LM2 upgrade questions - Bimmerfest - BMW Forums
Old 08-11-2019, 07:11 AM
ginomachino ginomachino is offline
Mein Auto:
Hi guys. I just upgraded to LM2 for angel eye as drl option. I was following a guide I found for the coding procedure to update LMA and VIN. I am unable to find the AHL_LM2.prg file on my PC. And I cannot edit the VIN in the canned file that came with NCS. Also, I'm getting new lamp errors that I wasn't getting before. My turn signals have been flashing fast since I bought the car 2 months ago, showing R and L front turn signal bulb errors. But now I also get rear turn signal bulb errors, as well as brake light lamps when I press the brake pedal. I'm thinking this might be due to coding, but the only info I can find online is about cleaning/replacing bulb sockets. Seems to me that this is not the problem. I have replaced all faulty bulbs.
Another problem I found is that the CAS VIN doesn't match the car VIN. I know I'm very much new to this, and the language barrier doesn't help since tool32 is in German, but I stumbled through it. Would anyone be willing to help me remotely and show my a thing or two? I know a few guys have mentioned doing this for a little fee. If not, please help me figure out which fields I should me looking at and which modules.
But I did get my angel eye option to work, sigh, lol
Thanks in advance.
Old 08-12-2019, 08:35 AM
Hsurf's Avatar
Hsurf Hsurf is offline
Super Moderator
Mein Auto: E63 645ci
If this was me I'd put the LM1 back in temporarily and undo any coding you've done to the CAS to confirm your bulb changes have fixed the fast flashing, you want a known good lighting configuration to start on before upgrading to the LM2, that way you know that any problems after the new LM is just coding issues and not faults on the car.
Has your car had a replacement CAS from another car? This is the only way I can see the CAS module would have a different VIN from that of your car in which case this might even be the thing that's stopping you from seeing the AHL_LM2 file, however, I'd ensure your software is as up to date as possible as this too can cause problems.
You should be able to change the VIN in the CAS using either tool32 or Winkfp and would be done in just the same way as the LM2.
Once you've got your car squared away in it's original form and everything works as it should then you can go ahead and fit the LM2 as any lighting differences from here on are going to be down to the coding setup.
I'm not sure which guide your following but I used the "LM Module upgrade" in the DIY section https://www.bimmerfest.com/forums/sh....php?t=1155649, this is a complete guide from start to finish and includes how to change VIN's.
The "Coding and Programming" forum on here is another good source of info for this type of thing.
Neal.
_________________
E63 645Ci
Toyota Hilux Surf 3.0
Honda CBR1100XX
_________________
Old 08-13-2019, 06:09 AM
Mein Auto:
Thanks for your input!
I pulled the configs for CAS and LMA last night to look them over. The VIN now matches CAS, which is odd because I didn't feel I achieved that the day before. however, it still does not match the VIN plate on the car. I just bought it 2 months ago, and the seller lied to me about many things about the car, so I am not surprised I am seeing this discrepancy.
Anyway, the errors that remain are:
Left Brake Lamp Malfunction (only when brake is pressed)
Right Brake Lamp Malfunction (when brake is pressed but at start as well, only sometimes)
Left Rear Turn Signal Malfunction (1st signal blink is long, then flasher is fast)
Right Rear Turn Signal Malfunction (1st blink is long, rest is fast)
High Beam Assistant Malfunction
I have been trying to find exactly which parameters need to be changed/checked for those bulbs, but cannot find the correct fields. The biggest roadblock I have is not knowing which module and which fields to look into and edit to test settings.
Also, my AHL are aimed too low. when they initialize, i can see the side to side and up and down movement and return to 'zero', but the lights need to be adjusted to point up quite a bit more...
Old 08-13-2019, 08:07 AM
Markst Markst is offline
Mein Auto: BMW 5
There are screws in the headlights you can turn to move them up or down.
Old 08-13-2019, 09:23 AM
Mein Auto:
They were good before the module change...
Old 08-13-2019, 10:58 AM
HerbP HerbP is online now
Super Moderator
Mein Auto: 05 645Ci, 14 750 M-Sport
Use a blankman file to put everything back to a default mode to see if that helps. Rename your current file before doing that, & compare them afterwards. Below are some files that might help what you are looking for?
File Type: pdf BMW E Series Coding - Features List.pdf (88.4 KB, 40 views)
Old 08-13-2019, 06:37 PM
Mein Auto:
defaulted LMA and everything is working with no errors!!! coded my preferences and I am happy with my lights, for now... what a learning experience this has been LOL
only a few "small" issues remain -
PDC gives an error
convertible top has a wiring issue, which shows up as intermittent inability to completely close the top.
engine smokes after idling. i checked the CCV and the diaphragms are good, there is a valve seal job in my near future
Then suspension needs a bit of attention and new absorbers
Thanks for your help guys!!!
Old 08-13-2019, 07:25 PM
Super Moderator
Glad that helped solve one of your problems. The PDC problem is usually a bad wiring harness which becomes very brittle over time. You can engage the PDC system & hold your finger on each sensor for a few seconds. You should feel a slight thump if the sensor is working. If someone has applied fresh paint over the sensor, it will not work then as well. If you replace the sensor, they must be already pre-painted,or used the same color.
Old 08-13-2019, 07:29 PM
Mein Auto:
None of the sensors are making sound / vibration. i will check power to the PDC unit and order a replacement
Old 08-13-2019, 07:36 PM
Super Moderator
Did you activate the PDC button, then feel each sensor? There will only be a faint thump at the sensor if it is working. Usually the front & rear systems do not fail at the same time. If you install a different module, it will most likely need to be programmed to the car. It is rare that the module fails. If you mean an audible sound inside the car, check the IDrive settings to see if the system is turned off?
Old 08-13-2019, 07:45 PM
Mein Auto:
I watched a video on youtube that showed the sensors making an audible clicking sound. mine are completely dead, front and back
Old 08-13-2019, 07:51 PM
Mein Auto:
am i reading this correctly, i can enable dvd playback on an e64?
Old 08-14-2019, 06:37 PM
Super Moderator
Check fuse 64 in the trunk to see if it is ok. You can do video playback if it is coded.
Old 08-14-2019, 06:44 PM
Super Moderator
Do you have DIS or ISTA?
Old 08-14-2019, 08:28 PM
Mein Auto:
INPA / NCS expert
Old 08-15-2019, 06:25 PM
Super Moderator
Go to the coding section here on the forum & download ISTA. This will get you to the most recent version of BMW software, & much easier to use. Esys is the newest coding tool.
Old 08-28-2019, 06:18 PM
Mein Auto:
I am still having an issue with the headlights, AHL specifically. it is disabled. I went into my LMA module settings and couldn't really find the correct fields to change. Only thing I changed was AHL2_ENABLE. now, when i manually turn on the headlights, the AHL is still off. When i switch to auto headlights, AHL is active, but the left headlight is aimed to its left limit. when i switch back to manual, it comes back to center. any help is appreciated, as always...
Old 08-28-2019, 06:19 PM
Mein Auto:
HELL_OFFSET_DEFAULT
hell_default
HELL_OFFSET_KEY_1
hell_default
HELL_OFFSET_KEY_2
hell_default
HELL_OFFSET_KEY_3
hell_default
HELL_OFFSET_KEY_4
hell_default
K931D_ZV_ALLE_TUEREN
par_frei
K931D_ZV_SELEKTIV
par_frei
K930E_ZV_VER_N_XMIN_FB
fkt_frei
K9901_WARNBLINKEN
par_gesperrt
K9323_ZV_VER_AB_X_KM/H
fkt_frei
K8129_ZWAKO_AC_EIN_AUTO
fkt_gesperrt
K7504_HEIMLEUCHTEN_AUS
par_frei
K7504_HEIMLEUCHTEN_40S
par_frei
K7504_HEIMLEUCHTEN_90S
par_frei
K7504_HEIMLEUCHTEN_150S
par_frei
K7504_HEIMLEUCHTEN_240S
par_frei
K4328_BLINKEN_TIPPBET
fkt_frei
K5303_GAL_SEHR_STARK
par_frei
K8116_KLAPPENAUTOMATIK
fkt_gesperrt
K5303_GAL_STARK
par_frei
K5303_GAL_MITTEL
par_frei
K5303_GAL_GERING
par_frei
K5303_GAL_SEHR_GERING
par_frei
K5303_GAL_KEINE_ANHEB
par_frei
K5305_KLANG_BASS
par_frei
K5305_KLANG_TREBLE
par_frei
K5305_KLANG_BALANCE
par_frei
K5305_KLANG_FADER
par_frei
K5305_KLANG_REVERB
par_frei
K5305_KLANG_EQULIZER
par_frei
K531A_LAUTST_NAV
par_frei
K531A_LAUTST_VERKEHR
par_frei
K531A_LAUTST_TELEFON
par_frei
K531A_LAUTST_SVS
par_frei
K531A_LAUTST_PDC
par_frei
K4310_ANZ_SPRACHE_1
par_frei
K4310_ANZ_SPRACHE_2
par_frei
K4310_ANZ_SPRACHE_3
par_frei
K4110_VERBR_L/100KM
par_frei
K4110_VERBR_MPG_US
par_frei
K4110_VERBR_MPG_UK
par_frei
K4110_VERBR_KM/L
par_frei
K410D_EINHEITEN_WEG
fkt_frei
K4113_ZEIT_STD_DARST
fkt_frei
K4116_EINH_TEMPERATUR
fkt_frei
K9901_UMLUFT_EIN
par_frei
K9901_NAV_LETZER_HINWEIS
par_frei
K9901_KOMFORT_PARKBREMSE
par_frei
K9901_MUTE_EIN
par_frei
K9901_MONITOR_EIN
par_frei
K9901_LENKRADHEIZUNG
par_frei
K9901_RADIO/TELEFON
par_frei
K9901_SWR
par_gesperrt
K430C_DATUM_FORMAT
fkt_frei
C750A_SCHWELLWERT_EMPFIN
par_gesperrt
C750A_SCHWELLWERT_NORMAL
par_gesperrt
C750A_SCHWELLWERT_SEHR_E
par_gesperrt
DRUCK_EINHEIT
psi
K8601_SOLLWERT_M3
par_gesperrt
K8601_SOLLWERT_M2
par_gesperrt
K8601_SOLLWERT_M1
par_gesperrt
K8601_SOLLWERT_0
par_gesperrt
K8601_SOLLWERT_P1
par_gesperrt
K8601_SOLLWERT_P2
par_gesperrt
K8601_SOLLWERT_P3
par_gesperrt
K4D01_OFF_CID_DISPL_HELL
fkt_frei
BLUETOOTH_FIX
aktiv
K4119_DRUCK_BAR
par_frei
K4119_DRUCK_PSI
par_frei
K4119_DRUCK_KPA
par_frei
K8313_GEBLAESE_M10
par_gesperrt
K8313_GEBLAESE_0
par_gesperrt
K8313_GEBLAESE_P10
par_gesperrt
K9901_HUPE
par_gesperrt
PHONE_MULF
nicht_aktiv
C940C_QUITT_OPT_ENTSCH
fkt_gesperrt
C940D_QUITT_OPT_SCHAERF
fkt_gesperrt
C940A_QUITT_OPT_ENTSCH
fkt_frei
C9419_QUITT_OPT_KLAPPE
fkt_frei
C9410_QUITT_OPT_SCHAERF
fkt_frei
C941C_QUITT_AKUST_KLAPPE
fkt_frei
K9416_QUITT_AKUST_ENTSCH
fkt_frei
C9413_QUITT_AKUST_SCHAERF
fkt_frei
K8119_PRG_AUTOMATIK
par_gesperrt
K8119_PRG_LUFTVERTEILUNG
par_gesperrt
K8127_KLAPPENPROGRAMM_BO
fkt_frei
K8119_PRG_GEBL_AKTUELL
par_gesperrt
K8119_PRG_SCHICHTUNG
par_gesperrt
K8119_PRG_AC
par_gesperrt
K8125_KLAPPENPROGRAMM_BO
fkt_frei
K532F_SENDERLISTE_AUDIO
fkt_gesperrt
K4D01_OFF_HUD_DISPL_HELL
fkt_gesperrt
K4D03_ANZEIGE_GESCHWNDGKT
par_gesperrt
K4D03_ANZEIGE_CHECKCONTRL
par_gesperrt
K4D03_ANZEIGE_ACC
par_gesperrt
K4D03_ANZEIGE_TEMPOMAT
par_gesperrt
K4D03_ANZEIGE_NAVIGATION
par_gesperrt
K2407_PDC_MONITORBILD
fkt_frei
CA107_AUT_VERST_DEAKT
par_frei
CA107_AUT_VERST_ENTR
par_frei
CA107_AUT_VERST_ENT_T
par_frei
C9C03_KLAPPENWINKEL
fkt_gesperrt
C9C01_HKL_TASTE
fkt_gesperrt
K931D_SCHEIBENABSENKUNG
par_gesperrt
NIVI
nicht_aktiv
VOLUME_MAXIMUM_TEL
standard
VOLUME_MAXIMUM_ON
standard
VOLUME_AUDIO_1
e60
VOLUME_MINIMUM_NAVI
standard
VOLUME_DELTA_NAVI_ENTER
standard
VOLUME_MINIMUM_TM
standard
VOLUME_MINIMUM_TEL
standard
VOLUME_DELTA_TEL_ENTER
standard
VOLUME_KLANG_1
e64_top_hifi
KLANG_OFFSET
standard
VOLUME_PDC
e64_top_hifi
VOLUME_DELTA_PDC_ENTER
standard
VOLUME_SECUR_1
e60
LOUDNESS
e60
GAL_MAIN
e60
GAL_DEFAULT
e60
MUTE_ON_CRASH
nicht_aktiv
KEY_MEMORY_ASK
aktiv
MUTEMIX_TIME
e60
DAUER
e60
ABSTAND_IDENT_PRIO
e60
NACHLAUF_INT
e60
TIMEOUT_INT
e60
HIGH_CUT
auto
EINH_MASTER
aktiv
VOLUME_MINIMUM_SPEECH
standard
AUDIO_ENTERTAIN_1
us
LUEFTER_SCHW1
e60
LUEFTER_SCHW2
e60
LUEFTER_WERT1
e60
LUEFTER_WERT2
e60
LUEFTER_WERT3
e60
LUEFTER_WERT4
e60
SINGLE_TUNER
nicht_aktiv
DOUBLE_TUNER
aktiv
CDC
aktiv
MMC
nicht_aktiv
TOP_HIFI
aktiv
EQUALIZER
aktiv
AUDIO_SYSTEM
e60_top_hifi
VOLUME_ADJ_1
e60_top_hifi
VOLUME_ADJ_2
e60_top_hifi
VOLUME_ADJ_3
e60_top_hifi
VOLUME_ADJ_4
e60_top_hifi
SVS
aktiv
NOTEPAD
nicht_aktiv
VR_EQUIPPED
nicht_aktiv
SVS_EIN_AUS
nicht_aktiv
SDARS
nicht_aktiv
UNIT_YARD
nicht_aktiv
SITZHEIZUNG
nicht_aktiv
SA_KONFIG_HZ_FAS
aktiv
SA_KONFIG_HZ_BFS
aktiv
KONF_SHT_MEMORISE
stufe_speichern
ECE_TELEFON
nicht_aktiv
PHONE_BUSINESS
aktiv
PHONE_PROF
nicht_aktiv
CAR_COLOR
nicht_aktiv
BMW_ASSIST
nicht_aktiv
CBS_SCEN_01H
aktiv
CBS_SCEN_02H
aktiv
CBS_SCEN_04H
aktiv
CBS_SCEN_06H
aktiv
CBS_SCEN_07H
nicht_aktiv
CBS_SCEN_08H
nicht_aktiv
CBS_SCEN_10H
nicht_aktiv
CBS_SCEN_11H
aktiv
CBS_SCEN_12H
nicht_aktiv
CBS_SCEN_03H
aktiv
CBS_SCEN_13H
nicht_aktiv
CBS_SCEN_14H
nicht_aktiv
CBS_SCEN_20H
aktiv
CBS_SCEN_21H
aktiv
HELPNET
nicht_aktiv
BMW_ONLINE
nicht_aktiv
PDC
aktiv
ABSENK_ENTERTAINMENT_PDC
standard
SHOW_PDC
aktiv
RDC
nicht_aktiv
HUD
nicht_aktiv
ELDRVSEAT
aktiv
MFL_HORN
nicht_aktiv
MFL_HAZARD
nicht_aktiv
MFL_CLEAN
nicht_aktiv
FOND_HIGH
nicht_aktiv
FOND_LOW
nicht_aktiv
LAENDERVARIANTE_TUNER
us
RDS_AF_FUNKTION
rds_aus
PWM_ANST_FL_BIXENON
wert_03
TP_FUNKTION
nicht_aktiv
TP
nicht_aktiv
TMC
nicht_aktiv
AMBANDS
nicht_aktiv
FILTER_FZG_BLOCK_1
e60_stereo
FILTER_FZG_BLOCK_2
e60_stereo
FILTER_FZG_BLOCK_3
e60_stereo
FILTER_FZG_BLOCK_4
e60_stereo
PHASE_BLOCK
e60_stereo
CROSS_OVER_1
e60_stereo
CROSS_OVER_2
e60_stereo
OUTPUT_GAIN_SYSTEM
e60_stereo
BAUREIHE
e64
BAUART
cabrio
TRACK_WIDTH
e63_e64
WHEEL_CIRCUMFERENCE
e63_e64
FZG_RADSTAND
wert_06
NORM_LEUCHTWEITE
wert_06
MAX_SW_SCHWENK_W_INNEN
wert_15
MAX_SW_SCHWENK_W_AUSSEN
wert_18
MAX_SW_SCHWENK_V_HORIZ
wert_20
MAX_SW_SCHWENK_V_VERTI
wert_12
TAU_ABSCHWAECHUNG
wert_20
LICHTZ_R_L_FAKTOR
wert_20
SW_NULL_BEREICH
wert_16
V_LO_SW_MITLENKEN
wert_16
V_HI_SW_MITLENKEN
wert_16
C_METER_NACH_INNEN_HI
wert_06
V_LO_SW_NACH_INNEN
wert_16
V_HI_SW_NACH_INNEN
wert_16
KENNL_MAX_UEBERST
wert_16
KENNL_REDUZ_MAX_SCHWENK
wert_16
T_FILTER_UEBERST
wert_16
V_LO_AENDER_LENK_UEBERS
wert_16
V_HI_AENDER_LENK_UEBERS
wert_16
T_FILTER_V_VEH
wert_16
V_LO_RED_SCHWENK_W
wert_16
V_HI_RED_SCHWENK_W
wert_16
ABSCHW_D_TAU_LO
wert_16
ABSCHW_D_TAU_HI
wert_16
V_LO_ABSCHW_D_TAU
wert_16
V_HI_ABSCHW_D_TAU
wert_16
ABSCHWAECH_D_TAU
wert_16
V_REFERENZLAUF_EN
wert_16
MIN_SW_SCHWENK_V_HORIZ
wert_16
AEND_V_SCHWENK_N_AUSSEN
wert_20
REDUZIERUNG_V_SCHWENK_LO
wert_16
V_LO_REDUZIER_V_SCHWENK
wert_16
V_M_LO_REDUZIER_V_SCHWENK
wert_16
REDUZIERUNG_V_SCHWENK_HI
wert_16
V_M_HI_REDUZIER_V_SCHWENK
wert_16
V_HI_REDUZIER_V_SCHWENK
wert_16
MAX_VERRINGERUNG_V_SCHW
wert_12
MIN_DELTA_MAX_VERR
wert_16
MAX_DELTA_KEINE_VERR
wert_16
T_FILTER_LENKWINKEL
wert_16
D_TAU_MITTEL_LENKW
wert_16
T_FILTER_GIERRATE
wert_16
D_TAU_MITTEL_GIERR
wert_16
V_LO_TAU_GIERRATE
wert_16
V_HI_TAU_GIERRATE
wert_16
T_F_GIERRATE_DEF
wert_16
SCHW_TAU_LW_GR
wert_16
DRIFT_INKR
wert_16
DRIFT_DEKR
wert_16
DRIFT_SCHWELLE
wert_16
T_FILTER_TAU_LW
wert_16
T_FILTER_DYN_LZ
wert_16
RAUSCH
wert_16
ZEITK_TRIGGER1
wert_16
MERKM_1_MAX
wert_16
MERKM_1_BEGR
wert_16
MERKM_1_INKR
wert_16
MERKM_1_DEKR
wert_16
ALC_KENNLIN_LWR_SENSOR_VO
wert_25
ALC_KENNLIN_LWR_SENSOR_HI
wert_06
ALC_DEF_LWR_SENSOR_HI
wert_06
ALC_LWR_NEIGUNG_KONSTANTE
wert_16
ALC_OFFSET_LWR
wert_06
ALC_EPSILON_DELTA_AV
wert_16
ALC_EPSILON_DELTA_A
wert_16
ALC_ANHEBUNG_175_KM/H
wert_15
ALC_ABSENKUNG_10_KM/H
wert_17
ALC_VMAX_BESCHLEUNIGUNG
wert_09
ALC_VMIN_BESCHLEUNIGUNG
wert_09
ALC_VMAX_BREMSEN
wert_17
ALC_VMIN_BREMSEN
wert_17
ALC_SCHW_GRAD_BESCHLEUNIG
wert_06
ALC_SCHW_GRAD_BREMSEN
wert_06
ALC_SCHW_PROP_ABWEICHUNG
wert_06
ALC_DIFFERENZ_MSP_DYN_STA
wert_17
ALC_DAUER_DYN_NACHFUEHR
wert_17
ALC_ABTASTRATE_DYN
wert_17
ALC_MITTELUNGSINTERV_DYN
wert_15
ALC_MIN_STEIGUNG_VZ_WECHS
wert_17
ALC_MITTELUNGSINT_VZ_WECH
wert_17
ALC_MINDESTANZAHL_VZ_WECH
wert_15
ALC_HOEHENWEG
wert_07
ALC_ABTASTRATE_TREND
wert_17
ALC_MITTELUNGSINTERV_TREN
wert_17
ALC_SCHW_TREND
wert_07
ALC_ABWEICHUNG_TREND
wert_07
ALC_NACHLAUF_SCHLECHTWEG
wert_17
WHEEL_BASE
e63_e64
CKM_ALC
wert_16
CKM_ALC_DEF
wert_16
MIN_SW_SCHWENK_V_VERTI
wert_16
CHECKSUM_0
grundcode_var
CHECKSUM_1
grundcode_var
CHECKSUM_2
grundcode_var
CHECKSUM_3
grundcode_var
CHECKSUM_4
grundcode_var
CHECKSUM_5
grundcode_var
CHECKSUM_6
grundcode_var
CHECKSUM_7
grundcode_var
CSUM_PERSONALISERUNG
grundcode_var
CODING_VALID_BMW
wert_01
DATEN_INDEX
wert_01
CODIERUNG_ERFOLGT
codierung_erfolgt
CODIERUNG_ERFOLGT_1
codierung_erfolgt
CC_BLINKFREQUENZ_LANGSAM
wert_01
CC_BLINKFREQUENZ_SCHNELL
wert_01
TANK_FILTER_FALLEND
wert_01
CC_15_EIN
wert_01
CC_15_AUS
wert_01
CC_R_EIN
wert_01
CC_ML
wert_01
TANK_ADC_FEHLER_UG
wert_01
TANK_ADC_FEHLER_OG
wert_01
CC_F_WASCHWASSERSTAND
wert_01
CC_F_KUEHLMITTELSTAND
wert_01
CBS_STAT_07H
sperre
CC_I_ZEITZELLE
wert_01
PREDRIVE_PERIODENDAUER
wert_01
BC_LEERZEILE
aktiv
TANK_FILTER_STEIGEND
wert_01
TANK_MITTLUNGSZEIT
wert_01
TANK_BERUHIGUNGSZEIT
wert_01
TANK_SICHERHEITSFAKTOR
wert_01
TANK_RED_REICHWEITE
wert_01
AUSSENTEMP_ZEITKONST_Z4
wert_01
AUSSENTEMP_ZEITKONST_Z5
wert_01
AUSSENTEMP_ZEITKONST_Z6
wert_01
AUSSENTEMP_DELTA_K2
wert_01
AUSSENTEMP_ZEITKONST_Z1
wert_01
AUSSENTEMP_ZEITKONST_Z2
wert_01
AUSSENTEMP_ZEITKONST_Z3
wert_01
AUSSENTEMP_DELTA_K1
wert_01
AUSSENTEMP_ANZ_FEHLER_1
wert_01
AUSSENTEMP_ANZ_FEHLER_2
wert_01
PREDRIVE_ABB_MOT
nicht_aktiv
TANK_SCHWELLE_AUF/AB
wert_01
TANK_VOLL_ERKENNUNG
wert_01
WARNFELD_INFO_DME
aktiv
SFY_ALIVE_ZAEHLER
aktiv
SEAT_BELT_MONITOR
wert_01
DSC_ALIVE_ZAEHLER
aktiv
DME_ALIVE_ZAEHLER
aktiv
SBR_BEIFAHRER
aktiv
CAS_ALIVE
aktiv
LM_ALIVE
aktiv
SBR_FAHRER
aktiv
SFY_ID_MONITOR
aktiv
DME_ID_MONITOR
aktiv
ZGM_ID_MONITOR
aktiv
PREDRIVE_START_MIT_OBD
aktiv
BC_DIGITAL_V
nicht_aktiv
BC_DIGITAL_V_KORREKTUR
nicht_aktiv
ZGM_ALIVE_ZAEHLER
aktiv
ACC_FILTER_FALLEND
wert_01
ACC_FILTER_STEIGEND
wert_01
TANK_EINGANG_WAHL
tnk_sensor
TANK_ANZEIGE_KL30
nicht_aktiv
TANK_RW_WARNUNG
wert_01
ACC_ZEIGER_AUF_NULL
aktiv
AUSSENTEMP_SPERR_FAKTOR
wert_01
AUSSENTEMP_SPERR_OFFSET
wert_01
TANK_UMRECHENKONSTANTE_1
wert_01
TANK_UMRECHENKONSTANTE_2
wert_01
MOTORKONSTANTE
wert_01
DSC_ID_MONITOR
aktiv
TEMPOMAT_SETZ_ANZ_DAUER
wert_01
KLICK_AMP
wert_01
KLICK_FRE
wert_01
KLICK_TON
wert_01
KLACK_AMP
wert_01
KLACK_FRE
wert_01
KLACK_TON
wert_01
AKUSTIK_V_X
wert_01
AKUSTIK_V_Y
wert_01
CC_R_AUS
wert_01
CBS_STAT_01H
anzeige
CBS_STAT_02H
anzeige
CBS_STAT_04H
anzeige
CBS_STAT_03H
anzeige
CBS_STAT_11H
anzeige
CBS_INTW_12H
wert_01
CBS_STAT_20H
anzeige
CBS_STAT_21H
anzeige
CBS_INTD_03H
wert_01
CBS_GELB_HUAU
wert_01
CBS_RES_SPERR
wert_01
CBS_AVKM_START
wert_01
CBS_GELB
wert_01
CBS_STAT_12H
sperre
CBS_STAT_06H
anzeige
CBS_STAT_08H
sperre
CBS_STAT_13H
sperre
CBS_STAT_14H
sperre
CBS_EINH_01H
wegbas
CBS_EINH_02H
wegbas
CBS_EINH_04H
wegbas
CBS_EINH_06H
wegbas
CBS_EINH_07H
wegbas
CBS_EINH_08H
wegbas
CBS_EINH_03H
zeitbas
CBS_EINH_10H
wegbas
CBS_EINH_11H
wegbas
CBS_EINH_12H
wegbas
CBS_EINH_13H
zeitbas
CBS_EINH_14H
zeitbas
CBS_EINH_20H
zeitbas
CBS_EINH_21H
zeitbas
CBS_INTD_13H
wert_01
CBS_INTD_14H
wert_01
CBS_TZ_SCHALTER
borddatum
CBS_GELB_KM_MIN
wert_01
CC_CSUM
grundcode_var
CSUM_ATEMP
grundcode_var
CSUM_CODIERDATUM
grundcode_var
CSUM_KODIERUNG_VALID
grundcode_var
CSUM_AUSSTATTUNG
grundcode_var
CC_ID_AKTIV
aktiv
CSUM_AUSSTATTUNG_1
grundcode_var
CSUM_CBS_01
grundcode_var
CSUM_AKUSTIK_KLANG
grundcode_var
CSUM_CC_ALIVE
grundcode_var
CSUM_ACC
grundcode_var
CSUM_ST_ANZEIGE_1
grundcode_var
CSUM_WEG
grundcode_var
CSUM_TANK_PROZESS
grundcode_var
CSUM_TANK_INPUT
grundcode_var
TNK_LITER_RECHTS
wert_01
TNK_LITER_LINKS
wert_01
TNK_OHM_LINKS
wert_01
TNK_OHM_RECHTS
wert_01
FUNKTION
wert_01
ABSCHALTI
wert_01
EINSCHALTI
wert_01
EINSCHALTII
wert_01
NWMAX
wert_01
UB
wert_01
TOUTU
wert_01
TAB
wert_01
TOUTR
wert_01
TTRANS
wert_01
DEBUG
wert_01
ID
wert_01
CHECKSUMME
wert_01
WAKE-UP-QUELLEN
wert_01
FUNKMODEM
wert_01
K_LIN_BUS
wert_01
NACHLAUFZEIT
wert_01
ANZAHL_WANDLER
8_wandler
NUR_KL15_BETRIEB
nicht_aktiv
TONGEBER
nicht_aktiv
AKUSTIK_RECHTS_LINKS
aktiv
PDC_SCHALTER
nicht_aktiv
EINSCHALTVERZOEGERUNG
aktiv
PDC_AKTIV/DEAKTIV
weg_geschw
EINSCHALTMELDUNG_BEI_1MAL
nicht_aktiv
AKUSTISCHE_FEHLERMELDUNG
nicht_aktiv
EINSCHALTMELDUNG_IMMER
nicht_aktiv
ABSCHALTMELDUNG
nicht_aktiv
MELDUNG_TASTER
nicht_aktiv
NOTFUNKTION
nicht_aktiv
EIS_AUSBLENDEN
aktiv
ABSTAND_EINBAU_WANDLER
e63
MESSBEREICHE_WANDLER
e60
OFFSET_MESSBEREICH
e60
DAUERTON_MESSBEREICH
e60
MESSBEREICH_HECKKL_ECKE
e60
MESSBEREICH_HECKKL_MITTE
e60
LAUTSTAERKE_HINTEN
e60
TONGEBER_HINTEN
lautsprecher
LAUTSTAERKE_VORN
e60
TONGEBER_VORN
lautsprecher
EINSCHALT_GESCHWINDIGKEIT
e60
ABSCHALT_GESCHWINDIGKEIT
e60
ABSCHALTWEG
e60
AHK_ABSTAND
e63
ECHOSCHWELLWERTE_ECKE_HI
e63_neu
ANFANGSWERT_ECKE_HINTEN
100_prozent
SKALIERUNG_ECKE_HINTEN
0.65
ECHOSCHWELLWERTE_MITTE_HI
e63_neu
ANFANGSWERT_MITTE_HINTEN
100_prozent
SKALIERUNG_MITTE_HINTEN
0.65
ECHOSCHWELLWERTE_ECKE_VO
e63_neu
ANFANGSWERT_ECKE_VORN
100_prozent
SKALIERUNG_ECKE_VORN
0.65
ECHOSCHWELLWERTE_MITTE_VO
e63_neu
ANFANGSWERT_MITTE_VORN
100_prozent
SKALIERUNG_MITTE_VORN
0.65
DYNAMIC_ABSCHALTEN_VORN
nicht_aktiv
LAMPENTAKTUNG_AHM
nicht_aktiv
TEILLAST_BREMSLICHT
nicht_aktiv
TEILLAST_BLINKER_L
