Dynamic Drive and Damping Control Malfunction - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series & 8 Series > 7 Series - F01 / F02 / F03 / F04 (2008 - 2015)
The 5th generation F01/F02/F03/F04 BMW 7 Series flagship forum. The redesigned 7 series leads off the BMW Fxx chassis code, offering an 8 speed automatic transmission and all turbocharged engine options.
Old 07-12-2019, 05:35 PM
isstatu1 isstatu1 is offline
Mein Auto: 2010 750Li
I have dynamic drive and damping control malfuncion error on the screen and the suspension is basically stuck in sport mode. Driving like that through the roads of NJ is terrible. Any ideas of what should I check? No lights on the screen or codes.
Old 07-12-2019, 06:55 PM
HerbP HerbP is offline
Super Moderator
Mein Auto: 05 645Ci, 14 750 M-Sport
Need to have someone to pull the codes with ISTA to find out exactly what caused your problem? It could be voltage related, or something else?
Old 07-15-2019, 05:07 PM
Read the codes.
Engine (DME/DDE)
CD8E01 Engine ECU LIN Bus, Communication Fault Short Circuit
CD8420 FlexRay Bus Communication Error
CDA004 FlexRay, Message (Request 2 Wheel Torque Drive Train Sum Fas, 131.1.4) Is Missing
1B0204 Driving Speed, Plausibility: Speed Not Plausible Or CAN Bus Communication Is Interrupted
CD9C04 Message (Actual Steering Angle, Driver, 59. 0. 2) Missing, Engine ECU Receiver, Steering Column Switch Cluster Transmitter
CD9D04 FlexRay, Message (Longitudinal Acceleration Centre Of Gravity 55.0.2) Is Missing
CD9E04 FlexRay, Message (Side Acceleration Centroid, 55.0.2) Is Missing
CDA104 FlexRay, Message (Inclination Roadway, 56.1.2) Is Missing
CD8801 FlexRay Controller Startup Exceeded Maximum Startup Time
Transmission (EGS)
CF16C1 No Message (Medium Severity) , Receiver Transmission Control Unit, Transmitter Dynamic Stability Control
CF16D1 No Message (Low Severity) , Receiver Transmission Control Unit, Transmitter Dynamic Stability Control
CF18D1 No Message (Medium Severity) , Receiver Transmission Control Unit, Transmitter Integrated Chassis Management
CF18E1 No Message (Low Severity) , Receiver Transmission Control Unit, Transmitter Integrated Chassis Management
Antilock Brakes (ABS/ASC/DSC)
D355A6 No Message (ARS Status, 35. 3. 4), Receiver DSC, Transmitter ICM
D3593C No Message (Predefined Damper Share Passive, 72. 1. 2), Receiver DSC, Transmitter VDM/EDC
Airbag (MRS/ASCM)
930AC1 Interface ICM (Speed 0x1 A1) Signal Invalid
Air Conditioning (IHKA/IHKR/IHKS)
8011FD Ioniser: Signal Line, Short Circuit To Ground Or Open Circuit
Air Suspension (EHC)
D70DA5 Interface Integrated Chassis Management (Road speed, Vehicle, 0x1A1): Signal Invalid
All Around Vision Camera (TRSVC)
800B8F Side View Camera, Left: Maximum Permissible Current Exceeded
800B8E Side View Camera, Right: Maximum Permissible Current Exceeded
CA9406 Communication Fault From ICM (Integrated Chassis Management) / DSC (Dynamic Stability Control): No Message (Steering Angle)
CA9402 Communication Fault From ICM (Integrated Chassis Management) / DSC (Dynamic Stability Control): No Message (Vehicle Speed)
CA8C03 Lin Bus: Side View Camera, Left: Not Responding
CA8C04 Lin Bus: Rear View Camera Not Responding
CAAC01 Communication Fault From KOMBI (Instrument Cluster): Invalid Message (Kilometer Reading)
800BDF Side View Camera, Left: Not Learned
800BE0 Side View Camera, Right: Not Learned
800BE1 Reversing Camera Not Learned
