650i N62 6HP26 Alpina software - Bimmerfest - BMW Forums
Old 08-06-2019, 04:16 PM
mcmt mcmt is offline
Mein Auto:
Hi!
Does anyone have or know the software number for 2006 650i N62 6HP26 tranny?
I'd like to have gear indicator (d1, d2...) and quicker shifts.
Matt
Old 08-08-2019, 12:13 AM
Hsurf's Avatar
Hsurf Hsurf is offline
Super Moderator
Mein Auto: E63 645ci
If memory serves I think it's the Alpina B5 software your after for this but you'll loose the sport button and a couple of other bits (can't remember exactly) on the E63, I'm not sure where you'd get it from though either. I've not tried it myself, this is just something I remember reading some time ago but I think it may have been on the E60 forum so it might be worth throwing a post up there.
If you could find the B6 software that might be better, I just only remember the B5, be careful though as I also remember the wrong one can brick your car and that would make for a whole world of problems.
Neal.
_________________
E63 645Ci
Toyota Hilux Surf 3.0
Honda CBR1100XX
_________________
Old 08-08-2019, 01:53 PM
HerbP HerbP is offline
Super Moderator
Mein Auto: 05 645Ci, 14 750 M-Sport
Originally Posted by mcmt View Post
Hi!
Matt
A valve kit from Sonnax might be a easier way to accomplish this, without trying to flash the EGS module?
Old 08-09-2019, 01:45 AM
Hsurf's Avatar
Super Moderator
Is the valve kit performance enhancing then? I always just thought it was replacement parts to bring the tolerances back to that from factory .
I must admit that the gear indicator in auto mode seems a bit of a gimmick but I guess it could be useful if experiencing problems, to be fair most of my driving is done in manual mode and I certainly never look at the dash to see what gear I'm in, I know what the gear is as I was the one that selected it , hell I don't even look at the rev counter I just go by the engine note.
Neal.
_________________
E63 645Ci
Honda CBR1100XX
_________________
Old 08-09-2019, 02:43 AM
Mein Auto:
Oh, thanks for your answers guys!
Throwing topic on E60 is a good idea.
Gear indicator isn't very usefull, I agree, but I just want it.
Wow, Sonnax solenoids... Can't find anything for 6hp.
Btw, I'm using 7564206 now and... I've got this feeling like this tranny could work better.
Old 08-09-2019, 01:34 PM
Hsurf's Avatar
Super Moderator
The Sonnax kits are here https://www.sonnax.com/transmission#kits, as I understand it (and others will need to confirm as I've not fitted one) you'll need to drop the tranny fluid, pan and mechatronic first so you can get the part numbers from the mech since there are two different zip kits for the 6hp26.
As HerbP says this may give you back what the tranny should be delivering but you'll still need some coding for the gear shifts so you could also ask the guys in the coding forum and programming forum to see if they can shed some light in it as well.
Neal.
_________________
E63 645Ci
Honda CBR1100XX
_________________
Old 08-09-2019, 03:47 PM
Mein Auto:
Now I can see them. Removing mechatronics isn't a problem for me. The problem is, they are 90usd each... Total is more then 6hp26 tranny is worth, I'm afraid...
Old 08-10-2019, 08:30 PM
Super Moderator
The Mechatronic unit rarely fails, & it is only the electronic brain of the tranny. Rebuilding or modifying the valve body is cheap.
Old 09-05-2019, 10:25 AM
Mein Auto:
Yay!
Ps. Didn't realise, that 6HP26 during stop is always on 2nd gear...
Old 02-09-2020, 01:50 AM
Mein Auto:
After some time, I don't recommend Alpina software, and this is why:
1. It's using 1st gear only when it's cold. You can only use 1st gear on manual when it's warmed up.
2. No noticeable improvement in gear change time.
3. Redline reduced to 6000-6100rpm (factory is 6500-6600).
Conclusion: The only way to improve ZF tranny (soft) is... xHP. But it costs $$$.
Old 02-11-2020, 04:48 AM
Mulchman's Avatar
Mulchman Mulchman is offline
Mein Auto: '07 650i
I installed a zip kit on a E53 X5. It worked great. Before I had hard shift from 2nd to 4th, no 3rd. Afterward everything was smooth. If you do it make sure to replace all of the gaskets and O-rings between trans and throttle body. If you run ISTA/P you can update your software to the latest for your car in about 10 seconds. The other thing to do every few months is a software reset. Ignition on, engine off, peddle to the metal for 30 seconds.
'14 X6 i50 - Deep Sea Blue Matallic
'07 650i Coupe - Black Sapphire Metallic
'11 328i Sedan - Alpine White
