2013 750i Soft close just went nuts - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series & 8 Series > 7 Series - F01 / F02 / F03 / F04 (2008 - 2015)
The 5th generation F01/F02/F03/F04 BMW 7 Series flagship forum. The redesigned 7 series leads off the BMW Fxx chassis code, offering an 8 speed automatic transmission and all turbocharged engine options.
Old 07-25-2019, 05:59 PM
dweeb84 dweeb84 is offline
Mein Auto: 2013 750i
So the soft close on my car just went crazy today. Here's a youtube link of what it does now:
The sound can be quite embarrassing. Does anyone have a fix for this before I go get it replaced at the dealer?
Old 07-25-2019, 08:06 PM
Robin750 Robin750 is offline
Mein Auto: 2013 750i and 2015 740i
Use a screwdriver to close the latch and see if it still does that. If so, the motor/latch assembly probably just needs to be replaced.
2015 BMW 740i and 2013 BMW 750i (current)
2011 BMW 750i (previous)
2002 BMW 745i (previous)
2001 Lexus LS430 (previous)
delete pls 8K
*NEW* delete pls 8K
Old 07-26-2019, 07:06 PM
HerbP HerbP is offline
Super Moderator
Mein Auto: 05 645Ci, 14 750 M-Sport
My rear drivers door is doing the same thing, but I have not had time to work on it yet. Others have said to move the latch outward towards the door, & the CA will close properly. It seems that this is happening quite often. If I was going to remove the locking assembly, I would open it up & inspect the internal spring. My 2007 drivers door did the same thing, & the spring had come loose, & not holding the latch in place. The hard part is getting the lock in & out of the door.