CAAC0F Communication Fault From KOMBI (Instrument Cluster): Invalid Message (Outside Temperature)
800BDA Side View Camera, Left: Not Connected
800BDB Side View Camera, Right: Not Connected
Automatic Luggage Compartment (HKL)
E3D406 Interface CAS (Electronic Immobilizer) (Button, Remote Control): Signal Invalid
Central Information Display (CID)
800351 CID Video Connection: No Synchronization
Damper Satellite Front Left (EDCSVL)
F25400 Communication Fault From VDM (Vertical Dynamics Management) / EDC (Electronic Damper Control)
F25407 Communication Fault From VDM (Vertical Dynamics Management) / EDC (Electronic Damper Control)
F25408 Communication Fault From VDM (Vertical Dynamics Management) / EDC (Electronic Damper Control)
F26C06 Communication From ICM (Integrated Chassis Management): Signal Invalid
F26C0B Communication From ICM (Integrated Chassis Management): Signal Invalid
F26C23 Communication From VDM (Vertical Dynamics Management): Signal Invalid
F26C24 Communication From VDM (Vertical Dynamics Management): Signal Invalid
F26C25 Communication From VDM (Vertical Dynamics Management): Signal Invalid
F2441FH/15877151 Undocumented Code
F24420 Damper Satellite, Flexray: Communication Fault
F25409 Communication Fault From VDM (Vertical Dynamics Management) / EDC (Electronic Damper Control)
Damper Satellite Rear Left (EDCSHL)
F2D400 Communication Fault From Transmitter VDM (Vertical Dynamics Management) / EDC (Electronic Damper Control)
F2D407 Communication Fault From Transmitter VDM (Vertical Dynamics Management) / EDC (Electronic Damper Control)
F2D408 Communication Fault From Transmitter VDM (Vertical Dynamics Management) / EDC (Electronic Damper Control)
F2EC06 Communication From ICM (Integrated Chassis Management): Signal Invalid
F2EC0B Communication From ICM (Integrated Chassis Management): Signal Invalid
F2EC23 Communication From VDM (Vertical Dynamics Management) : Signal Invalid
F2EC24 Communication From VDM (Vertical Dynamics Management): Signal Invalid
F2EC25 Communication From VDM (Vertical Dynamics Management): Signal Invalid
F2C41FH/15909919 Undocumented Code
F2C420 Damper Satellite, Flexray: Communication Fault
F2D409 Communication Fault From Transmitter VDM (Vertical Dynamics Management) / EDC (Electronic Damper Control)
Electronic Immobilizer (CAS/EWS)
9307A7 Outer Door Handle Electronics, Driver's Side, Rear: DATA Line, Short Circuit To Ground
9307AF Outside Door-Handle Electronic Module, Driver's Side, Rear: Non-Permissible Current Value On Unlock Line
9307B0 Outside Door-Handle Electronic Module, Driver's Side, Rear Plausibility Unlock Line To DATA Line
9307B5 Outside Door-Handle Electronic Module, Passenger's Side, Rear: DATA Line, Short Circuit To Ground
9307B6 Outside Door-Handle Electronic Module, Passenger's Side, Rear: Non-Permissible Current Value On Unlock Line
9307B7 Outside Door-Handle Electronic Module, Passenger's Side, Rear Plausibility Unlock Line To DATA Line
9307B8 Outside Door-Handle Electronic Module, Passenger's Side, Rear: Permanent Actuation
D91410 Message (Drive Train 2 Data, 230.0.2) Incorrect, Receiver CAS, Transmitter Engine ECU
D91420 ICM CAN-Message of Vehicle Speed: Failure or Invalid Signal Content (V VEH COG, ST V VEH NSS, Alive, Qualifier, CRC)
9308B0 Identification Transmitter: Under Voltage, Battery
Footwell Module (FRM)
030015 Driver's Door Power Window No Initialization
800F3A Fog Lights, Left, Faulty
