Horn won't work- possibly fuse? - Bimmerfest - BMW Forums
Old 07-20-2019, 11:06 AM
Sharonhonore Sharonhonore is offline
Mein Auto:
Recently purchased 2005 BMW conv and horn won't work. Might it be as simple as fuse short? Wait time to see mechanic is several months. Suggestions?
Old 07-20-2019, 12:46 PM
Doug Huffman's Avatar
Doug Huffman Doug Huffman is online now
Nuclear engineer
Location: Washington Island, Wisconsin, thru Death's Door
Mein Auto: CPO2012 X5 35d M57(E70)
https://www.newtis.info/tisv2/a/en/e...tion/fanfares/
Scepticism and Animal Faith (1923)
Scepticism is the chastity of the intellect, and it is shameful to surrender it too soon or to the first comer: there is nobility in preserving it coolly and proudly through long youth, until at last, in the ripeness of instinct and discretion, it can be safely exchanged for fidelity and happiness.
(The Works of George Santayana p. 65)
Eschew eristical argumentation. I am responsible for what I write, not for your understanding of it.
Old 07-20-2019, 10:52 PM
Hsurf's Avatar
Hsurf Hsurf is offline
Super Moderator
Mein Auto: E63 645ci
If it is the fuse it's number 28 in the glove box, this fuse also doubles up for the steering column switch cluster and should be a 20 amp, you'll need to flip down the black plastic cover at the back to access the fuses.
If your car was built after Sept 05 then also check number 17, again in the glove box, this will be a 5 amp.
Neal.
_________________
E63 645Ci
Toyota Hilux Surf 3.0
Honda CBR1100XX
_________________
Old 07-24-2019, 01:09 PM
QSilver7's Avatar
QSilver7 QSilver7 is offline
Mein Auto: 2006 X5 4.4/2013 650ix GC
Under what circumstances are you finding that the horn doesn't work? I ask this because if you are new to BMW...you may not know that the horn doesn't work if the ignition isn't turned on...same with the headlights and a few other things.
Q {BMW CCA Member #191509}
2006 E53 X5 4.4i (Sterling Gray) 12/05 mfg date <<~>> 2013 F06 650ix Gran Coupe` (Black Sapphire) 1/13 mfg date
(SOLD)
97 740iL (Arctic Silver) <<~>> 99 540iT (Orient Blue) <<~>> 95 525IT (Alpine White)
https://www.bimmerforums.com/forum/attachment.php?attachmentid=637911&d=1538398374&thumb=1&stc=1