nicht_aktiv
TEILLAST_BLINKER_R
nicht_aktiv
TEILLAST_SCHLUSSLICHT_L
nicht_aktiv
TEILLAST_SCHLUSSLICHT_R
nicht_aktiv
TEILLAST_RUECKFAHRLICHT
nicht_aktiv
TEILLAST_NEBELLICHT
nicht_aktiv
TEILLAST_RELATIV_WERT
wert_01
EFFEKTIVSPANNUNG_LAMPEN
wert_02
KALTLICHTABFRAGE_AHM
nicht_aktiv
NO_CHK_MESSAGE_RUECKFAHRL
nicht_aktiv
NO_CHK_MESS_NEBELSCHLUSSL
nicht_aktiv
NO_CHK_MESSAGE_BREMSLICHT
nicht_aktiv
KLSTRG_DISFERTMODE
nicht_aktiv
KLSTRG_DISTRANSMODE
nicht_aktiv
KLSTRG_DISWERKSTMODE
nicht_aktiv
STROM_RUHE
wert_01
TRANSPONDER
aktiv
KLR_AUS_TKSITZ
aktiv
AUSWERTUNG_B_DRUCK
nicht_aktiv
ZEIT_BREMSE
wert_04
BREMSE_DRUCK
wert_01
KOMFORT_AUS_IN_50MS
wert_03
MFS_MIT_TON
nicht_aktiv
KLR_AUS_TIMEOUT
wert_02
ZV_DISFERTMODE
nicht_aktiv
ZV_DISTRANSMODE
aktiv
ZV_DISWERKSTMODE
nicht_aktiv
CLT_TASTE
aktiv
SPERRE_CRASH_ER
aktiv
VR_KLR
nicht_aktiv
VR_KLR_EINMALIG
nicht_aktiv
VR_GESCHW_EINMALIG
aktiv
SPERRE_HECKKLAPPE_KLR
nicht_aktiv
ER_TANKKLAPPE_SER
aktiv
ER_TANKKLAPPE_VR
aktiv
ER_KEYOUT_AUTOVR
nicht_aktiv
ENABLE_CLT_NACH_CRASH
nicht_aktiv
ZV_AUTHENTISIERUNG
nicht_aktiv
CCM_SEND_INVALID
nicht_aktiv
CRASH_SCHWERE
wert_01
CRASH_BESCHLEUNIGUNG
wert_01
VERRIEGELUNGSSCHWELLE
wert_04
GESCHW_SPERRE_TOEHK
wert_01
ZEIT_AUTO_ZV_VR
wert_01
VER_AUT_X_MIN_OHNE_NR
nicht_aktiv
VER_AUT_X_MIN_SENDER_1
nicht_aktiv
VER_AUT_X_MIN_SENDER_2
nicht_aktiv
VER_AUT_X_MIN_SENDER_3
nicht_aktiv
VER_AUT_X_MIN_SENDER_4
nicht_aktiv
VERRIEGEL_XKM/H_OHNE_NR
nicht_aktiv
VERRIEGELN_XKM/H_SENDER_1
nicht_aktiv
VERRIEGELN_XKM/H_SENDER_2
nicht_aktiv
VERRIEGELN_XKM/H_SENDER_3
nicht_aktiv
VERRIEGELN_XKM/H_SENDER_4
nicht_aktiv
HECKSCHEI_ENTR_OHNE_NR
nicht_aktiv
HECKSCHEIBE_ENTR_SENDER_1
nicht_aktiv
HECKSCHEIBE_ENTR_SENDER_2
nicht_aktiv
HECKSCHEIBE_ENTR_SENDER_3
nicht_aktiv
HECKSCHEIBE_ENTR_SENDER_4
nicht_aktiv
TOEHK_EO_HS_OHNE_NR
nicht_aktiv
TOEHK_EO_HS_SCHL_NR01
nicht_aktiv
TOEHK_EO_HS_SCHL_NR02
nicht_aktiv
TOEHK_EO_HS_SCHL_NR03
nicht_aktiv
TOEHK_EO_HS_SCHL_NR04
nicht_aktiv
HKAT_EO_HS_OHNE_NR
nicht_aktiv
HKAT_EO_HS_SCHL_NR01
nicht_aktiv
HKAT_EO_HS_SCHL_NR02
nicht_aktiv
HKAT_EO_HS_SCHL_NR03
nicht_aktiv
HKAT_EO_HS_SCHL_NR04
nicht_aktiv
FBD_SERVICEFKT_AKTIV
aktiv
EE_TRSP_PERM
aktiv
FH_RESESCH
nicht_aktiv
FH_KINDERSICHERUNG
aktiv
FH_UMLSCH
nicht_aktiv
FH_ECEFIN
nicht_aktiv
FH_ABSCHALTKRITERIUM
aktiv
FH_USACANADA
nicht_aktiv
FH_DISAKL15
nicht_aktiv
FH_DISAKLR
nicht_aktiv
KOMFORTOEFFNUNG
aktiv
KOMFORTOEFFNUNG_FB
aktiv
KOMFORTSCHLIESSUNG
aktiv
FH_RESETTIMEOUTKL50
aktiv
FH_TUERBED_EINSTG
aktiv
FH_DISTGDEFECT
aktiv
FH_KMFRTFBDTIM
aktiv
FH_DISCLSYDEFECT
aktiv
FH_DISFBDDEFCT
aktiv
FH_DISFERTMODE
aktiv
FH_DISTRANSMODE
aktiv
FH_DISWERKSTMODE
aktiv
KMFRT_OEFF_HINTEN
wert_01
KMFRT_OEFF_SHD
wert_01
KMFRT_SCHL_VORNE
wert_01
KOMFORT_SCHL_SHD
wert_01
ANSTEUERZEIT
wert_01
KMFRT_OEFFNEN
wert_01
KMFRT_SCHLIESSEN
wert_01
MIND_KMFRT_NACH_UNTERB
wert_01
MAX_KMFRT_UNTERB
wert_01
MAX_KMFRT_UNTERB_FBD
wert_01
KISITMRMAX
wert_01
SLEEPTIMER_FH_KLRAUS
wert_01
PERSONALISIERUNG_AUS
nicht_aktiv
SONDERTASTE_INNENLICHT
nicht_aktiv
FBD_AKTIV_KL15AUS
nicht_aktiv
FBD_AKTIV_KEYIN
aktiv
FBD_TESTKEY_AKTIV
nicht_aktiv
FBD_HECKKLAPPE_TOTZEIT
wert_02
FBD_PANIK_TOTZEIT
wert_01
FBD_MOTORLAUF
wert_01
FBD_MOTORSTART
wert_01
FBD_PANIKDAUER
wert_01
EE_TRSP_CCM_0CD
nicht_aktiv
MFS_KEY_PLGD
nicht_aktiv
FBD_DISFERTMODE
nicht_aktiv
FBD_DISTRANSMODE
nicht_aktiv
FBD_DISWERKSTMODE
nicht_aktiv
PA_CONFIG_FBDREFCHECK
nicht_aktiv
PA_TVRERFATH
wert_01
PA_TSPERRVR
wert_01
PA_TBEREITPE
wert_01
PA_ID_GEBER
wert_01
PA_FBD_REF
wert_01
PA_TBEREIT_PG
wert_01
CHIPCARD
aktiv
BOS_DATEN_ANFRAGEN
aktiv
FS_DATEN_ANFRAGEN
aktiv
SQCNT_UPDATE
nicht_aktiv
BEDINGUNG_CC_10KM
aktiv
EE_ZEIT_NLF
wert_01
EE_ZEIT_ABFR
wert_01
GESCHW_REQ_CC
wert_01
EWS_NACHLAUF_KLR_AUS
nicht_aktiv
EWS_FEHLER_MOTORLAUF
aktiv
EWS_SCHRITTWEITE_2
nicht_aktiv
ERROR_EJECT
nicht_aktiv
KOMFORT_EIN
aktiv
STROM_KS_MAX
wert_01
FH_SCHLIESSEN_EINSTG
aktiv
STROM_KS_MIN
wert_01
ANLASSSPERRE_BLS
aktiv
BLOCKLAENGE_00
wert_01
BLOCKLAENGE_01
wert_01
BLOCKLAENGE_02
wert_01
BLOCKLAENGE_03
wert_01
BLOCKLAENGE_04
wert_01
BLOCKLAENGE_05
wert_01
BLOCKLAENGE_06
wert_01
BLOCKLAENGE_07
wert_01
CODIERINDEX_ARS
wert_01
A_QUER_ZUSCHALT_MAX
wert_01
Y2_AQ_WAWI_Z1
wert_01
T_WARTE_OELSTAND
wert_01
DEFAULT_SPORT
wert_01
AQ_AUSBLEND_X1
wert_01
TAUSSEN_X_FSZEITEN
wert_01
TAUSSEN_Y_FSZEITEN
wert_01
NM_TOL
wert_01
Q_PUMPE_MAX
wert_01
R_MKSCHLAUCH
wert_01
N_ETA_PUMPE_X
wert_01
P_ETA_PUMPE_Y
wert_01
ETA_PUMPE
wert_01
RP_CAN_ENABLE
wert_01
FG_TP_V_FZG
wert_01
FG_A_QUER_FEHLER
wert_01
FG_TP_SENSORFILTER
wert_01
FG_RES_FILT
wert_01
FG_TP_AQOF
wert_01
T_GERADEAUS
wert_01
AQ_LERN_V
wert_01
ANTEIL_AQ_NEU_LERN
wert_01
P_TANK
wert_01
AY_KONSISTENZ_SCHWELLE
wert_01
AY_LEWI_SCHWELLE
wert_01
A_QUER_OFFSET_D
wert_01
D_LEWI_SCHWELLE
wert_01
GERADEAUS_SCHWELLE
wert_01
WZ_PR_FS
wert_01
WIRKGRAD
wert_01
R_GESAMT_VA
wert_01
R_GESAMT_HA
wert_01
R_LECK
wert_01
STF_H_TOT_VA
wert_01
STF_H_TOT_HA
wert_01
FG_TP_DBVMOD
wert_01
FG_FEHLER_AKT
wert_01
D_TP_DBVMOD
wert_01
T_WARTE_DBV_VA
wert_01
UNEMPF_FAKTOR_AKTUE
wert_01
P_FEHLER_AKT
wert_01
P_FEHLER_AKT_MAX
wert_01
T_SCHALT_RV
wert_01
T_FS_HALTE
wert_01
PUSH_STROM
wert_01
HALTE_STROM_FS
wert_01
HALTE_STROM_RV
wert_01
I_SV_LIMIT
wert_01
P_ANTEIL_SV
wert_01
I_ANTEIL_SV
wert_01
P_SCHALT
wert_01
SV_STANDBY
wert_01
RV_INVERTIEREN
wert_01
AQ_SENSOR_INV
wert_01
Y2_MOMV_VFZG_Z1
wert_01
DRUCKREG_STROEM_HA
wert_01
Y_P_SOLL_HA_2_6
wert_01
T_RV_SCHNELL
wert_01
PSOLL_P_ANTEIL
wert_01
VERST_P_ANTEIL
wert_01
ISOLL_P_ANTEIL_GRENZ
wert_01
PSOLL_I_ANTEIL
wert_01
VERST_I_ANTEIL
wert_01
ISOLL_I_ANTEIL_GRENZ
wert_01
D_ANTEIL_DRUCKREG_VA
wert_01
D_ANTEIL_DRUCKREG_HA
wert_01
DRUCKREG_STROEM_VA
wert_01
KL_DKOMP_POS_X
wert_01
KL_DKOMP_POS_Y
wert_01
KL_DKOMP_NEG_X
wert_01
KL_DKOMP_NEG_Y
wert_01
X_P_SOLL_VA
wert_01
Y_P_SOLL_VA_1_6
wert_01
Y_P_SOLL_VA_2_6
wert_01
Y_P_SOLL_HA_1_6
wert_01
AY_VOREIL_AUS_LEWI
wert_01
X_P_SOLL_HA
wert_01
T_PUSH_FS
wert_01
T_PUSH_RV
wert_01
STEUER_ADD
wert_01
I_ANTEIL_STROMREGLER
wert_01
P_ANTEIL_STROMREGLER
wert_01
I_VORSTEUERANTEIL
wert_01
I_SOLL_PROPV_0
wert_01
T_MAX_PROPV_0
wert_01
PWM_LIMIT_OBEN
wert_01
PWM_LIMIT_UNTEN
wert_01
PWM2ISOLL
wert_01
FG_AQUER
wert_01
DELTA_AQ
wert_01
T_UEBERBLEND
wert_01
P_LUFT
wert_01
P_SOLL_VA
wert_01
P_SOLL_HA
wert_01
DP_VA_HA
wert_01
P_SOLLBAND
wert_01
P_ABFALL
wert_01
P_STAU_MAX
wert_01
P_MAX_ZYKL
wert_01
P_VENT_LIM
wert_01
P_SMVA_MIN
wert_01
P_SMHA_MIN
wert_01
WZ_RV_BESTR
wert_01
WZ_RV_UNBES
wert_01
WZ_FS_IVA
wert_01
WZ_FS_IHA
wert_01
WZ_FS_IAB
wert_01
WZ_FS_LFT
wert_01
WZ_FS_SOL
wert_01
WZ_FS_PVA
wert_01
WZ_FS_DYN
wert_01
WZ_FS_PAB
wert_01
WZ_DY_LFT
wert_01
WZ_DY_SOL
wert_01
WZ_DY_PHA
wert_01
WZ_DY_DYN
wert_01
WZ_DY_PAB
wert_01
WZ_KENNL
wert_01
DP_VA_TOL
wert_01
DP_HA_TOL
wert_01
GUETELIM_VA
wert_01
GUETELIM_HA
wert_01
I_PH1
wert_01
P1
wert_01
P2
wert_01
P3
wert_01
DP_VAMIN
wert_01
DP_VAMAX
wert_01
LIM_PVA
wert_01
LIM_IVA
wert_01
ISOLL_PREDRIVE
wert_01
TOLBANDTIME
wert_01
STRT_DRZ
wert_01
STP_DRZ_MIN
wert_01
WZ_FS_SOLLTOL
wert_01
LIM_IFS
wert_01
RESETVKMH
wert_01
WZ_PR_IVA
wert_01
WZ_PR_IHA
wert_01
WZ_PVAWAIT1
wert_01
P_VA_REGEL_DIFF_INT
wert_01
WZ_PVAWAIT2
wert_01
HI_AQLIM
wert_01
LOW_AQLIM
wert_01
WZ_DY_SOLLTOL
wert_01
TAUSSEN_Y_TMOT_MIN
wert_01
ANTEIL_LEWI_NEU_LERN
wert_01
VFZG_RV_MISSBRAUCH
wert_01
T_WARTE_CC_MOTOR_AUS
wert_01
VFGZ_LIMIT_MOTOR_AUS
wert_01
LEWI_OFFSET_D
wert_01
LEWI_LERN_V_MIN
wert_01
LEWI_LERN_V_MAX
wert_01
BT_UFN
wert_01
EMERGENCY_NUMBER
wert_01
AD_GAIN
wert_12
KALTUEBERWACHUNG_FL_L
aktiv
KALTUEBERWACHUNG_FL_R
aktiv
KALTUEBERWACHUNG_SL_V_L
aktiv
KALTUEBERWACHUNG_SL_V_R
aktiv
KALTUEBERWACHUNG_NSW_L
aktiv
KALTUEBERWACHUNG_NSW_R
aktiv
KALTUEBERWACHUNG_BLK_V_L
aktiv
KALTUEBERWACHUNG_BLK_V_R
aktiv
KALTUEBERWACHUNG_BLK_H_L
aktiv
KALTUEBERWACHUNG_BLK_H_R
aktiv
KALTUEBERWACHUNG_BLK_Z_L
aktiv
KALTUEBERWACHUNG_BLK_Z_R
aktiv
KALTUEBERWACHUNG_BL_M_1
nicht_aktiv
HEIMLEUCHTEN_FUNKSCHL
nicht_aktiv
SICHERHEITS_FZG_LM
nicht_aktiv
KALTUEBERWACHUNG_KZL_L
aktiv
KALTUEBERWACHUNG_KZL_R
aktiv
ALC_FAILSAVE
nicht_aktiv
KALTUEBERWACHUNG_RFS_L
aktiv
MIND_ANZ_ZYKL_TIPP_BLK
wert_02
ALC_ZUSTANDS_AUTOM
wert_02
DEF_HEIMLEUCHTEN_CKM
wert_02
DEF_ZYKL_TIPP_BLK_CKM
wert_02
HEIMLEUCHTEN_BLK_H
nicht_aktiv
KALTUEBERWACHUNG_RFS_R
aktiv
SL_PARKL_UNTERSP_ABSCHALT
aktiv
COMFORT_ACCESS_SL_ABSCH
wert_04
KALTUEBERWACHUNG_ZU_1
nicht_aktiv
KALTUEBERWACHUNG_ZU_2
nicht_aktiv
KALTUEBERWACHUNG_ZU_3
nicht_aktiv
WARMUEBERWACHUNG_FL_L
aktiv
WARMUEBERWACHUNG_FL_R
aktiv
WARMUEBERWACHUNG_AL_L
aktiv
WARMUEBERWACHUNG_AL_R
aktiv
WARMUEBERWACHUNG_SL_V_L
aktiv
WARMUEBERWACHUNG_SL_V_R
aktiv
WARMUEBERWACHUNG_NSW_L
aktiv
WARMUEBERWACHUNG_NSW_R
aktiv
WARMUEBERWACHUNG_BLK_V_L
aktiv
WARMUEBERWACHUNG_BLK_V_R
aktiv
WARMUEBERWACHUNG_BLK_H_L
aktiv
WARMUEBERWACHUNG_BLK_H_R
aktiv
WARMUEBERWACHUNG_BLK_Z_L
aktiv
WARMUEBERWACHUNG_BLK_Z_R
aktiv
WARMUEBERWACHUNG_BL_M_1
nicht_aktiv
WARMUEBERWACHUNG_KZL_L
aktiv
WARMUEBERWACHUNG_KZL_R
aktiv
CBD_ZEICHN_INDEX
wert_01
WARMUEBERWACHUNG_RFS_L
aktiv
WARMUEBERWACHUNG_RFS_R
aktiv
LCD_LD_DIMMER_TELEGRAMM
aktiv
WARMUEBERWACHUNG_ZU_1
nicht_aktiv
TASTVERH_KL_58G_MIN
wert_01
ZUWACHS_TASTVERH_KL_58G
wert_01
WARMUEBERWACHUNG_ZU_2
nicht_aktiv
WARMUEBERWACHUNG_ZU_3
nicht_aktiv
VERHALTEN_UEBERWACHUNG
wert_01
FEHLERMELDUNG_CC_FL_L
aktiv
FEHLERMELDUNG_CC_FL_R
aktiv
FEHLERMELDUNG_CC_AL_L
aktiv
FEHLERMELDUNG_CC_AL_R
aktiv
FEHLERMELDUNG_CC_SL_V_L
aktiv
FEHLERMELDUNG_CC_SL_V_R
aktiv
FEHLERMELDUNG_CC_NSW_L
aktiv
FEHLERMELDUNG_CC_NSW_R
aktiv
FEHLERMELDUNG_CC_BLK_V_L
aktiv
FEHLERMELDUNG_CC_BLK_V_R
aktiv
FEHLERMELDUNG_CC_BLK_H_L
aktiv
FEHLERMELDUNG_CC_BLK_H_R
aktiv
FEHLERMELDUNG_CC_BLK_Z_L
nicht_aktiv
FEHLERMELDUNG_CC_BLK_Z_R
nicht_aktiv
ALC_ERR_NSW_ZUSCHALTEN
aktiv
FEHLERMELDUNG_CC_BL_M_1
aktiv
ALC_CC_127_ZUST_5_OFF
aktiv
ALC_CC_AL_OFF
nicht_aktiv
FEHLERMELD_CC_RL_BL_2_L
nicht_aktiv
FEHLERMELD_CC_RL_BL_2_R
nicht_aktiv
FEHLERMELDUNG_CC_KZL_L
aktiv
FEHLERMELDUNG_CC_KZL_R
aktiv
WARNBLK_ENERGY_SAVE_MODE
aktiv
FEHLERMELDUNG_CC_RFS_L
aktiv
FEHLERMELDUNG_CC_RFS_R
aktiv
XENON_WIEDER_Z_AUS_PHASE
wert_01
FEHLERMELDUNG_CC_ZU_1
nicht_aktiv
LEUCHTDICHTE_EXPO
nicht_aktiv
PWM_ANSTEUERUNG_ZU_1
wert_01
FEHLERMELDUNG_CC_ZU_2
nicht_aktiv
FEHLERMELDUNG_CC_ZU_3
nicht_aktiv
LENKWINKEL_UEBERSCHREITEN
wert_01
LENKWINKEL_UNTERSCHREITEN
wert_01
LENKSTOCK_UMSCHALT_VERZ
wert_01
U_POTI_DIMM_MIN
wert_02
U_POTI_DIMM_DELTA
wert_02
MELDUNG_AENDERUNG_DIMMER
wert_01
POTI_DIMM_INVERS
aktiv
POTI_LWR_INVERS
nicht_aktiv
HEIMLEUCHTEN
wert_02
HEIMLEUCHTEN_AL
aktiv
HEIMLEUCHTEN_RL
aktiv
HEIMLEUCHTEN_FL
nicht_aktiv
HEIMLEUCHTEN_RFS
nicht_aktiv
HEIMLEUCHTEN_SL
aktiv
HEIMLEUCHTEN_NSW
nicht_aktiv
HEIMLEUCHTEN_NSL
nicht_aktiv
HEIMLEUCHTEN_BL
nicht_aktiv
HEIMLEUCHTEN_VERLAENG
nicht_aktiv
CRASH_58G_EIN
aktiv
DRL_WERT_DIMMUNG
wert_04
BLINKIMPULS_WARNBLK
wert_01
PWM_ANSTEUERUNG_FL_L
wert_02
BLINKIMPULS_CRASHBLK
wert_01
WERT_CRASHVERHALTEN
wert_01
CRASH_WARNBLINKEN
aktiv
PWM_ANSTEUERUNG_FL_R
wert_02
BFD_1_RL_BL_1_ERSCH_BILD
wert_01
BFD_1_RL_BL_2_ERSCH_BILD
wert_01
PWM_ANSTEUERUNG_NSW_L
wert_01
PWM_ANSTEUERUNG_NSW_R
wert_01
PWM_ANSTEUERUNG_BLK_V_L
wert_02
PWM_ANSTEUERUNG_BLK_V_R
wert_02
PWM_ANSTEUERUNG_BLK_H_L
wert_02
PWM_ANSTEUERUNG_BLK_H_R
wert_02
PWM_ANSTEUERUNG_BLK_Z_L
wert_01
PWM_ANSTEUERUNG_BLK_Z_R
wert_01
QUIT_OPT_SCHAERF
nicht_aktiv
PWM_ANSTEUERUNG_BL_M_1
wert_01
QUIT_OPT_SCHAERF_KLAPPE
aktiv
ALC_ENPRELL_AL_OK
wert_01
SL_V_PARKL_FKT
aktiv
ALC_ENPRELL_AL_NIO
wert_01
RL_BL_1_PO_RL_FKT
aktiv
PWM_ANSTEUERUNG_KZL_L
wert_01
PWM_ANSTEUERUNG_KZL_R
wert_01
AUTOM_LICHT_KONTROLLE
aktiv
BI_XENON_FL_ABSCHALT_OPT
wert_02
ALC_DEFEKT_TIMER
wert_01
ALC_EIN_DAEMMERUNGSSTUFE
wert_01
PWM_ANSTEUERUNG_ZU_2
wert_01
PWM_ANSTEUERUNG_ZU_3
wert_01
WERT_SPANNUNG_0
wert_01
WERT_SPANNUNG_1
wert_01
WERT_SPANNUNG_2
wert_01
WERT_SPANNUNG_3
wert_01
WERT_SPANNUNG_4
wert_01
WERT_SPANNUNG_5
wert_01
ALC_REF_LAUF_AL_AUS
wert_01
LWR_TREIBER_CODIERUNG_2
wert_01
SIDEMARKER_US
aktiv
ALC_CC_127_ZUST_4_OFF
aktiv
AUTOM_LICHT_ABSCHALTUNG
nicht_aktiv
MITTELUNGSINTERV_VZ_WECHS
wert_01
BI_XENON_BEI_LH
nicht_aktiv
TIPP_BLK_LOESCHT_IMMER
aktiv
HEIMLEUCHTEN_ABBRUCH
nicht_aktiv
MAX_BETAETIGUNG_FOMEHO
wert_01
LWR_TESTBETRIEB
nicht_aktiv
LWR_FEHLER_BEWERTUNG
wert_02
LWR_SCHRITTABSTAND_GRENZE
wert_01
LWR_TEMPERATUR_GRENZE
grad_-20
SCHRITTABSTAND_STARTPHASE
wert_01
LICHT_AN_LED
nicht_aktiv
KEINE_PARKLICHT_FUNKT
nicht_aktiv
SP_NACHREG_LANGSAM
nicht_aktiv
WERT_LCD_LD_KL58G_EIN
wert_01
WERT_LCD_LD_KL58G_AUS
wert_01
PRE_SLEEP_ZEIT
wert_01
FTW_MODE_DEAKTIVIERUNG
wert_01
HERSTELLER_PARAMETER_0
wert_02
FL_ABSCHALT_OPT
nicht_aktiv
HALB/VOLLSCHRITT
halbschritt
U_LWR_POTI_STELLUNG_0
wert_01
STANDVERBRAUCHER_ANMELDEN
aktiv
U_LWR_POTI_STELLUNG_1
wert_01
U_LWR_POTI_STELLUNG_2
wert_01
LWR_SCHRITTE_STELLUNG_0
wert_01
LWR_SCHRITTE_STELLUNG_1
wert_01
QUITT_BLK_ZU_CHECK
aktiv
BLEND_CHECK_IST_WINKEL
aktiv
BLEND_CHECK_SOLL_WINKEL
nicht_aktiv
SL_V_PO_RL_FKT
aktiv
ANHEBUNG_175_KM/H
wert_01
ABSENKUNG_10_KM/H
wert_02
VMAX_BESCHLEUNIGUNG
wert_01
VMIN_BESCHLEUNIGUNG
wert_01
VMAX_BREMSEN
wert_01
VMIN_BREMSEN
wert_01
SCHW_GRAD_BESCHLEUNIGUNG
wert_02
SCHW_GRAD_BREMSEN
wert_02
wert_02
DIFFERENZ_MSP_DYN_STAT
wert_01
DAUER_DYN_NACHFUEHRUNG
wert_01
ABTASTRATE_DYN
wert_01
wert_02
MIN_STEIGUNG_VZ_WECHSEL
wert_01
MINDESTANZAHL_VZ_WECHSEL
wert_01
HOEHENWEG
wert_01
ABTASTRATE_TREND
wert_01
MITTELUNGSINTERV_TREND
wert_01
SCHW_TREND
wert_01
ABWEICHUNG_TREND
wert_01
GRADIENT_SCHLECHTWEG
nicht_aktiv
wert_01
SAETT_TIMER_SCHLECHTWEG
aktiv
SCHW_GRADIENT_SCHLECHTWEG
wert_01
LENKWINKEL_BEI_KLR
aktiv
NOTLAUF_FKT_GESCHW
wert_01
NOTLAUF_FKT_TIMER
wert_01
WARNBLK_TASTE_KL58G
nicht_aktiv
LOAD_DUMP_SCHUTZ_AKTIV
aktiv
REICHWEITE_MAX
wert_01
NOTLAUF_FKT_GESCHW_ALT
nicht_aktiv
NOTLAUF_FKT_SCHALTERSTELL
aktiv
LOAD_DUMP_SCHUTZ_RFS
aktiv
LOAD_DUMP_SCHUTZ_FL
aktiv
LOAD_DUMP_SCHUTZ_RL_BL_2
aktiv
LOAD_DUMP_SCHUTZ_NSW
aktiv
LOAD_DUMP_SCHUTZ_NSL
aktiv
LOAD_DUMP_SCHUTZ_KZL
aktiv
LOAD_DUMP_SCHUTZ_SL_V
aktiv
LOAD_DUMP_SCHUTZ_BLK_Z
aktiv
LOAD_DUMP_MAX_TIME
wert_01
LOAD_DUMP_PRELL
wert_03
LOAD_DUMP_SCHUTZ_KL58G
aktiv
LOAD_DUMP_DIMM_WERL_BLK
wert_01
BFD_1_BL_M_ERSCH_BILD
wert_01
AL_KL50_SCHUTZ
nicht_aktiv
BFD_1_RL_BL_ERSCH_BILD
nicht_aktiv
BFD_1_WEGFALL
nicht_aktiv
HEIMLEUCHTEN_KL58G
nicht_aktiv
BFD_1_MIN_GESCHW
wert_01
BFD_1_THERM_TIMEOUT
wert_01
BFD_1_WERT_AX_RUCK
wert_01
BFD_1_STUFE_DELAY
wert_01
BFD_1_BLINK_FREQ_AUS
wert_01
BFD_1_BLINK_FREQ_EIN
wert_01
BFD_1_ENTPRELL_ABS
wert_01
BFD_1_ENTPRELL_AX
wert_01
BFD_2_THERM_TIMEOUT
wert_01
BFD_2_ALGORITHMUS
nicht_aktiv
BFD_2_RL_BL_1_ERSCH_BILD
wert_01
BFD_2_RL_BL_2_ERSCH_BILD
nicht_aktiv
BFD_2_RL_BL_ERSCH_BILD
wert_01
BFD_2_NSL_ERSCH_BILD
nicht_aktiv
BFD_2_WEGFALL
nicht_aktiv
BFD_2_MIN_GESCHW
wert_01
HEIMLEUCHTEN_BLK_V
nicht_aktiv
BFD_2_WERT_AX_RUCK
wert_01
BFD_2_STUFE_DELAY
wert_01
BFD_2_BLINK_FREQ_AUS
wert_03
BFD_2_BLINK_FREQ_EIN
wert_03
BFD_2_ENTPRELL_ABS
wert_01
BFD_2_ENTPRELL_AX
wert_01
HEIMLEUCHTEN_RL_I
aktiv
HEIMLEUCHTEN_KZL
aktiv
LICHT_AN_WARNUNG
aktiv
LICHT_AN_WARN_CA_OPT
aktiv
RL_BL_BREMSL_FKT
aktiv
STANDKLIMA
nicht_aktiv
RL_BL_2_BREMSL_FKT
nicht_aktiv
ALC_ERR_BLK_FREQ
wert_01
LICHT_AUS_TUER_AUF
aktiv
ALC_CC_ALC_ERR_OFF
nicht_aktiv
B_BLIND_EINAUS
aktiv
B_NEUINIT_EINAUS
aktiv
DYNAMIK_FLAG
aktiv
VEXAKT_MODUS
nur_aufsetzen
TO_SUSPEND
aktiv
EINBAUORT_HORIZONTAL
e60
ABSTANDSANZEIGE
wechsel_verst_aktivierung
OBJEKTANZEIGE
in_hintergrund
SOC
aktiv
LHT
aktiv
SOLLMOMENTENFILTER
aktiv
ACC_RESUME_INIT
nicht_aktiv
ABSTANDSSTUFE_WEIT
wert_01
SPURBREITE
e65
SUSPEND_SCHWELLE
wert_01
LENKUEBERSETZUNG
e65
MOTOR
wert_01
FAHRSCHLAUCHBREITE
wert_01
KERNZONE
wert_01
CSC_BESCHLEUNIGUNG_MAX
wert_01
FAHRZEUG
e60
BREMSSYSTEM
dsc_8
BASIS_SCHLEPPMOMENT
nicht_aktiv
T_TOL_B_NACH_A_BLIND
wert_01
ABSTANDSSTUFE_NACH_BO
wie_abstandsstufe_init
APPL_GEWICHT
e60
ABSTANDSVERSTELLRICHTUNG
fahrsituation
VSET_PLUS1
aktiv
ANZEIGE_VSET_DIGITAL
nicht_aktiv
BO_SYMBOL_MIT_OHNE_GONG
nicht_aktiv
AUFSETZEN_AUS_BRAKE_ONLY
nicht_aktiv
CC_LOW_MUE_MIT_OHNE_GONG
aktiv
CC_BLIND_ABSCH_M_O_GONG
aktiv
CC_FEHLER_MIT_OHNE_GONG
aktiv
CC_VMIN_MIT_OHNE_GONG
aktiv
CC_BREMSTEMP_MITOHNE_GONG
aktiv
CC_PARKBREMSE_M_O_GONG
aktiv
OBJEKTWECHSELANZEIGE
nicht_aktiv
WARNFUNKTION_TOR_ABSTAND
aktiv
WARNFUNKTION_TOR_BESCHL
aktiv
T_CC_MIN
wert_01
T_MIN_TOR
wert_01
T_MIN_GONG
wert_01
DIST_RELEVANT_FALL_A
wert_01
RADSTAND_ACC
e64
VERDECKTER_EINBAU
frei
EXTERNE_HEIZUNG
nicht_aktiv
EINBAU_LAGE
rechts
SCHWELLE_DEJU_HOR_SCHNELL
wert_01
SCHWELLE_DEJU_VER
wert_01
JUSTAGE_OFF_HOR
wert_01
JUSTAGE_OFF_VER
wert_01
SCHWELLE_EIN_A_BLIND
wert_01
ZEITSCHRANKE_A_BLIND
wert_01
SCHWELLE_EIN_B_BLIND
wert_01
SCHWELLE_EIN_B_EMPF_BLIND
wert_01
STRECKE_B_BLIND
wert_01
SCHWELLE_RUECK_A_BLIND
wert_01
STRECKE_B_EMPF_BLIND
wert_01
SCHWELLE_RUECK_B_BLIND
wert_01
VAR_BLIND_REACT
nicht_aktiv
SCHWELLE_DEJU_HORZ_RPU
wert_01
SCHWELLE_DEJU_HORZ_SPU
wert_01
DEJU_HORZ_FEHLERBALKN_RPU
wert_01
DEJU_HORZ_TOTE_ZONE_KOMP
wert_01
DEJU_HORZ_FEHLERBALKN_SPU
wert_01
MMI_BEDIENUNG_ON_OFF
nicht_aktiv
CC_HINWEIS_BLIND_M_O_GONG
aktiv
CC_BO_MIT_OHNE_GONG
aktiv
ANTISCHUBRUCKELBAND
wert_01
T_MIN_OBJANZ
wert_01
T_MAX_DISTANZ
wert_01
SCHWELLE_VANZ
wert_01
SCHWELLE_BASEWERTE
wert_01
SCHWELLE_BESCHL_UNTEN
wert_01
SCHWELLE_AX_SOLL_BREMS
wert_02
SCHWELLE_AX_SOLL_ANTRIEB
wert_01
SCHWELLE_BESCHL_OBEN
wert_01
SCHWELLE_AX_REF
wert_01
BREMSUNTERSTUETZUNG_VSA
aktiv
BESCHLEUNIGUNG_MAX_HIGH
parasatz_01
BESCHLEUNIGUNG_MAX_LOW
parasatz_01
BESCHLEUNIGUNG_V_CHAR
parasatz_01
STRANGVERSTAERK_MANUELL
automatik
KONFIG_RLS_REGEN
aktiv
KONFIG_RLS_GESCHW
nicht_aktiv
FLC_SCHWELLWERT_SATZ
wert_01
WISCHEN_STUFE2
aktiv
WISCHERMOTOR_RSK
nicht_aktiv
KONFIG_RLS_RAENDELRAD
aktiv
EMPF_OHNE_RAENDELRAD
empfindlichkeitsstufe_3
TYP_RLS_OPTIK
aktiv
KONFIG_NACHL_REGEN
wert_01
DEF_FLC_SCHWELLWERT_SATZ
wert_01
FLC_SCHWELLWERT_SATZ_1
wert_01
V_HIGH_SPEED_WISCHEN
wert_01
FLC_SCHWELLWERT_SATZ_2
wert_02
FLC_SCHWELLWERT_SATZ_3
wert_03
VISCOLUEFTER
nicht_aktiv
KENNFELDKUEHLUNG
aktiv
GEBL_ANZEIGE_AUTO
nicht_aktiv
LDA_B_KLIMABEREITSCHAFT
nicht_aktiv
TRANSPORTSICHERUNG
nicht_aktiv
PTC_PWM
aktiv
DEF_U_FUSS_ZU_DEFAULT
nicht_aktiv
VA_KORRIGIEREN
nicht_aktiv
SCHICHTUNG_RESET
nicht_aktiv
DUAL
nicht_aktiv
ELEKTR_MOTORWASSERPUMPE
nicht_aktiv
GLEITENDE_VERDAMPFERTEMP
aktiv
ZUSATZHEIZLEISTUNG
aktiv
GEBL_BEI_OFF
nicht_aktiv
OFF_MEMORY_KEY_1
nicht_aktiv
OFF_MEMORY_KEY_2
nicht_aktiv
OFF_MEMORY_KEY_3
nicht_aktiv
OFF_MEMORY_KEY_4
nicht_aktiv
OFF_MEMORY_KEY_DEFAULT
nicht_aktiv
DEF_U_FUSS_KLAPPE_ZU_PROG
aktiv
BELUEFTUNGS_PROGRAMM
aktiv
TEMP_OFFSET
aktiv
GEBL_OFFSET
aktiv
BELUEFTUNG_DEFAULT
nicht_aktiv
GEBL_OFFSET_DEFAULT
nicht_aktiv
TEMP_OFFSET_DEFAULT
nicht_aktiv
DEF_U_FUSS_KLAPPE_ZU_KEY1
nicht_aktiv
BELUEFTUNG_KEY1
nicht_aktiv
GEBL_OFFSET_KEY1
nicht_aktiv
TEMP_OFFSET_KEY1
nicht_aktiv
DEF_U_FUSS_KLAPPE_ZU_KEY2
nicht_aktiv
BELUEFTUNG_KEY2
nicht_aktiv
GEBL_OFFSET_KEY2
nicht_aktiv
TEMP_OFFSET_KEY2
nicht_aktiv
DEF_U_FUSS_KLAPPE_ZU_KEY3
nicht_aktiv
BELUEFTUNG_KEY3
nicht_aktiv
GEBL_OFFSET_KEY3
nicht_aktiv
TEMP_OFFSET_KEY3
nicht_aktiv
DEF_U_FUSS_KLAPPE_ZU_KEY4
nicht_aktiv
BELUEFTUNG_KEY4
nicht_aktiv
GEBL_OFFSET_KEY4
nicht_aktiv
TEMP_OFFSET_KEY4
nicht_aktiv
DEF_U_FUSS_ZU_DEFAULT_KEY
nicht_aktiv
BELUEFTUNG_DEFAULT_KEY
nicht_aktiv
GEBL_OFFSET_DEFAULT_KEY
nicht_aktiv
TEMP_OFFSET_DEFAULT_KEY
nicht_aktiv
ABWAHL_AC
nicht_aktiv
LAUTSTAERKE
nicht_aktiv
TIMEOUT_DEAKT_IRNE
wert_10
DEF_QUIT_OPT_SCHAERF_KLAP
aktiv
SIRENENABSCHALTUNG
nicht_aktiv
DEF_QUIT_AKUST_SCHAERF
nicht_aktiv
QUIT_AKUST_SCHAERF
nicht_aktiv
ALARM_OPT_WARNBLINKER
aktiv
STILLER_ALARM
nicht_aktiv
nicht_aktiv
PARAMETER_IRS
wert_03
KOFFERRAUMUEBERWACHUNG
aktiv
NOTLAUFFUNKTION_HUPE
aktiv
HOTELSTELLUNG
nicht_aktiv
DISTRIBUTIONSMODUS
nicht_aktiv
VALUE_ANWENDUNG
wert_01
VALUE_NEIGUNGSGEBER
wert_01
MAX_DRIFT_X
wert_03
ERR_BANDW_1ALARM_X
wert_03
COUNT_RESET_LEV_1ALARM_X
wert_03
ERR_BANDW_2ALARM_X
wert_03
COUNT_RESET_LEV_2ALARM_X
wert_03
ALARM_LEVEL_X
wert_03
MAX_DRIFT_Y
wert_03
ERR_BANDW_1ALARM_Y
wert_03
COUNT_RESET_LEV_1ALARM_Y
wert_03
ERR_BANDW_2ALARM_Y
wert_03
COUNT_RESET_LEV_2ALARM_Y
wert_03
ALARM_LEVEL_Y
wert_03
CHECK_DRIFT_TIME
wert_03
NOISE_CORRECTION_TIME
wert_03
ARMING_TIME
wert_03
ARMING_TIME_BETW_ALARMS
wert_03
CONTROL_BYTE
ok
ALARM_TIME_EXT_SUPPLY
28_5s
ALARM_TIME_SELF_SUPPLY
26s
ALARM_PAUSE_TIME
14s
DUTY_CICLE_EXT_SUPPLY
100%
MIN_CHARGING_TEMP
wert_02
MAX_CHARGING_TEMP
wert_02
MIN_ALARM_TEMP
wert_02
MAX_ALARM_TEMP
wert_02
POWER_REDUCTION_TEMP
wert_02
POWER_REDUCTION_DUTY
50%
USA_MAX_SEMIPERIOD
249_6us
USA_MIN_SEMIPERIOD
182_4us
USA_SWEEP
2_5hz
ECE_SEMIPERIOD
208us
ECE_MODULATION
240ms
BUZZER_LOW_LEVEL
wert_03
BUZZER_HIGH_LEVEL
wert_03
BUZZER_SEMIPERIOD
208us
BUZZER_TIME
98ms
BACK_UP_BATTERY_DATA
primary_battery
BACK_UP_BATTERY_CAPACITY
wert_02
AKTIVZEIT_KAPSENSOR_BTH
wert_01
ANZ_RUNIN_BITS_BTH
wert_01
T_ZEIT_ZUG_NACH_DRUCK_FT
wert_01
AKTIVZEIT_KAPSENSOR_FT
wert_01
ANZ_RUNIN_BITS_FT
wert_01
AKTIVZEIT_KAPSENSOR_FTH
wert_01
ANZ_RUNIN_BITS_FTH
wert_01
wert_01
ANZ_RUNIN_BITS_BT
wert_01