800F3B Fog Lights, Right, Faulty
800F86 Daytime Driving Light / Side Light, Left, Faulty
800F87 Daytime Driving Light / Side Light, Right, Faulty
800F8D Turning Light, Right, Faulty
800F92 Welcome Light, Repeat Interlock, Active
E58500 Message (Stabilization Of Dynamic Stability Control, 0x173) Missing, Footwell Module Receiver, Dynamic Stability Control Transmitter
E58501 Message (Operation Of Steering Column Switch, 0x1Ee) Missing, Footwell Module Receiver, Steering Column Switch Cluster Transmitter
E58502 Message (Vehicle Ride Height, 0xe4) Missing, Footwell Module Receiver, Integrated Chassis Management Transmitter
E58503 Message (Operation Of Steering Column Adjustment, 0x1Ea) Missing, Footwell Module Receiver, Steering Column Switch Cluster Transmitter
E58509 Message (Driving Speed, 0x1A1) Missing, Footwell Module Receiver, Integrated Chassis Management Transmitter
E5850A Message (Yaw Rate, 0x19F) Missing, Footwell Module Receiver, Integrated Chassis Management Transmitter
Gear Selector Switch (GWS)
E0940E Message (Vehicle Speed, 0x1A1) Missing, Gear Selector Switch Receiver, Integrated Chassis Management Transmitter
Integrated Chassis Management (ICM)
D00420 ICM: Internal Control -Unit Fault
482608 Interface VDM: Signal Invalid
480114H/4718868 Undocumented Code
482630 ICM: FlexRay Communication Fault
D01646 No Message (Angle, Accelerator Pedal, 40. 1. 4), Receiver ICM, Transmitter Engine ECU
D017B7 Message (Actual Braking Torque, Total, 43. 3. 4) Missing, Receiver ICM, Transmitter DSC
D017AB Message (Actual Braking Torque, Wheel, 44. 3. 4) Missing, Receiver ICM, Transmitter DSC
D0179F Message (Actual Number Of Sensor Edges, Wheel, 64. 1. 2) Missing, Receiver ICM, Transmitter DSC
D014D6 Message (Actual Steering Angle, Driver, 59. 0. 2) Missing, Receiver ICM, Transmitter Steering Column Switch Cluster
D01575 No Message (Display, Check Control Driving Dynamics 01, 218. 9. 32), Receiver ICM, Transmitter VDM/EDC
D016F2 No Message (Display, Check Control Driving Dynamics 03, 218. 13. 32), Receiver ICM, Transmitter VDM/EDC
D01964 No Message (Dome Acceleration, Vehicle, 5. 0. 1), Receiver ICM, Transmitter VDM/EDC
D01782 Message (Data, Function, Hill Descent Control, 44. 1. 4) Missing, Receiver ICM, Transmitter DSC
D0194E No Message (Rolling Moment, Vehicle, 35. 0. 2), Receiver ICM, Transmitter VDM/EDC
D01B06 No Message (Proportion, Rolling Moment, Stabilization, 35. 0. 2), Receiver ICM, Transmitter VDM/EDC
D01B3A Message (Qualifier Service ECBA, 63. 1. 4) Missing, Receiver ICM, Transmitter DSC
D01705 No Message (Requirement, Crankshaft Torque, ARS, 35. 3. 4), Receiver ICM, Transmitter VDM/EDC
D0193C No Message (Predefined Damper Passive Component, 72. 1. 2), Receiver ICM, Transmitter VDM/EDC
D015A6 No Message (Dynamic Drive (ARS), 35. 3. 4), Receiver ICM, Transmitter VDM/EDC
D018E1 No Message (Torque, Crankshaft 1, 40. 1. 4), Receiver ICM, Transmitter Engine ECU
D01557 No Message (Wheel Torque Powertrain 1, 41. 3. 4), Receiver ICM, Transmitter Engine ECU
D01558 No Message (Wheel Torque Powertrain 2, 41. 3. 4), Receiver ICM, Transmitter Engine ECU
D0156D No Message (Wheel Torque Powertrain 3, 61. 3. 4) Missing, Receiver ICM, Transmitter Engine ECU
D01570 No Message (Wheel Torque Powertrain 4, 40. 3. 4), Receiver ICM, Transmitter Engine ECU
D01B3F No Message (Wheel Torque Powertrain 5, 40. 3. 4) , Receiver ICM, Transmitter Engine ECU
