Lock Issue . - Bimmerfest - BMW Forums
Old 07-25-2019, 06:31 PM
Newbimmerguy19 Newbimmerguy19 is offline
Mein Auto:
Lock Issue .
Hi , I own a 09 650 I . This particular car has an issue with the locks . The car has comfort controls. If the car is locked and you walk up to the car grab the handle. Nothing . Car won't unlock. If you use the remote . It will lock /unlock .Then you can grab the handle / touch the lock and they will work. Sometimes the drivers side door will unlock but not passengers door. Additionally, you can't open the trunk with the remote . It's kind of hit or miss. Sometimes it will happen other times forget it. You can open the trunk with the button under the dash and the bmw button in the rear of car . Plus , I never noticed this on any other car I've owned but when you open the door there is a humming noise . After that humming noise the interior lights come on and the seat memory will go off. Not sure if that's related to the lock issue. Thank for any help you can provide
Old 07-25-2019, 08:45 PM
HerbP HerbP is offline
Super Moderator
Mein Auto: 05 645Ci, 14 750 M-Sport
Sounds like you have some type of problem with the comfort access. Have you tried changing the battery in the remote, & try charging the cars battery? Try these 2 things to see it might help. Our cars do not like low voltage.
