09 650i - Bimmerfest - BMW Forums
Old 07-30-2019, 12:27 PM
Newbimmerguy19 Newbimmerguy19 is offline
Mein Auto:
09 650i
Comfort access issues
I have a 09 650. Comfort access will work when you use the fob . After you unlock , lock doors then try using the comfort access it comfort access will work until the interior lights shut off . From that point on comfort access does not work.I have changed the batteries in the fobs , I've checked the battery ( it's fine ) . Thanks
Old 07-30-2019, 02:45 PM
HerbP HerbP is offline
Super Moderator
Mein Auto: 05 645Ci, 14 750 M-Sport
Not sure what you mean by I checked the battery? I would suggest charging the car battery to a full charge of 12+ volts, then see if anything changes. Low voltage can cause a lot of problems on our cars. You could also try to reinitialize the key fob, to see if that helps? It sounds like the car is going to sleep, so that is a good thing.