D01A08 No Message (Wheel Torque Powertrain 6, 61. 3. 4) , Receiver ICM, Transmitter Engine ECU
Instrument Panel (KOMBI)
E11456 No Message (Steering Column Switch Operation 0x1EE) Receiver Instrument Cluster Transmitter Switch Centre, Steering Column
E11464 No Message (Vehicle Speed 0x1A1) Receiver Instrument Cluster Transmitter Integrated Chassis Management
E12C11 Interface Integrated Chassis Management (Road speed Vehicle 0x1A1) Signal Invalid
E11490 No Message (Display Check Control Bypass 0x36E) Receiver Instrument Cluster Transmitter Antilock Brakes
B7F668 System Time Was Reset
E11494 No Message (Configuration SPORT Button 0x3A7) Receiver Instrument Cluster Transmitter Integrated Chassis Management
E1149B No Message (Vehicle Distance Travelled 0x2BB) Receiver Instrument Cluster Transmitter Integrated Chassis Management
E12C1F Interface Integrated Chassis Management (Distance Travelled Vehicle 0x2BB) Signal Invalid
E114B8 No Message (Display Check Control Driving Dynamics 0x2A7) Receiver Instrument Cluster Transmitter Integrated Chassis Management
Junction Box Electronics (JBE)
8020DB Wake Up Line To Intelligent Battery Sensor IBS: Short Circuit To Ground Or Open Circuit
8020E7 Starting Capacity Limit Reached
C90C96 Electrochromic Interior Mirror: Internal Fault
Park Distance Control (PDC)
803282 Rear View Unavailable
E21409 No Message (Vehicle Distance Travelled, 0x2BB) Receiver Park Distance Control (PDC) Transmitter Integrated Chassis Management (ICM)
E2140B No Message (Speed Vehicle, 0x1A1) Receiver Park Distance Control (PDC) Transmitter Integrated Chassis Management (ICM)
E21700 Interface Integrated Chassis Management (ICM) (Drive Status, Vehicle, 0x1A1) Signal Invalid
Parking Brake (EMF)
D395BC Message (Stabilization Of Dynamic Stability Control, 0x173) Missing, Parking Brake Receiver, Dynamic Stability Control Transmitter
D39660 Message (Actuation Request, Parking Brake, 0x225) Missing, Parking Brake Receiver, Dynamic Stability Control Transmitter
Roof Function Centre (FZD)
DE9412 Message (1A1, Speed Of Vehicle) Failure
801A3A Burglar Alarm, Details In Alarm Memory
030215 Sunroof Module No Normalization
030295 Electrical Sliding Headlining Invalid Characteristic Curve, No Standardisation Available
801A4A Deactivation Irs And Tilt Sensor By Customer Function
Seat Module Driver (SMFA/FAS)
8029CA Longitudinal Seat Adjustment: No Or Invalid Normalization
Seat Module Passenger (SMBF/BFS)
802B8D Hall Sensor, Seat Depth Adjustment: Short Circuit To Positive Or Open Circuit
Transfer Box (VGS)
CF441F FlexRay: Line Fault
CF4420 FlexRay: Communication Fault
CF5401 No Message (Set Point Torque, 43. 1. 4) Receiver Transfer Box, Transmitter Dynamic stability control
CF5480 Interface Dynamic stability control (Set Point - Value Input, Torque, 43. 1. 4) Signal Invalid
CF5493 ICM Interface (Vehicle Speed, 55. 3. 4) Signal Invalid
It's a crazy amount of codes. Nothing else is really wrong with the car.
Old 07-15-2019, 07:06 PM
Super Moderator
What happened to start this problem? Did you work on something, or do any coding, or programming?
Old 07-15-2019, 07:51 PM
i bought the car with this issue. I know the rear door handles were shorting, and that was causing a lot of dash lights, but the fuses were replaced and it's now good to go besides thia issue.
Old 07-16-2019, 11:33 AM
Super Moderator
Have you replaced the battery, as the voltage must stay above 12 volts with the lights on, & the engine off?