MINZEIT_IOUT_ANSTEUER_FT
wert_01
T_ZEIT_ZUG_NACH_DRUCK_FTH
wert_01
MINZEIT_IOUT_ANSTEUER_FTH
wert_01
T_ZEIT_ZUG_NACH_DRUCK_BT
wert_01
MINZEIT_IOUT_ANSTEUER_BT
wert_01
T_ZEIT_ZUG_NACH_DRUCK_BTH
wert_01
MINZEIT_IOUT_ANSTEUER_BTH
wert_01
RETRIGGER_T_ZEIT_BTH
wert_01
Y_SILENT_TEL
nicht_aktiv
Y_STOP_IF_SHORTCIRCUIT
nicht_aktiv
RETRIGGER_T_ZEIT_FT
wert_01
RETRIGGER_T_ZEIT_FTH
wert_01
RETRIGGER_T_ZEIT_BT
wert_01
Y_BAUREIHE
e64
DATENSATZ_JAHR
wert_01
DATENSATZ_MONAT
wert_01
DATENSATZ_TAG
wert_01
OELSTAND_INVERTIEREN
wert_01
CODINDEX_AKTUELL_00
wert_01
CODINDEX_AKTUELL_01
wert_01
B_ENABLE_DIRECT_DRIVEMODE
wert_01
B_LANGZEITABGLEICH
wert_01
I_AUFSTARTVERHALTEN
wert_01
I_FESTUSCFG
wert_01
S_AY_MAX_MOD
wert_01
S_AYSCALE
e64_ll_basis_n62_ars
S_DEN_0_PD2T2
wert_01
S_HALB_TOTZ_BREITE
wert_01
S_DEN_1_PD2T2
wert_01
S_DEN_2_PD2T2
wert_01
S_KARDANGELENK
wert_01
S_LWDS_BL
S_NUM_0_PD2T2
wert_01
S_TBY
wert_01
S_NUM_1_PD2T2
wert_01
S_NUM_2_PD2T2
wert_01
S_TOTZNEU_PARX2
wert_01
S_TRDIFF_PT1
wert_01
S_TVSRPT1
wert_01
S_VX2RR_CCORR
wert_01
S_VXMIN
wert_01
S_VXMIN_AYDIVVX
wert_01
S_ZD
wert_01
S_ZM
wert_01
B_ENABLE_YRC
wert_01
B_ENABLE_RIGHT_HAND_DRIVE
S_DEGRESSIONSFAKTOR
S_DMEAYVA
S_DMEPUMPMOMENT
S_DUTY_MAX
S_ZH
S_KRR_FILTER
S_LENKVENTIL_LECKAGE
S_FZG_DYN
S_LWG_PUMP
S_MAX_ABFALLRATE
S_STRAP_TRANSMISSION
S_TFILTER_AY
S_TFILTER_LWDGC_DOT
S_TFILTER_LWDS_DOT
S_TFILTER_RR
S_V_DOT_PUMP_VSR
S_V_DOT_PUMP_BASIS
S_V_DOT_PUMP_MAX
S_XVALVE_2I_SERVO
S_ECO_PUMP_VOL_FLOW
S_TRACK
S_ZG_INV
S_ZG
S_ZTOTAL
S_CH
S_CV
S_IZ
S_LH
S_HINRUECKFILT_SW
S_LV
S_MASS
VARIANTEN_NUMMER
S_VCHMOD_MAX
S_VCHMOD_MIN
S_I_SF_DEH_VARIANTES
S_I_SF_MODEL_VARIANTES
S_I_SF_VX_VARIANTES
S_I_SF_DPSI_VARIANTES
S_I_SF_AY_VARIANTES
TIMEOUT_ID_UEBERW_SIM
wert_01
STROMVERTEILER_A1_BYTE_1
wert_01
STROMVERTEILER_A1_BYTE_2
wert_01
STROMVERT_A1_BYTE_3/0
sv_sk_ein_sleep
STROMVERT_A1_BYTE_3/6
skein_ein
STROMVERT_A1_BYTE_3/7
skaus_ein
STROMVERTEILER_A2_BYTE_1
wert_01
STROMVERTEILER_A2_BYTE_2
wert_01
STROMVERT_A2_BYTE_3/0
sv_sk_ein_sleep
STROMVERT_A2_BYTE_3/6
skein_ein
STROMVERT_A2_BYTE_3/7
skaus_ein
STROMVERTEILER_A3_BYTE_1
wert_01
STROMVERTEILER_A3_BYTE_2
wert_01
STROMVERT_A3_BYTE_3/0
sv_sk_ein_sleep
STROMVERT_A3_BYTE_3/6
skein_ein
STROMVERT_A3_BYTE_3/7
skaus_ein
STROMVERTEILER_A4_BYTE_1
wert_01
STROMVERTEILER_A4_BYTE_2
wert_01
STROMVERT_A4_BYTE_3/0
sv_sk_ein_sleep
STROMVERT_A4_BYTE_3/6
skein_ein
STROMVERT_A4_BYTE_3/7
skaus_ein
STROMVERTEILER_B1_BYTE_1
wert_01
STROMVERTEILER_B1_BYTE_2
wert_01
SG_RESET
aktiv
ECO_REGELZEIT
wert_01
PAO_SCHWELLWERT_KS_GND
wert_01
PAO_SCHWELLWERT_UNTR
wert_01
BEST_ANZAHL_MESSUNG
wert_01
WARTEZEIT_ZW_MESSUNG
wert_01
UNT_GRENZWERT_U_ASE
wert_01
OBE_GRENZWERT_U_ASE
wert_01
UNT_GRENZWERT_U5_SW
wert_01
OBE_GRENZWERT_U5_SW
wert_01
UNT_GRENZWERT_U60
wert_01
OBE_GRENZWERT_U60
wert_01
RUECKFALLEBENE_U_ASE
nicht_aktiv
RUECKFALLEBENE_U_ASE_S
nicht_aktiv
RUECKFALLEBENE_U_5_S
nicht_aktiv
UPF_LINKS_VORZEICHEN
normal
FEHLEREINTRAG_U_ASE
aktiv
FEHLEREINTRAG_U_ASE_S
aktiv
FEHLEREINTRAG_U_5_S
aktiv
FEHLEREINTRAG_U60
aktiv
UPF_GRENZWERT_FEHLER
wert_01
ENTLADEZEIT_ER
wert_01
UPF_RAUSCHBAND
wert_01
UPF_L_INTEGRALLAENGE_1
wert_01
UPF_L_INTEGRALLAENGE_2
wert_01
UPF_R_INTEGRALLAENGE_1
wert_01
UPF_R_INTEGRALLAENGE_2
wert_01
UPF_RECHTS_VORZEICHEN
normal
STROMVERT_B1_BYTE_3/6
skein_ein
STROMVERT_B1_BYTE_3/7
skaus_ein
STROMVERTEILER_B2_BYTE_1
wert_01
STROMVERTEILER_B2_BYTE_2
wert_01
STROMVERT_B2_BYTE_3/6
skein_ein
SCHRITTE_KENN_UMSCHAL
wert_01
STROMVERT_B2_BYTE_3/7
skaus_ein
STROMVERTEILER_B3_BYTE_1
wert_01
STROMVERTEILER_B3_BYTE_2
wert_01
STROMVERT_B3_BYTE_3/0
sv_sk_aus_sleep
STROMVERT_B3_BYTE_3/6
skein_ein
STROMVERT_B3_BYTE_3/7
skaus_ein
STROMVERTEILER_B4_BYTE_1
wert_01
STROMVERTEILER_B4_BYTE_2
wert_01
STROMVERT_B4_BYTE_3/0
sv_sk_aus_sleep
STROMVERTEILER_C1_BYTE_1
wert_01
STROMVERTEILER_C4_BYTE_1
wert_01
SVT_KP_FAKTOR
wert_01
STROMVERTEILER_C1_BYTE_2
wert_01
STROMVERT_C1_BYTE_3/0
sv_sk_aus_sleep
SVT_TN_FAKTOR
wert_01
STROMVERTEILER_C2_BYTE_1
wert_01
STROMVERTEILER_C2_BYTE_2
wert_01
SVT_REGELZEIT
wert_01
STROMVERTEILER_C3_BYTE_1
wert_01
STROMVERTEILER_C3_BYTE_2
wert_01
STROMVERT_C3_BYTE_3/0
sv_sk_aus_sleep
STROMVERTEILER_C4_BYTE_2
wert_01
STROMVERT_C4_BYTE_3/0
sv_sk_aus_sleep
STROMVERT_C2_BYTE_3/0
sv_sk_aus_sleep
STERNKOPPLER_XA_BYTE_1
wert_01
STERNKOPPLER_XA_BYTE_2
wert_01
STERNKOPPLER_XA_BYTE_3/0
sk_ein_sleep
STERNKOPPLER_XA_BYTE_3/6
skein_ein
STERNKOPPLER_XA_BYTE_3/7
skaus_ein
STERNKOPPLER_XB_BYTE_1
wert_01
STERNKOPPLER_XB_BYTE_2
wert_01
STERNKOPPLER_XB_BYTE_3/0
sk_ein_sleep
STERNKOPPLER_XB_BYTE_3/6
skein_ein
STERNKOPPLER_XB_BYTE_3/7
skaus_ein
STERNKOPPLER_XC_BYTE_1
wert_01
STERNKOPPLER_XC_BYTE_2
wert_01
STERNKOPPLER_XD_BYTE_3/6
skein_aus
PAO_SCHWELLWERT_KS_PLUS
wert_01
PAO_FEHLERGRENZE
wert_01
STERNKOPPLER_XD_BYTE_1
wert_01
STERNKOPPLER_XD_BYTE_2
wert_01
HARDWARE_CODE_AKTIV
aktiv
TIME_SLEEP_MODE
wert_02
SAT_TEST_ZYKL
wert_01
GRENZWERT_FZ_SK
wert_01
SVT_ECO_ENT_LEIT
wert_01
SVT_ECO_ENT_WID
wert_01
INDEXTAB_FC_SIM
wert_01
CHECKCTRLTAB_SIM
wert_01
PDC3_ERR_LIMIT_SIM
wert_01
ALGOPARAM_SIM_SAFING
wert_01
SVT_ECO_ENT_STR
wert_01
SVT_ECO_ENT_ZEIT
wert_01
STROMVERT_B4_BYTE_3/6
skein_ein
SVT_ECO_WIDERM
wert_01
SVT_MAX_WID
wert_01
STROMVERT_B4_BYTE_3/7
skaus_ein
STROMVERT_C1_BYTE_3/6
skein_ein
STROMVERT_C1_BYTE_3/7
skaus_ein
SVT_ECO_TOL_STROMPL
wert_01
SVT_MIN_WID
wert_01
STERNKOPPLER_XC_BYTE_3/6
skein_aus
STERNKOPPLER_XD_BYTE_3/0
sk_aus_sleep
STERNKOPPLER_XD_BYTE_3/7
skaus_aus
TIMEOUT_ID_UEBERW_SFZ
wert_01
ZK1_SFZ
nicht_bestueckt
SBK
aktiv
ZK1_MIN
wert_01
ZK1_MAX
wert_01
ZK2_MIN
wert_01
ZK2_MAX
wert_01
CHECKCTRLTAB_SFZ
wert_01
PDC3_ERR_LIMIT_SAT
wert_01
OFFSET_MAX_ZUL_X_SFZ
wert_01
RAUSCHWERT_X_SFZ
wert_01
ACL_MAX_VALUE_X_SFZ
wert_01
MIN_WERT_SELBSTST_X_SFZ
wert_01
MAX_WERT_SELBSTST_X_SFZ
wert_01
OFFSET_MAX_ZUL_Y_SFZ
wert_01
RAUSCHWERT_Y_SFZ
wert_01
ACL_MAX_VALUE_Y_SFZ
wert_01
MIN_WERT_SELBSTST_Y_SFZ
wert_01
MAX_WERT_SELBSTST_Y_SFZ
wert_01
SENSORWERT_X_INV_SFZ
nicht_invertiert
SENSORWERT_Y_INV_SFZ
nicht_invertiert
LAENGE_INTEGRAL_1_X_SFZ
wert_01
LAENGE_INTEGRAL_2_X_SFZ
wert_01
LAENGE_INTEGRAL_1_Y_SFZ
wert_01
LAENGE_INTEGRAL_2_Y_SFZ
wert_01
UEBERWACHUNG_U_ASE_MIN
wert_02
UEBERWACHUNG_U_ASE_MAX
wert_02
ZEITPARA_SPG_UEBERWACHUNG
wert_02
ALGOPARAM_SFZ_2
wert_01
ALGOPARAM_SFZ_3
wert_01
PROGRAMMPARAM_ALC_SG_1
wert_01
PROGRAMMPARAM_ALC_SG_2
wert_01
PROGRAMMPARAM_ALC_SG_3
wert_01
PROGRAMMPARAM_ALC_SG_4
wert_01
PROGRAMMPARAM_ALC_SG_5
wert_01
CAN_11H
nicht_aktiv
SCHALTER_R_GANG
nicht_aktiv
ABSTELLPOS_SMC
aktiv
ABSTELLPOS_CUSTOM
nicht_aktiv
ALC_AUSWERT_GRADIENT
aktiv
ALC_AUSWERT_PROP_ABWEICH
aktiv
ALC_EINSCHALTBEDINGUNG
wert_01
ALC_GRADIENT_SCHLECHTWEG
nicht_aktiv
ALC_KLS_ENABLE
aktiv
AUTO_LWR_ENABLE
aktiv
DYNAM_LWR_ENABLE
aktiv
KLASSIF_LENKM_ENA
aktiv
ALC_SCHW_GRAD_SCHLECHTWEG
wert_01
ALC_SCHWENK_LATCH
aktiv
ALC_SAETT_TIMER_SCHLECHTW
aktiv
ERR_LWR_L_IGNORIEREN
nicht_aktiv
ERR_LWR_R_IGNORIEREN
nicht_aktiv
ERR_SCHWENK_R_IGNORIEREN
nicht_aktiv
IK_BUS_TEILNEMER
nicht_aktiv
KLS_BEI_AL_AKTIV
nicht_aktiv
KEINE_L_R_SYNCHRONISATION
nicht_aktiv
KLASSIF_UEBERST_ENA
aktiv
OHNE_GIERRATE
nicht_aktiv
KLASSIF_DRIFT_ENA
aktiv
ERR_SCHWENK_L_IGNORIEREN
nicht_aktiv
LWR_ABSTELLPOS
wert_01
FUNKTION_TOEHKI
nicht_aktiv
FUNKTION_FBD_SCHLIESSEN_2
nicht_aktiv
WERT_SANFTEINLAUF_UNTEN
wert_03
REVERSIEREN
nicht_aktiv
KLAPPE_OEFFNEN
nicht_aktiv
KLAPPE_OEFFNEN_WINKEL
nicht_aktiv
KOMFORT_OEFFNEN_HKL
nicht_aktiv
KOMFORT_SCHLIESSEN
wert_01
PUMPE_AN_M_HKK
aktiv
SANFTAUSLAUF
wert_03
SANFTEINLAUF
nicht_aktiv
PWM_PUMPE
nicht_aktiv
WIEDERHOLSPERRE
nicht_aktiv
BLOCKIERERKENNUNG_AUF
nicht_aktiv
BLOCKIERERKENNUNG_ZU
nicht_aktiv
PDC_AKTIV_VOR_ZU
nicht_aktiv
PDC_AKTIV_BEI_AUF
nicht_aktiv
PDC_AKTIV_BEI_ZU
nicht_aktiv
REVERSIEREN_PDC
nicht_aktiv
SPANNUNGSREGELUNG_PUMPE
nicht_aktiv
TIMEOUT_TOEHK
aktiv
TIMEOUT_TOEHKK
nicht_aktiv
TIMEOUT_TOEHKI
nicht_aktiv
KLEMME_50
nicht_aktiv
UNTERSPANNUNG
nicht_aktiv
UNTERTEMPERATUR
nicht_aktiv
GESCHWINDIGKEITSSCHWELLE
nicht_aktiv
PROPVENTIL
nicht_aktiv
WINKELGEBER
nicht_aktiv
WERT_SANFTAUSLAUF_OBEN
wert_03
TOEHK_AKTIV_HIGH
nicht_aktiv
TOEHKK_AKTIV_HIGH
nicht_aktiv
TOEHK_DIREKT
nicht_aktiv
WERT_UNTERTEMPERATUR
wert_01
WERT_UNTERSPANNUNG
wert_03
WERT_GESCHWINDIGKEIT
wert_01
WERT_KLAPPENOEFFNUNG
wert_02
TIMEOUT_OEFFNEN
wert_01
TIMEOUT_SCHLIESSEN
wert_01
TIMEOUT_HKK_AUF
wert_01
TIMEOUT_HKK_ZU
wert_01
REVERSIERZEIT
wert_01
WINKELGEBER_1
wert_03
WINKELGEBER_2
wert_03
ANALYSE_WG_1
wert_03
ANALYSE_WG_2
wert_01
SEGMENT_2_3
wert_03
SEGMENT_3_4
wert_03
SEGMENT_4_5
wert_03
SEGMENT_5_6
wert_03
SEGMENT_6_7
wert_03
SEGMENT_7_8
wert_03
MAX_VENTIL_PWM
wert_01
PERIODENDAUER_V_PWM
wert_03
TEILUNG_SANFTANL_VENTIL
wert_03
ZEITSEG_PERIODE_AUF_2
wert_03
ZEITSEG_PERIODE_AUF_3
wert_03
ZEITSEG_PERIODE_AUF_4
wert_03
ZEITSEG_PERIODE_AUF_5
wert_03
ZEITSEG_PERIODE_AUF_6
wert_03
ZEITSEG_PERIODE_AUF_7
wert_03
ZEITSEG_PERIODE_AUF_8
wert_03
ZEITSEG_PERIODE_ZU_2
wert_03
ZEITSEG_PERIODE_ZU_3
wert_03
ZEITSEG_PERIODE_ZU_4
wert_03
ZEITSEG_PERIODE_ZU_5
wert_03
ZEITSEG_PERIODE_ZU_6
wert_03
ZEITSEG_PERIODE_ZU_7
wert_03
ZEITSEG_PERIODE_ZU_8
wert_03
PERIODENDAUER_P_PWM
wert_03
TEILUNG_SANFTAN_PUMPE
wert_03
BASISWERT_PWM_PUMPE
wert_03
TOEHKI_AKTIV_HIGH
nicht_aktiv
TIMEOUT_TASTE_3
wert_01
FEHLERSTROM_PUMPE_UNTEN
wert_03
FEHLERSTROM_PUMPE_OBEN
wert_03
ABSCHALTPUNKT_OBEN
nicht_aktiv
SCHNELL_ANFAHREN_OBEN
nicht_aktiv
BLOCKIERUNG_VERRZOEGERUNG
wert_03
BLOCKIERUNG_ZYKLUS
wert_03
KLAPPE_AUF_HOTEL
aktiv
KLAPPE_AUF_MECH_ENTR
nicht_aktiv
TEMP_AUSGLEICH_PWM_PUMPE
wert_03
PUMPE_AUS_O_HKK
nicht_aktiv
AUTO_CLOSE
wert_03
VENTILANSTEUERUNG
nicht_aktiv
BLOCKIERUNG_AUSLOESUNG
wert_03
TIMEOUT_ID_UEBERW_STVL
wert_01
TIMEOUT_ID_UEBERW_STVR
wert_01
ZK_2_STVL
nicht_bestueckt
ZK_MIN_SIDEBAG_VO_LI
wert_01
ZK_MAX_SIDEBAG_VO_LI
wert_01
ZK_2_MIN_STVL
wert_01
ZK_2_MAX_STVL
wert_01
RAUSCHWERT_STVL
wert_01
INDEXTAB_FC_STVL
wert_01
ALGOPARAM_STVL_1
wert_01
MOTOR_DELAY_TIME
wert_01
PFIE_ILUM_CHARACTERISTIC
wert_01
PANIKMODUS
aktiv
NACHLAUF_KLR_AUS
aktiv
ZK_2_STVR
nicht_bestueckt
PANIKMODUS_EKS
nicht_aktiv
UNTER_OBERGRENZE
wert_01
TUERAUF_STOP_NACHLAUF
nicht_aktiv
TUERZU_STOP_NACHLAUF
nicht_aktiv
TUERAUF_STOP_EKS
nicht_aktiv
TUERZU_STOP_EKS
nicht_aktiv
REVERSIERWEG_PANIK
wert_01
REVERSIERWEG_EKS
wert_01
KURZHUB
wert_01
LANGHUB
wert_01
NACHLAUF
wert_01
KURZHUBDELAY_ZU
wert_01
KURZHUBDELAY_AUF
wert_01
SOFTSTOP_POS
wert_01
HEATING
aktiv
DELAY_HEATING
nicht_aktiv
HEIZKORR
wert_01
SPEED_MAX_FOLD
wert_01
KERB_POSITION
wert_01
HOR_MIN_MAX_POS
wert_01
VER_MIN_MAX_POS
wert_01
MOTOR_DRIVE_TIME
wert_01
AMBIENTES_LICHT
wert_01
DIMM_FKT_LED_MAX
wert_01
TIGNORE
wert_01
TLOW
wert_01
IMAX_LOW_PHASE
wert_01
IMIN_LOW_PHASE
wert_01
IFAKTOR_LOW_PHASE
wert_01
IFAKTOR_HIGH_PHASE
wert_01
U_ASE_ZEITWERT
wert_01
U_ASE_RESERVE
wert_01
SZT_EQUAL_SB
aktiv
PANIC_E38
nicht_aktiv
U_OVER_MAX
wert_01
U_SPHEIZ
wert_01
U_SPLMP
wert_01
U_ZV
wert_01
ALGOPARAM_STVR_1
wert_01
LAUFZEITFAKTOREN
wert_01
ZK_MIN_SIDEBAG_VO_RE
wert_01
ZK_MAX_SIDEBAG_VO_RE
wert_01
RAUSCHWERT_STRE
wert_01
ZK_2_MIN_STRE
wert_01
ZK_2_MAX_STRE
wert_01
INDEXTAB_FC_STVR
wert_01
DIMMUNG_FKT_LED
aktiv
DIMM_FKT_LED_MIN
wert_01
FH_FAHRERTUER_TIPP_AUF
aktiv
MAUT_MIT_EKS
aktiv
MAN_MIT_EKS
aktiv
FH_BEIFAHRERTUER_TIPP_AUF
aktiv
FH_BEIFAHRERTUER_TIPP_ZU
aktiv
FH_FAHRERTUER_TIPP_ZU
aktiv
TIMEOUT_ID_UEBERW_SZL
wert_01
LHZ_POWERSAVEMOD_TAKT
wert_01
UEBERWACHUNG_U_LRE_MAX
wert_01
ZK_MIN_AIRBAG_FA_STUFE1_1
wert_01
ZK_MAX_AIRBAG_FA_STUFE1_1
wert_01
ZK_MIN_AIRBAG_FA_STUFE2_1
wert_01
ZK_MAX_AIRBAG_FA_STUFE2_1
wert_01
ABSTIMMPARA_LWVERIFIZ
wert_01
NORMIERUNG_LW
wert_01
AUFSETZ_MAX_RADDREHZV
wert_01
AUFSETZEN_MAX_GESCHW
wert_01
AUFSETZEN_MIN_GESCHW
wert_01
AUFSETZEN_KLASSSICHER
wert_01
LWS_DIFF_KL_ABSTAND
wert_01
WICHTUNG_FZG_GESCHW
wert_01
WICHTUNG_DIFFERENZ
wert_01
WICHTUNG_WINKELABH
wert_01
AUFSETZEN_EINSCHALTEN
aktiv
LWS_DIAGNOSE_SER
nicht_aktiv
LENKWINKEL_AUF_SI_BUS
wert_01
LW_GRADIENT
wert_01
ABSTIMMPARAM_BELEUCHTUNG
wert_01
LENKRADHEIZUNG_REGELPARA
wert_01
REGENSENSOR
aktiv
INDEXTAB_FC_SZL
wert_01
CHECKCTRLTAB_SZL
wert_01
ALGOPARAM_SZL_1
wert_01
BELEUCHT_RS_TAG
wert_01
BELEUCHT_RS_NACHT
wert_01
BELEUCHT_LHZ_TAG
wert_01
BELEUCHT_LHZ_NACHT
wert_01
SCHLEIFERABW_MAX
wert_01
REFERENZSPGSGRENZE
wert_01
LHZ_POWERSAVEMOD_PER
wert_01
MFL_TASTEN
wert_01
UEBERWACHUNG_U_LRE_MIN
wert_01
EHC_KENNFELD
e61_para_000
EINSTIEGSHILFE_HOEHE
aktiv
TYP_SITVERSTELLSCHALTER
sitze_elektrisch
SCS_OR_SVS
scs
DSP_ACOUSTIC_PROFILE
wert_01
PER_WAKEUP-STEP1_DURATION
wert_01
PER_WAKEUP-STEP1_PERIOD
wert_01
NAD_EQUIPPED
aktiv
TWO_HANDSETS
wert_02
PER_WAKEUP-STEP2_DURATION
wert_01
PER_WAKEUP-STEP2_PERIOD
wert_01
PER_WAKEUP-STEP3_DURATION
wert_01
PER_WAKEUP-STEP3_PERIOD
wert_01
PER_WAKEUP-STEP4_DURATION
wert_01
PER_WAKEUP-STEP4_PERIOD
wert_01
PER_WAKEUP-EMERG_DURATION
wert_01
PER_WAKEUP-EMERG_PERIOD
wert_01
DRIVE_WHEELS
rear_wheel
PER_WAKEUP-AMPS_SNOOPING
wert_01
DELAY_PWR_DOWN_INIT_DUR
wert_01
BACKUP_BATTERY
nicht_aktiv
BACKUP_BATTERY_ENABLED
nicht_aktiv
TWO_MICROPHONES
wert_01
SIM_IN_TELEMATIK_READER
nicht_aktiv
TELEMATIK_SIM_ENABLED
nicht_aktiv
BORDNETZ
e6x_bordnetz
MOST_ASYNC_OR_CTRL_CH_JAP
most_async_channel
TWO_MICROPHONES_JAPAN
wert_01
VEHICLE_MANUFACTURER
wert_01
AUT_SITZVERSTELLUNG
nicht_aktiv
STVLBV_EA_GURT_ZU_FAS
aktiv
MAX_PWM_PH_1_KI_FAS
wert_03
MOT_KONFIG_SLV
aktiv
MOT_KONFIG_SHV
aktiv
MOT_KONFIG_LNV
aktiv
MOT_KONFIG_SNV_FAS
aktiv
MOT_KONFIG_KHV
aktiv
AUTOML_KHV_KENNF_FAS
nicht_aktiv
KHV_WEG_VERZOEGERUNG_FAS
wert_01
STVLBV_EA_HILFE_FAS
nicht_aktiv
STVLBV_EA_SBE_ON_FAS
nicht_aktiv
STVLBV_EA_KL15_OFF_FAS
nicht_aktiv
STVLBV_EA_TUER_AUF_FAS
aktiv
STVLBV_EA_GURT_AUF_FAS
aktiv
STVLBV_EA_KL15_ON_FAS
nicht_aktiv
STVLBV_EA_TUER_ZU_FAS
aktiv
ZEIT_ST3_NACH_ST2
wert_10
NACHLAUFZEIT_HZ_KL_AS_FAS
wert_15
DEF_AUT_SITZVERSTELLUNG
nicht_aktiv
MAX_PWM_PH_1_LE_FAS
wert_03
ANST_SCHNELLH_PH_3_LE_FAS
wert_03
ANST_SCHNELLH_PH_3_KI_FAS
wert_03
MAX_PWM_RESTH_STEUER_FAS
max_pwm_resth_steuer_e65
MIN_T_SCHNELLH_1MIN_FAS
mintemp_schnellh_1min_e65
MIN_T_RESTH_1MIN_FAS
min_temp_resth_1min_e65
MOT_KONFIG_SNV_BFS
aktiv
AUTOML_KHV_KENNF_BFS
nicht_aktiv
KHV_WEG_VERZOEGERUNG_BFS
wert_01
STVLBV_EA_HILFE_BFS
nicht_aktiv
STVLBV_EA_SBE_ON_BFS
nicht_aktiv
STVLBV_EA_KL15_OFF_BFS
nicht_aktiv
STVLBV_EA_TUER_AUF_BFS
aktiv
STVLBV_EA_GURT_AUF_BFS
aktiv
STVLBV_EA_KL15_ON_BFS
nicht_aktiv
STVLBV_EA_TUER_ZU_BFS
aktiv
STVLBV_EA_GURT_ZU_BFS
aktiv
MIN_T_RESTH_1MIN_BFS
NACHLAUFZEIT_HZ_KL_AS_BFS
wert_15
ZIELTEMP_STUFE_1_KI_BFS
wert_03
ZIELTEMP_STUFE_2_KI_BFS
wert_03
ZIELTEMP_STUFE_3_KI_BFS
wert_03
ABST_ENDT_VOR_PH_2_KI_BFS
wert_03
MAX_ZEIT_PH_1_KI_BFS
wert_03
MAX_PWM_PH_1_KI_BFS
wert_03
ANST_SCHNELLH_PH_3_KI_BFS
wert_03
ZIELTEMP_STUFE_1_LE_BFS
wert_03
ZIELTEMP_STUFE_2_LE_BFS
wert_03
ZIELTEMP_STUFE_3_LE_BFS
wert_03
ABST_ENDT_VOR_PH_2_LE_BFS
wert_03
MAX_ZEIT_PH_1_LE_BFS
wert_03
ANST_SCHNELLH_PH_3_LE_BFS
wert_03
MAX_PWM_SCHNELL_REGEL_BFS
wert_03
MAX_PWM_RESTH_STEUER_BFS
MIN_T_SCHNELLH_1MIN_BFS
ZIELTEMP_STUFE_1_KI_FAS
wert_03
ZIELTEMP_STUFE_2_KI_FAS
wert_03
ZIELTEMP_STUFE_3_KI_FAS
wert_03
ABST_ENDT_VOR_PH_2_KI_FAS
wert_03
MAX_ZEIT_PH_1_KI_FAS
wert_03
MAX_PWM_SCHNELL_REGEL_FAS
wert_03
ZIELTEMP_STUFE_1_LE_FAS
wert_03
ZIELTEMP_STUFE_2_LE_FAS
wert_03
ZIELTEMP_STUFE_3_LE_FAS
wert_03
ABST_ENDT_VOR_PH_2_LE_FAS
wert_03
MAX_ZEIT_PH_1_LE_FAS
wert_03
SA_KONFIG_HZTYP
wert_02
DWS_TRWAK
e64
DWS_THWAK
e64
DWS_WKCNT
e64
DWS_WKIGON
e64
DWS_TRSLW
e64
DWS_THSLW
e64
DWS_TRDEC
e64
DWS_THDEC
e64
DWS_TRFLT
e64
DWS_THFLT
e64
DWS_TRBNG
e64
DWS_TDBNG
e64
DWS_THBNG
e64
DWS_THIDT
e64
DWS_AKASP
e64
DWS_AKRJT
e64
DWS_THUSP
e64
DWS_TRNRN
e64
DWS_THRPR
e64
DWS_THACCLN
e64
DWS_THACCLT
e64
DWS_THVEL
e64
DWS_STDRVB
e64
DWS_RVB
e64
DWS_COR1
e64
DWS_COR2
e64
DWS_FACR
e64
DWS_DLRF
e64
DWS_DLRR
e64
DWS_TWDF
e64
DWS_TWDR
e64
DWS_GULA
e64
DWS_GULB
e64
DWS_DRVSW
e64
DWS_WTCOEFF_1
e64
DWS_WTCOEFF_2
e64
DWS_DYNLR
e64
DWS_TEWP
e64
DWS_TEWM
e64
DWS_SAST
e64
DWS_SART
e64
DWS_SATF
e64
DWS_SASTD
e64
DWS_LTACC
e64
DWS_LTACCF
e64
DWS_LTSTD
e64
DWS_YAWR
e64
DWS_YRF
e64
DWS_YRSTD
e64
DWS_BRAKT
e64
DWS_IDWE
e64
FZG_ID
wert_01
SHD_BRAKE_OFFSET
wert_01
SHD_TRACKLIMITMAXOUTSIDE
wert_01
PANIC_CLOSE
aktiv_1p
KLEMME_15_NOTWENDIG
nicht_aktiv
KOMFORT_BEDIENUNG
aktiv
PANIC_CLOSE_TILT
aktiv_1p
SCHIEBEHEBEDACH_TIPP_HEB
aktiv
SCHIEBEHEBEDACH_TIPP_SENK
aktiv
SCHIEBEHEBEDACH_TIPP_AUF
aktiv
SCHIEBEHEBEDACH_TIPP_ZU
aktiv
SICHERHEITS_FZG
nicht_aktiv
KOMFORTPOSITION
nicht_aktiv
HINTER_KOMFORT_POS
nicht_aktiv
AUTOCLOSE
nicht_aktiv
LED_MIN
wert_01
LED_MAX
wert_01
LED_BAT_NORM
wert_01
POWER_ERR_LEN
wert_01
LOW_BAT_OFF
wert_01
LOW_BAT_ON
wert_01
LOAD_DUMP_ON
wert_01
LOAD_DUMP_OFF
wert_01
MEAS_VBAT_LOW
wert_01
MEAS_AMBIENT_TEMP_LOW
wert_01
MEAS_AMBIENT_TEMP_HIGH
wert_01
KOMFORT_OEFFNEN
wert_01
PREPANIC_START_TIME
wert_01
PANICWAITTIME
wert_01
NO_RAIN_INTENSITY
wert_01
RAIN_CLOSE_INTENSITY
wert_01
CHECK_IGNITIONK
aktiv
CHECK_IGNITIONC
aktiv
CHECK_IGNITIONA
nicht_aktiv
TEMPSENSOR_ALLOWED
aktiv
SIEMENS_RES_3001_16_4
nicht_aktiv
PARAM0
wert_01
PARAM1
wert_01
PARAM2
wert_01
PARAM3
wert_01
PARAM4
wert_01
PARAM5
wert_01
PARAM6
wert_01
PARAM7
wert_01
PARAM8
wert_01
PARAM9
wert_01
PARAM10
wert_01
PARAM11
wert_01
PARAM12
wert_01
PARAM13
wert_01
PARAM14
wert_01
PARAM15
wert_01
SIEMENS_RES_3007_2
wert_01
ANTI_WUMMER
nicht_aktiv
SHD_MAXDVDT
wert_01
WASSERSTOFF_FZG
nicht_aktiv
SIEMENS_RES_300A_3
wert_01
SIEMENS_RES_3008_6
wert_01
SIEMENS_RES_3008_7
wert_01
SHD_POS_SEAL
wert_01
SHD_POSSEAL2
wert_01
SHD_CAR_SPEED_THRESH
wert_01
PANIC_FREIGABE_KL15
nicht_aktiv
SIEMENS_RES_300A_4
wert_01
SIEMENS_RES_300A_6
wert_01
SIEMENS_RES_300A_7
wert_01
SIEMENS_RES_300A_16
wert_01
SIEMENS_RES_300A_20
wert_01
SIEMENS_RES_300A_22
wert_01
SIEMENS_RES_300A_23
wert_01
SIEMENS_RES_300A_24
wert_01
SHD_BRAKE_MUL
wert_01
SHD_TEMP_COIL_START
wert_01
SHD_TRACKLIMITMINOUTSIDE
wert_01
SHD_POSITION_CLOSED
wert_01
SHD_LIMPHOMEALLOWED
aktiv
SIEMENS_RES_300A_12
wert_01
SHD_QCASE
wert_01
SHD_LIMPHOME2DIR
nicht_aktiv
KOMFORT_POS_AUF
nicht_aktiv
SHD_POLEPAIRS
wert_01
SHD_OPPDIR_HALL
nicht_aktiv
SHD_OPPDIR_VMOT
aktiv
SHD_OPPDIR_DRIVER
aktiv
AUTOOPEN
nicht_aktiv
SHD_TMON_ALLOWED
aktiv
SHD_RRD_ALLOWED
aktiv
HIMMEL_AUTO_ZU
nicht_aktiv
SOS_OPPDIR_HALL
nicht_aktiv
SOS_ACTU_ALLOWED
nicht_aktiv
SOS_CLOUD_ALLOWED
nicht_aktiv
E9X_FZG
nicht_aktiv
VBATTOPLIMIT
wert_01
KOMFORT_HEBEN
wert_01
NOTLAUF_IMMER
nicht_aktiv
TEMPTMONUSESENSOR
aktiv
TEMPCFLUSESENSOR
aktiv
SHD_MINDIFFFORACTU
wert_01
SOS_EXOPENBEGIN
wert_01
SOS_FORCETHRESHEXOPEN
wert_01
SOS_EXOPENEND
wert_01
SHD_TEMPIDLE
wert_01
SHD_REVERSINGDELAYTIME
wert_01
SIEMENS_RES_3008_22
wert_01
SIEMENS_RES_3008_23
wert_01
SIEMENS_RES_3008_26
wert_01
SIEMENS_RES_3008_27
wert_01
SHD_SKB_OHNE_KL_SCH
nicht_aktiv
SHD_PRERUNLEARN
wert_01
SHD_POSTRUNLEARN
wert_01
SHD_PRERUNACTU
wert_01
SHD_POSTRUNACTU
wert_01
SHD_PRERUNFROMTILT
wert_01
SHD_OPPDIRVMOTLIMIT
wert_01
SHD_TEMPTHRESH1
wert_01
SHD_TEMPTHRESH2
wert_01
SHD_MULVDIFFHIGHLIMIT
wert_01
SHD_MULVDIFFLOWLIMIT
wert_01
SOS_LIMPHOME2DIR
nicht_aktiv
SOS_SKB_OHNE_KL_OE
nicht_aktiv
SOS_SKB_OHNE_KL_SCH
nicht_aktiv
SHD_BOOTINGTIME
wert_01
SHD_STARTUPTIME
wert_01
SHD_TURNTIME
wert_01
SHD_NORMINGBLOCKTIME
wert_01
SHD_WRITEPOSTIME
wert_01
SHD_CLEARPOSTIME
wert_01
SHD_DRIVERILLEGALONTIME
wert_01
SHD_DRIVERBADTIME
wert_01
SHD_MOTORSHORTTIME
wert_01
SHD_ERRMECHCOUNT
wert_01
SHD_OPPDIRCOUNT
wert_01
SHD_FORCEOFFSTAROUT
wert_01
SIEMENS_RES_3010_7
wert_01
SIEMENS_RES_3010_14
wert_01
SIEMENS_RES_3010_15
wert_01
SIEMENS_RES_3010_17
wert_01
SIEMENS_RES_3010_19
wert_01
SIEMENS_RES_3010_20
wert_01
SIEMENS_RES_3010_21
wert_01
SIEMENS_RES_3010_22
wert_01
SIEMENS_RES_3010_24
wert_01
SIEMENS_RES_3010_26
wert_01
SIEMENS_RES_3010_27
wert_01
SIEMENS_RES_3010_28
wert_01
SIEMENS_RES_3011_0
wert_01
SIEMENS_RES_3011_1
wert_01
SIEMENS_RES_3011_3
wert_01
SIEMENS_RES_3011_6
wert_01
SIEMENS_RES_3011_7
wert_01
SIEMENS_RES_3011_8
wert_01
SIEMENS_RES_3011_10
wert_01
SIEMENS_RES_3011_13
wert_01
SIEMENS_RES_3011_14
wert_01
SIEMENS_RES_3011_15
wert_01
SIEMENS_RES_3011_17
wert_01
SIEMENS_RES_3011_20
wert_01
SIEMENS_RES_3011_21
wert_01
SIEMENS_RES_3011_22
wert_01
SIEMENS_RES_3011_24
wert_01
SIEMENS_RES_3011_27
wert_01
SIEMENS_RES_3011_28
wert_01
SOS_TRACKLIMITEXOPEN
wert_01
HIMMEL_AUTO_AUF
nicht_aktiv
E9X_HIMMEL
nicht_aktiv
TASTE_UEBER_CAN
nicht_aktiv
KOMFORT_POS_ZU
nicht_aktiv
T_SCHOTT_ZU_HS
wert_01
VSCHOTT_AUF
wert_01
VSCHOTT_ZU
wert_01
TSCHOTT_AUF
wert_01
T_DOPPELKLICK
wert_01
DELTA_SOS_SHD
wert_01
CAS_OPEN
wert_01
T_PANIC1
wert_01
T_PANIC2
wert_01
HS_SCHOTT_ZU
wert_01
CAS_CLOSE
wert_01
CAS_CLOSE_TILT
wert_01
T_SCHOTT_ZU
wert_01
HECK_NICHT_ENTSICHERN
nicht_aktiv
KEINE_WRS_IM_STAND
nicht_aktiv
ZEIT_DEKR_N_WDHSPERRE_ER
wert_01
WIEDERHOLSPERRE_ER
wert_01
WISCHER_RUECKSCHALT_S2_1
wert_01
ZEIT_DEKR_N_WDHSP_HKKL
wert_08
WDHSPERRE_HECKKLAPPE
wert_01
MIN/MAX_ANSTRG_BELEUCHT
wert_01
SCHEINW_REINIGUNGS_AUTOM
aktiv
ZEIT_FRONTWASCHEN_WASCHEN
aktiv
KEINE_IB_EIN_ER_SCHLOSS
nicht_aktiv
