Can you jump start the BMW650 2007? - Bimmerfest - BMW Forums
Old 07-24-2019, 11:44 AM
asimrazvi asimrazvi is offline
Mein Auto: bmw 650i
So my car has been sitting in the garage for a while and the battery is so low that it barely started last time I checked and ran a little rough. I am pretty sure its close to dead or there already. Can I jump start it? Seem to remember that it would not work and also if not a jump start can I put a trickle charger on it?
thanks
Asim
Old 07-24-2019, 12:58 PM
terrapinsmdb terrapinsmdb is offline
Mein Auto: 2009 BMW 650i
I have, my 2009 has a red cover with a plus sign to the back right of your engine compartment. It's not good to jump your car but you will see the positive post on upper right side
Old 07-24-2019, 12:59 PM
QSilver7's Avatar
QSilver7 QSilver7 is offline
Mein Auto: 2006 X5 4.4/2013 650ix GC
Every BMW I've owned since 1986...can be jump started. The instructions are in the owners manual.
You are supposed to use the jump start terminals dedicated for doing this that are located in the engine bay. And especially if you have an IBS (intelligent battery sensor)...then it is imperative that you use the engine bay terminals and DO NOT hook up a trickle charger or jumper cables directly to the battery.
ID:	859125   Click image for larger version
ID:	859127   Click image for larger version
Name:	BMW F06 F12 F13 POS Engine Bay Jump Start Terminal.jpg
ID:	859129   Click image for larger version
Name:	Where to hook up BMW trickle charger with AGM Battery.jpg
Q {BMW CCA Member #191509}
2006 E53 X5 4.4i (Sterling Gray) 12/05 mfg date <<~>> 2013 F06 650ix Gran Coupe` (Black Sapphire) 1/13 mfg date
(SOLD)
97 740iL (Arctic Silver) <<~>> 99 540iT (Orient Blue) <<~>> 95 525IT (Alpine White)
https://www.bimmerforums.com/forum/attachment.php?attachmentid=637911&d=1538398374&thumb=1&stc=1
Old 07-24-2019, 01:44 PM
zod zod is offline
Mein Auto: 1987 BMW 535is 2008 E64
I hooked up my trickle charger using this method: https://www.meeknet.co.uk/e64/Timms_...n_the_Boot.htm
Old 07-25-2019, 11:19 AM
Mein Auto: bmw 650i
Thanks everyone for the detailed responses. I am going in now lets see what happens
asim
