il
Got the call this morning to go pickup my car. They did knock out some charges and my total is $2,700 for the door handle replacement, crank case and turbo cooler lines replacement and an alignment. Next time i will consult with members before i have them do any major job. Issatu was right the door handle job is a quick DIY. When i had an e38 i was king of DIY, now i did'nt have 2 elementary age kids and i had more time back then but that's a discussion for another day.
Old 08-15-2019, 07:40 AM
Do you know how much exactly did they charge for the door handle replacement?
Old 08-15-2019, 10:13 PM
wjhughes420384's Avatar
wjhughes420384 wjhughes420384 is offline
whughes
Mein Auto: 2009 750li, 2018 X5
i have had my door handle replaced a few times i think the price was around $600
2009 750Li - Space Grau Metallic, Camera pkg, Conv pkg, Driver Asst pkg, Lux Seat pkg, Lux rear seat pkg, Prem sound pkg, Sport pkg, HUD, Massaging rear seats, Smartphone integration, Sat radio, MTEC H8 4750K Halo lights,
Dinan Stage 1 SW, Air intake, Free Flow Exhaust, Camber Arm
Old 08-20-2019, 09:48 AM
Mein Auto: 750i
Update: took it in to find it had been previously done and not recorded in the maintenance record somehow. Ah well, it was a nice drive there and back.