INTERVALLZEIT_STAND
wert_03
KEINE_IB_EIN_NACH_KLR_AUS
nicht_aktiv
OHNE_SOFT_ON_OFF
aktiv
FH_EMERGENCY_TA
wert_01
VERBRAUCHERABSCHALT_AUS
nicht_aktiv
IB_AN_BEI_MEHRFACH_VR
aktiv
FH_EMERGENCY_TZF
wert_01
FH_EKS_LOW
high
ABSCHALTKRITERIEN_ECE
aktiv
ABSCHALTKRITERIEN_US
nicht_aktiv
BLOCK_ERKENNUNG_FRWISCHER
wert_02
KEINE_IB_EIN_FBD_AUF
nicht_aktiv
ANZ_EIN_N_BLOCK_FRWISCHER
wert_01
SPERRZ_N_BLOCK_FRWISCHER
wert_01
VERZ_FRWISCHER_N_WASCHANF
wert_01
ZEIT_WASCH_M/O_FRWISCHER
wert_02
ENTPRELLZEIT_FRWISCHER
wert_06
ANZ_NACHWISCH_FRSCH_WASCH
wert_02
IL_CRASH
aktiv
HECKWISCHER_ENTPRELLZEIT
wert_01
FAHRZEUG_TYP
wert_01
BUSSYSTEM
wert_01
KEIN_NETWORK
nicht_aktiv
KEINE_ANFRAGE_SCHEIBEN
nicht_aktiv
KEIN_SENDEN_STATUS
nicht_aktiv
DIAG_OUTPUTS
nicht_aktiv
OHNE_GESCHWINDIGKEIT
nicht_aktiv
OHNE_TEMPERATUR
nicht_aktiv
OHNE_SEITENSCHEIBEN
nicht_aktiv
OHNE_HECKKLAPPE
nicht_aktiv
OHNE_UEBERSPANNUNG
nicht_aktiv
OHNE_UNTERSPANNUNG
nicht_aktiv
OHNE_KLEMME_R
nicht_aktiv
LOGIK_VSW12
nicht_aktiv
LOGIK_VSW41
nicht_aktiv
LOGIK_VSW42
nicht_aktiv
LOGIK_VSW71
nicht_aktiv
LOGIK_VSW72
nicht_aktiv
ERROR_VSW12
nicht_aktiv
ERROR_VSW41
nicht_aktiv
ERROR_VSW42
nicht_aktiv
ERROR_VSW71
nicht_aktiv
ERROR_VSW72
nicht_aktiv
ERROR_HS
nicht_aktiv
ERROR_SB
nicht_aktiv
ERROR_VOEFF
nicht_aktiv
ERROR_VSCHL
nicht_aktiv
ERROR_SWBUNT
nicht_aktiv
ERROR_V1
nicht_aktiv
ERROR_V2
nicht_aktiv
ERROR_V3
nicht_aktiv
ERROR_MAS_V4
nicht_aktiv
ERROR_MAK_PUMPE
nicht_aktiv
ERROR_WINDLAUF
nicht_aktiv
NOTLAUF
nicht_aktiv
LED2_ROT
nicht_aktiv
RICHTUNG_WLM
nicht_aktiv
LED_HARDWARE
nicht_aktiv
SCHEIBE_AB_OHNE_HALL
nicht_aktiv
SCHEIBE_AUF_MIT_TIMEOUT
aktiv
SCHEIBE_AUF_POSITION
aktiv
OHNE_KOMFORT_OEFF
nicht_aktiv
OHNE_KOMFORT_SCHL
nicht_aktiv
SEGMENTGRENZEN_HS
wert_01
SEGMENTGRENZEN_SB
wert_01
DWG_KURZ_MASSE
wert_01
DWG_KURZ_UBATT
wert_01
SEGMENTGRENZEN_HALLS
wert_01
POS_SCHEIBE_OBEN
wert_01
GESCHWINDIGKEIT
wert_01
HALTEZEIT
wert_01
ZEIT_SLEEP
wert_01
HYSTERESE_KL30
wert_01
SCHWELLE_KL15
wert_01
PUMPE_PREALARM
wert_01
PUMPE_ALARM
wert_01
ANZ_SCHEIBEN_AB
wert_01
ZEIT_SCHEIBEN_AUF
wert_01
MIN_TEMPERATUR
wert_01
MIN_UNTERSPANNUNG
wert_01
BATT_V_NORM
wert_02
BATT_OFFSET_MAX
wert_02
BATT_V_SEND
wert_02
BATT_V_FIRE
wert_02
TIMEOUT_ID_UEBERW_SBSL
wert_01
ZK1_ZF_SBSL
vom_ss_nicht_beeinflusst
ALGOPARAM_FRONT_2_SBSL
wert_07
ZK2_ZF_SBSL
ZK1_MIN_SBSL
wert_01
ALGOPARAM_FRONT_3_SBSL
wert_07
ZK1_MAX_SBSL
wert_01
ZK2_MIN_SBSL
wert_01
ALGOPARAM_FRONT_4_SBSL
wert_07
ZK3_GURTSTR_FA
aktiv
ZK3_ZF_SBSL
ALGOPARAM_FRONT_5_SBSL
wert_07
ZK4_ZF_SBSL
ZK3_MIN_SBSL
wert_01
ALGOPARAM_FRONT_6_SBSL
wert_07
ZK4_MIN_SBSL
wert_01
ZK4_MAX_SBSL
wert_01
ZK2_MAX_SBSL
wert_01
ZK5_ZF_SBSL
ZK6_ZF_SBSL
ZK3_MAX_SBSL
wert_01
ZK5_MIN_SBSL
wert_01
ZK5_MAX_SBSL
wert_01
ZK6_MIN_SBSL
wert_01
ZK6_MAX_SBSL
wert_01
GURTSCHLOSS_LI
aktiv
HALLSCH_EIN_GURT_LI
hall_ein_gurt_an
STROMGR_KS_HSCH_ZU_LI
wert_01
STROMG_UNP_HSCH_ZU_LI
wert_01
STROMGR_UNP_HSCH_AUF_LI
wert_01
STROMGR_AUF_HSCH_UB_LI
wert_01
KINDERSI_SBEX_LINKS
nicht_aktiv
SBEY_HINTEN_LINKS
nicht_aktiv
SBE1_SBSL
nicht_aktiv
OC3_SBSL
nicht_aktiv
INDEXTAB_FC_SBSL
wert_01
CHECKCTRLTAB_SBSL
wert_01
PDC3_ERR_LIMIT_SAT_SBSL
wert_01
OFFSET_MAX_ZUL_X_SBSL
wert_01
RAUSCHWERT_X_SBSL
wert_01
ACL_MAX_VALUE_X_SBSL
wert_01
MIN_WERT_SELBSTST_X_SBSL
wert_01
MAX_WERT_SELBSTST_X_SBSL
wert_01
OFFSET_MAX_ZUL_Y_SBSL
wert_01
RAUSCHWERT_Y_SBSL
wert_01
ACL_MAX_VALUE_Y_SBSL
wert_01
MIN_WERT_SELBSTST_Y_SBSL
wert_01
MAX_WERT_SELBSTST_Y_SBSL
wert_01
LAENGE_INTEGRAL_1_X_SBSL
wert_01
BF_AIRBAG_SBSL
nicht_bfa
LAENGE_INTEGRAL_2_X_SBSL
wert_01
LAENGE_INTEGRAL_1_Y_SBSL
wert_01
LAENGE_INTEGRAL_2_Y_SBSL
wert_01
ALGOPARAM_FRONT_1_SBSL
wert_07
ALGOPARAM_HECK_1_SBSL
wert_07
ALGOPARAM_SEITE_L_1_SBSL
wert_07
ALGOPARAM_SEITE_L_2_SBSL
wert_07
ALGOPARAM_SEITE_R_1_SBSL
wert_07
ALGOPARAM_SEITE_R_2_SBSL
wert_07
ALGOPARAM_UPFRONT_1_SBSL
wert_07
ALGOPARAM_UPFRONT_2_SBSL
wert_07
ALGOPARAM_UPFRONT_3_SBSL
wert_07
ALGOPARAM_UPFRONT_4_SBSL
wert_07
ID_UEBERWACHUNG
wert_01
TIMEOUT_ID_UEBERW_SBSR
wert_01
ZK3_GURTSTR_BF
aktiv
ZK3_ZF_SBSR
ZK1_MIN_SBSR
wert_01
ZK5_ZF_SBSR
ZK6_ZF_SBSR
ZK1_MAX_SBSR
wert_01
ZK2_MIN_SBSR
wert_01
ZK2_MAX_SBSR
wert_01
ZK4_ZF_SBSR
ZK3_MIN_SBSR
wert_01
ZK3_MAX_SBSR
wert_01
ZK4_MIN_SBSR
wert_01
ZK4_MAX_SBSR
wert_01
INDEXTAB_FC_SBSR
wert_01
ZK5_MIN_SBSR
wert_01
ZK5_MAX_SBSR
wert_01
ZK6_MIN_SBSR
wert_01
ZK6_MAX_SBSR
wert_01
GURTSCHLOSS_RE
aktiv
HALLSCH_EIN_GURT_RE
hall_ein_gurt_an
STROMGR_KS_HSCH_ZU_RE
wert_01
STROMG_UNP_HSCH_ZU_RE
wert_01
STROMGR_UNP_HSCH_AUF_RE
wert_01
STROMGR_AUF_HSCH_UB_RE
wert_01
KINDERSI_SBEX_RECHTS
nicht_aktiv
SBEY_HINTEN_RECHTS
nicht_aktiv
CHECKCTRLTAB_SBSR
wert_01
PDC3_ERR_LIMIT_SAT_SBSR
wert_01
OFFSET_MAX_ZUL_X_SBSR
wert_01
RAUSCHWERT_X_SBSR
wert_01
ACL_MAX_VALUE_X_SBSR
wert_01
MIN_WERT_SELBSTST_X_SBSR
wert_01
MAX_WERT_SELBSTST_X_SBSR
wert_01
OFFSET_MAX_ZUL_Y_SBSR
wert_01
RAUSCHWERT_Y_SBSR
wert_01
ACL_MAX_VALUE_Y_SBSR
wert_01
MIN_WERT_SELBSTST_Y_SBSR
wert_01
MAX_WERT_SELBSTST_Y_SBSR
wert_01
SENSORWERT_X_INV_SBSR
nicht_invertiert
LAENGE_INTEGRAL_1_X_SBSR
wert_01
LAENGE_INTEGRAL_2_X_SBSR
wert_01
LAENGE_INTEGRAL_1_Y_SBSR
wert_01
LAENGE_INTEGRAL_2_Y_SBSR
wert_01
ALGOPARAM_FRONT_1_SBSR
wert_07
ALGOPARAM_HECK_1_SBSR
wert_07
ALGOPARAM_FRONT_2_SBSR
wert_07
ALGOPARAM_FRONT_3_SBSR
wert_07
ALGOPARAM_FRONT_4_SBSR
wert_07
ALGOPARAM_FRONT_5_SBSR
wert_07
ALGOPARAM_FRONT_6_SBSR
wert_07
ALGOPARAM_SEITE_L_1_SBSR
wert_07
ALGOPARAM_SEITE_R_1_SBSR
wert_07
ALGOPARAM_SEITE_R_2_SBSR
wert_07
ALGOPARAM_UPFRONT_1_SBSR
wert_07
ALGOPARAM_UPFRONT_2_SBSR
wert_07
ALGOPARAM_UPFRONT_3_SBSR
wert_07
ALGOPARAM_UPFRONT_4_SBSR
wert_07
ALGOPARAM_SEITE_L_2_SBSR
wert_07
BF_AIRBAG_SBSR
bfa
SHD_ACTU_ALLOWED
nicht_aktiv
SIEMENS_RES_3002_27
wert_04
SET_CODE_0
wert_05
SET_CODE_1
wert_05
SET_CODE_2
wert_05
SET_CODE_3
wert_05
SET_CODE_4
wert_05
SET_CODE_6
wert_05
SET_CODE_8
wert_05
SET_CODE_A
wert_05
SET_CODE_C
wert_05
SET_CODE_E
wert_05
SET_CODE_10
wert_05
SET_CODE_12
wert_05
FZG_BAUREIHE
glashubdach
DACHTYPE
glashubdach
BEDIENKONZEPT
glashubdach
SHD_RF_LENGTH
wert_03
SHD_POSITION_NORMED
wert_03
SHD_POS5
wert_04
SHD_POS6
wert_04
SOS_POSITION_NORMED
wert_03
SOS_POSITION_TILTED
wert_03
SOS_POS0
wert_04
SOS_POS1
wert_04
SOS_POS2
wert_04
SOS_POS3
wert_04
SOS_POS4
wert_04
SOS_POS5
wert_04
SOS_POS6
wert_04
SHD_TRACK_LIMIT_MAX
wert_03
SOS_POS7
wert_04
SOS_POS8
wert_04
SOS_POS9
wert_04
SOS_POSITION_OPEN
wert_04
SOS_QUARTER_TURN
wert_03
SET_CODE_5
wert_05
SHD_POSITION_100MM
wert_03
SHD_TRACKLIMITMIN
wert_03
SHD_POSPANICSREV
wert_03
SHD_POSITION_5MM_TILT
wert_03
SHD_POSITION_0MM_TILT
wert_01
SHD_LENGTH_NO_STOP
wert_03
SHD_LENGTH_NO_STOP_TILT
wert_03
SHD_RF_DISTANCE
wert_03
SET_CODE_7
wert_05
SOS_POSITION_100MM
wert_03
SOS_POSITION_0MM_TILT
wert_03
SOS_POSPANICSREV
wert_03
SOS_POSITION_0MM
wert_03
SOS_POSITION_5MM_TILT
wert_03
SIEMENS_RES_3008_18
wert_03
SOS_LENGTH_NO_STOP
wert_03
SOS_LENGTH_NO_STOP_TILT
wert_03
SOS_RF_DISTANCE
wert_03
SOS_RF_LENGTH
wert_03
SOS_RF_LENGTH_TILT
wert_03
SIEMENS_RES_3009_17
wert_03
SIEMENS_RES_3008_10
wert_03
SIEMENS_RES_3009_8
wert_03
SIEMENS_RES_3009_20
wert_03
SOS_MAXDVDT
wert_03
SOS_TRACK_LIMIT_MAX
wert_03
SIEMENS_RES_300D_20
wert_03
SOS_TRACKLIMITMIN
wert_03
SHD_RF_DISTANCE_TILT
wert_03
SIEMENS_RES_3009_10
wert_03
SIEMENS_RES_3009_15
wert_03
SIEMENS_RES_3009_16
wert_03
SIEMENS_RES_3009_18
wert_03
SIEMENS_RES_3009_19
wert_03
SIEMENS_RES_300C_20
wert_03
SOS_TIMEOUTTIME
wert_03
SIEMENS_RES_3008_8
wert_03
SHD_POSITION_CLOUD
wert_03
SHD_TRACK_LIMIT_MIN_TILT
wert_03
SET_CODE_9
wert_05
SET_CODE_B
wert_05
SET_CODE_D
wert_05
SET_CODE_F
wert_05
SET_CODE_11
wert_05
SET_CODE_13
wert_05
SHD_POS8
wert_04
SHD_POS9
wert_04
SHD_POSITION_OPEN
wert_04
REGENSCHLIESSEN
aktiv
REGENSCHLIESSENTILT
aktiv
PANIC_FREIGABE_CAS
nicht_aktiv
SHD_CFL_ALLOWED
nicht_aktiv
SHD_POSITION_0MM
wert_01
SIEMENS_RES_3006_2
wert_01
SHD_FORCE_OFFSET_START
wert_01
SOS_CFL_ALLOWED
nicht_aktiv
SIEMENS_RES_300A_9
wert_01
SIEMENS_RES_300A_10
wert_01
SIEMENS_RES_3008_13
wert_01
SIEMENS_RES_3008_14
wert_01
SIEMENS_RES_3008_16
wert_01
SIEMENS_RES_300A_11
wert_01
SHD_TC_COIL_ROTOR
wert_01
SHD_QCOIL
wert_01
SIEMENS_RES_3010_0
wert_01
SIEMENS_RES_3010_1
wert_01
SIEMENS_RES_3010_13
wert_01
SIEMENS_RES_3010_3
wert_01
SIEMENS_RES_3010_5
wert_01
SIEMENS_RES_3010_6
wert_01
SIEMENS_RES_3010_8
wert_01
SIEMENS_RES_3010_10
wert_01
SIEMENS_RES_3010_12
wert_01
SIEMENS_RES_3008_20
wert_01
SIEMENS_RES_3008_19
wert_01
SHD_TIMEOUTLIMPHOMETIME
wert_02
SHD_RESTARTALLOWED
aktiv
SIEMENS_RES_300A_1
wert_01
SIEMENS_RES_300A_2
wert_01
SIEMENS_RES_300A_5
wert_01
SIEMENS_RES_300A_8
wert_01
SIEMENS_RES_300B_1
wert_02
SIEMENS_RES_300B_2
wert_02
SIEMENS_RES_300B_5
wert_02
SIEMENS_RES_300B_8
wert_02
SHD_POSITION_TILTED
wert_03
SHD_POS0
wert_03
SHD_POS1
wert_03
SHD_POS2
wert_03
SHD_POS3
wert_03
SHD_POS4
wert_03
SHD_RF_LENGTH_TILT
wert_03
SHD_POS7
wert_04
USE_SOS
nicht_aktiv
SOS_TMON_ALLOWED
nicht_aktiv
SOS_RRD_ALLOWED
nicht_aktiv
SHD_TOLERANCE
wert_01
SOS_TOLERANCE
wert_01
SOS_REVERSINGDELAYTIME
wert_01
SOS_RF_DISTANCE_TILT
wert_01
SIEMENS_RES_3008_17
wert_01
SIEMENS_RES_300B_9
wert_01
SOS_FORCE_OFFSET_START
wert_01
SOS_FORCE_OFFSET_RESTART
wert_01
SOS_TRACK_LIMIT_MIN_TILT
wert_01
SIEMENS_RES_3009_6
wert_01
SIEMENS_RES_3009_7
wert_01
SOS_POS_SEAL
wert_01
SOS_POSSEAL2
wert_01
SIEMENS_RES_3009_13
wert_01
SIEMENS_RES_3009_14
wert_01
SIEMENS_RES_300A_14
wert_01
SIEMENS_RES_300A_18
wert_01
SOS_CAR_SPEED_THRESH
wert_01
SIEMENS_RES_300B_3
wert_01
SOS_RESTARTALLOWED
nicht_aktiv
SIEMENS_RES_300B_4
wert_01
SIEMENS_RES_300B_6
wert_01
SIEMENS_RES_300B_7
wert_01
SIEMENS_RES_300B_10
wert_01
SIEMENS_RES_300B_11
wert_01
SIEMENS_RES_300B_12
wert_01
SIEMENS_RES_300B_14
wert_01
SIEMENS_RES_300B_16
wert_01
SIEMENS_RES_300B_18
wert_01
SIEMENS_RES_300B_20
wert_01
SIEMENS_RES_300B_22
wert_01
SIEMENS_RES_300B_23
wert_01
SIEMENS_RES_300B_24
wert_01
SOS_BRAKE_MUL
wert_01
SOS_BRAKE_OFFSET
wert_01
SOS_BLOCK_TIME
wert_01
SOS_TEMP_COIL_START
wert_01
SOS_TC_COIL_ROTOR
wert_01
SOS_TC_ROTOR_CASE
wert_01
SOS_TC_CASE_AMBIENT
wert_01
SOS_QCOIL
wert_01
SOS_QROTOR
wert_01
SOS_QCASE
wert_01
SOS_POWER_DISS_FACT
wert_01
SOS_THERMAL_MOTOR_CONST
wert_01
SOS_POLEPAIRS
wert_01
SOS_OPPDIR_VMOT
nicht_aktiv
SOS_OPPDIR_DRIVER
nicht_aktiv
SOS_POSITION_CLOSED
wert_01
DOPPELKLICK_ZU
nicht_aktiv
SIEMENS_RES_3009_22
wert_01
SIEMENS_RES_3009_23
wert_01
SIEMENS_RES_3009_27
wert_01
SHD_BLOCK_TIME
wert_01
SHD_TC_ROTOR_CASE
wert_01
SHD_TC_CASE_AMBIENT
wert_01
SHD_POWER_DISS_FACT
wert_01
SHD_THERMAL_MOTOR_CONST
wert_01
SHD_CLOUD_ALLOWED
aktiv
SOS_TRACKLIMITMINOUTSIDE
wert_01
SOS_TRACKLIMITMAXOUTSIDE
wert_01
DOPPELKLICK_AUF
nicht_aktiv
SOS_LIMPHOMEALLOWED
nicht_aktiv
SOS_PRERUNLEARN
wert_01
SOS_POSTRUNLEARN
wert_01
SOS_PRERUNACTU
wert_01
SOS_POSTRUNACTU
wert_01
SOS_PRERUNFROMTILT
wert_01
SIEMENS_RES_300D_21
wert_01
SOS_OPPDIRVMOTLIMIT
wert_01
SOS_TEMPIDLE
wert_01
SOS_TEMPTHRESH1
wert_01
SOS_TEMPTHRESH2
wert_01
SOS_MULVDIFFHIGHLIMIT
wert_01
SOS_MULVDIFFLOWLIMIT
wert_01
SOS_BOOTINGTIME
wert_01
DOPPELKLICK_HEBEN
nicht_aktiv
SOS_STARTUPTIME
wert_01
SOS_TURNTIME
wert_01
SOS_NORMINGBLOCKTIME
wert_01
SOS_WRITEPOSTIME
wert_01
SOS_CLEARPOSTIME
wert_01
SOS_TIMEOUTLIMPHOMETIME
wert_01
SOS_DRIVERILLEGALONTIME
wert_01
SOS_DRIVERBADTIME
wert_01
SOS_MOTORSHORTTIME
wert_01
SOS_ERRMECHCOUNT
wert_01
SOS_OPPDIRCOUNT
wert_01
SOS_FORCEOFFSTAROUT
wert_01
SIEMENS_RES_3011_5
wert_01
SIEMENS_RES_3011_12
wert_01
SIEMENS_RES_3011_19
wert_01
SIEMENS_RES_3011_26
wert_01
SIEMENS_RES_3009_26
wert_01
SIEMENS_RES_300C_21
wert_01
SOS_MINDIFFFORACTU
wert_01
SHD_QROTOR
wert_01
TEMPTMONUSEOUTER
nicht_aktiv
TEMPCFLUSEOUTER
nicht_aktiv
BROSE_ZONE_0
wert_03
BROSE_ZONE_1
wert_03
BROSE_ZONE_2
wert_03
BROSE_ZONE_3
wert_03
FH_HINTEN
aktiv
TASTVERH_BEL_WBL_MIN
wert_02
COUPE_TUER
aktiv
EINKLEMMSCHUTZ_HINTEN
nicht_aktiv
TIPP_ZU_MOEGLICH_HINTEN
nicht_aktiv
FH_EMERGENCY_CLOSE
nicht_aktiv
FH_EMERGENCY_CLOSE_VAR
aktiv
FH_LONG_REVERSE
aktiv
E63_E64
aktiv
KONF_SM_CKM_FREIGABE
konfiguration_moeglich
KALTUEBERWACHUNG_BL_L
nicht_aktiv
KALTUEBERWACHUNG_BL_R
nicht_aktiv
KALTUEBERW_RL_BL_1_L
nicht_aktiv
KALTUEBERW_RL_BL_1_R
nicht_aktiv
WARMUEBERWACHUNG_BL_L
nicht_aktiv
WARMUEBERWACHUNG_BL_R
nicht_aktiv
WARMUEBERW_RL_BL_1_L
nicht_aktiv
WARMUEBERW_RL_BL_1_R
nicht_aktiv
FEHLERMELDUNG_CC_BL_L
aktiv
FEHLERMELDUNG_CC_BL_R
aktiv
FEHLERMELD_CC_RL_BL_1_L
aktiv
FEHLERMELD_CC_RL_BL_1_R
aktiv
ZUWACHS_TASTVERH_WBL_BEL
wert_02
RL_BL_PARKL_FKT
nicht_aktiv
PWM_ANSTEUERUNG_RFS_L
wert_01
PWM_ANSTEUERUNG_RFS_R
wert_01
PWM_ANSTEUERUNG_NSL_SL
wert_01
K_ZAHL_TACHO
wert_02
K_ZAHL_TACHO_KOMPL
wert_02
RL_BL_PO_RL_FKT
nicht_aktiv
K_ZAHL_WEG
wert_02
K_ZAHL_WEG_KOMPL
wert_02
RL_BL_1_PARKL_FKT
aktiv
PWM_ANST_RL_BL_2_BL
wert_02
PWM_ANSTEUERUNG_RL_BL_L
wert_02
PWM_ANSTEUERUNG_RL_BL_R
wert_02
PWM_ANSTEUERUNG_RL_BL_1_L
wert_04
PWM_ANSTEUERUNG_RL_BL_1_R
wert_04
PWM_ANST_RL_BL_BL
wert_02
PWM_ANST_RL_BL_1_BL
wert_03
PWM_ANSTEUERUNG_SL_V_AL
wert_03
PWM_ANSTEUERUNG_SL_V_FL
wert_03
PWM_ANST_RL_BL_2_AL
wert_03
PWM_ANST_RL_BL_2_FL
wert_03
RL_BL_2_PO_RL_FKT
nicht_aktiv
BFD_1_ALGORITHMUS
aktiv
RL_BL_1_BREMSL_FKT
aktiv
SIDEBAG_VO_RE
aktiv
SIDEBAG_VO_LI
aktiv
STROMVERT_B1_BYTE_3/0
sv_sk_ein_sleep
STROMVERT_C2_BYTE_3/6
skein_ein
STROMVERT_C2_BYTE_3/7
skaus_ein
STROMVERT_C3_BYTE_3/6
skein_ein
STROMVERT_C3_BYTE_3/7
skaus_ein
STROMVERT_C4_BYTE_3/6
skein_ein
STROMVERT_C4_BYTE_3/7
skaus_ein
STERNKOPPLER_XC_BYTE_3/7
skaus_aus
STROMVERT_B2_BYTE_3/0
sv_sk_ein_sleep
STERNKOPPLER_XC_BYTE_3/0
sk_aus_sleep
ACC_FUNKTION
wert_01
ALGOPARAM_STVL_EAM
wert_09
ALGOPARAM_STVR_EAM
wert_09
EAM_3_PARAM_SBSL
wert_08
EAM_3_PARAM_SBSR
wert_08
LINKS_RECHTS_VERKEHR
rechtsverkehr
ALGOPARAM_SFZ_1
wert_17
ALGOPARAM_SZL_EAM
wert_08
ALGOPARAM_SIM_EAM
wert_08
EAM_1_PARAM_SBSL
wert_08
EAM_1_PARAM_SBSR
wert_08
EAM_2_PARAM_SBSL
wert_08
EAM_2_PARAM_SBSR
wert_08
TYP_LENKUNG
linkslenker
LL/RL_KLIMA
linkslenker
CHECKCTRLTAB_STVL
wert_01
LSVSCHALTER_BEDIENUNG
wert_01
OUTPUT_SIGNAL_TABLE_1
e60_ll
OUTPUT_SIGNAL_TABLE_2
e60_ll
FAHRZEUGTYP_LL_RL
wert_01
CHECKCTRLTAB_STVR
wert_01
FBDIN_9_6_KBAUD
aktiv
SA_KONFIG_KL_FAS
nicht_aktiv
SA_KONFIG_KL_BFS
nicht_aktiv
SA_KONFIG_AS_FAS
nicht_aktiv
SA_KONFIG_AS_BFS
nicht_aktiv
SA_KONFIG_LD_FAS
nicht_aktiv
SA_KONFIG_LD_BFS
nicht_aktiv
MOT_KONFIG_LBV
nicht_aktiv
MOT_KONFIG_LKV
nicht_aktiv
SA_KONFIG_SAL_FAS
nicht_aktiv
SA_KONFIG_SAL_BFS
nicht_aktiv
MOT_KONFIG_SLV_MEM__BFS
nicht_aktiv
MOT_KONFIG_SHV_MEM_BFS
nicht_aktiv
MOT_KONFIG_LBV_MEM_BFS
nicht_aktiv
MOT_KONFIG_LNV_MEM_BFS
nicht_aktiv
MOT_KONFIG_SNV_MEM_BFS
nicht_aktiv
MOT_KONFIG_KHV_MEM_BFS
nicht_aktiv
MOT_KONFIG_LKV_MEM_BFS
nicht_aktiv
MOT_KONFIG_STV_MEM_BFS
nicht_aktiv
MOT_KONFIG_STV
aktiv
MOT_KONFIG_SLV_MEM_FAS
aktiv
MOT_KONFIG_SHV_MEM_FAS
aktiv
LENKSAEULENVERSTELLUNG
elektrisch
MOT_KONFIG_LBV_MEM_FAS
nicht_aktiv
MOT_KONFIG_LNV_MEM_FAS
aktiv
MOT_KONFIG_SNV_MEM_FAS
aktiv
MOT_KONFIG_KHV_MEM_FAS
aktiv
MOT_KONFIG_LKV_MEM_FAS
nicht_aktiv
MOT_KONFIG_STV_MEM_FAS
aktiv
AUTOML_TTB_FAS
aktiv
AUTOML_TTB_BFS
nicht_aktiv
MEMORY
aktiv
KERBING
aktiv
MILANSTEUERUNG
wert_01
OELWARTUNGSINTERVALL
wert_01
TAGFAHRLICHT_ECE
nicht_aktiv
DEF_TAGFAHRLICHT_ECE_CKM
nicht_aktiv
KENNLINIE_LWR_SENSOR_VO
wert_01
KENNLINIE_LWR_SENSOR_HI
wert_01
DEF_LWR_SENSOR_HI
wert_01
LWR_NEIGUNG_KONSTANTE
wert_01
OFFSET_LWR
wert_01
EPSILON_DELTA_AV
wert_01
EPSILON_DELTA_A
wert_01
ZK1_SBSL
abgesteckt
ZK2_SBSL
abgesteckt
ZK5_GURTSTR_HI_LI
abgesteckt
ZK5_GURTSTR_HI_RE
abgesteckt
ZK4_SBSL
aktiv
ZK4_SBSR
aktiv
ZK6_SBSL
abgesteckt
ZK6_SBSR
abgesteckt
ZK1_SBSR
aktiv
ZK1_ZF_SBSR
vom_ss_beeinflusst
ZK2_SBSR
aktiv
ZK2_ZF_SBSR
vom_ss_beeinflusst
AIRBAG_FA_STUFE1_1
aktiv
AIRBAG_FA_STUFE2_1
aktiv
FAHR_DYNAMIK_CONTROL
aktiv
FDC_VERBAUT
aktiv
ACC_ALIVE_ZAEHLER
nicht_aktiv
ACC_ID_MONITOR
nicht_aktiv
ACC
nicht_aktiv
ACC_CSUM_MONITOR
nicht_aktiv
GESCHWINDIGKEITSREGLER
aktiv
CRUISE_CTRL
nicht_aktiv
ACC_AUSSTATTUNG
fgr_aktiv
FKT_AUSWAHL_DEFAULT
wert_03
FKT_AUSWAHL_KEY_1
wert_03
FKT_AUSWAHL_KEY_2
wert_03
FKT_AUSWAHL_KEY_3
wert_03
FKT_AUSWAHL_KEY_4
wert_03
KL_PREDRIVE_AUSWAHL
wert_04
SPRACHE
us
WAEHLBARE_SPRACHE_1
us
WAEHLBARE_SPRACHE_2
franzoesisch
WAEHLBARE_SPRACHE_3
spanisch
US_BUSINESS/PROF_VARIANT
professional_model
AIRBAG_TRIGGERED_E-CALL
aktiv
E-CALL_CHECK_CONTROL
nicht_aktiv
WAKE-UP_BY_E-CALL
nicht_aktiv
CUSTOMER_CALLS_OVER_GMIN
nicht_aktiv
E-CALL_HARDKEY_FITTED
aktiv
NON-TELEMATIC_E-CALL
aktiv
MOST_ASYNC_OR_CTRL_CHANNL
most_async_channel
HARDWARE
hw_ccc
ADRBOOK
aktiv
BLUETOOTH_NODES
profil_2
CID
cid_high
RING
aktiv
SCHEIBE_AUSSTATTUNG
serie_scheibe
GLASSTYP
esg_glass
SERVOTRONIK
aktiv
AFS_ALIVE_ZAEHLER
nicht_aktiv
ACTIVE_FRONT_STEERING
nicht_aktiv
ANSCHLAG_L_WINKEL_VA
wert_01
ANSCHLAG_L_WINKEL_NA
wert_01
AFS_ID_MONITOR
nicht_aktiv
AFS
nicht_aktiv
GESCHWIND_WERTE_KOMFORT
wert_21
STROMWERTE_KOMFORT
wert_21
GESCHWIN_WERTE_SPORT
wert_15
STROMWERTE_SPORT
wert_15
VERBAU_TELEFON
verbaut
UBERWACH_TELEFON
aktiv
WEG_EINHEIT
mls
BC_2_ENABLE
aktiv
BC_LIMIT_ENABLE
aktiv
BC_HIGH
aktiv
KLIMA_SG_ART
high
SOLARSENSOR
aktiv
BESCHLAGSENSOR
aktiv
STANDLUFT
aktiv
NAVI_AUSSTATTUNG
low_guiding
AEREA_CODE_DVD
wert_01
DRL_V_GEDIMMT
nicht_aktiv
KALTUEBERW_BLK_V_L_2
aktiv
KALTUEBERW_BLK_V_R_2
aktiv
PWM_ANSTEUERUNG_BLK_V_L_2
wert_03
WARMUEBERW_BLK_V_L_2
aktiv
WARMUEBERW_BLK_V_R_2
aktiv
PWM_ANSTEUERUNG_BLK_V_R_2
wert_03
FEHLERMELD_CC_BLK_V_L_2
aktiv
FEHLERMELD_CC_BLK_V_R_2
aktiv
RL_BL_2_ALS_SL_VORNE
nicht_aktiv
LWR_ANSTEUERN
nicht_aktiv
ALC_FAHRZEUG
aktiv
UMSCHALTOPT_LICHTSCHALTER
aktiv
XENON_AL_VERBAUT
aktiv
KALTUEBERWACHUNG_AL_L
nicht_aktiv
KALTUEBERWACHUNG_AL_R
nicht_aktiv
PWM_ANSTEUERUNG_AL_L
wert_01
PWM_ANSTEUERUNG_AL_R
wert_01
LWR_SCHRITTE_STELLUNG_2
wert_02
LWR_ABS_MIN_STELLUNG_2
wert_02
LWR_HYSTERESE_START
wert_02
LWR_VORBESTROMUNG
wert_02
XENON_LI
wert_02
XENON_WIEDER_ZUEND
aktiv
AUSWERT_PROP_ABWEICHUNG
aktiv
AUSWERT_GRADIENT
aktiv
PWM_ANSTEUERUNG_RL_BL_2_L
wert_02
PWM_ANSTEUERUNG_RL_BL_2_R
wert_02
KALTUEBERW_RL_BL_2_L
nicht_aktiv
KALTUEBERW_RL_BL_2_R
nicht_aktiv
WARMUEBERW_RL_BL_2_L
nicht_aktiv
WARMUEBERW_RL_BL_2_R
nicht_aktiv
BI_XENON_VERBAUT
aktiv
RL_BL_2_PARKL_FKT
nicht_aktiv
PWM_ANSTEUERUNG_SL_V_L
wert_03
PWM_ANSTEUERUNG_SL_V_R
wert_03
LEUCHTWEITENREG_AUTOM
aktiv
LEUCHTWEITENREG_DYNAM
aktiv
NEIGUNGSGEBER
aktiv
FUNK_INNENRAUMSCHUTZ
aktiv
MOTORHAUBENKONTAKT
aktiv
QUIT_OPT_ENTSCH
aktiv
DEF_QUIT_OPT_ENTSCH
aktiv
QUITT_BLK_SICHERN
nicht_aktiv
QUITT_BLK_ENTSICHERN
nicht_aktiv
DEF_QUITT_BLK_ENTSI_CKM
nicht_aktiv
DEF_QUITT_BLK_SICH_CKM
nicht_aktiv
DWS
aktiv
KL30G_TIMEOUT
wert_01
BMW_MOBILE
aktiv
BMW_DEALER
aktiv
BMW_HOTLINE
aktiv
BMW_N_DEALER
nicht_aktiv
LENKRADHEIZUNG
aktiv
SONDERTASTE_PANIKALARM
panikalarm
CC_TEMPERATURWARNUNG
nicht_aktiv
UMLUFT_MEMORY
aktiv
SEAT_BELT_DISTANCE
wert_02
CC_GURTWARNUNG
aktiv
LAENDERVARIANTE_SHD
us
LAENDERVARIANTE_KBM
us
TRIGGERANZAHL_KLAPPEN
wert_01
TRIGGERANZAHL_SENSOREN
wert_01
WARNUNG_GESCHW_LIMIT
nicht_aktiv
TRF
nicht_aktiv
KANA_WRITER
nicht_aktiv
SMS
nicht_aktiv
RECHTSVERKEHR
aktiv
LINKSVERKEHR
nicht_aktiv
CC_BREMSWARNL_NUR_ROT
nicht_aktiv
VSETZ_MIN
mph
GESCHWINDIGKEITSEINHEIT
mph
VSETZ_MAX
mph
TOR_SYMBOL_NORMALREGELUNG
systemgrenze_u_distanz
TOR_SYMBOL_BRAKEONLY
ABSTANDSSTUFE_NAH
usa
ABSTANDSSTUFE_MITTEL_NAH
usa
ABSTANDSSTUFE_MITTEL_WEIT
usa
VERZOEGERUNG_MAX
usa
BESCHL_RUCKBEGR_MOTOR_UNT
usa
BESCHL_RUCKBEGR_UNTEN
usa
BESCHL_RUCKBEGR_OB_FREIF
usa
SSC_VERZOEGERUNG_MAX
usa
CSC_QUERBESCHL_MAX
usa
SCHWELLE_TOR_SYSTEMGRENZE
usa
TOR_DISTANZ_FAKTOR_EIN
usa
TOR_DISTANZ_FAKTOR_AUS
usa
TOR_DISTANZ_MIN
usa
TOR_DISTANZ_CHAR_VREL
usa
KLIMA_US
aktiv
CC_ZUENDSCHLUESSEL
aktiv
PTY_TABELLE
pty_us
USA_REVERSE
aktiv
TOR_SYMBOL_FA_UEBERTRETEN
nur_distanz_m_gong
ABSTANDSSTUFE_INIT
weit
LONG_TIP_UP/DOWN
nicht_aktiv
ALARM_OPT_FERNLICHT
aktiv
ES_EINMALIG_CLT
aktiv
BC_V_KORREKTUR
aktiv
PANIK_ALARM
aktiv
QUIT_AKUST_ENTSCH
aktiv
DEF_QUIT_AKUST_SCHAERF_KL
aktiv
DEF_QUIT_AKUST_ENTSCH
aktiv
QUIT_AKUST_SCHAERF_KLAPPE
aktiv
PAO_HELL
nicht_aktiv
FL_UND_NSW_NICHT_GLEICHZ
aktiv
ABSCHALTUNG_RFS
nicht_aktiv
BFD_1_WERT_AX_EIN
wert_04
KALTUEBERWACHUNG_NSL_L
nicht_aktiv
KALTUEBERWACHUNG_NSL_R
nicht_aktiv
WARMUEBERWACHUNG_NSL_L
nicht_aktiv
WARMUEBERWACHUNG_NSL_R
nicht_aktiv
BFD_2_BL_M_ERSCH_BILD
wert_01
SBE1_SBSR
aktiv
FEHLERMELDUNG_CC_NSL_L
nicht_aktiv
FEHLERMELDUNG_CC_NSL_R
nicht_aktiv
PWM_ANSTEUERUNG_NSL_L
wert_03
BFD_2_WERT_AX_EIN
wert_01
TCU_TYPE
e60_us_thin
OC3_SBSR
nicht_aktiv
WEATHERBAND
aktiv
LEGAL_DISCL
aktiv
TIMER_SMS_NACK
wert_02
PWM_ANSTEUERUNG_NSL_R
wert_03
LAENDERVARIANTE_AHM
us
FUNKTION_FBD_SCHLIESSEN_1
aktiv
KOMFORTSCHLIESSUNG_FB
nicht_aktiv
FH_DISASHD_KL15
aktiv
CBS_INTW_11H
wert_03
CBS_INTW_10H
wert_02
REV_INPUT
aktiv
UNIT_FEET
aktiv
ACOUSTIC
aktiv
REGIONALISIERUNG
reg_aus
BLUETOOTH
nicht_aktiv
PER_WAKEUP-SMS_SNOOPING
wert_01
E_CALL_COUNTD_DELAY_TIMER
wert_02
STARTABBRUCH_BREMSE
aktiv
UPF_VERBAUT
nicht_verbaut
BFD_1_NSL_ERSCH_BILD
nicht_aktiv
ALARMTYP
us
ALARM_TYPE
wert_02
TEMPERATUR_EINHEIT
grad_f
GRAD_C_GRAD_F_AUSWAHL
