Rear body frame sits low near tire - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series & 8 Series > 7 Series - F01 / F02 / F03 / F04 (2008 - 2015)
The 5th generation F01/F02/F03/F04 BMW 7 Series flagship forum. The redesigned 7 series leads off the BMW Fxx chassis code, offering an 8 speed automatic transmission and all turbocharged engine options.
Old 08-02-2019, 05:06 PM
vsummers vsummers is offline
Mein Auto: BMW 2012 750 LI
Any idea as to what I need to fix and how much it would cost?
BMW 750 LI AWD
I believe it may be rear shocks. Thanks for any information you may provide!
Old 08-05-2019, 12:39 PM
Cmhyde72 Cmhyde72 is offline
Mein Auto: 750LI
What part of Texas are you in? I had to get both my rear shocks replaced and it costed a small fortune. I found out after the fact that there is a place that rebuilds them.
Old 08-05-2019, 12:57 PM
Poncherello Poncherello is offline
Mein Auto: 2013 750Li
Use re-manufactured ones.... plenty of places on line sell them
https://www.arnottindustries.com/as-...02-f04-chassis
Old 08-05-2019, 01:03 PM
Autoputzer Autoputzer is offline
Mein Auto: 2014 535i + 2018 X3 30i
Shock absorbers resist movement, but they do not provide static resistance to the weight of the car. The springs do that. Springs can weaken over time, some more than others. Metallurgists call this "slip." So, you might have slip in on spring and not the other. Because of slip, springs should always be replace in pairs.
