Slow start - no start - fuel purge valve!! - Bimmerfest - BMW Forums
Old 08-04-2019, 09:31 AM
Mulchman's Avatar
Mulchman Mulchman is offline
Mein Auto: '07 650i
I'm at 158k now. Replaced the starter a while back. Recently (past 6 months) been having slow first crank then start. Then it became two long slow cranks on first button push with no start, then fire right up on second. My IVM is only a few years old but I replaced it anyway.
ISTA said I had a dirty VANOS solenoid so I cleaned and swapped them.
It also said I had a fuel purge valve issue. I ran though the test procedure and it all checked out (including the did you hear the valve click? part). So I figured that was a ghost. I finally decide to pull the valve and pressure test it. That was it, it wasn't closing all the way. It should be closed when not under load and open when powered. I sprayed it with some WD and banged it around a couple times and then it held vacuum. I used alligator clips and a 9 volt battery to test open and close it a few times, then reinstalled. The car fired up like new and I got back all of my low end (low RPM) power, that I was missing.
Part will be waiting for me at Bimmerzone tomorrow, $80. I've been driving for the past two days and I can literally tell when it gets stuck open now. I will report back if this doesn't solve my problem, but I think I found the culprit.
Hope this helps someone. Hi Herb!!
'14 X6 i50 - Deep Sea Blue Matallic
'07 650i Coupe - Black Sapphire Metallic
'11 328i Sedan - Alpine White
Old 08-04-2019, 04:22 PM
HerbP HerbP is offline
Super Moderator
Mein Auto: 05 645Ci, 14 750 M-Sport
The fuel purge valve does pop up quite often, but it is an easy repair. I have noticed that if the battery voltage is low, that the error code for it will pop up occasionally. I have not seen you around for a while, but good to hear from you!
Old 08-04-2019, 05:05 PM
FredoinSF FredoinSF is offline
Mein Auto: 4 BMWs, 1 Mini, 1 Vespa
Great info. Subscribed to thread so I can find it if / when needed.
Current:
2018 540ix
2015 428i convertible
2013 Cooper S
2007 650i - 6 speed
2002 330ci convertible - 5 speed
Past:
2012 X5 Diesel
2012 Countryman S All4 - 6 speed
2006 Cooper S - 6 speed
2006 330i - 6 speed
1997 328is - 5 speed
1991 318is - 5 speed
1988 635csi - 5 speed
1988 325i convertible - 5 speed
1969 2002 with tii and 5 speed conversions
Old 08-05-2019, 04:06 AM
Mulchman's Avatar
Mein Auto: '07 650i
Exactly the reason I blew it off. I've seen the code come and go many times. When it came back a few times I rolled though the ISTA test and it came up fine. It does not test the valve closure for vacuum, It test the system as a whole for vacuum and checks to make sure the valve will open (listen for clicking noise). So I overlooked it again. The only way to tell it's bad is to pull it and apply vacuum.
Like I said, Vincent at Bimmerzone will have one by noon today and I will know for sure if this was my entire problem.
Old 08-08-2019, 06:24 AM
Mulchman's Avatar
Mein Auto: '07 650i
Well I was still getting a CPS error (bank 1 exhaust) after installing the new purge valve. I pulled it, cleaned it and swapped it with the intake CPS. Cleared the errors and she's running like a champ. No errors (so far), starting seems back to normal and low end power restored. Took less than 30 minutes. Purge valve takes less than 15 to swap.
Old 08-08-2019, 01:51 PM
Super Moderator
Sounds like you were running lean, but I would have thought it would have caused Bank 2 to go lean? Smoke test is the easy to find any vacuum leaks on our engines. After any repairs to the valve covers or intake. smoke test everything before you button everything up. I simply remove the air intake, & insert a 4" drain test plug to block the port. After that pump the smoke to it, you will find your leaks very fast!