grad_f
ZEIT_EINHEIT
12_stunden
DATUM_EINHEIT
mm_tt_jj
SPEECH_MF
weiblich
TANK_SCHWELLE_RESERVE
wert_02
VSA_SET
perm_verhindern
VERBRAUCH
mpg
LAENDERVARIANTE_BNDB
us
KUEHL_MTL_AKTIV
aktiv_high
MOTOR_ART
benzin_normal
MOTOR_HUBRAUM
n62b48
ZYLINDER_ZAHL
8_zylinder
DS_CHECKPATTERN
e64_n62
Y1_MOMV_VFZG_Z1
e64_n62
Y1_AQ_WAWI_Z1
e64_n62
AQ_SCHALT
e64_n62
FG_A_QUER_ROH
e64_n62
C_VA
e64_n62
C_HA
e64_n62
CVO
e64_n62
CHO
e64_n62
K_VOREIL_RES
e64_n62
KL_K_VOREIL
e64_n62
H_ROLLZENT
e64_n62
F_BEOBACHTER
e64_n62
K_VOREIL
e64_n62
K_VOREIL_AB
e64_n62
K_VOR_AY_EST
e64_n62
RADSTAND
e64
SPUR_VA
e64
SPUR_HA
e64
GIERTRAEGHEIT
e64
I_STABI_VA
e64
PSOLL_MAX_VA
e64
I_STABI_HA
e64
SCHENKEL_V
e64
SCHENKEL_H
e64
K_MOT_VA
e64
K_MOT_HA
e64
PSOLL_MAX_HA
e64
I_LENK
e64
LENK_UEBERSETZUNG
wert_19
LENK_UEBERSETZUNG_LO
wert_20
WINKEL_BLENDUNG
wert_02
M_AUFBAU
e64_n62
M_FZG
e64_n62
M_ANTEIL_VA
e64_n62
FACT_PU_MOT
e64_n62
N_MOT_MIN
e64_n62
N_MOT_MAX
e64_n62
NM_FEST
e64_n62
GETRIEBE_GAENGE
6_gaenge
KMV_UEBERSETZUNG
n62b44
WASSERPUMPE
aktiv
UMWAELZPUMPE
nicht_aktiv
ZUHEIZUNG
nicht_aktiv
PTC
nicht_aktiv
CBS_STAT_10H
anzeige
EKP_ALIVE_ZAEHLER
nicht_aktiv
EKP_ID_MONITOR
nicht_aktiv
BATT_LTG_DIAG
aktiv
ALC_LWR_VORZEICHEN
beide_aktiv
CHECK_FGN_SMC_ALC_OFF
aktiv
RUECKFALLEBENE_U_60
aktiv
STARTDELAY_K_START
nicht_aktiv
GRENZWERT_BAT_LEITUNG_DIA
wert_01
DREHZAHL/FOERDERKENNLINIE
wert_07
MAX_MOTORSP._MSB/LSB
wert_07
MIN_MOTORSP._MSB/LSB
wert_07
MAX_MOTORSTROM._MSB/LSB
wert_07
MIN_MOTORSTROM._MSB/LSB
wert_07
KEIN_MOTORSTROM._MSB/LSB
wert_07
MAX_POS_DREHZAHLDIFF
wert_07
MAX_NEG_DREHZAHLDIFF
wert_07
KEINE_DREHZAHL_MSB/LSB
wert_07
MAX_SPANNUNG_KL15_MSB/LSB
wert_07
MIN_SPANNUNG_KL15_MSB/LSB
wert_07
MAX_SPANNUNG_KL30_MSB/LSB
wert_07
MIN_SPANNUNG_KL30
wert_07
KEINE_SPANNUNG_KL30
wert_07
UEBERTEMP_LS/HS
wert_03
REGELPARAMETER_P_MSB/LSB
wert_07
REGELPARAMETER_I_MSB/LSB
wert_07
REGELPARAMETER_D_MSB/LSB
wert_07
MOTORPOLE
wert_07
VCO_CONFIG
wert_03
BANDPASS_CONFIG
wert_03
STROMUMRECHNUNG
wert_03
P0_U_KL.30_MSB/LSB
wert_03
P0_DREHZAHL_MSB/LSB
wert_03
P1_U_KL_30_MSB/LSB
wert_03
P1_DREHZAHL_MSB/LSB
wert_03
BEDUG_1/2
wert_03
PUMPEN_ID
wert_07
DATUM_JAHR
wert_07
DATUM_MONAT
wert_07
DATUM_TAG
wert_07
CHECKSUMME_EKP
wert_07
TYP_FRONTSCHEIBE
serienscheibe
FOLDING
nicht_aktiv
VORFELDBELEUCHTUNG
aktiv
GPS_UHR
aktiv
NAVIGATION
aktiv
TEMP_CONSUMER_PIN_STORAGE
nicht_aktiv
BACKUP_ANTENNA
aktiv
GPS_ON/OFF
nicht_aktiv
TELEMATIK_ENABLED
nicht_aktiv
PDC_AKTIV
nicht_aktiv
PDC_AKTIV_VOR_AUF
nicht_aktiv
ERSATZFKT_BL1_BL
wert_01
LADEEINRICHTUNG
nicht_aktiv
BACKDOOR
nicht_aktiv
EHC_ALIVE
nicht_aktiv
WINDSCHOTT
nicht_aktiv
SHD_QUARTER_TURN
wert_01
SHD_FORCE_OFFSET_RESTART
wert_01
SIEMENS_RES_3008_24
wert_01
SHD_SKB_OHNE_KL_OE
nicht_aktiv
SHD_TIMEOUTTIME
wert_01
SHD_EXOPENBEGIN
wert_01
WDHSPERRE_HKSCHEIBE
wert_02
INTERVALLZEIT_HECKWISCHER
wert_01
SHD_FORCETHRESHEXOPEN
wert_01
SHD_EXOPENEND
wert_01
SHD_TRACKLIMITEXOPEN
wert_01
SOS_POSITION_CLOUD
wert_01
SIEMENS_RES_3008_15
wert_01
ANZ_EIN_N_BLOCK_HKWISCHER
wert_01
SPERRZ_N_BLOCK_HKWISCHER
wert_01
VERZ_HKWISCHER_N_WASCHANF
wert_01
ZEIT_WASCH_M/O_HKWISCHER
wert_01
ENTPRELLZEIT_HKWISCHER
wert_01
ANZ_NACHWISCH_HKSCH_WASCH
wert_01
BLOCK_ERKENNUNG_HKWISCHER
wert_01
ZEIT_DEKR_N_WDHSP_HKSCHEI
wert_02
SCA_HECKKLAPPE
nicht_aktiv
INTERVALLZEIT_HK_WISC_RG
wert_01
OEFFNEN_AUS_GEHOBEN
aktiv
HEBEN_AUS_GEOEFFNET
aktiv
SIEMENS_RES_3009_24
wert_01
TIPP_AUF_MOEGLICH_HINTEN
aktiv
FH_CABRIO_VERDECK_MODUL
aktiv
EINSTIEGSHILFE_OHNE_NR
nicht_aktiv
EINSTIEGSHILFE_SENDER_1
nicht_aktiv
EINSTIEGSHILFE_SENDER_2
nicht_aktiv
EINSTIEGSHILFE_SENDER_3
nicht_aktiv
EINSTIEGSHILFE_SENDER_4
nicht_aktiv
SITZ_L_UEBERWACHUNG
aktiv
E64
aktiv
ROLLOVER_BETRIEBSART
standard
LEHNE_FA_ALIVE_ZAEHLER
aktiv
LEHNE_BF_ALIVE_ZAEHLER
aktiv
LEHNE_FA_ID_MONITOR
aktiv
LEHNE_BF_ID_MONITOR
aktiv
INDEXTAB_FC_SFZ
wert_02
SENSORWERT_X_INV_SBSL
nicht_invertiert
SENSORWERT_Y_INV_SBSL
nicht_invertiert
SENSORWERT_Y_INV_SBSR
invertiert
ASE_TYP
e64
SICHERHEITSFAHRZEUG
nicht_aktiv
FH_SICHERHEITSFAHRZEUG
nicht_aktiv
FBD_HSF_0
wert_09
FBD_HSF_1
wert_09
STANDHEIZUNG
nicht_aktiv
PSEUDOZUHEIZEN
nicht_aktiv
STANDHEATING
nicht_aktiv
DEAKTIVIERUNG_SHZH
aktiv
CAN_MEHRFACH_SICHERN
aktiv
AHM_ALIVE
nicht_aktiv
ANHAENGERKUPPLUNG
nicht_aktiv
ARS_ALIVE_ZAEHLER
aktiv
ARS_ID_MONITOR
aktiv
ECO_MIN_WID
wert_02
ECO_MAX_WID
wert_02
ECO_ERSATZSTROMWERT
wert_02
ECO_KP_FAKTOR
wert_02
ECO_TN_FAKTOR
wert_02
RDC_ALIVE
nicht_aktiv
AUSSTATTUNG_RPA
aktiv
GETRIEBE_TYP
schrittschaltung
SS_GETRIEBE
nicht_aktiv
GETRIEBE_ART
automatik
GETRIEBE
automatik
R_GANG_VON_LM
nicht_aktiv
EGS_ALIVE_ZAEHLER
aktiv
EGS_ID_MONITOR
aktiv
KOMFORTSTART
aktiv
EGS_CSUM_MONITOR
aktiv
ANZ_SCHALTAUFFORDERUNG
nicht_aktiv
AUSWERTUNG_P_CAN
aktiv
ZV_SELEKTIV
aktiv
SEL_ZV_SENDER_1
aktiv
SEL_ZV_SENDER_2
aktiv
SEL_ZV_SENDER_3
aktiv
SEL_ZV_SENDER_4
aktiv
MOTORFERNSTART
nicht_aktiv
MOTORFERNSTART_CAN
nicht_aktiv
MOTORFERNSTART_GENERELL
nicht_aktiv
SCHAERFEN/ENTSCHAERFEN
schloss_und_fernbedienung
SCHIEBEHEBEDACH
nicht_aktiv
KOMFORTSCHLIESSUNG_PA
nicht_aktiv
PASSIVE_ACCESS
nicht_aktiv
COMFORT_ACCESS_LICHT
aktiv
KLASSE_BATTERIE
110ah
OHNE_STOP_COMSCHL
aktiv
SCHL_END_GESCHW
aktiv
FEH_MOTOR_BFS
nicht_aktiv
FUNKTIONSVARIANTE
wert_01
HEIZUNG_AN_AUS
aktiv
BASE_FEHL_EINTR
wert_01
DEF_POSIT_LWR
wert_01
GESCHW_TAB_0
kennlinie_01
GESCHW_TAB_1
kennlinie_01
GESCHW_TAB_2
kennlinie_01
GESCHW_TAB_3
kennlinie_01
GESCHW_TAB_4
kennlinie_01
KL_ABST_POSIT_LI
wert_01
KL_ACC_AUS
wert_01
KL_ANSCHLAG_OPT_LI
wert_01
KL_ANSCHLAG_WEICH_LI
wert_01
KL_ENABLE
wert_02
KL_FLANKE_SEN_ERR
wert_01
KL_HELLA_MES_SEN_ERR
wert_01
KL_HOCH_STROM
wert_02
KL_HS
wert_02
KL_HS_GRAD_LOW
wert_01
KL_HS_GRAD_WERT
wert_01
KL_KOMFORT
wert_01
KL_MAX_WINKEL_MIN_LI
wert_01
KL_MAX_WINKEL_PL_LI
wert_01
KL_NUL_LAGE_SENSOR_LI
wert_01
KL_POSIT_RECHTS_LI
wert_01
KL_PWM_SENS_MAX_PLUS_LI
wert_01
KL_RAMP_BESCH
wert_02
KL_RAMP_BREMS
wert_02
KL_REF_SPEED
wert_01
KL_REF1_MODE
wert_02
KL_REF2_MODE
wert_02
KL_SCHRITT_ABST_REF2
wert_01
KL_SENS_INVERT_LI
wert_02
KL_SENSOR
wert_01
KL_SENSOR_AUSWERT
wert_02
KL_SIZE_RAMP_BESCH
wert_01
KL_SIZE_RAMP_BREMS
wert_01
KL_TEST
wert_01
KL_TIME_OUT
wert_02
KL_TREIBER_BEW
wert_01
KL_TREIBER_ERR
wert_01
LWR_ABS_LINKS_VERK
wert_02
LWR_ABS_RECHTS_VERK
wert_02
LWR_ACC_AUS
wert_01
LWR_ANSCHLAG_OPT
wert_03
LWR_ANSCHLAG_WEICH
wert_03
LWR_ENABLE
wert_02
LWR_HOCH_STROM
wert_02
LWR_HS
wert_02
LWR_HS_GRAD_LOW
wert_03
LWR_HS_GRAD_WERT
wert_03
LWR_MAX_WERT_START
wert_01
LWR_MAX_WINKEL_MIN
wert_03
LWR_MAX_WINKEL_PL
wert_03
LWR_POSIT_RECHTS_LI
wert_01
LWR_RAMP_BESCH
wert_02
LWR_RAMP_BREMS
wert_02
LWR_REF1_MODE
wert_02
LWR_REF2_MODE
wert_02
LWR_SIZE_RAMP_BREMS
wert_01
LWR_TEST
wert_01
LWR_TIME_OUT
wert_02
LWR_TREIBER_BEW
nicht_aktiv
LWR_TREIBER_ERR
nicht_aktiv
NOT_U_SENS
wert_02
OFFSET_FEHL_EINTR
wert_01
RAMPE_ZUS_0
kennlinie_1
RAMPE_ZUS_1
kennlinie_1
RAMPE_ZUS_2
kennlinie_1
RAMPE0_BL_0
kennlinie_01
RAMPE0_BL_1
kennlinie_01
RAMPE0_BL_2
kennlinie_01
RAMPE0_BL_3
kennlinie_01
RAMPE1_BL_0
kennlinie_01
RAMPE1_BL_1
kennlinie_01
RAMPE1_BL_2
kennlinie_01
RAMPE1_BL_3
kennlinie_01
RAMPE2_BL_0
kennlinie_01
RAMPE2_BL_1
kennlinie_01
RAMPE2_BL_2
kennlinie_01
RAMPE2_BL_3
kennlinie_01
RAMPE3_BL_0
kennlinie_01
RAMPE3_BL_1
kennlinie_01
RAMPE3_BL_2
kennlinie_01
RAMPE3_BL_3
kennlinie_01
SPIKE_ERR
wert_01
KL_ABST_POSIT_RE
wert_01
KL_ANSCHLAG_OPT_RE
wert_01
KL_ANSCHLAG_WEICH_RE
wert_01
KL_MAX_WINKEL_MIN_RE
wert_01
KL_MAX_WINKEL_PL_RE
wert_01
KL_NUL_LAGE_SENSOR_RE
wert_01
KL_POSIT_RECHTS_RE
wert_02
KL_PWM_SENS_MAX_PLUS_RE
wert_01
KL_SENS_INVERT_RE
wert_02
LWR_POSIT_RECHTS_RE
wert_01
DELAY_KL50L
wert_03
IB_AN_BEI_FUNKHEIZUNG
aktiv
MINUTEN_VA_IL
wert_01
KURZSCHLUSS_KL30_ENABLE
aktiv
AUXIN
aktiv
FLAP
nicht_aktiv
PDC_LOW
nicht_aktiv
VOLUME_KLANG_EMERGENCY
e64_top_hifi
VOLUME_PDC_EMERGENCY
e64_top_hifi
IL_SUCHFUNKTION
aktiv
DIGITAL_AUDIO_SOURCE
cd-player
LAENDERVARIANTE_GT
us
BEEP_CONTROL_CG1
e64_top_hifi
BEEP_CONTROL_CG2
e64_top_hifi
BEEP_CONTROL_CGL
e64_top_hifi
BEEP_CONTROL_PDC
e64_top_hifi
INPUT_SCALING
wert_02
OUTPUT_GAIN
e60_stereo
PHONE_VERSION
most-phone1-1mic
SOUND_SYSTEM_DATA
wert_01
CHECK_SMC_ERROR
aktiv
VOICE_PRE_PROC_MIC_DIST
par_vpp_210mm
VOICE_PRE_PROC_STEER_SIDE
par_vpp_left_steering
HK_ENABLE_OPEN
aktiv
SHD_ANLIEFERPOSITION
wert_03
SHD_BLOCK_1
wert_04
SHD_BLOCK_2
wert_04
SHD_BLOCK_4
wert_03
SHD_BLOCK_5
wert_03
SHD_POS
wert_05
SIEMENS_RES_3001_27
wert_04
SOS_ANLIEFERPOSITION
wert_03
SOS_BLOCK_1
wert_03
SOS_BLOCK_2
wert_04
SOS_BLOCK_4
wert_02
SOS_BLOCK_5
wert_03
SOS_POS
wert_04
TDECKEL_AUF
wert_01
TSHOTT_AUF_HS
wert_01
VDECKEL_ZU
wert_01
VSCHOTT_AUF_HS
wert_01
VSCHOTT_ZU_HS
wert_01
WINDSCHOTT_OPT
nicht_aktiv
ANFRAGE_FENSTERPOSITIONEN
nicht_aktiv
BA_LAENDER_VARIANTE
usa
DEF_DATUM_EINHEIT
mm_tt_jj
DEF_DRUCK_EINHEIT
psi
DEF_TEMPERATUR_EINHEIT
grad_f
DEF_VERBRAUCH
mpg
DEF_WEG_EINHEIT
mls
DEF_ZEIT_EINHEIT
12_stunden
JAPAN
nicht_aktiv
MULTIPARTY
nicht_aktiv
NAVIGATION_TYPE
navi_sv
ONLINE
nicht_aktiv
ONLINE_DISABLE_CONTENT
content_enable
ONLINE_DISABLE_VMAX
standard
REVERSE_GONG
nicht_aktiv
SIM
nicht_aktiv
SPRECHER_AKTIVE_SPRACHE
sprecher_weiblich
SPRECHER_ALTERNATIVE_2
sprecher_weiblich
SPRECHER_ALTERNATIVE_3
sprecher_weiblich
TELEFON_TYPE
prof_phone
VIDEO_DENY
deny_slow_key
PROGRAMMPARAMETER_LM_2
wert_01
PROGRAMMPARAMETER_LM_3
wert_01
PROGRAMMPARAMETER_LM_4
wert_01
PROGRAMMPARAMETER_LM_5
wert_01
PROGRAMMPARAMETER_LM_6
wert_02
ANLASSSPERRE_KLR
nicht_aktiv
MAX_ZUL_ALARMPULS_PDC_PH1
wert_02
SHD_BLOCK_6
wert_03
SOS_BLOCK_6
wert_03
MOTOR_DREHM_MAX_CHAR
automatik
MOTOR_DREHZAHL_MAX
automatik
MOTOR_TRAEGH_MOM
automatik
DEF_BALANCE_VOLUME
standard
DEF_BASS_VOLUME
standard
DEF_ENTERTAIN_VOL
standard
DEF_EQUALIZER_VALUE
standard
DEF_FADER_VOLUME
standard
DEF_GAL_VALUE
keine_anhebung
DEF_GONG_VOLUME
e64_top_hifi
DEF_JPGONG_VOL
e64_top_hifi
DEF_LAST_SPEECH
us
DEF_NAVI_VOLUME
standard
DEF_PDC_VOLUME
e64_top_hifi
DEF_REVERB_VALUE
standard
DEF_SEC_VOLUME
standard
DEF_SPEECH_VOLUME
standard
DEF_TEL_VOLUME
standard
DEF_TM_VOLUME
standard
DEF_TREMBLE_VOLUME
standard
GAL_VALUE
keine_anhebung
LAST_BALANCE_VOLUME
standard
LAST_BASS_VOLUME
standard
LAST_ENTERTAIN_VOL
standard
LAST_EQUALIZER_VALUE
standard
LAST_FADER_VOLUME
standard
LAST_GONG_VOLUME
e64_top_hifi
LAST_JPGONG_VOL
e64_top_hifi
LAST_NAVI_VOLUME
standard
LAST_PDC_VOLUME
e64_top_hifi
LAST_REVERB_VALUE
standard
LAST_SEC_VOLUME
standard
LAST_SPEECH
us
LAST_SPEECH_VOLUME
standard
LAST_TEL_VOLUME
standard
LAST_TM_VOLUME
standard
LAST_TREMBLE_VOLUME
standard
ACS_NB_PT1
dx06006
ADW_ADW_2PIFGBP_HA
dx06006
ADW_ADW_2PIFGBP_VA
dx06006
ADW_ADW_BPHP1_HA
dx06006
ADW_ADW_BPHP1_VA
dx06006
ADW_ADW_BPHP2_HA
dx06006
ADW_ADW_BPHP2_VA
dx06006
ADW_ADW_IHP1_HA
dx06006
ADW_ADW_IHP1_VA
dx06006
ADW_ADW_K_SKY
dx06006
ADW_ADW_TP1_HUELL
dx06006
ADW_AUFBAU_ADW_SP
dx06006
ADW_AUFBAU_ADW1
dx06006
ADW_AUFBAU_ADW1_2
dx06006
ADW_AUFBAU_ADW2
dx06006
ADW_AUFBAU_ADW3
dx06006
ADW_AUFBAU_ADW3_2
dx06006
ADW_AUFBAU_VFZG_SP
dx06006
ADW_IFA_K_ADW
dx06006
ADW_IFA_K_ADW_KOM_HA
dx06006
ADW_IFA_K_ADW_KOM_VA
dx06006
ADW_KENNL_I_ADW_HA
dx06006
ADW_KENNL_I_ADW_HA_2
dx06006
ADW_KENNL_I_ADW_SP
dx06006
ADW_KENNL_I_ADW_SP_2
dx06006
ADW_KENNL_I_ADW_VA
dx06006
ADW_KENNL_I_ADW_VA_2
dx06006
ADW_KENNL_RDW
dx06006
ADW_KENNL_RDW_SP
dx06006
ADW_KENNL_VFZG_HA
dx06006
ADW_KENNL_VFZG_HA_SP
dx06006
ADW_KENNL_VFZG_VA
dx06006
ADW_KENNL_VFZG_VA_SP
dx06006
ADW_SITZREITKENNF_ADW1
dx06006
ADW_SITZREITKENNF_ADW2
dx06006
ADW_SITZREITKENNF_ADW2_2
dx06006
ADW_SITZREITKENNF_ADW3
dx06006
ADW_SITZREITKENNF_V_SP
dx06006
ADW_SITZREITKENNF_V_SP_2
dx06006
ADW_SITZREITKENNL_ADW_SP
dx06006
AUFRUFFREQUENZ_F_ABT
dx06006
BLENDE_VFZG_MAX
dx06006
BLENDE_VFZG_MIN
dx06006
CHECKSUMME_EDCK
dx06006
DATENSATZNUMMER
dx06006
DATUM_AENDERUNG
dx06006
DB_FEST_I_HA
dx06006
DB_FEST_I_VA
dx06006
DUMP_MODE
dx06006
FZG_B_SENSOR_UMRECHNUNG
dx06006
FZG_DB_ZAEHNE_ABS
dx06006
FZG_DW_RADUMFANG
dx06006
FZG_V_FILTER_VFZG_TP2
dx06006
IRGL_NW_V_OFF_DELAY
dx06006
IRGL_NW_V_OFF_I_IST_MAX
dx06006
IRGL_NW_V_OFF_I_SOLL_MAX
dx06006
IRGL_NW_V_ON_I_SOLL_MAX
dx06006
KDW_KDW_ABKLING
dx06006
KDW_KDW_ADWMAX
dx06006
KDW_KDW_BPHP1
dx06006
KDW_KDW_BPTP2
dx06006
KDW_KDW_FAKTOR
dx06006
KDW_KDW_HALT
dx06006
KDW_KDW_IHP1
dx06006
KDW_KENNL_KDW
dx06006
KDW_KENNL_KDW_I_HA
dx06006
KDW_KENNL_KDW_I_VA
dx06006
KDW_KENNL_KDW_SP
dx06006
KDW_KENNL_KDW_SP_2
dx06006
KDW_KENNL_KDW_VF_SP
dx06006
LDW_KENNL_I_LDW
dx06006
LDW_KENNL_I_LDW_SP
dx06006
LDW_LDW_ADMAX
dx06006
LDW_LDW_ADMIN
dx06006
LDW_LDW_FAKTOR
dx06006
LDW_LDW_K_DYN_BESCHL
dx06006
LDW_LDW_K_DYN_BREMS
dx06006
LDW_LDW_K_STAT_BESCHL
dx06006
LDW_LDW_K_STAT_BREMS
dx06006
LDW_LDW_TP2
dx06006
LDW_LDW_TP2NL
dx06006
LDW_LDW_TP2NL_2
dx06006
LENKWINKELKORREKTUR
dx06006
LWS_VFZG_MAX
dx06006
LWS_VFZG_MIN
dx06006
MSPORT_FEST_I_HA
dx06006
MSPORT_FEST_I_VA
dx06006
NW_UNUSED
dx06006
QDW_KENNL_I_QDW_HA
dx06006
QDW_KENNL_I_QDW_HA_2
dx06006
QDW_KENNL_I_QDW_SP
dx06006
QDW_KENNL_I_QDW_SP_2
dx06006
QDW_KENNL_I_QDW_VA
dx06006
QDW_KENNL_K_DYN_VA
dx06006
QDW_KENNL_K_DYN_VA_SP
dx06006
QDW_KENNL_K_DYN_VA_SP_2
dx06006
QDW_KENNL_K_STAT
dx06006
QDW_KENNL_K_STAT_SP
dx06006
QDW_PARALL_RADSTAND
dx06006
QDW_QDW_K_DYN_FAK_HA
dx06006
QDW_QDW_LEWI_UMRECHNUNG
dx06006
QDW_QDW_TP1
dx06006
QDW_QDW_TP2NL
dx06006
QDW_QDW_V_CHARAKT_QUAD
dx06006
RDW_KENNL_I_HA
dx06006
RDW_KENNL_I_HA_SP
dx06006
RDW_KENNL_I_VA
dx06006
RDW_KENNL_I_VA_SP
dx06006
RDW_KENNL_VFZG_VA
dx06006
RDW_KENNL_VFZG_VA_SP
dx06006
RDW_RAUSCH_OFFSET_160
dx06006
RDW_RDW_HP2
dx06006
RDW_RDW_TP1
dx06006
RDW_RDW_TP2NL
dx06006
REGLER_MODE
dx06006
SOFTWARE_MODE
dx06006
SPEZIAL_MODE
dx06006
STRUKTURVERSION
dx06006
SYS_NW_SDI_MAX
dx06006
SYS_NW_SDV_MAX
dx06006
SYS_U_EEPROM_HIGH
dx06006
TOL_KENNL_TOL_A_HA
dx06006
TOL_KENNL_TOL_A_VA
dx06006
TOL_KENNL_TOL_A_VA_2
dx06006
TOL_KENNL_TOL_B_HA
dx06006
TOL_KENNL_TOL_B_HA_2
dx06006
TOL_KENNL_TOL_B_VA
dx06006
TOL_KENNL_TOL_SP
dx06006
VMESS_NB_MAX_TOL
dx06006
VMESS_NB_V_MIN
dx06006
LM_IM_E65_VERBAUT
nicht_aktiv
FEHLERSP
wert_01
MAX_PWM_PH_1_LE_BFS
wert_03
SVS_LOW
nicht_aktiv
AMS_R1_SRON
wert_07
AMS_R2_SRON_STAT
wert_07
AMS_R3_R5_SRON_MIN
wert_07
AMS_R4_SROFF
wert_07
AMS_R6_R8_ACU_ON
wert_07
AMS_R7_AV_TRIMM
wert_07
AMS_R9_R10_OVERC
wert_07
DEBUG_BYTE1
wert_07
DEBUG_BYTE2
wert_07
DEBUG_BYTE3
wert_07
LIMIT_M_DREHZAHL
wert_07
MOTOR_FREQUENZ
wert_07
RIPPLEFILTER_LP_1
wert_07
RIPPLEFILTER_LP_2
wert_07
RIPPLEFILTER_NO
wert_07
SPARE_1
wert_07
SPARE_2
wert_07
SPARE_3
wert_07
SPARE_4
wert_07
SPARE_5
wert_07
SPARE_6
wert_07
UEBERTEMP_LEVEL1
wert_07
UEBERTEMP_LEVEL2
wert_07
RO_DIAGNOSE
nicht_aktiv
RO_VERBAUT
verbaut
VMAXCODIERUNG
wert_01
SHD_BLOCK_3
wert_04
SOS_BLOCK_3
wert_03
SITZMODULTYP
nicht_aktiv
KOMFORT_SCHLIESSEN_HKL
nicht_aktiv
FAILSAVE_OPTION
wert_01
PROGRAMMPARAMETER_LM_10
wert_02
PROGRAMMPARAMETER_LM_11
wert_02
PROGRAMMPARAMETER_LM_12
wert_02
PROGRAMMPARAMETER_LM_13
wert_02
PROGRAMMPARAMETER_LM_14
wert_02
PROGRAMMPARAMETER_LM_7
wert_02
PROGRAMMPARAMETER_LM_8
wert_02
PROGRAMMPARAMETER_LM_9
wert_02
IGNORIERE_CVM_CTRL
nicht_aktiv
MAUT_ZU_ALLE_E64_AUS
aktiv
SBLK_E64_FKT_TIMEOUT
wert_01
PROGRAMMPARAM_ALC_SG_6
wert_01
PROGRAMMPARAM_ALC_SG_7
wert_01
HDC_VERBAUT
nicht_aktiv
BYTE_3_LI
wert_01
BYTE_4_LI
wert_01
ERROR_SCHEIBE_AB_HHS
nicht_aktiv
ERROR_SCHEIBE_AUF_V5
nicht_aktiv
ERROR_VSW91_8
aktiv
ERROR_VSW92_HTOP
nicht_aktiv
ERROR_VSWSUNT_RESERVE
nicht_aktiv
FEHLER_ABTAKTEN
nicht_aktiv
GESCHWINDIGKEIT_FEHLER
wert_01
HALLSENSOR_VSW72
aktiv
HALLSENSOR_VSW91_8
nicht_aktiv
HARDTOP_ERKENNUNG
nicht_aktiv
KBUS_FUNKTION
nicht_aktiv
KLA_VERR_BIS_PAUSE
wert_01
KLA_VERR_PAUSE
wert_01
LOGIK_VSW91_8
nicht_aktiv
LOGIK_VSW92_HTOP
nicht_aktiv
LOGIK_VSWSUNT_RESERVE
nicht_aktiv
PATCH_ENABLE_1
wert_01
PATCH_ENABLE_2
wert_01
RAM_CHECK
aktiv
ROM_CHECK
aktiv
SICHERN_VERDECKLAPPE
aktiv
SPERR_VENT_TEST
aktiv
SPERR_WLM_TEST
aktiv
TO_ZEIT_ABL_HS
wert_01
TO_ZEIT_ANH_HS
wert_01
TO_ZEIT_ANH_SB
wert_01
TO_ZEIT_ANH_VDK
wert_01
TO_ZEIT_WLM
wert_01
VENTIL_HALTESTELLUNG
wert_01
VENTIL_V5GO
nicht_aktiv
VKBODEN_ERKENNUNG
aktiv
ZEIT_PAUSE_PUMPE
wert_01
BACKUP_LOUDSPEAKER
aktiv
CSUM_DIMMUNG_SERIE_1
grundcode_var
CSUM_DIMMUNG_SERIE_2
grundcode_var
X_KENNLINIE
serie_scheibe_e63
Y_KENNLINIE
serie_scheibe_e63
OPT_ABSCHALTUNG_ZGM
aktiv
SBR_VERBAUT
nicht_aktiv
UEBERFALLALARM_SIM
nicht_aktiv
EA_HILFE
nicht_aktiv
EINH_MASTER_KOMBI
nicht_aktiv
RW_DAUERWISCH_FW_SPEED_2
nicht_aktiv
ONLINE_CALLSTRATEGY
use_csd_paketdata
ONLINE_DAR_TYPE
dar_us
VIDEOMODUL_CCC
nicht_aktiv
VALUE_MUW_HL
wert_04
VALUE_MUW_HR
wert_04
VALUE_MUW_VL
wert_04
VALUE_MUW_VR
wert_04
BEIKLAPPEN_B_KOMFORTSCHL
nicht_aktiv
OHNE_KOMFORT_OEFF_FBD
nicht_aktiv
OHNE_KOMFORT_SCHL_FBD
aktiv
GALLON_VAL
us
MP3
nicht_aktiv
UNTER_KORREKT_WERT
wert_03
WARN_GRENZ
wert_03
CRUISE_CTRL_CCC
nicht_aktiv
wert_01
PROGRAMMPARAMETER_LM_15
wert_02
PROGRAMMPARAMETER_LM_16
wert_02
PROGRAMMPARAMETER_LM_17
wert_02
CSUM_ZENTRALE_DIMMUNG
grundcode_var
DIMMRAD
serie_scheibe_e63
SHD_MT
wert_03
SOS_MT
wert_03
MOTORSPORT
wert_02
RDC_VERBAUT
nicht_aktiv
DWS_BREMSSCHWELLE
e64
DWS_CARID
e64
DWS_GFULA
e64
DWS_GFULB
e64
DWS_LTGACC
e64
DWS_MLTG
e64
DWS_RVW
e64
DWS_THACCLT2
e64
DWS_THIDTF
e64
DWS_THIDTR
e64
DWS_THNHTSA_F100
e64
DWS_THNHTSA_F50
e64
DWS_THNHTSA_R100
e64
DWS_THNHTSA_R50
e64
DWS_TRFAG
e64
DWS_TRLTG
e64
DWS_TRNHTSA
e64
DWS_TRNRM
e64
DWS_TRRPR
e64
DWS_TRUSP
e64
DWS_TRVEL
e64
US_VARIANTE
aktiv
AMBAND_KW
nicht_aktiv
AMBAND_LW
nicht_aktiv
AMBAND_MW
nicht_aktiv
OIL_LEVEL
aktiv
ANTENNA_DIAG_PARA
e64
ANTENNENPARA
e64
Y_RSSI_LENGTH
signallaenge_in_500_ms
Y_TAGS_BFT
verbaut
Y_TAGS_FATH_BFTH
nicht_verbaut
ABZUGSPERRE_PLOCK
aktiv
PIAU_AKUST_ENTSCH
aktiv
PIAU_AKUST_SCHAERF_KLAPPE
aktiv
STROMVERT_A3_BYTE_3/2
nicht_ueberwachen
STROMVERT_A4_BYTE_3/2
nicht_ueberwachen
STROMVERT_B1_BYTE_3/1
nicht_abschaltbar
STROMVERT_B1_BYTE_3/2
nicht_ueberwachen
STROMVERT_B2_BYTE_3/1
nicht_abschaltbar
STROMVERT_B2_BYTE_3/2
nicht_ueberwachen
STROMVERT_B3_BYTE_3/1
nicht_abschaltbar
STROMVERT_B3_BYTE_3/2
nicht_ueberwachen
STROMVERT_B4_BYTE_3/1
nicht_abschaltbar
STROMVERT_B4_BYTE_3/2
nicht_ueberwachen
STROMVERT_C1_BYTE_3/2
nicht_ueberwachen
STROMVERT_C2_BYTE_3/2
nicht_ueberwachen
STROMVERT_C3_BYTE_3/2
nicht_ueberwachen
STROMVERT_C4_BYTE_3/2
nicht_ueberwachen
SVT_ECO_VERSION_PARAMETER
wert_04
EDCK_ALIVE_ZAEHLER
nicht_aktiv
M_TAG_SKALENBELEUCHTUNG
nicht_aktiv
HKWISCH_AN_NACH_KLWECHSL
nicht_aktiv
VR_EQUIPPED_JAPAN
nicht_aktiv
SPEED_AUTO_UNFOLD
wert_01
NAVIGATION_MASK
aktiv
CBS
cbs_3
CID_CCC
cid_high
CID_COLOUR
table_1
CID_TYPE
static
KLIMA_SG_ART_CCC
high
PDC_SIGNAL
pdc_no
PDC_TYPE
full
PIA
ckm
VA_FLAP_CC
nicht_aktiv
VA_FLAP_DISPLAY_CONFIG
nicht_aktiv
VA_FLAP_HMISTART
nicht_aktiv
VA_FLAP_NAVI
nicht_aktiv
VA_FLAP_PHONE
nicht_aktiv
VA_FLAP_SVS
nicht_aktiv
EE_TRSP_DEBUG
nicht_aktiv
ECHOSCHWELLWERTE_SEITE_HI
e63
ECHOSCHWELLWERTE_SEITE_VO
e63
ALBV_BAUREIHE
e64
M_DRIVE_ACTIVE
nicht_aktiv
PWM_ALBV_OPEN
pwm_act_open_komfort
PWM_COMF_CLOSE
pwm_comf_close_komfort
PWM_COMF_OPEN
pwm_comf_open_komfort
SITZTYP
komforsitz
TEMP_MOT_OFF
temp_off_komfort
BAUART_MK60
e63
M_GETRIEBE
sequentiell
ANLASSERSPERRE_KPS
nicht_aktiv
KLSTRG_TESTER
nicht_aktiv
AQ_SENSACK_RES_MAX
e64_n62
AQ_SENSACK_RES_MIN
e64_n62
FG_A_QUER_ROH_HIGH
e64_n62
FG_A_QUER_ROH_LOW
e64_n62
ANZ_SCHEIBEN_AB_KOMPL
wert_01
ZEIT_NACHLAUF_PUMPE
wert_01
SBR_AKUSTISCH_SGM
nicht_aktiv
SBR_BEIFAHRER_SGM
nicht_aktiv
SBR_FAHRER_SGM
nicht_aktiv
LW_DELTA_MIN
wert_01
T_RV_MIN
wert_01
BFD_1_DEAKTIV_BEI_NSL
nicht_aktiv
K_DREHMOMENT
nicht_aktiv
ZK1_ZF_STVR
PORTABLE_BT
nicht_aktiv
SCHEIBE_MIT_KOMFORT
aktiv
SCHEIBE_MIT_KOMFORT_ZU
aktiv
W_FERNSTART
nicht_aktiv
KOMFORT_EJECT
nicht_aktiv
PA_CHIPCARD_ACTIVE
aktiv
PA_DISABLE_HK_REV
nicht_aktiv
PA_HK_BACK_IR_SEARCH
nicht_aktiv
PA_HK_INTERIOR_SEARCH
nicht_aktiv
PA_HK_PGS_SEARCH
aktiv
PA_HK_REOPEN_CTL_DEP
aktiv
PA_HK_REOPEN_CTR_LOCK
nicht_aktiv
PA_HK_RSCR_ACTIVE
nicht_aktiv
PA_SILENTTIMEOUT
wert_01
BEHOERDEN_FZG
nicht_aktiv
BEHRD_FZG_ASYNCHRON_BLK
nicht_aktiv
DUAL_SP__AL_L
nicht_aktiv
DUAL_SP__AL_R
nicht_aktiv
DUAL_SP__FL_L
aktiv
DUAL_SP__FL_R
aktiv
DUAL_SP__KZL_L
aktiv
DUAL_SP__KZL_R
aktiv
DUAL_SP__NSL_L
nicht_aktiv
DUAL_SP__NSL_R
nicht_aktiv
DUAL_SP__NSW_L
aktiv
DUAL_SP__NSW_R
aktiv
DUAL_SP__SL_V_L
aktiv
DUAL_SP__SL_V_R
aktiv
DUAL_SP_PARAMETER
wert_01
GESCHW_DOWN
wert_02
GESCHW_UP
wert_02
PROZENT_EE
wert_01
PWM_ANSTEUERUNG_AL
wert_01
PWM_ANSTEUERUNG_BLK_H
wert_02
wert_02
PWM_ANSTEUERUNG_BLK_V_2
wert_03
PWM_ANSTEUERUNG_FL
wert_02
PWM_ANSTEUERUNG_NSL
wert_03
PWM_ANSTEUERUNG_NSW
wert_01
PWM_ANSTEUERUNG_RFS
wert_01
wert_02
wert_04
wert_02
wert_03
QUITT_BLK_IGNORE_MOTORH
aktiv
ABSTANDSSTUFE_INIT_2
wert_02
ABSTANDSSTUFEN
wert_02
ABSTANDSVERSTELLRICHTUNG2
wert_02
BREMSSYSTEM_2
wert_02
EINBAUORT_HORIZONTAL_2
wert_03
GETRIEBE_2
wert_01
SCHWELLE_TOR_SYS_GRENZE
wert_02
TOR_DISTANZ_CHAR_VREL_2
wert_02
TOR_DISTANZ_FAKTOR_AUS_2
wert_02
TOR_DISTANZ_FAKTOR_EIN_2
wert_02
TOR_DISTANZ_MIN_2
wert_02
TOR_SYMBOL_FA_UEBERTRET_2
wert_02
TRIEBSTRANGVERSTAERKUNGEN
wert_02
VSA_SET_2
wert_02