Old 07-16-2019, 03:48 PM
Changed the battery. Still the issue remains. I'll read the codes tomorrow.
Old 07-16-2019, 06:00 PM
Super Moderator
Are you pulling these codes with Carly? You are showing a lot of short circuits to ground, linbus problems, & canbus problems. There is a communication problem due to a short, somewhere on your car. You are going to have this hooked up to ISTA, or take the car to a shop that has the proper equipment.
Old 07-16-2019, 06:05 PM
I was using the ethos pro scanner by Snap on. I also used the Foxwell scanner on it but it's showing less errors. Will work on getting ISTA on my computer.
Old 07-22-2019, 06:14 AM
Is there a damping relay somewhere in the car? I could check that out while I'm waiting for the ENET cable for ISTA.
Old 07-29-2019, 03:25 PM
Did a scan with ISTA and still have errors. I'm attaching the screenshots. The side view camera issues and faulty lights are not related since the cameras are missing and the lights were switched out to non compatible LEDs.
ID:	859637   Click image for larger version
ID:	859639   Click image for larger version
Old 07-29-2019, 07:46 PM
Super Moderator
I would suspect that the ICM is the place to start with, since it is popping up all over the place. Try working thru the modules & clear the faults in the module themselves. I think I remember reading somewhere lately that there might be a recall for the Chassis Management problems?
Old 07-31-2019, 05:24 PM
Looks like my VDM module as well as the EDCSHR and EDCSVL are red and not communicating. I checked fuses 37 and 45 and they are good. I'm wondering why only the right side damper satellites are red and left ones are communicating..
Old 07-31-2019, 06:13 PM
Super Moderator
Right click on the red modules, then enter the ECU button on the bottom of the page. Then enter the module, & run the ECU test again. After that you can go to the tabs at the top of the page, then work your way thru whatever you want to see. You can manually clear the faults on the last tab, highlight the clear fault, then hit the apply button at the bottom of the page. After that you can go back into the module & run what ever sensor test you want. You should also have a service plan in the fault list. Run the service plan & follow the path of the test. This should help you pinpoint your problem.
Old 08-06-2019, 05:24 PM
So far I'm thinking it's a faulty VDM module, but I can't find where to buy one.
Old 08-07-2019, 06:53 PM
Super Moderator
Here is a list of control module functions, & active commands. I found this a while back, but not have really researched it much. I am going to assume that the active commands, are commands that can be run from the modules themselves, while search or running diagnostics on the module. This might help you in while searching for your problem.
https://www.autoenginuity.com/images...-List.html#top
Old 08-10-2019, 04:58 PM
When I turn off DSC with the button next to the gear selector it turns it off but as soon as i reach 30mph it switches it back to normal.
Old 08-11-2019, 06:49 PM
Super Moderator
Try holding it down longer to completely shut it down.
Old 08-11-2019, 06:53 PM
That's what I do. I hold it for about 10 seconds.
Old 09-04-2019, 05:07 AM
andro822 andro822 is offline
Mein Auto: bmw alpina b3
hi, did u solve that problem? what was the fault? I have almost similar dtcs on F06
Old 09-04-2019, 05:29 AM
i believe it's the VDM module. I've did some insvestigation with ISTA, as well as an indie BMW shop. The only thing is that they can't guarantee me that it is it without replacing it. I'm gonna sort a couple of other issues out first and then replace the VDM. Doesn't look like it's a lot of trouble since it's next to the floor by the A pillar on the passenger side.
Old 09-24-2019, 10:56 AM
Bought the VDM module from Germany. Will take some time to get here. I'll see if it will do anything.
Old 11-02-2019, 03:52 PM
Turns out it was a broken front right strut connection. Replaced the strut and now I'm back in business!
Old 11-03-2019, 07:45 PM
Super Moderator
Glad to see you found the problem.
Old 01-29-2020, 12:23 PM
tremartin06 tremartin06 is offline
Mein Auto: 04 745Li
How did you figure out the issue was a broken strut?
Tre' Martin
Atlanta, Ga
2004 745Li