VSETZ_MAX_2
wert_02
VSETZ_MIN_2
wert_02
RDC_CCC
nicht_aktiv
RING_CCC
nicht_aktiv
EQU_FILTER_SET
e60_stereo
LOUDNESS_TEST
off
SDVC_IPC_CTRL
off
XOVER_FILTER_SET
e60_stereo
CBS_MODE
level_3
PIA_LEVEL
level_1
US_BLUE
nicht_aktiv
ACK_2_AIRBAG
nicht_aktiv
ALIVE_SIGNAL
aktiv
ANLASSERSPERRE_P
aktiv
AUSWERTUNG_P_HW
aktiv
CLASS_PWR
keine
DELAY_KLR_AUS
wert_02
ELV_TESTER
nicht_aktiv
STARTABBRUCH_P
aktiv
AUDIO_SOUND_CTRL_BUNDLE
e64
ALC_SCHWENK_BEI_S_FLC
nicht_aktiv
FLC_OHNE_RLS
nicht_aktiv
HEIMLEUCHTEN_SEND_OPT
wert_04
UNTERDRUECK_BL_BLITZEN
aktiv
CSC_QUERBESCHL_MAX2
wert_02
SSC_VERZOEGERUNG_MAX_2
wert_02
VERZOEGERUNG_MAX_2
wert_02
SBR_OPTISCH_SGM
nicht_aktiv
RR_SCHALTER
nicht_aktiv
AUTO_CLOSE_CYCLE
wert_02
AUTO_CLOSE_SEGMENT
wert_02
AUTO_CLOSE_WINKEL
wert_02
SENDER_TAB_HGL
aktiv
KL_HS_GRAD_HIGH
wert_01
VENTILSTROM_KALIBRIERUNG
wert_03
TIPP_BLK_ABBRUCH
aktiv
TIPP_BLK_ABBRUCH_IMMER
aktiv
KLR_EIN_GESCHW
aktiv
WE_MODE
nicht_aktiv
STELLGROESSE
wert_03
CALL_WAITING_ENABLE
nicht_aktiv
CAS_KEY_DATA_METHOD
wert_01
AUTO_DRV_LIGHT
nicht_aktiv
C7501_TAGFAHRLICHT
fkt_gesperrt
DAY_RUN_LIGHT
nicht_aktiv
HDC
nicht_aktiv
ANLASSERSCHUTZ_3SEK
aktiv
SPERRE_KLRAUS_SST
nicht_aktiv
BLOCK_AUS_BEI_AC
wert_03
MAX_WINKEL_MMI
nicht_aktiv
TEMPBEREICH
wert_03
ECU_BLOCK
wert_02
ECU_BLOCK_1
glashubdach
SHD_BLOCK_01
wert_05
SHD_BLOCK_02
wert_05
SHD_BLOCK_03
wert_05
SHD_POS_1
wert_05
SHD_POS_2
wert_04
SIEMENS_RES_3000_27
wert_05
SOS_BLOCK_01
wert_04
SOS_BLOCK_03
wert_05
SOS_POS_1
wert_05
SOS_POS_2
wert_05
VERSIONSINDEX
wert_01
KENNLINIE_A_MAX_STUETZ_1
wert_02
KENNLINIE_A_MAX_STUETZ_2
wert_02
KENNLINIE_A_MAX_STUETZ_3
wert_02
KENNLINIE_A_MAX_STUETZ_4
wert_02
KENNLINIE_A_MAX_STUETZ_5
wert_02
KENNLINIE_A_MAX_STUETZ_6
wert_02
MOTOR_DREHM_MAX_CHAR_2
wert_05
MOTOR_DREHZAHL_MAX_2
wert_01
MOTOR_TRAEGHEITSMOMENT
wert_05
EINSTIEGSHILFE_DEFAULT
nicht_aktiv
EINSTIEGSHILFE_PORT
nicht_aktiv
PA_HK_REOPEN_INDICATE
aktiv
PA_HK_REV_ZYKL
aktiv
PA_MONITOR_ACTIVE
nicht_aktiv
RSSI_THRESHOLD
wert_02
SEL_ZV_SENDER_DEFAULT
aktiv
SEL_ZV_SENDER_PORT
aktiv
STARTWUNSCH_KL50
aktiv
VER_AUT_X_MIN_DEFAULT
nicht_aktiv
VER_AUT_X_MIN_PORT
nicht_aktiv
VERRIEGELN_XKM/H_DEFAULT
nicht_aktiv
VERRIEGELN_XKM/H_PORT
nicht_aktiv
RAIN_LIGHT_SENSOR
nicht_aktiv
SPEED_MODE
speed_mode_intern
CID_EXT_CCC_H
size_640
SIGNAL_HK
aktiv
KATENTFALLCODIERUNG
wert_00
OLULCODIERUNG
wert_00
STARTABBR_KLR
nicht_aktiv
TEST_DUTY_CYCLE
aktiv
TEST_LED_KS_AKTIV
aktiv
STANDLUEFTUNG_CCC
aktiv
DELAY_DETECT_TIME
e64
DELAY_STD_TIME
e64
OVER_COUNT_CLR_TIME
e64
REJECT_STD_SUS
e64
REJECT_SUS
e64
SUS_COR_THRESHOLD
e64
MIT_PUMPE_BEI_VERR
nicht_aktiv
SCHEIBE_BEI_TRA_MODE_AUS
aktiv
ZEIT_BEDIENUNG_FENSTER
wert_01
CSUM_AUSSTATTUNG_2
grundcode_var
OEL_MAX_WERT
wert_01
FH_SEQENZIELL_KOMF_VERD
aktiv
FH_SEQUENZIELL_ZENTRAL
aktiv
MDRIVE
nicht_aktiv
MDRIVE_ALBV
nicht_aktiv
MDRIVE_SMG
aktiv
SVS_HIGH
aktiv
MAX_ALBV_POS
max_pos_komfort
PWM_INIT
pwm_init_komfort
BLUETOOTH_NODES_CCC
nicht_aktiv
HUD_M
nicht_aktiv
MAX_PHONE_VOL
standard
MFL_MENU
nicht_aktiv
HEIMLEUCHTEN_KL58G_1
aktiv
QUITT_BLK_ZU_CHECK_1
aktiv
VOLUME_SECTIONS_1
wert_01
DELAY_KEY_PLUG
wert_01
AUX_CONFIG
mounted
VA_BPI
nicht_aktiv
CSUM_M_SPORT
grundcode_var
DREHZAHL_KENNLINIE
wert_01
M_PARAMETER
wert_01
M_SPORT
nicht_aktiv
AKIRA_MEMS/GATS
gats
OUTPUT_GAIN_FRONTLEFT
wert_01
OUTPUT_GAIN_FRONTRIGHT
wert_01
OUTPUT_GAIN_REARLEFT
wert_01
OUTPUT_GAIN_REARRIGHT
wert_01
OUTPUT_GAIN_SUBWOOFERL
wert_01
OUTPUT_GAIN_SUBWOOFERR
wert_01
HIP
aktiv
RDS_AF_FUNKTION_CCC
rds_aus
SMART_BEAM
nicht_aktiv
AUDIO_SYSTEM_MASK
e60_top_hifi
BATT_LEIT_DIAG
aktiv
BATT_PARAM
e64_us
EAM_TIMEDELAY
e64_us
EBS_FAHRER
nicht_aktiv
EBS_FOND_BEIFAHRER
nicht_aktiv
EBS_FOND_FAHRER
nicht_aktiv
FR_HE_PARAM_1
e64_us
FR_HE_PARAM_2
e64_us
FR_HE_PARAM_3
e64_us
FR_HE_PARAM_4
e64_us
FR_HE_PARAM_5
e64_us
GURTKONTAKT_FOND_BFAHRER
nicht_aktiv
GURTKONTAKT_FOND_FAHRER
nicht_aktiv
HECK_PARAM
e64_us
KOEPFBAG_BEIFAHRER
nicht_aktiv
KOEPFBAG_FAHRER
nicht_aktiv
KOEPFST_BEIFAHRER
nicht_aktiv
KOEPFST_FAHRER
nicht_aktiv
KOPPLUNG_SBR_POS
nicht_aktiv
LANGES_AHPS
curtain
PARAMETERSATZ_0
e64_us
PREPROC_PARAM
e64_us
ROLL_PARAM_1
e64_us
ROLL_PARAM_2
e64_us
SEITEN_PARAM
e64_us
SIDEBAG_BEIFAHRER
aktiv
SIDEBAG_FAHRER
aktiv
SIDEBAG_FOND_BEIFAHRER
nicht_aktiv
SIDEBAG_FOND_FAHRER
nicht_aktiv
UP_FR_PARAM_1
e64_us
UP_FR_PARAM_2
e64_us
UP_FR_PARAM_3
e64_us
UPFRONT_BEIFAHRER
aktiv
UPFRONT_FAHRER
aktiv
HEIZUNG_TYP
wert_02
KHV_HALL_BFS
nicht_aktiv
KHV_KENNFELD
nicht_aktiv
KHV_MOTOR_BFS
aktiv
KHV_WEG_VERZ
wert_00
KUNDEN_MEMORY_BFS
nicht_aktiv
LBV_HALL_BFS
nicht_aktiv
LBV_MOTOR_BFS
nicht_aktiv
LEHNENVER_KONTAKT
wert_00
LKV_HALL_BFS
nicht_aktiv
LKV_MOTOR_BFS
nicht_aktiv
LNV_HALL_BFS
nicht_aktiv
SHV_HALL_BFS
nicht_aktiv
SLV_BLOCK_KENN_PARM_1_BFS
wert_03
SLV_BLOCK_KENN_PARM_3_BFS
wert_03
SLV_BLOCK_KENN_PARM_4_BFS
wert_03
SLV_BLOCK_KENN_PARM_5_BFS
wert_03
SLV_HALL_BFS
nicht_aktiv
SNV_HALL_BFS
nicht_aktiv
STV_HALL_BFS
nicht_aktiv
STV_MOTOR_BFS
aktiv
TIMEOUT_NACH_FEHLSPANNUNG
wert_01
VERSTELL_SCHALTER_TYP
wert_05
CKM_BEH_AUSLOESE_FAS
wert_02
FEH_MOTOR_FAS
nicht_aktiv
KA30A_C_AUT_SITZV_1
nicht_aktiv
KA30A_C_AUT_SITZV_2
nicht_aktiv
KA30A_C_AUT_SITZV_3
nicht_aktiv
KA30A_C_AUT_SITZV_4
nicht_aktiv
KA30A_D_AUT_SITZV
nicht_aktiv
KA30A_S_AUT_SITZV
nicht_aktiv
KHV_HALL_FAS
aktiv
KHV_MOTOR_FAS
aktiv
KUNDEN_MEMORY_FAS
aktiv
LBV_HALL_FAS
nicht_aktiv
LBV_MOTOR_FAS
nicht_aktiv
LKV_HALL_FAS
nicht_aktiv
LKV_MOTOR_FAS
nicht_aktiv
LNV_HALL_FAS
aktiv
SHV_HALL_FAS
aktiv
SLV_BLOCK_KENN_PARM_1_FAS
wert_03
SLV_BLOCK_KENN_PARM_3_FAS
wert_03
SLV_BLOCK_KENN_PARM_4_FAS
wert_03
SLV_BLOCK_KENN_PARM_5_FAS
wert_03
SLV_HALL_FAS
aktiv
SNV_HALL_FAS
aktiv
STV_HALL_FAS
aktiv
STV_MOTOR_FAS
aktiv
SFY_ID_WAHL
aktiv
MOTORISIERUNG
wert_01
NAVI_KOPPLUNG
wert_04
MP3_CCC
full
GESCHW_TEMP_BEGR
wert_02
MAX_TEMP_BEGR
wert_02
DISPLAY_LOG7_SYMBOL
aktiv
E61
nicht_aktiv
IBUS_R_GANG
nicht_aktiv
I_REGLERFAKTOR_FAS
wert_01
KHV_BLOCK_KENN_PARM_1_FAS
wert_01
KHV_BLOCK_KENN_PARM_3_FAS
wert_01
KHV_BLOCK_KENN_PARM_4_FAS
wert_01
KHV_BLOCK_KENN_PARM_5_FAS
wert_01
KHV_SOFTBLOCK_FAS
wert_02
LBV_BLOCK_KENN_PARM_1_FAS
wert_01
LBV_BLOCK_KENN_PARM_3_FAS
wert_01
LBV_BLOCK_KENN_PARM_4_FAS
wert_01
LBV_BLOCK_KENN_PARM_5_FAS
wert_01
LBV_SOFTBLOCK_FAS
wert_02
LKV_BLOCK_KENN_PARM_1_FAS
wert_01
LKV_BLOCK_KENN_PARM_3_FAS
wert_01
LKV_BLOCK_KENN_PARM_4_FAS
wert_01
LKV_BLOCK_KENN_PARM_5_FAS
wert_01
LKV_SOFTBLOCK_FAS
wert_02
LNV_BLOCK_KENN_PARM_1_FAS
wert_01
LNV_BLOCK_KENN_PARM_3_FAS
wert_01
LNV_BLOCK_KENN_PARM_4_FAS
wert_01
LNV_BLOCK_KENN_PARM_5_FAS
wert_01
LNV_SOFTBLOCK_FAS
wert_02
P_REGLERFAKTOR_FAS
wert_01
SHV_BLOCK_KENN_PARM_3_FAS
wert_01
SHV_BLOCK_KENN_PARM_4_FAS
wert_01
SHV_BLOCK_KENN_PARM_5_FAS
wert_01
SHV_SOFTBLOCK_FAS
wert_02
SLV_SOFTBLOCK_FAS
wert_02
SNV_BLOCK_KENN_PARM_1_FAS
wert_01
SNV_BLOCK_KENN_PARM_3_FAS
wert_01
SNV_BLOCK_KENN_PARM_4_FAS
wert_01
SNV_BLOCK_KENN_PARM_5_FAS
wert_01
SNV_SOFTBLOCK_FAS
wert_02
STV_BLOCK_KENN_PARM_1_FAS
wert_01
STV_BLOCK_KENN_PARM_3_FAS
wert_01
STV_BLOCK_KENN_PARM_4_FAS
wert_01
STV_BLOCK_KENN_PARM_5_FAS
wert_01
STV_SOFTBLOCK_FAS
wert_02
UEBERLAST
wert_02
I_REGLERFAKTOR_BFS
wert_01
KHV_BLOCK_KENN_PARM_1_BFS
wert_01
KHV_BLOCK_KENN_PARM_3_BFS
wert_01
KHV_BLOCK_KENN_PARM_4_BFS
wert_01
KHV_BLOCK_KENN_PARM_5_BFS
wert_01
KHV_SOFTBLOCK_BFS
wert_02
LBV_BLOCK_KENN_PARM_1_BFS
wert_01
LBV_BLOCK_KENN_PARM_3_BFS
wert_01
LBV_BLOCK_KENN_PARM_4_BFS
wert_01
LBV_BLOCK_KENN_PARM_5_BFS
wert_01
LBV_SOFTBLOCK_BFS
wert_02
LKV_BLOCK_KENN_PARM_1_BFS
wert_01
LKV_BLOCK_KENN_PARM_3_BFS
wert_01
LKV_BLOCK_KENN_PARM_4_BFS
wert_01
LKV_BLOCK_KENN_PARM_5_BFS
wert_01
LKV_SOFTBLOCK_BFS
wert_02
LNV_BLOCK_KENN_PARM_1_BFS
wert_01
LNV_BLOCK_KENN_PARM_3_BFS
wert_01
LNV_BLOCK_KENN_PARM_4_BFS
wert_01
LNV_BLOCK_KENN_PARM_5_BFS
wert_01
LNV_SOFTBLOCK_BFS
wert_02
P_REGLERFAKTOR_BFS
wert_01
SHV_BLOCK_KENN_PARM_3_BFS
wert_01
SHV_BLOCK_KENN_PARM_4_BFS
wert_01
SHV_BLOCK_KENN_PARM_5_BFS
wert_01
SHV_SOFTBLOCK_BFS
wert_02
SLV_SOFTBLOCK_BFS
wert_02
SNV_BLOCK_KENN_PARM_1_BFS
wert_01
SNV_BLOCK_KENN_PARM_3_BFS
wert_01
SNV_BLOCK_KENN_PARM_4_BFS
wert_01
SNV_BLOCK_KENN_PARM_5_BFS
wert_01
SNV_SOFTBLOCK_BFS
wert_02
STV_BLOCK_KENN_PARM_1_BFS
wert_01
STV_BLOCK_KENN_PARM_3_BFS
wert_01
STV_BLOCK_KENN_PARM_4_BFS
wert_01
STV_BLOCK_KENN_PARM_5_BFS
wert_01
STV_SOFTBLOCK_BFS
wert_02
BFD_US_CC_MELD
nicht_aktiv
SMART_BEAM_ZUSTAND
nicht_aktiv
AFH_DOA
aktiv
GEARMOMENTREGLER_MAX_HA_2
wert_00
GEARMOMENTREGLER_MIN_HA_2
wert_00
LENKWINKELKENNLINIE_2
wert_00
INPUT_SCALING_SUB2
wert_02
AIRBAG_BEIFAHRER_ACSM
aktiv
AIRBAG_FAHRER_ACSM
aktiv
BEIFAHRERBAG_STUFE2_ACSM
aktiv
BPLUS_TRENNUNG1_ACSM
aktiv
CC_GURTWARNUNG_ACSM
aktiv
aktiv
FR_HE_PARAM_6
e64_us
GURTKONTAKT_BEIFAHRER
aktiv
GURTKONTAKT_FAHRER
aktiv
GURTSTRAFFER_BEIFAHRER
aktiv
GURTSTRAFFER_FAHRER
aktiv
GURTSTRAMM_SEITENCRASH
nicht_aktiv
ITS_SCHRAEGCRASH
nicht_aktiv
KNIEBAG_BEIFAHRER
aktiv
KNIEBAG_FAHRER
aktiv
MRSA_TUERE
aktiv
OC3_ACSM
aktiv
POL_ACSM
aktiv
POS_ACSM
nicht_aktiv
ROC
aktiv
ROLLOVER_OPTION
aktiv
SBE1_ACSM
nicht_aktiv
SBE1_STATUS_VERZ_ACSM
nicht_aktiv
SBR_BEIFAHRER_ACSM
aktiv
SBR_FAHRER_ACSM
aktiv
SLV_BEIFAHRER
aktiv
SLV_FAHRER
aktiv
US_SCHWELLEN
aktiv
SBR_OPTISCH_BF_SGM
nicht_aktiv
SBR_OPTISCH_FA_SGM
nicht_aktiv
CODIERINDEX_ABC
wert_01
S_KPD2T2
wert_01
FL_ASSIST_FUNKTIONS_ANZ
nicht_aktiv
LWR_DIAG_PARAM
wert_01
LWR_HEBEL
wert_03
LWR_TERMO_MODEL_EIN
aktiv
PAY_TMC_CONTROL
nicht_aktiv
REGLER_INIT_SCHNELLH_KI
wert_01
AUC_MKIV
aktiv
ASP_BEIKLAPPEN
nicht_aktiv
ASP_BORDSTEIN
aktiv
ASP_LIN_SPIEGEL
aktiv
ASP_MEMORY
aktiv
ASP_STANDHEIZUNG
nicht_aktiv
FH_COUPE_TUER
aktiv
FH_USA_REVERSE
aktiv
FKT1_E64
aktiv
FKT2_E64
aktiv
GESCHW_WERTE_KOMFORT_KGM
wert_03
GESCHWIN_WERTE_SPORT_KGM
wert_03
STROMWERTE_KOMFORT_KGM
wert_03
STROMWERTE_SPORT_KGM
wert_03
SVT_SCHRITTE
wert_01
ASL
aktiv
BSW
aktiv
EVB
aktiv
HBA_DXC_8
wert_03
HHC
aktiv
HILLDESC_DXC_8
nicht_aktiv
HPS
aktiv
HVV
aktiv
RPA_WARNSCHWELLWERTE_1
wert_04
RPA_WARNSCHWELLWERTE_2
wert_04
RPA_WARNSCHWELLWERTE_3
wert_04
RPA_WARNSCHWELLWERTE_4
wert_04
SST
aktiv
ABSCHALTPKT_ALBV_OEFF
wert_01
ABSCHALTPKT_MEM_OEFF
wert_01
HECKWISCHER
nicht_aktiv
LENKSAULENVERSTELLUNG
elektrisch
CC_HINWEIS_BLI_M_O_GONG_2
aktiv
SCHWELLE_EIN_B_BLIND_2
wert_01
STRECKE_B_BLIND_2
wert_01
VAR_BLIND_REACT_2
nicht_aktiv
HECKKLAPPE_RL_BL_OPT
nicht_aktiv
PWM_ANSTEUERUNG_NSL_BL
wert_01
REGLER_INIT_SCHNELLH_LE
wert_01
FBD_HKL_NUR_ER
nicht_aktiv
NAVIGATION_FLOTTENMODUS
nicht_aktiv
DIAGN_OFFSET
wert_01
FH_RECHTSLENKER
nicht_aktiv
AD_GAIN_2
wert_12
GATS_SMS_DESTIN_BACKUP
atxus_prod
GATS_SMS_DESTIN_DEFAULT
atxus_prod
GATS_SMSC_OR_AMPS_BACKUP
atxus_prod
GATS_SMSC_OR_AMPS_DFLT
atxus_prod
ACKERMANN_FLAG
wert_01
K_VOREIL_X_NEW_FLAG
e64_n62
MOM_VERT_AQ_ADD_KNICK
e64_n62
MOM_VERT_AQ_ADD_STEIGUNG
e64_n62
CBS_EINH_09H
wegbas
CBS_SCEN_09H
nicht_aktiv
CBS_STAT_09H
sperre
DSC_ALLRAD_CC_WAHL
nicht_aktiv
FDC_ID_MONITOR
aktiv
HDC_ID_MONITOR
nicht_aktiv
LDM_ALIVE_ZAEHLER
nicht_aktiv
LDM_CSUM_MONITOR
nicht_aktiv
LDM_ID_MONITOR
nicht_aktiv
TCM_ALIVE_ZAEHLER
aktiv
TCM_ID_MONITOR
aktiv
RLS_AUSSTATTUNG
aktiv
DELAY_PWR_DOWN_INIT_JAPAN
wert_01
PA_HA_SEARCH_ACTIVE
nicht_aktiv
BROSE1
wert_03
BROSE2
wert_03
BROSE3
wert_03
BROSE4
wert_03
BROSE5
wert_03
BROSE6
wert_03
BROSE7
wert_03
BROSE8
wert_03
LAENDERVARIANTE_DAB
ece
NON_TELEMATIC_E_CALL_NR
nummer2
FILTER_GIERR
wert_04
FZG_RADSTAND_NVC
wert_04
LENK_UEBERSETZUNG_NVC
wert_04
PANN_RATE
wert_04
POI
wert_04
TAU_GIERR_LENKWINKEL
wert_04
V_ZOOM
wert_12
WINKEL_GERADEAUS_10
wert_04
MP3CDC
nicht_aktiv
IBOC_CCC
nicht_aktiv
ANTRIEBSDEFINITION
heckantrieb
FEHLERMATRIX
wert_01
KL15HW01_ALLWAYS
aktiv
PA_TRUNK_HIGH
nicht_aktiv
SENDMHKCCMLIMIT
wert_02
S_FAHRWERKVARIANTE
e64_basis_n62_ars
S_FAHRZEUGVARIANTE
e64_basis_n62_ars
V_MIN_FUER_A_MAX
wert_01
EL_INTERLOCK
aktiv
NIC
aktiv
ALC_DISABLE_AUSGL_NICK_GW
nicht_aktiv
HECKD_REV_BLK_DOPPELB
aktiv
HECKDECK_REVERS_BLK
wert_01
MOTORISIERUNG_1
wert_01
NIVI_DISPLAY_OPTIONS
main_or_fullscreen
RVC
nicht_aktiv
RVC_CONNECTED_TO_VM
nicht_aktiv
RVC_DISPLAY_OPTIONS
main_or_fullscreen
TOWBAR
nicht_aktiv
PROGRAMMPARAMETER_LM_18
wert_01
PROGRAMMPARAMETER_LM_19
wert_01
FAHRSCHLAUCHBREITE_FSK
wert_02
RDU_CONTROL
nicht_aktiv
DSC_MIT_RPA_CC
aktiv
SVS_MICROPHONE_PATH
analog
NEUSEELAND
nicht_aktiv
LWS_1
wert_01
HS_ENABLE_OPEN
nicht_aktiv
EMPFINDLICHKEIT_VERSTELL
aktiv
S_DEGR_NACHLFIL
e64_basis_n62_ars
S_FZGDYN_ALL
e64_basis_n62_ars
S_PUMP_LG_ABH
e64_basis_n62_ars
S_TFILTER_LW_DOT
e64_basis_n62_ars
S_V_DOT_PUMP_ALL
e64_basis_n62_ars
ALC_NSW_BEDIEN_MOEGL
aktiv
ALC_NSW_SPERREN
nicht_aktiv
CC_MELD_SW_CI_NOT_AKTIV
nicht_aktiv
CI_KODIERDATEN
wert_01
FL_ASSIST_CC_NOT_AKTIV
aktiv
FL_ASSIST_ZUST_22_32
nicht_aktiv
NEUE_FAHRT_BEI_SICHERN
aktiv
NEUE_FAHRT_BEI_SLEEP
aktiv
NEUE_FAHRT_KL_15_NACHL
nicht_aktiv
NSL_VORHEIZ_BEI_BL
wert_01
ALTER_NEUER_BEDIENHEBEL
aktiv
SYNCML
aktiv
PWM_ALBV_CLOSE_KEN_1
wert_01
PWM_ALBV_CLOSE_KEN_3
wert_01
ALLOW_GPS
aktiv
BMW_DEALER_CCC
aktiv
BMW_HOTLINE_CCC
aktiv
BMW_MOBILE_CCC
aktiv
DAY_RUN_LIGHT_CCC
nicht_aktiv
DSC
nicht_aktiv
ROLLER_COVER
nicht_aktiv
ZBE
high
BLUETOOTH_NODES_MASK
profil_2
BMW_DEALER_MASK
aktiv
BMW_HOTLINE_MASK
aktiv
BMW_MOBILE_MASK
aktiv
DAB
nicht_aktiv
DAB_BAND_SETTINGS
nicht_aktiv
DAB_FM_SWITCH
nicht_aktiv
DAY_RUN_LIGHT_MASK
nicht_aktiv
IBOC
nicht_aktiv
LAENDERVARIANTE_FLA
us
KL_SENSOR_PWM_NULL_RE
wert_01
PWM_VER_EINHEIT
wert_03
SENSOR_PWM_NEG
wert_02
SENSOR_VALEO
wert_02
STROM_HALT_KL
wert_01
STROM_NORMAL_KL
wert_01
STROM_RAMPE_KL
wert_01
SW_DATEN_BL_1
kennlinie_01
SW_DATEN_BL_2
kennlinie_01
SW_DATEN_BL_3
kennlinie_01
SW_DATEN_BL_4
kennlinie_01
WINKEL_ZUM_PWM
wert_03
KL_SENSOR_PWM_NULL_LI
wert_01
KL_PREDRIVE_AUSWAHL_1
wert_01
BLINKER_AUSSTATTUNG
nicht_aktiv
CSUM_ANZEIGEMANAGEMENT
grundcode_var
ENTERTAINMENT_AUSSTATTUNG
nicht_aktiv
FARBE_GRUEN2
farbe_aktiv
FKT_AUSWAHL2_DEFAULT
wert_01
FKT_AUSWAHL2_KEY_1
wert_01
FKT_AUSWAHL2_KEY_2
wert_01
FKT_AUSWAHL2_KEY_3
wert_01
FKT_AUSWAHL2_KEY_4
wert_01
M_SPORT_HUD
nicht_aktiv
PU_TIMER
pu_aktiv
TELEFON_AUSSTATTUNG
nicht_aktiv
SVR_CONTROL
aktiv
CCM_AHV_SG
keine_ccm
DIM_MODE
standard
LRA_VERBAUT
nicht_aktiv
WECHSELKRV_FUNKT
wert_01
VORFELDBELEUCHTUNG_KGM
aktiv
SERVOTRONIK_KGM
aktiv
DELTA_PSI_BETA_LIMITKORR2
wert_00
MDYNAMIC_MODE_USA
nicht_aktiv
UEBERSTEUERN_MUE_0_2
wert_00
UEBERSTEUERN_MUE_1_2
wert_00
ALKS
nicht_aktiv
KOMPRESSORKUPPLUNG
nicht_aktiv
ANZ_TAGE_VERBAUT
wert_01
VARIANTE_AFS
nicht_aktiv
S_SSC
e64_basis_n62_ars
CBS_SCEN_07H_1
nicht_aktiv
CBS_SCEN_10H_1
aktiv
CBS_SCEN_12H_1
nicht_aktiv
PHONEBOOK_PRIORITY
wert_01
FH_SEQUENZIELL_KOMF_VERD
aktiv
VSET_PLUS1_ACC2
nicht_aktiv
ISO_OBD
wert_04
VCH
aktiv
CBS_SCEN_13H_1
nicht_aktiv
CODIER_CHECK
aktiv
LOGISTIK_CHECK
aktiv
VMAXCODIERUNG_ALPINA
wert_00
ALC_FAILSAVE_AHL
nicht_aktiv
FL_AUS_BEI_BIX_IN_S_FLC
nicht_aktiv
FSP_ISP_SPERREN
wert_01
FSP_MASKIERUNG
wert_01
ISP_MASKIERUNG
wert_01
CKS_BL
wert_06
DEF_POSIT_LWR_LI
wert_01
KL_MAX_WERR_SPEED
wert_01
KL_MAX_WERT_START
wert_01
KL_SCHRITT_ABST_REF2_LI
wert_02
KL_SCHRITT_ANZ_REF2
wert_02
KL_TREIBER_BEW_LI
wert_02
LWR_ABST_POSIT
wert_04
LWR_MAX_WERR_SPEED
wert_01
LWR_TREIBER_BEW_LI
aktiv
STROM_NORMAL_LWR
wert_02
STROM_RAMPE_LWR
wert_02
DEF_POSIT_LWR_RE
wert_01
KL_SCHRITT_ABST_REF2_RE
wert_02
KL_TREIBER_BEW_RE
wert_02
LWR_TREIBER_BEW_RE
aktiv
NTC_GETAKTET
nicht_aktiv
IGRCODIERUNG
nicht_aktiv
XENONCODIERUNG
aktiv
RAMPE3_BL_0_LI
kennlinie_01
RAMPE3_BL_0_RE
kennlinie_01
BRIGHTNESS_DEFAULT
wert_01
BRIGHTNESS_KEY_1
wert_01
BRIGHTNESS_KEY_2
wert_01
BRIGHTNESS_KEY_3
wert_01
BRIGHTNESS_KEY_4
wert_01
BRIGHTNESS_UNPERS_AREA
wert_01
CBD_CAM_HOR_ANGLE
wert_01
CBD_CAM_RESOLUTION
wert_01
CBD_CCC_FULL_CENTRE
wert_01
CBD_CCC_SPLIT_CENTRE
wert_01
CBD_NO_PANN_RATE
wert_04
CBD_VERTICAL_DEFAULT
wert_04
CHECK_CONTROL
aktiv
CONTRAST_DEFAULT
wert_01
CONTRAST_KEY_1
wert_01
CONTRAST_KEY_2
wert_01
CONTRAST_KEY_3
wert_01
CONTRAST_KEY_4
wert_01
CONTRAST_UNPERS_AREA
wert_01
GAMMA_CORRECTION_TABLE
wert_01
NACHRICHT_NEIGUNSWINKEL
aktiv
PANZOOMSPLIT_DEFAULT
alles_aktiv
PANZOOMSPLIT_KEY_1
alles_aktiv
PANZOOMSPLIT_KEY_2
alles_aktiv
PANZOOMSPLIT_KEY_3
alles_aktiv
PANZOOMSPLIT_KEY_4
alles_aktiv
PANZOOMSPLIT_UNPERS
alles_aktiv
REGENINTENSITAET
wert_01
DYNAMIK_FLAG_ACC2
nicht_aktiv
AXV_EPS_AXV_REF_SIS
default
DY_LANE_WIDTH_INIT
default
DY_LANE_WIDTH_INIT_RLC
default
DY_LANE_WIDTH_MIN
default
FUS_DY_LRR
default
FUS_DY_SRR_LINKS
serie_e63
FUS_DY_SRR_RECHTS
serie_e63
GATEW_APP_AKTIV
wert_02
GATEW_DIA_AKTIV
wert_02
GATEW_NM_AKTIV
wert_02
LANE_WIDTH_ADAPT_RLC_AC
default
VARIANTE_ANTRIEB
ipm
VARIANTE_BREMSE
ecba
WHEEL_BASE_LDM
default
VMAXCODIERUNG_MSD
wert_01
RPA
aktiv
HKL_LIFT_BEI_CA
nicht_aktiv
SPERRE_HKL_KEY_VALID
aktiv
FH_CCM_259_DENORM
aktiv
FH_CCM_259_PANIC
aktiv
FH_CCM_261
aktiv
FH_EKS_AKTIV
aktiv
FH_PANICMODE_BFT
aktiv
FH_PANICMODE_FAT
aktiv
MAN_MIT_EKS_BFT
aktiv
MAN_MIT_EKS_FAT
aktiv
B_ENABLE_RIGHT_HAND_DRV_2
ll
S_DMEAYVA_2
e64_basis_n62_ars
S_DMEPUMPMOMENT_2
e64_basis_n62_ars
S_DUTY_MAX_2
e64_basis_n62_ars
S_ECO_PUMP_VOL_FLOW_2
e64_basis_n62_ars
S_HINRUECKFILT_SW_2
e64_basis_n62_ars
S_I_SF_AY_VARIANTES_2
e64_basis_n62_ars
S_I_SF_DEH_VARIANTES_2
e64_basis_n62_ars
S_I_SF_DPSI_VARIANTES_2
e64_basis_n62_ars
S_I_SF_MODEL_VARIANTES_2
e64_basis_n62_ars
S_I_SF_VX_VARIANTES_2
e64_basis_n62_ars
S_KRR_FILTER_2
e64_basis_n62_ars
S_LWDS_BL_2
e64_basis_n62_ars
S_STRAP_TRANSMISSION_2
e64_basis_n62_ars
S_TRACK_2
e64_basis_n62_ars
S_XVALVE_2I_SERVO_2
e64_basis_n62_ars
S_ZG_2
e64_basis_n62_ars
S_ZTOTAL_2
e64_basis_n62_ars
VARIANTEN_NUMMER_2
e64_basis_n62_ars
VCH_EHB
aktiv
KL_PREDRIVE_AUSWAHL_2
wert_01
DSC_IN_MDRIVE
nicht_aktiv
REAR_HEAD_UNIT
nicht_aktiv
VA_MP3_DISCLAIMER
nicht_aktiv
ACC2_FUNKTION
wert_05
GESCHW_NOT_PROGR
wert_01
AUTOAIM
wert_03
KL30G_EIN_HKT_AUSSEN
nicht_aktiv
KL30G_EIN_HKT_FBD
nicht_aktiv
CHK_MESS_NEBELSCHLUSSL
nicht_aktiv
KALTCHECK_NSL_CH14
aktiv
LAENDERVARIANTE_AHM_2
ece
TEILLAST_BRL_CH_16
aktiv
U_RMS_BRL_CH16
nicht_aktiv
U_RMS_NSL_CH14
nicht_aktiv
FLA_AUSGEFALLEN
nicht_aktiv
LS_UMSCHALT_FEHLER_ZEIT
wert_01
ANSCHLAG_DELAY
wert_01
ASP_EC_INPUT
aktiv
LWG_LIMIT
wert_01
LWG_WERT_A
wert_01
LWG_WERT_B
wert_01
VX_ANSCHLAGAUS
wert_01
FH_PANICMODE_EKS
nicht_aktiv
ABBIEGELICHT_CKM_0
nicht_aktiv
ABBIEGELICHT_CKM_1
nicht_aktiv
ABBIEGELICHT_CKM_2
nicht_aktiv
ABBIEGELICHT_CKM_3
nicht_aktiv
ABBL_LZ_PROZENT
wert_01
ABK_KNICK
wert_01
ABK_MIN_PROZ
wert_01
ABK_VERLAENG
wert_01
ABSCHALTUNG_RFS_1
wert_02
ABSCHW_D_TAU_HI_SP
wert_16
ABSCHW_D_TAU_LO_SP
wert_16
ABSCHWAECH_D_TAU_SP
wert_16
AEND_V_SCHWENK_N_AUSSE_SP
wert_20
AHL_MODE_CKM_0
wert_01
AHL_MODE_CKM_1
wert_01
AHL_MODE_CKM_2
wert_01
AHL_MODE_CKM_3
wert_01
ALC_ERR_BLK_AL_EIN
aktiv
ALC_SCHWENK_IM_STAND
aktiv
BFD_1_BFD_AUSG_ERSCH_BILD
wert_01
BFD_2_BFD_AUSG_ERSCH_BILD
wert_00
BFD_2_DEAKTIV_BEI_NSL
nicht_aktiv
BFD_BREMSL_FKT
nicht_aktiv
BFD_ERS_DEF_RL_BL
nicht_aktiv
BFD_ERS_DEF_RL_BL_1
nicht_aktiv
CC_MELD_BFD_BL
nicht_aktiv
CC_MELD_NSL_BFD
nicht_aktiv
CC_MELD_NSL_SL
nicht_aktiv
DEF_ABBIEGELICHT_CKM
nicht_aktiv
DEF_AHL_MODE_CKM
wert_01
DEF_SMART_BEAM_CKM
nicht_aktiv
DEF_WELCOMELIGHT_CKM
nicht_aktiv
DUAL_SP__BL_L
nicht_aktiv
DUAL_SP__BL_M_1
nicht_aktiv
DUAL_SP__BL_R
nicht_aktiv
DUAL_SP__BLK_H_L
nicht_aktiv
DUAL_SP__BLK_H_R
nicht_aktiv
DUAL_SP__BLK_V_L
nicht_aktiv
DUAL_SP__BLK_V_R
nicht_aktiv
DUAL_SP__RFS_L
nicht_aktiv
DUAL_SP__RFS_R
nicht_aktiv
DUAL_SP__RL_BL_1_L
nicht_aktiv
DUAL_SP__RL_BL_1_R
nicht_aktiv
DUAL_SP__RL_BL_2_L
nicht_aktiv
DUAL_SP__RL_BL_2_R
nicht_aktiv
EINLENKEN_RKW
nicht_aktiv
ENTGEGENGES_RKW
nicht_aktiv
FEHLERMELDUNG_CC_BL_M_2
nicht_aktiv
FEHLERMELDUNG_CC_SML_L
nicht_aktiv
FEHLERMELDUNG_CC_TFL_L
nicht_aktiv
FEHLERMELDUNG_CC_TFL_R
nicht_aktiv
FSP_ISP_SPERREN_1
wert_00
GETRIEBE_HANDSCHALTER
nicht_aktiv
HEIMLEUCHTEN_1
wert_02
HEIMLEUCHTEN_2
wert_02
HEIMLEUCHTEN_3
wert_02
HEIMLEUCHTEN_ENABLE
aktiv
HEIZ_ANF
wert_01
HEIZ_KNICK
wert_01
KALTUEBERWACHUNG_SML_L
nicht_aktiv
KALTUEBERWACHUNG_TFL_L
aktiv
KALTUEBERWACHUNG_TFL_R
aktiv
KENNL_MAX_UEBERST_SP
wert_16
KENNL_REDUZ_MAX_SCHWEN_SP
wert_16
KURZSCHL_WIERHOL_ZAEHLER
wert_01
KURZSCHLUSS_CHECK_DISA
wert_01
KURZSCHLUSS_CHECK_TIME
wert_01
KURZSCHLUSS_ENTPRELL
wert_01
LENK_UEBERSETZUNG_LO_SP
wert_20
MAX_DELTA_KEINE_VERR_SP
wert_16
MAX_HEIZZEIT
wert_05
MAX_VERRINGERUNG_V_SCH_SP
wert_12
MIN_DELTA_MAX_VERR_SP
wert_16
MIN_SW_SCHWENK_V_HORIZ_SP
wert_16
MIND_ANZ_ZYKL_TIPP_BLK_1
wert_02
MIND_ANZ_ZYKL_TIPP_BLK_2
wert_02
MIND_ANZ_ZYKL_TIPP_BLK_3
wert_02
NACHL_RKW
wert_01
NO_BLK_RKW
nicht_aktiv
NSL_BREMSL_FKT
nicht_aktiv
NSL_ERS_DEF_RL_BL_1
nicht_aktiv
NSL_VERBAU_OTP
wert_01
PWM_ANSTEUERUNG_KZL
wert_01
PWM_ANSTEUERUNG_SML
wert_01
PWM_BFD_ALS_SL
wert_01
PWM_NSL_ODER_BFD_ALS_BL
wert_01
PWM_SIDEMARKER_BLK_V
wert_01
QUITT_BLK_ENTSICHERN_1
nicht_aktiv
QUITT_BLK_ENTSICHERN_2
nicht_aktiv
QUITT_BLK_ENTSICHERN_3
nicht_aktiv
QUITT_BLK_SICHERN_1
nicht_aktiv
QUITT_BLK_SICHERN_2
nicht_aktiv
QUITT_BLK_SICHERN_3
nicht_aktiv
RAMPE_AUS_BLK
wert_01
RAMPE_AUS_KRV
wert_01
RAMPE_AUS_RUE
wert_01
RAMPE_EIN_BLK
wert_01
RAMPE_EIN_KRV
wert_01
RAMPE_EIN_RUE
wert_01
REDUZIERUNG_V_SCHWE_HI_SP
wert_16
REDUZIERUNG_V_SCHWE_LO_SP
wert_16
SL_BL_ERS_DEF_RL_BL_1
nicht_aktiv
SMART_BEAM_CKM_0
nicht_aktiv
SMART_BEAM_CKM_1
nicht_aktiv
SMART_BEAM_CKM_2
nicht_aktiv
SMART_BEAM_CKM_3
nicht_aktiv
SP_GRENZE
wert_01
START_ABBL
wert_01
SW_NULL_BEREICH_SP
wert_16
T_FILTER_UEBERST_SP
wert_16
T_FILTER_V_VEH_SP
wert_16
TAGFAHRLICHT_ECE_1
aktiv
TAGFAHRLICHT_ECE_2
nicht_aktiv
TAGFAHRLICHT_ECE_3
nicht_aktiv
TASTVERH_BEL_FLC_LED
wert_03
TAU_ABSCHWAECHUNG_SP
wert_20
UNP_ABBIEGELICHT_CKM
nicht_aktiv
UNP_AHL_MODE_CKM
wert_01
UNP_HEIMLEUCHTEN_CKM
wert_02
UNP_QUITT_BLK_ENTSI_CKM
nicht_aktiv
UNP_QUITT_BLK_SICH_CKM
nicht_aktiv
UNP_SMART_BEAM_CKM
nicht_aktiv
UNP_TAGFAHRLICHT_ECE_CKM
aktiv
UNP_WELCOMELIGHT_CKM
nicht_aktiv
UNP_ZYKL_TIPP_BLK_CKM
wert_02
V_E_HI_BLK
wert_01
V_E_HI_KRV
wert_08
V_E_LO_BLK
wert_01
V_E_LO_KRV
wert_08
V_HI_ABSCHW_D_TAU_SP
wert_16
V_HI_AENDER_LENK_UEBER_SP
wert_16
V_HI_RED_SCHWENK_W_SP
wert_16
V_HI_REDUZIER_V_SCHWEN_SP
wert_16
V_HI_SW_MITLENKEN_SP
wert_16
V_HI_SW_NACH_INNEN_SP
wert_16
V_LO_ABSCHW_D_TAU_SP
wert_16
V_LO_AENDER_LENK_UEBER_SP
wert_16
V_LO_RED_SCHWENK_W_SP
wert_16
V_LO_REDUZIER_V_SCHWEN_SP
wert_16
V_LO_SW_MITLENKEN_SP
wert_16
V_LO_SW_NACH_INNEN_SP
wert_16
V_M_HI_REDUZIER_V_SCHW_SP
wert_16
V_M_LO_REDUZIER_V_SCHW_SP
wert_16
V_S_HI_BLK
wert_01
V_S_HI_KRV
wert_01
V_S_LO_BLK
wert_01
V_S_LO_KRV
wert_01
WARMUEBERWACHUNG_SML_L
nicht_aktiv
WARMUEBERWACHUNG_TFL_L
aktiv
WARMUEBERWACHUNG_TFL_R
aktiv
WELCOMELIGHT_CKM_0
nicht_aktiv
WELCOMELIGHT_CKM_1
nicht_aktiv
WELCOMELIGHT_CKM_2
nicht_aktiv
WELCOMELIGHT_CKM_3
nicht_aktiv
ZUWACHS_TASTVERH_FLC_LED
wert_03
CITY_LONG_AVG_PEAK_TC
wert_02
CITY_LONG_AVG_TC
wert_02
CITY_SHORT_AVG_PEAK_TC
wert_02
CITY_SHORT_AVG_TC
wert_02
RICHTUNG_BILD_OFFSET
ab
VERTIKAL_BILD_OFFSET
wert_03
ZEIT_AUFBLENDEN_TRUCK
wert_02
EA_HILFE_BED_BFS
wert_01
FEH_SCHALTER
wert_00
FEH_START
wert_01
KHV_EINBAUHILFE
wert_01
KOLL_LNV_ARMAUF_FOND
wert_00
KOLLISION_FEH_MODE
wert_01
LNV_MAX
wert_00
MEM_RESTORE_PAUSE_FEH
wert_00
MIN_T_RESTH_N_MIN_BFS
min_temp_resth_1min_e65
MIN_T_SCHNELLH_N_MIN_BFS
mintemp_schnellh_1min_e65
P1_SHV
wert_00
P1_SLV
wert_00
P1H_SHV
wert_00
P2_SHV
wert_00
P2_SLV
wert_00
P2H_SLV
wert_00
P3_SHV
wert_00
P3_SLV
wert_00
P4_SHV
wert_00
P4_SLV
wert_00
P5_SHV
wert_00
P5_SLV
wert_00
P8_SHV
wert_00
P8_SLV
wert_00
SLV_MINDESTVERSTELLWEG
wert_00
SVS_KLEMMEND
wert_15
ZEITFENSTER_FUER_MIN_T
wert_03
EA_AKT_EVENT_FAS
wert_01
EA_HILFE_BED_FAS
wert_01
MIN_T_RESTH_N_MIN_FAS
MIN_T_SCHNELLH_N_MIN_FAS
BAUART_KBM
cabrio
N_FSW
wert_02
T_SPERR
wert_01
FBM_COMMUNICATION
nicht_aktiv
FBM_ENTERTAINMENT
nicht_aktiv
FBM_FMAM_TOGGLE
nicht_aktiv
FBM_MODE_TOGGLE
nicht_aktiv
FBM_NAVIGATION
nicht_aktiv
FBMS
nicht_vorhanden
HANGUL_TYPEWRITER
nicht_aktiv
KANJI_TYPEWRITER
nicht_aktiv
MOST_ASYNC_CTRL_CHANNL
most_control_channel
RAMP_CONTROL
nicht_aktiv
ENABLE_UNICODE
nicht_aktiv
K_ZAHL
e63_e64
MINIMUM_PULSE_FREQ
standard
SORTING_VARIANT
standard
TRAFFIC_BY_VOICE
nicht_aktiv
DUAL_SP__BLK_2_VL
nicht_aktiv
DUAL_SP__BLK_2_VR
nicht_aktiv
DUAL_SP__SML
nicht_aktiv
DUAL_SP__TFL_L
nicht_aktiv
DUAL_SP__TFL_R
nicht_aktiv
FEHLERMELDUNG_CC_BLK_2_VL
aktiv
FEHLERMELDUNG_CC_BLK_2_VR
aktiv
KALTUEBERWACHUNG_BLK_2_VL
aktiv
KALTUEBERWACHUNG_BLK_2_VR
aktiv
PWM_ANS_RL_BL_2_AL
wert_03
PWM_ANS_RL_BL_2_FL
wert_03
PWM_ANST_1_UNBELEGT
wert_01
WARMUEBERWACHUNG_BLK_2_VL
aktiv
WARMUEBERWACHUNG_BLK_2_VR
aktiv
SEATVENTILATION
nicht_aktiv
SITZHEIZUNG_SLIDER
nicht_aktiv
BELUEFTUNG_WS
nicht_aktiv
DEF_U_FUSS_ZU_WS
nicht_aktiv
GEBL_OFFSET_WS
nicht_aktiv
HELLA_RLSS_CAN
aktiv
LAENDERVARIANTE_IHKA
aktiv
RESTWAERME
aktiv
TEMP_OFFSET_WS
nicht_aktiv
USA_LV_INDIVIDUAL
aktiv
FOND_MID
nicht_aktiv
KLIMA_INDIVIDUAL
nicht_aktiv
LAST_PANEL_TIMEOUT
e6x
LEGAL_DISCL_TIMEOUT
e6x
MANUAL_SHIFT
nicht_aktiv
NOAIRVENT_FINE
nicht_aktiv
PIA_MENU
wert_00
ACC_ALIVE_ZAEHLER_1
nicht_aktiv
ACC_AUSSTATTUNG_1
wert_01
ACC_CSUM_MONITOR_1
nicht_aktiv
ACC_E60_ALIVE_ZAEHLER
nicht_aktiv
ACC_E60_CSUM_MONITOR
nicht_aktiv
ACC_E60_ID_MONITOR
nicht_aktiv
ACC_ID_MONITOR_1
nicht_aktiv
AHM_APPL_MONITOR
nicht_aktiv
AIRBAG_ALIVE_ZAEHLER
aktiv
AIRBAG_ID_MONITOR
aktiv
CAS_APPL_MONITOR
aktiv
CC_EHH_ANZ_MIN_TIME
wert_01
EHC_APPL_MONITOR
nicht_aktiv
LM_APPL_MONITOR
aktiv
RDC_APPL_MONITOR
nicht_aktiv
TANK_EINGANG
wert_01
TANK_KL_STEIGUNG
wert_01
TEL_ALIVE_ZAEHLER
aktiv
TEL_ID_MONITOR
aktiv
TLC_ALIVE_ZAEHLER
nicht_aktiv
TLC_ENABLE
nicht_aktiv
TLC_ID_MONITOR
nicht_aktiv
VDM_ALIVE_ZAEHLER
nicht_aktiv
VDM_ID_MONITOR
nicht_aktiv
DIMMUNG_POL
wert_01
GK_OC3_POL
aktiv
POL_MAX_SCHWELLE
wert_01
POL_MIN_SCHWELLE
wert_01
POL_TELEGRAMME
wert_01
SBE_SCHWELLE_ON
wert_01
SBE_STEP_DOWN
wert_01
SBE_STEP_UP
wert_01
SBR_SENSOR
nicht_aktiv
SBR_SENSOR_FAHRER
nicht_aktiv
SEAT_BELT_DIST_1
wert_01
SEAT_BELT_SPEED
wert_01
LRR_FUNKTION
wert_01
SCHWELLE_EIN_B_BLIND_3
wert_01
STRECKE_B_BLIND_3
wert_01
STREETLAMP_COUNT
wert_02
MILANSTEUERUNG_DDE
wert_01
CA_TMC
nicht_aktiv
JAP_SIDEVIEW_CAM
nicht_aktiv
LEGAL_DISCL_TIMOUT
standard
TOP_AMPL_TYPE
logic_7
VA_ADAPTIVEHEADLIGHT
nicht_aktiv
VA_CORNERINGLIGHT
nicht_aktiv
VA_FB
nicht_aktiv
VA_FB_COMMUNICATION
nicht_aktiv
VA_FB_ENTERTAINMENT
nicht_aktiv
VA_FB_NAVIGATION
nicht_aktiv
VA_FM_AM_TOGGLE
nicht_aktiv
VA_FOND_CLIMATE
nicht_aktiv
VA_LONGDISTANCELIGHT
nicht_aktiv
VA_MANUAL_SHIFT
nicht_aktiv
VA_MODE_TOGGLE
nicht_aktiv
VA_NOAIRVENT_FINETUNING
nicht_aktiv
VA_SEATVENTILATION
nicht_aktiv
VA_WELCOMELIGHT
nicht_aktiv
CBD_ZEICHN_INDEX_1
wert_01
FEHLERMELD_CC_NSW_L
aktiv
FEHLERMELD_CC_NSW_R
aktiv
PWM_ANST_2_UNBELEGT
wert_01
PWM_ANST_3_UNBELEGT
wert_01
HUD_HEIGHT_AJUSTMENT
nicht_aktiv
ABS_VOL_GONG
e64_top_hifi
ABS_VOL_PDC
e64_top_hifi
ABS_VOL_SRS
e70_top_hifi
ABS_VOL_TA
e70_top_hifi
ABS_VOL_TEL
e70_top_hifi
ACOUSTIC_CHAMP
aktiv
AMBAND_KW_CHAMP
nicht_aktiv
AUDIO_SIGNAL_ROUTING
standard
BLUETOOTH_NODES_CHAMP
profil_2
BMW_ASSIST_CHAMP
aktiv
BMW_DEALER_CHAMP
aktiv
BMW_HOTLINE_CHAMP
aktiv
BMW_MOBILE_CHAMP
aktiv
BMW_N_DEALER_CHAMP
nicht_aktiv
BMW_TELESERVICE
nicht_aktiv
CAR_COLOR_CHAMP
nicht_aktiv
CID_CHAMP
cid_e60
DAB_DUALBAND
nicht_aktiv
DAB_TUNER
nicht_aktiv
DELTA_GONG_ENT
e70_top_hifi
DELTA_PDC_ENT
e70_top_hifi
DELTA_SRS_ENT
e70_top_hifi
DELTA_TA_ENT
e70_top_hifi
DELTA_TEL_ENT
e70_top_hifi
DISPLAY_LOG7_SYMBOL_CHAMP
aktiv
DOUBLE_TUNER_CHAMP
nicht_aktiv
ELDRVSEAT_CHAMP
aktiv
ENT_MUTE_ON_CRASH
e70
EXTERIOR_MIRROR_PACKAGE
nicht_aktiv
FADE_MUTE_SOURCE_CHANGE
standard
FAN_HZ_LEVEL1
e70
FAN_HZ_LEVEL2
e70
FAN_HZ_LEVEL3
e70
FAN_VAL1_DOWN
e70
FAN_VAL1_UP
e70
FAN_VAL2_DOWN
e70
FAN_VAL2_UP
e70
FAN_VAL3_DOWN
e70
FAN_VAL3_UP
e70
FBM_COMMUNICATION_CHAMP
aktiv
FBM_ENTERTAINMENT_CHAMP
aktiv
FBM_FMAM_TOGGLE_CHAMP
aktiv
FBM_MODE_TOGGLE_CHAMP
aktiv
FBM_NAVIGATION_CHAMP
aktiv
KEY_MEMORY_CHAMP
aktiv
LEGAL_DISCL_CHAMP
aktiv
LOGISTIK_CHECK_CHAMP
aktiv
MP3_CHAMP
aktiv
NOAIRVENT_FINE_CHAMP
nicht_aktiv
OCEANTRACE
nicht_aktiv
OFFSET_ENT_GONG
e70_top_hifi
OFFSET_ENT_PDC
e70_top_hifi
OFFSET_ENT_SRS
e70_top_hifi
OFFSET_ENT_TA
e70_top_hifi
OFFSET_ENT_TEL
e70_top_hifi
PHONE
tcu_us_sa639
RADIO_DIGITAL
nicht_aktiv
RDS_AF_FUNKTION_CHAMP
rds_ein_af_aus
RING_CHAMP
aktiv
SENDER_TAB_HGL_CHAMP
nicht_aktiv
SINGLE_TUNER_CHAMP
aktiv
SVS_LOW_CHAMP
nicht_aktiv
TACTIVE
e70
TIME_DIST_SAME_PRIO
e70
TIME_LAG_IMG
e70
TIME_OUT_GONG
e70
VOL_E_CALL_MAX
e70
VOL_E_CALL_MIN
e70
VOL_SRS_MAX
e70_top_hifi
VOL_SRS_MIN
e64_top_hifi
VOL_TA_MAX
e70_top_hifi
VOL_TA_MIN
e70_top_hifi
VOL_TEL_MAX
e70_top_hifi
VOL_TEL_MIN
e64_top_hifi
VOLUME_MAX_ON
e70_top_hifi
SCHALT_HINW_ID_MONITOR
nicht_aktiv
SCHALT_PKT_BC
nicht_aktiv
SCHALT_PKT_DAUERHAFT
nicht_aktiv
KLIMA_SG_ART_CHAMP
high
CONTINUEAFTERKL50
nicht_aktiv
SEAT_BELT_DISTANCE_ACSM
wert_01
EINSCHALTZEIT_DELAY
wert_02
KEINE_FREIGABE_BEWEGUNG
aktiv
TIMEOUT_FREIGABE
wert_02
HW_NOTLAUF_CHECK_COUNTER
wert_01
ANSCHLUSS_KLEMME
wert_02
BOTSCHAFT_OHNE_POSITION
wert_01
HEIZUNG_NOTBETRIEB
aktiv
NORMIEREN_SCHW
wert_01
SCHWELLE_VON_VORNE
wert_01
SOFTBLOCK_AUS_SCHW
wert_01
AIRBAG_POS
nicht_aktiv
FHM_CA_OHNE_EKS
nicht_aktiv
FHM_CA_OHNE_EKS_DELAY
wert_01
HK_GESPERRT_IN_GESICHERT
nicht_aktiv
AC_FOND
nicht_aktiv
OIL_LEVEL_CHAMP
aktiv
SW_I_AUFSTARTVERHALTEN
wert_01
SW_I_ECO_PUMPE
e64_basis_n62_ars
SW_I_RIEMENUEBERSETZUNG
e64_basis_n62_ars
SW_I_SBS_SWITCH
e64_basis_n62_ars
SW_I_SERVOTRONIK
e64_basis_n62_ars
SW_I_ZTOTAL
e64_basis_n62_ars
VARIANTEN_NUMMER_3
e64_basis_n62_ars
A_MAX
wert_00
A_MIN
wert_00
ECBA_DCC
wert_00
IPM_MAX_P_RES
wert_00
R_RAD_DYN
wert_00
SCHUBABSCHALTUNG
wert_01
SETZ_V_MAX_CC
wert_00
SETZ_V_MIN
wert_00
V_ABSCHALT
wert_00
V_EINHEIT
wert_01
VERZOEG_NEG_FEIN
wert_00
VERZOEG_NEG_GROB
wert_00
VERZOEG_POS_FEIN
wert_00
VERZOEG_POS_GROB
wert_00
BLK_TIMER_STAND
wert_01
HYST_STAND_KRV
wert_01
MAX_SCHWENK_V_H_BEGR
wert_06
MAX_SCHWENK_V_H_BEGR_SP
wert_21
PWM_FL_NSW_FKT_ABBLIEGELI
wert_02
SENSEWID_PIN_04
aktiv
SENSEWID_PIN_05
nicht_aktiv
SENSEWID_PIN_10
nicht_aktiv
SENSEWID_PIN_11
aktiv
SENSEWID_PIN_22_68
aktiv
SENSEWID_PIN_24_39
aktiv
SENSEWID_PIN_25
aktiv
SENSEWID_PIN_30
nicht_aktiv
SENSEWID_PIN_40
aktiv
SENSEWID_PIN_42
nicht_aktiv
SENSEWID_PIN_61
aktiv
SENSEWID_PIN_62
nicht_aktiv
SENSEWID_PIN_63
aktiv
SENSEWID_PIN_64
nicht_aktiv
SL_ABSCH_OHNE_ECE
aktiv
TIMEOUT_SET_DTC
aktiv
WELCOME_LIGHT_ACTIVE
nicht_aktiv
WL_AL
nicht_aktiv
WL_BLK_H
nicht_aktiv
WL_BLK_V
nicht_aktiv
WL_DAUER
wert_01
WL_FL
nicht_aktiv
WL_KZL
soft_einschalten
WL_MAX_DAUER
wert_01
WL_NSL
nicht_aktiv
WL_NSW
nicht_aktiv
WL_POL
aktiv
WL_SL_1
nicht_aktiv
WL_SL_2
hart_einschalten
ANHEBUNG_VERDAMPFER_MIN
nicht_aktiv
FH_E64_VORFREIGABE
nicht_aktiv
AUT_OFFNEN_HK_IN_ENTLPOS
nicht_aktiv
EWS_EGS
nicht_aktiv
WARTEZEIT_CA_FREIGABE
wert_01
LAENDERVARIANTE_TUNER_ANT
us
TP_FUNKTION_ANT
nicht_aktiv
AMBANDS_HST
nicht_aktiv
FOND_HIGH_HST
nicht_aktiv
SITZHEIZUNG_APP
nicht_aktiv
WEATHERBAND_HST
aktiv
NAVI_LA_VARIANTE
wert_05
AMBAND_LW_CHAMP
nicht_aktiv
AMBAND_MW_CHAMP
aktiv
LAENDERVAR_TUNER_CHAMP
us
SMS_CHAMP
nicht_aktiv
TOGGLE_AIR_VENT
nicht_aktiv
TOGGLE_AUTO_PROG
nicht_aktiv
TOGGLE_SEAT_CLIMATE
nicht_aktiv
TP_FUNKTION_CHAMP
nicht_aktiv
HILLDESC_DXC_8_0C
nicht_aktiv
EMPFINDLICHKEIT_ROTE
wert_02
TYP_FRONTSCHEIBE_FLA
klimakomfort
IGR_CODIERUNG
nicht_aktiv
LEUCHTWEITENREG_AUTOM_0E
aktiv
LEUCHTWEITENREG_DYNAM_0E
aktiv
KL30G_NACHLAUF_NACH_SZ1
wert_00
VILLAGE_TYP
wert_02
AUTO_LWR_ENABLE_LM2
aktiv
DYNAM_LWR_ENABLE_LM2
aktiv
AIRVENT_TOGGLE
nicht_aktiv
AUTOMATIC_TOGGLE
nicht_aktiv
ONLINE_DAR_TYPE_MASK
dar_bmw
SEATCLIMATE_TOGGLE
nicht_aktiv
SURROUND
nicht_aktiv
VA_CA_TMC
nicht_aktiv
TELEFON_TYPE_C08
prof_phone
SLV2FEH_UMSCHALTZEIT
wert_02
CBS_VERSION
wert_03
SCHLUESSELVARIANTE
wert_02
ABBL_LZ_RKW
wert_01
ABBL_LZ_STAND
wert_01
BL_2_BREMSL_FKT
aktiv
BL_2_PARKL_FKT
nicht_aktiv
BL_2_RL_FKT
nicht_aktiv
CC_MELD_AL_OFF
nicht_aktiv
CC_MELD_PARKLICHT
nicht_aktiv
DRL_TFL_BLK_V_GED
nicht_aktiv
DRL_TFL_KZL
nicht_aktiv
DRL_TFL_RL_BL
nicht_aktiv
DRL_TFL_RL_BL_1
nicht_aktiv
DRL_TFL_RL_BL_2
nicht_aktiv
DRL_TFL_SML
nicht_aktiv
ENDE_ABBL
wert_01
wert_01
HYST_RKW
wert_01
LH_UND_NSW_NICHT_GLEICHZ
aktiv
LICHT_AN_WARN_NORM
aktiv
PIN_CONFIGURATION
wert_01
PWM_ANST_BL_2_SL
wert_01
PWM_ANSTEUERUNG_BL
wert_04
PWM_ANSTEUERUNG_RL
wert_04
PWM_PIN_05_62
wert_02
PWM_PIN_11_63
wert_01
PWM_PIN_22_68_24_39
wert_02
PWM_PIN_25_40
wert_07
PWM_RL_BL_1_FKT_PARKL
wert_03
RLS_RESTART_COMM
wert_01
RLS_VERBAUT
nicht_aktiv
TIPP_BLK
nicht_aktiv
VERHALTEN_DRL_TFL
drl_h
WARNBLK_AHM_ENERGY_SAVE
aktiv
LWR_ABS_SENS_DEF
wert_02
RAMPE4_BL_0
kennlinie_02
RAMPE4_BL_1
kennlinie_02
RAMPE4_BL_2
kennlinie_02
RAMPE4_BL_3
kennlinie_02
RAMPE5_BL_0
kennlinie_02
RAMPE5_BL_1
kennlinie_02
RAMPE5_BL_2
kennlinie_02
RAMPE5_BL_3
kennlinie_02
RAMPE6_BL_0
kennlinie_02
RAMPE6_BL_1
kennlinie_02
RAMPE6_BL_2
kennlinie_02
RAMPE6_BL_3
kennlinie_02
RAMPE7_BL_0
kennlinie_02
RAMPE7_BL_1
kennlinie_02
RAMPE7_BL_2
kennlinie_01
RAMPE7_BL_3
kennlinie_01
VA_AIRVENT_SHORTCUT
nicht_aktiv
VA_AUTOMATIC_SHORTCUT
nicht_aktiv
VA_PDC_LOW
nicht_aktiv
VA_SEATCLIMA_SHORTCUT
nicht_aktiv
VA_SEATHEAT_SLIDER
nicht_aktiv
AFS_VERBAUT
nicht_verbaut
ANZ_HOLD_KI
wert_01
ANZ_SYS_SPEED
aktiv
AUDIBLE_WARNING
aktiv
AUDIBLE_WARNING_MAX
wert_01
AUDIBLE_WARNING_MIN
wert_01
BREAK_INTERMITTEND_MODE
wert_01
CSUM_SYS_CODE
grundcode_var
LAENDER_CODE
usa
MAX_WARNING_LENGTH
wert_01
MIN_WARNING_LENGTH
wert_01
PULS_INTERMITTEND_MODE
wert_01
PWM_FREQUENZ
wert_01
REF_BORD_SPG
wert_01
SEND_CAN_MESSAGE_TLC
default
SPEED_PWM_DATA_X
wert_01
SPEED_PWM_DATA_Y
wert_01
SWITCH_ACTUATOR_MODE
perma_without_pwm
THRESHOLD_LOWER
wert_01
THRESHOLD_UPPER
wert_01
THRV_AVAI_TLC_HIGH
wert_02
THRV_AVAI_TLC_LOW
wert_02
TLC_GESCHW_MAX
wert_01
VIBRATION_WARNING
aktiv
AUDIO_SETUP_1
wert_01
AUDIO_SETUP_2
wert_01
DPD
wert_01
SVS_EIN_AUS_2
nicht_aktiv
TEL_BUCH_ASYNC_CONTROL
most_async_channel
UNICODE
nicht_aktiv
DAB_FM_SWITCH_CH
nicht_aktiv
LOUDNESS_CHAMP
aktiv
ACC_ANFAHR_GONG
nicht_aktiv
ACC_APPL_MONITOR
nicht_aktiv
ACC_MODE_ANZEIGE
aktiv
DZM_DAEMPFUNG
aktiv
DZM_DISP_RPM
wert_01
NOTRUF_AACN
nicht_aktiv
AUTO_SRVC_CALL
aktiv
BT_ENABLE
aktiv
CALL_SRVC_CENTER
nicht_aktiv
CAR_PHONE
nicht_aktiv
CCM_FILTER
wert_03
INTERNAL_GPS
nicht_aktiv
INTERNAL_NAD
aktiv
MOST_CHANNEL
most_async_channel
USED_MICROPHONES
wert_01
GESAMTSCHIENENLAENGE_HALL
wert_01
MAX_TOLERANZ_HALLWERTE
wert_01
SH_BFS
nicht_aktiv
SH_FAS
nicht_aktiv
CODIERUNG_PROTOKOLL
wert_02
IGR_HERSTELLER_A
nicht_aktiv
AFS_ENABLE
wert_01
AQ_BANDPASS_FG
wert_01
AQBES_SENSRESFAKTOR_MAX
wert_01
AQBES_SENSRESFAKTOR_MIN
wert_01
ARD_DTVOREIL
wert_01
ARD_ENABLE
wert_01
ARD_FG_TP
wert_01
ARD_FG_TP2
wert_01
ARD_KP
wert_01
ARD_MAXMOMENT
wert_01
ARD_MISUSE_RV_TMIN
wert_01
ARD_MISUSE_RV_TRELAX
wert_01
ARD_RRP_ERR_LEVEL_V_1
wert_01
ARD_RRP_ERR_LEVEL_V_2
wert_01
ARD_RRP_ERR_LEVEL_X0
wert_01
ARD_RRP_FG_DT1
wert_01
ARD_RRP_FG_TP
wert_01
ARD_RRP_PHIP_DT
wert_01
ARD_SCHALTRVTOGGLELOCK
wert_01
ARD_TB_MOMENT
wert_01
ARD_VSCAL_0
wert_01
ARD_VSCAL_X
wert_01
ARD_VSCAL_Y
wert_01
ARS_AQSENSOR_DISABLE
wert_01
ARS_EDC_EXCH_ENABLE
wert_01
ETA_PUMPE_1
wert_01
ETA_PUMPE_2
wert_01
F_BEOBACHTER_F
e64_n62
F_CAN_ENABLE
wert_01
FG_A_QUERBESCH_ROH_HIGH
wert_01
FG_A_QUERBESCH_ROH_LOW
wert_01
FG_AQ_HUELLKURVE
wert_01
FG_AQSENSRESON_LOW
wert_01
FG_SENSOR_RESONANZ
wert_01
K_FG_A_QUER_ROH
wert_01
NPUMPE_FEST
wert_01
NPUMPE_TOL
wert_01
NX_PU_MAX
wert_01
NX_PU_MIN
wert_01
P_ETA_PUMPE_Y_1
wert_01
P_ETA_PUMPE_Y_2
wert_01
PREDR_STOPPUDRZ
wert_01
PREDR_STRTPUDRZ
wert_01
ROSE_ENABLE
wert_01
RRP_SCHWELLEPHIPBER
wert_01
RRP_SCHWELLEPHIPGRD
wert_01
SD_VENTIL_ENALBE
wert_01
STWA_TOP_ENABLE
wert_01
T_BEOAUSBLEND
wert_01
T_BEOEINBLEND
wert_01
T_RV_STELLUNG_ERR
wert_01
V_MAX_AQ_FILT_VAR
wert_01
VERSCHRAENKUNG_MAX
wert_01
AIR_SUSP
nicht_aktiv
DDS_SW_CAN
nicht_aktiv
PRE_MSR
nicht_aktiv
KONF_RPA_ON_CAN
kein_rpa_on_can
KALTCHECK_FRA_CH10_12
aktiv
KALTCHECK_RFS_CH15
aktiv
KALTCHECK_SLH_CH11_13
aktiv
TEILLAST_FRA_CH10_12
nicht_aktiv
TEILLAST_SLH_CH11_13
nicht_aktiv
ENTFROSTUNG_ZU_NACH_NEUST
wert_00
KLIMASTIL
aktiv
KLIMASTIL_DEFAULT
medium
KLIMASTIL_DEFAULT_KEY
medium
KLIMASTIL_KEY1
medium
KLIMASTIL_KEY2
medium
KLIMASTIL_KEY3
medium
KLIMASTIL_KEY4
medium
KLIMASTIL_WS
medium
OFF_MEMORY_KEY_WS
nicht_aktiv
SW_B_GRR_AKTIV
e64_basis_n62_ars
IGR
nicht_aktiv
PVAR_INNEN
wert_03
PVAR_KUPPL
wert_03
VMAX-BEGRENZUNG-606
wert_02
IGR_XENON
wert_02
VMAX-BEGRENZUNG-6ZYL
wert_07
VMAXCODIERUNG_ME17
wert_01
ACK_2_AIRBAG_01
nicht_aktiv
ALIVE_SIGNAL_01
aktiv
BACKUP_ANTENNA_01
nicht_aktiv
BACKUP_LOUDSPEAKER_01
nicht_aktiv
BLUETOOTH_01
aktiv
CALL_WAITING_ENABLE_01
aktiv
CUSTOMER_CALLS_OVER_GMIN1
nicht_aktiv
MOST_ASYNC_OR_CTRL_CHA_01
most_async_channel
PAY_TMC_CONTROL_01
nicht_aktiv
PORTABLE_BT_01
aktiv
SIM_IN_TELEMATIK_READER01
nicht_aktiv
TELEMATIK_ENABLED_01
nicht_aktiv
TELEMATIK_SIM_ENABLED01
nicht_aktiv
VR_EQUIPPED_01
nicht_aktiv
TYP_FAHRZEUG
e60
VMAXCODIERUNG_MSV80
wert_01
ZEIT_KL50_ANSTRG
wert_04
EXCESS_TEMP_VOLUME
wert_00
DVD_EJECT_LOCKED
free
AIRBAG_COMM_TEST_DELAY
wert_01
AIRBAG_INTRFCE_ERROR_DUR
wert_01
FIRST_POLY_COEFFICIENT
e63_e64
SECOND_POLY_COEFFICIENT
e63_e64
THIRD_POLY_COEFFICIENT
e63_e64
WSPEED_SIG_ERROR_DUR
wert_01
WSPEED_SIG_TEST_DELAY
wert_01
CAN_STATUS_HKL
aktiv
AFS_ENABLE_12
e60
AQ_BANDPASS_D
e60
AQ_SCHALT_12
e60
ARD_MAXMOMENT_12
e60
F_BEOBACHTER_F_12
e60
F31_RED_ENABLE
e60
K_F31_WRES_MAX
e60
K_F31_WRES_MIN
e60
K_VOREIL_RES_12
e60
RRP_SCHWELLEPHIPBER_12
e60
RRP_SCHWELLEPHIPGRD_12
e60
FH_KOMFORTF_MIT_SUBST
nicht_aktiv
SICHERHEITSFAHRZEUG_IHKA
nicht_aktiv
PANIC_FREIGABE_CAS_2
nicht_aktiv
AUDIO_VOLUME_STEPS
e64_top_hifi
FULLWORD_RECOG
aktiv
TMC_REGIONAL
nicht_aktiv
ABL_AUS_BEI_FL_LH_EIN
nicht_aktiv
BFD_1_BL_2_ERSCH_BILD
nicht_aktiv
BFD_2_BL_2_ERSCH_BILD
nicht_aktiv
CC_MEL_SL_BEI_DEF_RL_BL_1
nicht_aktiv
DWA_UEBERFALL_ALARM
wert_02
ENERGIE_UBATT_LIMIT
wert_01
ENERGIE_ZEIT_ENTPRELL
wert_01
ENERGIE_ZEIT_LIMIT
wert_01
FSP_LAMPEN_MASK
wert_01
FZG_RADSTAND_LM
wert_06
nicht_aktiv
LOAD_DUMP_DIMM_AL
aktiv
LOAD_DUMP_DIMM_BL
aktiv
LWR_MAX_POS_NORM
wert_01
LWR_MAX_POS_REF
wert_01
LWR_OFFSET_PLATTLAUF_L
wert_01
LWR_OFFSET_PLATTLAUF_R
wert_01
NSL_AUS_BEI_FE_MODE
nicht_aktiv
SL_SCHALT_UMSCHALT_OPT
wert_01
STANDVERBRAUCHER_ANMELD
aktiv
VORH_HEIZZ
wert_01
nicht_aktiv
WL_MIT_FLC
nicht_aktiv
WL_ZYKLEN
wert_01
MINDZEIT_VR_SEN_FT_AKTIV
wert_02
ABSCHALTTEMP
e60chl
AKTIVE_SPRACHE
leitsprache
AUDIO_GRENZE
e60chl
AUDIO_OFFSET_CD_AUDIO
e60chl
AUDIO_OFFSET_COMP_AUDIO
e60chl
AUDIO_OFFSET_COMP_VIDEO
e60chl
AUDIO_OFFSET_DVD_AUDIO
e60chl
AUDIO_OFFSET_DVD_VIDEO
e60chl
AUDIO_OFFSET_VCD
e60chl
AUX_IN_1
e60chl
AUX_IN_2
rse_mid
CD_UPDATE
e60chl
DIMMUNG
e60chl
LVDS_MODUS
e60chl
NACHLAUFZEIT_BEL_HIGH
e60chl
NACHLAUFZEIT_BEL_LOW
e60chl
SPRACHVERSION
us
STARTUP_MODUS
e60chl
TASTENDRUCK_LANG
e60chl
VOLUME_AUX_OUT
ccc
VOLUME_KH_IR
e60chl
KHV_GRENZE_UNTEN
wert_00
CBS_LIST
aktiv
CC_LIST
aktiv
CLIMATE_WITHOUT_PREVIEW
nicht_aktiv
ABZUGSPERRE_PLOCK_C6
aktiv
GETRIEBE_TYP_C6
automatik
ADAPTIVEHEADLIGHT
nicht_aktiv
ALBV_TOGGLE
nicht_aktiv
CORNERINGLIGHT
nicht_aktiv
DKG
nicht_aktiv
EDC
nicht_aktiv
ENTERT_NEXTSOURCE
nicht_aktiv
LONGDISTANCELIGHT
nicht_aktiv
MAP_2D
nicht_aktiv
MDRIVE_LOW
nicht_aktiv
MMDEVICE
nicht_aktiv
MMDEVICE_2
nicht_aktiv
TIME_LINE_CROSSING
nicht_aktiv
WELCOMELIGHT
nicht_aktiv
DSC_NO
nicht_aktiv
CSUM_CAR_PARAM_ECU
grundcode_var
INITIAL_HEIGHT
wert_02
WAITTIME_UNTIL_DIAG_START
wert_01
X_DIST_CAM_TO_FRONT_AXLE
wert_02
Y_DISTANCE_LEFT
wert_02
Y_DISTANCE_RIGHT
wert_02
CODIERUNG_PROTOKOLL_MSD80
wert_02
CODIERUNG_PROTOKOLL_MSV80
wert_02
SPA
wert_02
FZE_FORMFAKTOR
fze_nicht_aktiv
VR_EQUIPPED_TCU15
nicht_aktiv
CRUISE_CTRL_CHAMP
aktiv
IR_TF1_NOM
e60chl
IR_TF2_NOM
e60chl
PLL_DUTY_TF1
rse_mid
PLL_DUTY_TF2
e60chl
PLL_MAX_ABWEICHUNG
e60chl
PLL_PERIOD_TF1
e60chl
PLL_PERIOD_TF2
e60chl
SCHWELLE_KLEMME_30
e60chl
SCHWELLE_KLEMME_31
e60chl
SCHWELLE_LEERLAUF
e60chl
SCHWELLE_LEERLAUF_AUX
ccc
SCHWELLE_LEERLAUF_IR
e60chl
TEST_DELAY
e60chl
TEST_DELAY_AUX
e60chl
TEST_DELAY_LEERLAUF
e60chl
TEST_DELAY_LEERLAUF_AUX
e60chl
VOLUME_AUX_OUT_2
e60chl
CBS_STATUS
aktiv
CLIMATE_WO_PREVIEW
nicht_aktiv
NO_DETOUR
nicht_aktiv
AMP_VARIANTE
e64
VERSTELL_SCHALTER_TYP_FAS
wert_05
VERSTELL_SCHALTER_TYP_BFS
wert_05
CSUM_CONFIG_WARNING
grundcode_var
DISP_ENGDAT_ALIVE_ZAEHLER
nicht_aktiv
DISP_ENGDAT_ID_MONITOR
nicht_aktiv
TELEX_STATUS_SC
wert_02
TLC_SYMBOLIK
wert_01
ALC_SG_VERBAUT
nicht_aktiv
BL_2_BREMSL_FKT_33
aktiv
CC_MELD_ABIEGL_BEI_DEF_FL
nicht_aktiv
DRL_TFL_RL_BL_1_33
nicht_aktiv
DRL_TFL_RL_BL_2_33
nicht_aktiv
DRL_TFL_SML_33
aktiv
DRL_TFL_TFL_33
nicht_aktiv
LWR_ABS_MIN_STELL_2
wert_02
LWR_HEBEL_33
wert_03
LWR_SCHRITTE_STELL_0
wert_01
LWR_SCHRITTE_STELL_1
wert_01
LWR_SCHRITTE_STELL_2
wert_02
PIN_CONFIGURATION_33
wert_01
PWM_AN_NSL_SL
wert_01
PWM_AN_SL_V_AL_1
wert_03
PWM_AN_SL_V_FL_1
wert_03
PWM_ANS_RL_BL_2_AL_33
wert_03
PWM_ANS_RL_BL_2_FL_33
wert_03
PWM_ANST_RL_BL_BL_33
wert_02
PWM_ANSTEUERUNG_NSL_33
wert_03
PWM_ANSTEUERUNG_RFS_33
wert_01
PWM_ANSTEUERUNG_RL_33
wert_04
PWM_FL_FKT_DRL_33
wert_01
PWM_PIN_05_62_33
wert_02
PWM_PIN_11_63_33
wert_01
PWM_RL_BL_1_FKT_PARKL_33
wert_05
RL_BL_1_BREMSL_FKT_33
aktiv
RL_BL_1_PARKL_FKT_33
aktiv
RL_BL_2_PARKL_FKT_33
nicht_aktiv
RL_BL_2_PO_RL_FKT_33
nicht_aktiv
RL_BL_PO_RL_FKT_33
nicht_aktiv
SENSEWID_PIN_04_33
aktiv
SENSEWID_PIN_05_33
nicht_aktiv
SENSEWID_PIN_10_33
nicht_aktiv
SENSEWID_PIN_11_33
aktiv
SENSEWID_PIN_25_33
aktiv
SENSEWID_PIN_40_33
aktiv
SENSEWID_PIN_61_33
aktiv
SENSEWID_PIN_62_33
nicht_aktiv
SENSEWID_PIN_63_33
aktiv
SENSEWID_PIN_64_33
nicht_aktiv
SL_PARKL_ABSCH_12H
nicht_aktiv
VERHALTEN_DRL_TFL_33
drl_s
PWM_AN_BLK_H
wert_02
PWM_ANSTEUERUNG_SML_33
wert_01
GLASSTYP_1
esg2_glass
CSUM_CODIERUNG_DATUM
grundcode_var
CSUM_CODIERUNG_VALID
grundcode_var
ACC_TIMER_BALKEN
acc_balken_timer
ACC_TIMER_PAUSE
acc_pause_timer
ACC2_RESUME
aktiv
ACC2_SEITENBALKEN
aktiv
TLC_AUSSTATTUNG
nicht_aktiv
TLC_VARIANTE_A_B
variante_a
TLC_VARIANTE_C_D
variante_d
ACC_AUSSTATTUNG_HUD
fgr_aktiv
CCM_AHV_SG_5
keine_ccm
SW_B_GRR_AKTIV08
wert_02
SW_B_STELLMOTOR_VAR08
wert_01
SW_I_ECO_PUMPE08
wert_02
SW_I_RIEMENUEBERSETZUNG08
wert_04
SW_I_SBS_SWITCH08
wert_08
SW_I_SERVOTRONIK08
wert_03
SW_I_ZTOTAL08
wert_07
FBD_LOAD_POS_HK_HK
nicht_aktiv
FBD_LOAD_POS_LF_PING
nicht_aktiv
FBD_NO_LOAD_POS
aktiv
FH_RELEASE_CA_BASIC
nicht_aktiv
KL30G_EIN_HKT_AUSSEN_07
nicht_aktiv
KL30G_EIN_HKT_FBD_07
nicht_aktiv
KLR_AUS_TK
aktiv
KLSTRG_GRB_ID
wert_01
SPERRE_HKL_KEY_VALID_07
aktiv
SS_GETRIEBE_7
nicht_aktiv
STARTABBRUCH_KLR
nicht_aktiv
STARTDELAY_K_START_R5X
nicht_aktiv
TC_KL15_AUTO_OFF
nicht_aktiv
TC_KL15_AUTO_OFF_LIGHT
nicht_aktiv
TC_MSA_NO_KL15_AUTO_OFF
nicht_aktiv
TC_TIME_KL15_AUTO_OFF
wert_00
BLINKEN_FA
wert_02
ENTPRELLZEIT_HALLSENSOREN
wert_01
ENTPRELLZEIT_P
wert_01
ENTPRELLZEIT_SPORT
wert_04
ENTPRELLZEIT_UNLOCK
wert_01
ERROR_MASK
wert_01
FA_PWM_MAX
wert_01
FA_PWM_MIN
wert_01
HAFT_ANZ_RUECKSTEL_BIS_FS
wert_03
HAFT_ANZAHL_RUECKSTELL
wert_04
HAFT_RUECKSTELL_PERIODE
wert_01
HAFT_RUECKSTELL_VERZGRNG
wert_04
HAFT_RUECKSTELLPULSLAENGE
wert_05
SPERREN_ANZUG_PWM
wert_07
SPERREN_ANZUGSZEIT
wert_05
SPERREN_HALTE_PWM
wert_02
SUCHBEL_PWM_MAX
wert_01
SUCHBEL_PWM_MIN
wert_01
U_MAX_FS
wert_02
U_MAX_SPERREN
wert_02
U_MIN_FS
wert_02
U_MIN_SPERREN
wert_02
A2DP_EIN_AUS
nicht_aktiv
API_EIN_AUS
nicht_aktiv
API_IPOD_COM_TYPE
ipod_two_wire_seriel
API_IPOD_EIN_AUS
nicht_aktiv
API_MTP_EIN_AUS
nicht_aktiv
API_TWO_USB
nicht_aktiv
API_USB_EIN_AUS
nicht_aktiv
BT_EIN_AUS
nicht_aktiv
CAR_TYPE_IPODLOGO
bmw
DUN_EIN_AUS
nicht_aktiv
ISPEECH_ALLOW_GPS
aktiv
ISPEECH_AUX_CONFIG
mounted
ISPEECH_BAUART_CABRIO
aktiv
ISPEECH_BAUREIHE_E70
nicht_aktiv
ISPEECH_BAUREIHE_R5X
nicht_aktiv
ISPEECH_BLUETOOTH_NODES
nicht_aktiv
ISPEECH_BMW_ASSIST
aktiv
ISPEECH_BMW_DEALER
aktiv
ISPEECH_BMW_HOTLINE
aktiv
ISPEECH_BMW_MOBILE
aktiv
ISPEECH_BMW_N_DEALER
nicht_aktiv
ISPEECH_CDC
aktiv
ISPEECH_CID
cid_low
ISPEECH_CID_TYPE
static
ISPEECH_DAB
nicht_aktiv
ISPEECH_DIG_AUDIO_SRC
cd-player
ISPEECH_EIN_AUS
nicht_aktiv
ISPEECH_FOND_LOW
nicht_aktiv
ISPEECH_FOND_MID
nicht_aktiv
ISPEECH_HDC
nicht_aktiv
ISPEECH_HUD
nicht_aktiv
ISPEECH_IBOC
nicht_aktiv
ISPEECH_JAPAN
aktiv
ISPEECH_KLIMA_BASIS
nicht_aktiv
ISPEECH_KLIMA_HIGH
aktiv
ISPEECH_KLIMA_LOWTEMP
nicht_aktiv
ISPEECH_KLIMA_LOWVENT
nicht_aktiv
ISPEECH_MDRIVE
nicht_aktiv
ISPEECH_MDRIVELOW
nicht_aktiv
ISPEECH_MMC
nicht_aktiv
ISPEECH_MMDEVICE
nicht_aktiv
ISPEECH_NAVI
aktiv
ISPEECH_NAVI_TYPE_JP
nicht_aktiv
ISPEECH_NAVI_TYPE_SV
aktiv
ISPEECH_NIVI
nicht_aktiv
ISPEECH_ONLINE
nicht_aktiv
ISPEECH_PDC
aktiv
ISPEECH_RDC
nicht_aktiv
ISPEECH_RDS_AF_FUNKTION
aktiv
ISPEECH_RVC
nicht_aktiv
ISPEECH_SDARS
nicht_aktiv
ISPEECH_SINGLETUNER
nicht_aktiv
ISPEECH_SITZHEIZUNG
nicht_aktiv
ISPEECH_SMS
nicht_aktiv
ISPEECH_SPRACHE_US
aktiv
ISPEECH_STANDHEIZUNG
nicht_aktiv
ISPEECH_STANDLUEFTUNG
aktiv
ISPEECH_TEL_TYPE_BUSI
nicht_aktiv
ISPEECH_TEL_TYPE_ECE
nicht_aktiv
ISPEECH_TEL_TYPE_JAP
nicht_aktiv
ISPEECH_TEL_TYPE_MULF
nicht_aktiv
ISPEECH_TEL_TYPE_PROF
aktiv
ISPEECH_TEL_TYPE_TPP
nicht_aktiv
ISPEECH_TMC
nicht_aktiv
ISPEECH_TP_FUNKTION
nicht_aktiv
ISPEECH_TRF
nicht_aktiv
ISPEECH_VA_BPI
aktiv
ISPEECH_VA_FB
aktiv
ISPEECH_VA_FLAP_DICONFI
nicht_aktiv
ISPEECH_VA_FOND_CLIMATE
nicht_aktiv
ISPEECH_VA_SEATVENT
nicht_aktiv
ISPEECH_VIDEOMODUL
nicht_aktiv
ISPEECH_WEATHERBAND
aktiv
SORTING_VARIANT_2MULF
standard
CKS_BL_1
wert_06
GESCHW_NOT_PROGR_1
wert_01
GESCHW_TAB_1_0
kennlinie_01
GESCHW_TAB_1_1
kennlinie_01
GESCHW_TAB_1_2
kennlinie_01
GESCHW_TAB_1_3
kennlinie_01
GESCHW_TAB_1_4
kennlinie_01
KL_ABST_POSIT_LI_1
wert_01
KL_ANSCHLAG_OPT_LI_1
wert_01
KL_ANSCHLAG_WEICH_LI_1
wert_01
KL_HS_GRAD_LOW_1
wert_01
KL_NUL_LAGE_SENSOR_LI_1
wert_01
KL_RAMP_BREMS_1
wert_02
KL_REF_SPEED_1
wert_01
KL_SIZE_RAMP_BESCH_1
wert_01
KL_SIZE_RAMP_BREMS_1
wert_01
LWR_ABST_POSIT_1
wert_04
LWR_ANSCHLAG_OPT_1
wert_03
LWR_ANSCHLAG_WEICH_1
wert_03
LWR_HS_GRAD_LOW_1
wert_03
LWR_HS_GRAD_WERT_1
wert_03
LWR_MAX_WERT_START_1
wert_01
LWR_MAX_WINKEL_MIN_1
wert_03
LWR_MAX_WINKEL_PL_1
wert_03
RAMPE_ZUS_1_0
kennlinie_1
RAMPE_ZUS_1_1
kennlinie_1
RAMPE_ZUS_1_2
kennlinie_1
RAMPE0_BL_1_0
kennlinie_01
RAMPE0_BL_1_1
kennlinie_01
RAMPE0_BL_1_3
kennlinie_01
RAMPE1_BL_1_0
kennlinie_01
RAMPE1_BL_1_1
kennlinie_01
RAMPE1_BL_1_2
kennlinie_01
RAMPE1_BL_1_3
kennlinie_01
RAMPE2_BL_1_0
kennlinie_01
RAMPE2_BL_1_1
kennlinie_01
RAMPE2_BL_1_2
kennlinie_01
RAMPE2_BL_1_3
kennlinie_01
RAMPE3_BL_1_0
kennlinie_01
RAMPE3_BL_1_1
kennlinie_01
RAMPE3_BL_1_2
kennlinie_01
RAMPE3_BL_1_3
kennlinie_01
STROM_NORMAL_LWR_1
wert_02
STROM_RAMPE_LWR_1
wert_02
RAMPE0_BL_1_2
kennlinie_01
KL_ABST_POSIT_RE_1
wert_01
KL_ANSCHLAG_OPT_RE_1
wert_01
KL_ANSCHLAG_WEICH_RE_1
wert_01
KL_NUL_LAGE_SENSOR_RE_1
wert_01
MIL_SCAN_TOOL
wert_01
PADDLES
wert_00
MOTORISIERUNG_2
wert_01
ABA_ABP
nicht_aktiv
BERGAB_GERAST_C04
wert_00
BERGAB_KENNEN_C04
wert_00
BERGABANSATZ
wert_01
BREMSLUFTKLAPPE_04
nicht_aktiv
C_AAT_SCHUB_AUS_OFFSET
wert_00
C_AAT_SCHUB_EIN_KORR_SKAL
wert_00
C_AAT_SCHUB_EIN_OFFSET
wert_00
FDB
nicht_aktiv
FZG_MASSE_04
wert_00
MOTOR_LEISTUNG_MAX_04
wert_00
P_AUSROLL_ANTRIEB_04
wert_00
CAN_MESSAGE
wert_02
JUMP_RDC_RPA_MENU
nicht_aktiv
AAT_SCHUB_AUSST_OFFS
wert_02
AAT_SCHUB_EINST_OFFS
wert_02
ABSTANDSSTUFE_INIT_LDM
wert_04
AKT_STILLST_FREIF
aus
AKTIV_FREIF_U_30
aus
AUTO_LOSF_WARTEZEIT
wert_01
AUTOM_LOSFAHREN
ein
AX_MAX_SKAL
wert_01
AX_MIN_SKAL
wert_01
BERGABANSATZ_LDM
aus
C_ACC_FKT_DSC
dsc
C_ANZ_FPD_GETR
ein
C_BEDSTAT
ein
C_DCC_FKT_DSC
dsc
C_DEAKT_ZOV_ACC30_MIN
aus
C_RGL_STEHENDE_ZO
aus
CAC_AKTIV
aktiv
CAC_NAVI_A_QUER
aus
CAC_SKAL_A_QUER
wert_01
CDS_AX_NEG_FEIN
wert_01
CDS_AX_NEG_GROB
wert_01
DEAKT_SCHEINFEHLER_1
aus
DEAKT_SCHEINFEHLER_2
aus
DEAKT_SCHEINFEHLER_3
aus
DEAKT_SCHEINFEHLER_4
aus
DIC_AKUT_WARN_PCW
ein
DIC_SCHW_IST_ZEITL_OBJ
wert_01
DIC_VOR_WARN_PCW
ein
DS_AX_POS_FEIN
wert_01
DS_AX_POS_GROB
wert_01
DSC_ABSCHALTUNG
ein
DYN_ROLLRADIUS
wert_01
ENTW_HIL_TEST
aus
EXIT_NO_DYN
aus
EXT_FZG_VERLASS_WARN
hupe_und_blink
FAHRFUNKTION
keine_funktion
FUS_DX_LRR
wert_01
FUS_DX_SRR_LINKS
wert_01
FUS_DX_SRR_RECHTS
wert_01
GETRIEBETYP
egs
GW_PBA_PARA_DBC
ein
GW_PBA_VORBEFUELLUNG
ein
HANDGAS_AKTIV
ein
HDC_VORHANDEN
aus
IPM_P_MAX
p270kw
IPM_P_MIN
wert_01
LAENDERVARIANTE_LDM
us
LANGTIPPEN
ein
M_ANHAENGER
wert_01
M_FZG_LDM
e60_e64_n62
MANIPUL_DRASY_PT
aus
NAVI
ein
NAVI_DYNAMIK_ON_OFF
ein
NAVI_FAHRSCHLAUCH
aus
PBA_FUNKTION_AKTIV
ein
RESERVE
frei
SCHUB_EINST_KORR_SKAL
n62
SCHUBABSCHALTUNG_LDM
aus
SKAL_IPM_LEISTUNGSRES
wert_01
SKAL_LEISTBEGR_OBEN_BERG
wert_01
SKAL_PMIN_AUSROLL
wert_01
SKAL_PMIN_BERGAB_AUSST
wert_01
SKAL_PMIN_BERGAB_ERK
wert_01
SKAL_PMIN_BRGB_GRST
n62
SPURW_DYN_FLAG
aus
SRR_DEJU_WINKEL
wert_04
SRR_DEJU_ZAEHLER
wert_01
SSC_VERZ_VERST_ON_OFF
ein
TOR_DYN_SCHWELLE_ACCRGLT
wert_03
TOR_DYN_SCHWELLE_SUS
wert_01
TOR_IM_SUSPEND
ein
TOR_STAT_SCHWELLE_ACCRGLT
wert_03
TOR_STAT_SCHWELLE_SUSP
wert_03
TREE_STABILITY_ON_OFF
ein
UMSCH_ACC_DCC
unterdruecken
V_WUNSCH_ACC_MAX_KMH
wert_01
V_WUNSCH_ACC_MAX_MPH
wert_01
V_WUNSCH_DCC_MAX_KMH
wert_01
V_WUNSCH_DCC_MAX_MPH
wert_02
V_WUNSCH_DELTA_FEIN_KMH
wert_01
V_WUNSCH_DELTA_FEIN_MPH
wert_01
V_WUNSCH_DELTA_GROB_KMH
wert_01
V_WUNSCH_DELTA_GROB_MPH
wert_01
V_WUNSCH_MIN_KMH
wert_01
V_WUNSCH_MIN_MPH
wert_01
VAR_FESTSTELLBREMSE
handbremse
VARIANTE_ANZEIGE_LDM
l6w
VARIANTE_BEDIENUNG
lenksth_2stuf
VARIANTE_MOTOR
benzin_8_zyl
ZEITLUECKE_1
wert_01
ZEITLUECKE_2
wert_01
ZEITLUECKE_3
wert_01
ZEITLUECKE_4
wert_01
IGR_CODIERUNG_0A
nicht_aktiv
IGR_HERSTELLER_0A
nicht_aktiv
LCL
nicht_aktiv
ACC_E60_APPL_MONITOR
nicht_aktiv
TWO_MICROPHONES_ULF2
wert_01
VMAX-BEGRENZUNG-6ZYL_C0C
wert_07
ALBV_TOGGLE_APP
nicht_aktiv
BGSCREEN_JUMP
aktiv
DAB_FROM_FM
wert_01
DAB_TO_FM
wert_01
MEDIA_CHAR_ENCODING
iso
MM_DEVICE
nicht_aktiv
MM_DEVICE2
nicht_aktiv
NEXT_SOURCE
nicht_aktiv
OLD_TELEMAT_STRUCT
nicht_aktiv
TLC
nicht_aktiv
VA_HANGUL_TYPEWRITER
nicht_aktiv
VA_KANJI_TYPEWRITER
nicht_aktiv
TDA_ASC_STATUS
nicht_aktiv
TDA_ATM_CALL_ID
standard
TDA_ATM_INTERVAL
standard
TDA_ATM_START_TIME
standard
TDA_BDA_STATUS
nicht_aktiv
TDA_CFG_AUTO_TRIG
nicht_aktiv
TDA_CFG_CUST_MOBILE_USE
aktiv
TDA_CFG_HLC_DATA
nicht_aktiv
TDA_CFG_IND_PDM_GR_NBR
file0
TDA_CFG_SER_ERR_SINK
aktiv
TDA_CFG_VEHICLE_SER
nicht_aktiv
TDA_DEACTIVATE_STATUS
aktiv
TDA_HLC_STATUS
nicht_aktiv
TDA_MSC_STATUS
nicht_aktiv
TDA_SERVICE_STATUS
nicht_aktiv
TDA_TDC_STATUS
nicht_aktiv
MDRIVE_LOW_CCC
nicht_aktiv
AB_BOOST
wert_02
AB_DIMM
wert_02
AEND_IND
wert_02
BOOST-KL_Y
wert_02
BOOST_SA_PWM
wert_02
BOOST_ZB
wert_02
CAN_IND
wert_02
CHECK_SUM_DIMM_BLOCK
grundcode_var
CSUM_ID-DATEN
grundcode_var
CSUM_KENNLINIEN
grundcode_var
DIMM-BOOST-FB
wert_02
DIMM-DAEM-AB
wert_02
DIMM-DAEM-AUF
wert_02
DIMM-HYST
wert_02
DIMM_AUS_KL_X8
wert_02
DIMM_AUS_KL_Y8
wert_02
DIMM_MIN
wert_02
EIN_ST_MON
wert_02
EINBAUORT
wert_02
ER_DIMM-X1
wert_02
ER_DIMM-X2
wert_02
ER_DIMM-X3
wert_02
ER_DIMM-X4
wert_02
ER_DIMM_Y1
wert_02
ER_DIMM_Y2
wert_02
ER_DIMM_Y3
wert_02
ER_DIMM_Y4
wert_02
FAHRZEUG_CID
wert_02
FOTO-HYST
wert_02
FOTOTRANS_X8
wert_02
FOTOTRANS_Y8
wert_02
GROESSE
wert_02
HW_IND
wert_02
MODELL
wert_02
MODUS
wert_02
NTC_X
wert_02
NTC_Y
wert_02
OV_SW_OFF
wert_02
OV_SW_ON
wert_02
OV_TL
wert_02
RED_DIMM
wert_02
SCHWELLE/TAG_NACHT
wert_02
TEMP_BER-1_2
wert_02
TEMP_BER-2_3
wert_02
TEMP_FLAG_AUS
wert_02
TEMP_FLAG_EIN
wert_02
TEMP_X8
wert_02
VSYNC_DELAY
wert_02
ALPHA
e6x_hi
AMBIENT_LUMINANCE_AXIS
e6x_hi
BETA
e6x_hi
BOUNDARY_DAY_NIGHT
e6x_hi
BOUNDARY_NIGHT_MIN
e6x_hi
CB_START_TEMPERATURE
e6x_hi
CFL_PROTECT_TEMP
e6x_hi
CHECKSUM_CID
e6x_hi
DELTA_BOUNDARY
e6x_hi
DTC_VOLTAGE_THESHOLD
e6x_hi
GAMMA
e6x_hi
HI_TEMP_DET_CONT_TIME
e6x_hi
HIGH_VOLTAGE_LEVEL
e6x_hi
HIGH_VOLTAGE_RECOVERY
e6x_hi
LCD_PWM_CURVE
e6x_hi
LCD_SHUT_DOWN_TIMING
e6x_hi
LOOP_CYCLE_COUNTER
e6x_hi
LOW_VOLTAGE_LEVEL
e6x_hi
LOW_VOLTAGE_RECOVERY
e6x_hi
MAX_DELTA
e6x_hi
MAX_OFFSET
e6x_hi
PHOTO_SENSOR_HYSTERESIS
e6x_hi
PWB_HI_TEMP_THRESHOLD
e6x_hi
PWB_SHUT_DOWN_WAIT_TIME
e6x_hi
PWM_REDUCTION_CURVE
e6x_hi
PWM_SECUR_REDUC_RATE
e6x_hi
PWM_STEP_ADDITION_10V
e6x_hi
PWM_STEP_ADDITION_12V
e6x_hi
PWM_STEP_ADDITION_14V
e6x_hi
PWM_STEP_ADDITION_16V
e6x_hi
PWM_STEP_ADDITION_9V
e6x_hi
PWM_TEMP_OBSERVING_TIME
e6x_hi
START_TEMP_T1
e6x_hi
STOP_TEMP_T2
e6x_hi
TEMPERATURE_AXIS
e6x_hi
TRAVEL_TIME_DOWN
e6x_hi
TRAVEL_TIME_UP
e6x_hi
ENABLE_KL_GR_BL
nicht_aktiv
ENABLE_KL_VA
nicht_aktiv
PWM_BL1__GR_BL
wert_03
PWM_BL1__KL_BL
wert_02
PWM_BL2__GR_BL
wert_03
ACC_TIMER_AKTIV_ERFOLGLOS
acc_erfolglos_timer
RPA_WARNSCHWELLW_1
wert_04
RPA_WARNSCHWELLW_2
wert_04
RPA_WARNSCHWELLW_3
wert_04
RPA_WARNSCHWELLW_4
wert_04
AKTUATOR_DIAGNOSE
aktiv
BRK_ACT_THR
wert_02
CRD_OUT_BND
wert_02
CRV_TLC_RDC
wert_02
CSUM_AKTUATOR_DIAGNOSTIC
grundcode_var
CSUM_ALGO_PARAMETER_1
grundcode_var
CSUM_ALGO_PARAMETER_2
grundcode_var
CSUM_ALGO_PARAMETER_3
grundcode_var
CSUM_ALGO_PARAMETER_4
grundcode_var
CSUM_ALGO_PARAMETER_5
grundcode_var
IN_CRV_SHF
wert_02
IN_CRV_THR
wert_02
IN_RST_FCT
wert_02
IN_RST_OFF
wert_02
MAX_WARNING_DISTANCE
wert_02
MIN_LN_WDT
wert_02
NRR_LN_WDT
wert_02
OUT_CRV_SHF
wert_02
OUT_CRV_THR
wert_02
OUT_RST_OFF
wert_02
RD_BND_SHF
wert_02
SPEED_TURN_OFF
wert_02
SPEED_TURN_ON
wert_02
STE_RAT_THR
wert_02
T_ENB
wert_02
T_MAX_WRN
wert_02
T_MIN_WRN
wert_02
T_NOT_WRN
wert_02
TIME_00
wert_01
TIME_01
wert_01
TIME_02
wert_01
TIME_03
wert_01
TIME_TO_LANE_CROSSING
wert_02
TLC_ANZEIGE_VARIANTE
anz_variante_01
TLC_START_VARIANTE
last_function_mode
TURNOFF_HYSTERESIS_OFF
wert_02
WARNING_LINE_DISTANCE
wert_02
SCHALT_HINW_ALIVE_MONITOR
nicht_aktiv
SCHALT_HINW_CSUM_MONITOR
nicht_aktiv
DCC_DTC
wert_01
MESSBOTSCH_EIN
aus
PATCH_BOTSCH_FAHRB
aus
PATCH_FAHR_SITZBLG
aus
ABSCHALTZEIT_IR
e60chl
AUDIO_OFFSET_AUX1
e60chl
AUDIO_OFFSET_AUX2
e60chl
CHAUFFEURSMODE
e60chl
PHONE_TYPE_JAPAN
nicht_aktiv
AUX_IN_GAIN
wert_01
ISPEECH_CA_TMC
nicht_aktiv
ISPEECH_MASK
nicht_aktiv
ISPEECH_UNIT_FEET
aktiv
MIC_SOURCE
mic_from_most_or_no_mic
USB_HUB
nicht_aktiv
FESTLAGER_POS
wert_01
LRR_FUNKTION_1
wert_05
SENSOR_EINBAULAGE_VERT
wert_01
AUTOMATIC_LIGHT_NEW
nicht_aktiv
SITZHEIZUNG_SLIDER_D
nicht_aktiv
SVS_LOW_D
nicht_aktiv
AUXIN_CHAMP_31
aktiv
ENTERT_NEXTSOURCE_CHAMP
aktiv
HUD_POSITION
nicht_aktiv
LEGAL_DISCL_TIMEOUT_CH
aktiv
SITZHEIZUNG_CHAMP_31
nicht_aktiv
SITZHEIZUNG_APP_9
nicht_aktiv
VIDEOMODUL_CCC_9
nicht_aktiv
DEFAULT_ONTIME
standard
FBD_COMFORT_OPEN_LF_PING
nicht_aktiv
PA_TBEREIT_HK
wert_01
ENABLE_RL1_ERS_BL1
nicht_aktiv
IGR_MIT_SL_AL
aktiv
PWM_ANSTEUERUNG_AL_33
wert_01
PWM_ANSTEUERUNG_KZL_33
wert_01
PWM_RL1_ERS_BL1
wert_01
SONDERKANAL_DIRAC_BYPASS
ein
CHECKSUMME_EKP3
wert_08
DATUM_UND_PUMPEN_ID
wert_08
FEHLERLIMITS
wert_08
FUNKTIONEN
wert_08
KENNLINIEN
wert_08
PUMPEN_PARAMETER
wert_08
SW_I_FAHRWERKVARIANTE
wert_16
SW_I_FAHRZEUGVARIANTE
wert_16
PDC_ADAPTION_F_R_1
e64_top_hifi
RATIO_AUDIO_SOURCES_1
e64_top_hifi
VOL_GONG_MAX_1
e64_top_hifi
VOL_GONG_MIN_1
e64_top_hifi
VOL_PDC_MAX_1
e64_top_hifi
VOL_PDC_MIN_1
e64_top_hifi
MDRIVE_SMG_MASK
aktiv
CCC_E71
nicht_aktiv
NAVI_PFEIL
aktiv
TELESERVICE
nicht_aktiv
AUSSTATTUNG_RPA_EHB
aktiv
MAX_PHONE_VOL_06
standard
ONLINE_DISABLE_CONTENT_6
content_disable_vmax
ONLINE_DISABLE_VMAX_6
disable_us
PWM_ANSTEUERUNG_FL_33
wert_02
WL_BL
nicht_aktiv
WL_SM
soft_einschalten
SW_I_VCH_FAHRZEUGVAR
wert_02
SRR_MISALIGN_COMP
ein
ZOV_VARIANTE
zov_verm_dyn
VMAXCODIERUNG_EK928
wert_01
DECAY
e60chl
HOLDTIME
e60chl
KOMP_ENABLE
e60chl
POST_GAIN
e60chl
CCM_0X42_IM_NACHLAUF
nicht_aktiv
NLF_AUS_ALLE_TUEREN
nicht_aktiv
BASE_FEHL_EINTR_1
wert_01
OFFSET_FEHL_EINTR_1
wert_01
UNTER_KORREKT_WERT_1
wert_03
GESCHW_ABH_SPERREN_AKTIV
wert_02
GESCHW_ABH_SPERREN_ENTPR
wert_02
GESCHW_ABH_SPERREN_SCHW
wert_02
SHD_BLOCK_1_02
wert_05
SHD_BLOCK_1_03
wert_05
SOS_BLOCK_1_02
wert_04
ENTPRELLZEIT_IGR
wert_02
KONFIG_REGEN_AUS
aktiv
TYP_WISCHSYSTEM
mehr_stufen
VMAXCODIERUNG_ME17_ECE
wert_01
MSA_CODIERUNG
nicht_aktiv
VMAXCODIERUNG_MSD80N43
wert_01
A2DP_AUDIO_STREAMING
nicht_aktiv
AACN_DATA_SEND
aktiv
AVAIL_SERVICES_REPORTING
short
BEAMFORMING
nicht_aktiv
ECALL_TERMINATE_REDIAL
aktiv
GATS_SMSC_BACKUP
atxus_att
GATS_SMSC_DEFAULT
atxus_att
HANG_UP_E-CALL
nicht_aktiv
HIGH_POWER_MAX_TIME
8_minutes
IN_BAND_MODEM
aktiv
KEY_DATA_FETCH_BCALL
aktiv
KEY_DATA_FETCH_HOTLINE
aktiv
MAX_RS_ACTIVATIONS
wert_30
MOST_WAKEUP_LINE
aktiv
MULTIPLE_CALLS
nicht_aktiv
NAD_ALWAYS_ON
rs_provisioned
NAD_ALWAYS_ON_MAX_TIME
3_weeks
PARK_CONSUMER_TYPE
wert_00
POWER_FLLW_UP_THRESHHOLD
5_minutes
POWER_MONITOR_TYPE
kl_30b
POWER_SUBNETWORK_TYPE
short
RINGTONE
ringtone_1
SMS_TCU
nicht_aktiv
TCU_POWER_SOURCE
kl_30gf
TELEMATIC_AKD
aktiv
TELEMATIC_B-CALL
aktiv
TELEMATIC_DEALER_CALL
aktiv
TELEMATIC_E-CALL
aktiv
TELEMATIC_FCD
nicht_aktiv
TELEMATIC_HEATING_CONTROL
nicht_aktiv
TELEMATIC_HORN_CONTROL
nicht_aktiv
TELEMATIC_HOTLINE_CALL
aktiv
TELEMATIC_LIGHT_CONTROL
nicht_aktiv
TELEMATIC_MY_INFO
aktiv
TELEMATIC_RDL_CONTROL
nicht_aktiv
TELEMATIC_TRFFC_BY_VOICE
nicht_aktiv
TELEMATIC_VENT_CONTROL
nicht_aktiv
VCARD_OVER_MOST
nicht_aktiv
LWR_MAX_POS_NORM_2
wert_02
PATCH_FAHR_SITZBELEGUNG
aus
SRR_KORREKTUR
aus
AKTIVE_SPRACHE_08
leitsprache
SPRACHVERSION_C09
us
MILANSTEUERUNG_DDE7X
wert_01
MSA
nicht_aktiv
VMAX-BEGRENZUNG-N47
wert_01
SHOW_PDC_VOL_OFFSET
nicht_aktiv
SPRACHE_1_MASK_CHAMP
us
SPRACHE_2_MASK_CHAMP
franzoesisch
SPRACHE_3_MASK_CHAMP
spanisch
ONLINE_CALLSTRATEGY_M
use_csd_paketdata
DISPLAY_TYPE
siemens_8_8_fixed_new
LWR_DIAG_ANSTIEG
wert_02
LWR_DIAG_OFFSET
wert_01
PIAU_AKUST_SCHAERF
nicht_aktiv
PIAU_OPT_ENTSCH
aktiv
PIAU_OPT_SCHAERF
nicht_aktiv
PIAU_OPT_SCHAERF_KLAPPE
aktiv
GAMMA_TABLE_CONTROL
nicht_aktiv
A3C6_APPL_MONITOR
aktiv
A569_APPL_MONITOR_UEP
aktiv
DZM_UMRECHNUNG
wert_02
TORQUE_3_ID_MONITOR
aktiv
BAUDRATE_SBE_FAHRER
wert_01
HS_SPERRE_AKTIV
nicht_aktiv
ZEIT_PARKL_AKTIVIERUNG
wert_03
CITY_ABBLENDEN_KURZ_HB
wert_02
CITY_ABBLENDEN_KURZ_LB
wert_02
CITY_AUFBLENDEN_KURZ_HB
wert_02
CITY_AUFBLENDEN_KURZ_LB
wert_02
EMPFINDLICHKEIT_FARBLOS
wert_02
GESCHWINDIGKEIT_ABBLENDEN
wert_02
GESCHWINDIGKEIT_AUFBLEND
wert_02
SITZHEIZUNG_MASK
nicht_aktiv
NAV_LOV_AKTIV
aus
UEKB_AUSFAHREN
nicht_aktiv
UEKB_EINFAHREN
nicht_aktiv
MDRIVE_MENU
nicht_aktiv
RSEMIDPLUS_AVAILABLE
nicht_aktiv
SVR
nicht_aktiv
TV_FRONT_ENABLED
nicht_aktiv
VEHICLE_FINDER
nicht_aktiv
VIDEO_DENY_C0B
deny_slow_key
GET_POSITION_TIMEOUT
5_minuten
INBAND_MODEM_TIMER
wert_30
BERGAB_GERAST_C05
wert_00
BERGAB_KENNEN_C05
wert_00
C_AAT_SCHUB_EIN_KORR_05
wert_00
FLM
aktiv
SEAT
wert_00
ISPEECH_MDRIVEMENU
nicht_aktiv
ISPEECH_MMDEVICEVIAMULF
nicht_aktiv
ISPEECH_OLDTELEMAT_STRUCT
aktiv
ISPEECH_PDC_LOW
nicht_aktiv
ISPEECH_REG
aktiv
IGR_HERSTELLER_0D
nicht_aktiv
REAR_VIEW_CAM
nicht_aktiv
REG_FUNCTION
aktiv
STOLEN_VEHICLE_REC
nicht_aktiv
TOW_BAR
nicht_aktiv
AG_M_ALWR
wert_01
AHL2_ENABLE
aktiv
ALC_DIS_AUSGL_NICK_GW
nicht_aktiv
ALWR_ENABLE
nicht_aktiv
C1_HORI_BF
wert_01
C1_HORI_FA
wert_01
C1_VERT_BF
wert_01
C1_VERT_FA
wert_02
C2_HORI_BF
wert_01
C2_HORI_FA
wert_01
C2_VERT_BF
wert_01
C2_VERT_FA
wert_02
E__HORI_BF
wert_01
E__HORI_FA
wert_02
E__VERT_BF
wert_01
E__VERT_FA
wert_02
LWR_DIAG_ANSTIEG_2
wert_02
LWR_DIAG_OFFSET_2
wert_01
NSW_AUTOBAHN
wert_02
OFFSET_GESCHW
wert_02
REF_DEMO
wert_01
V__HORI_BF
wert_01
V__HORI_FA
wert_01
V__VERT_BF
wert_01
V__VERT_FA
wert_02
VERZ_REF_DEMO
wert_02
DSC_OFF
nicht_aktiv
KLEMME_15
wert_00
ABGASKLAPPE
wert_01
IGR_HERSTELLER_DDE
nicht_aktiv
KL_15_ANSTEUERUNG
wert_00
MDRIVE_MENUE
nicht_aktiv
OLD_TELEMATICS_STRUCTURE
aktiv
AUTO_DRV_LIGHT_CHAMP
nicht_aktiv
JUMP_RDC_RPA_MENU_CH
nicht_aktiv
SHOW_PDC_VOL_OFFSET_C31
nicht_aktiv
NEUES_FSE_KONZEPT
nicht_aktiv
PA_SUPERRANGE_R56
nicht_aktiv
CHECK_SUM_CRC
e64
FILTER_FZG_BLOCK_AMP_00
e64
FILTER_FZG_BLOCK_AMP_01
e64
FILTER_FZG_BLOCK_AMP_02
e64
FILTER_FZG_BLOCK_AMP_03
e64
FILTER_FZG_BLOCK_AMP_04
e64
FILTER_FZG_BLOCK_AMP_05
e64
FILTER_FZG_BLOCK_AMP_06
e64
FILTER_FZG_BLOCK_AMP_07
e64
FILTER_FZG_BLOCK_AMP_08
e64
FILTER_FZG_BLOCK_AMP_09
e64
FILTER_FZG_BLOCK_AMP_0A
e64
FILTER_FZG_BLOCK_AMP_0B
e64
FILTER_FZG_BLOCK_AMP_0C
e64
FILTER_FZG_BLOCK_AMP_0D
e64
FILTER_FZG_BLOCK_AMP_0E
e64
FILTER_FZG_BLOCK_AMP_0F
e64
FILTER_FZG_BLOCK_AMP_10
e64
FILTER_FZG_BLOCK_AMP_11
e64
FILTER_FZG_BLOCK_AMP_12
e64
FILTER_FZG_BLOCK_AMP_13
e64
FILTER_FZG_BLOCK_AMP_14
e64
FILTER_FZG_BLOCK_AMP_15
e64
FILTER_FZG_BLOCK_AMP_16
e64
FILTER_FZG_BLOCK_AMP_17
e64
FILTER_FZG_BLOCK_AMP_18
e64
FILTER_FZG_BLOCK_AMP_19
e64
FILTER_FZG_BLOCK_AMP_1A
e64
FILTER_FZG_BLOCK_AMP_1B
e64
FILTER_FZG_BLOCK_AMP_1C
e64
FILTER_FZG_BLOCK_AMP_1D
e64
FILTER_FZG_BLOCK_AMP_1E
e64
FILTER_FZG_BLOCK_AMP_1F
e64
FILTER_FZG_BLOCK_AMP_20
e64
FILTER_FZG_BLOCK_AMP_21
e64
FG_AQUER_SEKUNDAER
wert_01
ACC_CIC
nicht_aktiv
ACC_SGN
nicht_aktiv
ACTIVE_BACKREST_ADJ
nicht_aktiv
ADRESSBOOK
aktiv
AF_FUNKTION
af_aus
AREA_CODE_DVD
area_code_1
ASSIST
aktiv
ASSIST_AKD
aktiv
ASSIST_AUTOMATIC_SERVREQ
aktiv
ASSIST_BCALL
aktiv
ASSIST_ECALL
aktiv
ASSIST_FCD
aktiv
ASSIST_HOTLINE
aktiv
ASSIST_INITIALIZATION
aktiv
ASSIST_MY_INFO
aktiv
ASSIST_REMOTE_DOORLOCK
nicht_aktiv
ASSIST_REMOTE_HORNLIGHT
nicht_aktiv
ASSIST_REMOTE_HVAC
nicht_aktiv
ASSIST_SERVREQ
aktiv
ASSIST_SVR_SHOW
aktiv
ASSIST_VEHICLEFINDER_SHOW
nicht_aktiv
ASSIST_VI_PLUS
aktiv
AUDIO_SYSTEM_CIC
top_hifi
AUX1
standard
AUX2_INTEGRATED_IN_RSE
wert_255
AUX4
standard
BACKDOOR_OPENINGANGLE
nicht_aktiv
BEHANDLUNG_2S_TIMER
aktiv
BRAKE_ASSISTENT
nicht_aktiv
CDMM_AUX_HU
aktiv
CDMM_BLUETOOTH_AUDIO
nicht_aktiv
CDMM_DVD_SINGLE
aktiv
CDMM_ES
aktiv
CDMM_TV_AUDIOTRACE
nicht_aktiv
CDMM_TV_AUTOSTORE
nicht_aktiv
CDMM_TV_BML
nicht_aktiv
CDMM_TV_EPG
nicht_aktiv
CDMM_TV_FOLLOWING
nicht_aktiv
CDMM_TV_PRESETLIST
nicht_aktiv
CDMM_TV_TELETEXT
nicht_aktiv
CDMM_USB
nicht_aktiv
CDMM_USB_AUDIO_DOUBLE
nicht_aktiv
CDMM_USB_AUDIO_SINGLE
nicht_aktiv
CDMM_VIDEO
aktiv
CONTACT_NUMBERS_BCALL
aktiv
CONTACT_NUMBERS_BT
aktiv
CONTACT_NUMBERS_DEALER
aktiv
CONTACT_NUMBERS_HOTLINE
aktiv
DAB_LAENDERVARIANTEN
nicht_aktiv
DCC
nicht_aktiv
DKG_CIC
nicht_aktiv
DOOR_LOCKING_SELECTABLE
aktiv
DVDAUDIO_AOP
nicht_aktiv
DVDVIDEO_AOP
nicht_aktiv
EDC_CIC
nicht_aktiv
ENTWICKLER_MENUE
nicht_aktiv
ENTWICKLER_MENUE_ASIEN
nicht_aktiv
EXTERNER_MOST
aktiv
FGR
aktiv
FOLLOWING_AVAILABLE
aktiv
GUIDED_TOURS
nicht_aktiv
GUIDING_TIMING
us
HEADUP_DISPLAY
nicht_aktiv
HVAC_INDEPENDENT_HEATING
nicht_aktiv
IPD_BEHANDLUNG
nicht_aktiv
KOPIEREN_VON_PROFILEN
aktiv
LANE_DEPARTURE_WARNING
nicht_aktiv
MACRO_CAM_LEGALDISCLAIMER
ld_mit_timeout
MACRO_NIVI
nicht_aktiv
MACRO_NIVICAM_LDISCLAIMER
ld_mit_timeout
MACRO_PDC
aktiv
MACRO_PDC_TOPVIEW
nicht_aktiv
MACRO_PMA
nicht_aktiv
MACRO_REARVIEW
nicht_aktiv
MACRO_SIDEVIEW
nicht_aktiv
MACRO_TRAILER_COUPLING
nicht_aktiv
MICROPHONE
one_mic_steering_column
MMC_CIC
wert_255
MMS
standard
MULTICHANNEL_MMC_DVD
nicht_aktiv
NAVI_2D_MAP_OPTIONS
nicht_aktiv
NAVI_3D_MAP_OPTIONS
nicht_aktiv
NAVI_FLEET_MODE
nicht_aktiv
NAVI_MAPMODE_AUTOMATIC
nicht_aktiv
NAVI_MAPSCROLL_LIGHTBEAM
aktiv
NAVI_MECCA_INDICATOR
nicht_aktiv
NAVI_ROAD_PREVIEW
nicht_aktiv
NAVI_SHOW_GEOCORDINATES
aktiv
NAVI_TRAFFIC_INFO_MAP
nicht_aktiv
NAVI_USE_WHILE_UPDATE
aktiv
NVC
wert_255
ONLINE_CONFIG_TABLE_INDEX
config_table_1
PHONE_MPC
nicht_aktiv
PHONE_OBJPUSH_MENUE
nicht_aktiv
PHONE_SMS
nicht_aktiv
PIA_MMI
kein_pia_menue
PIA_PORTIERUNGSMASTER
aktiv
PIA_RESERVED
nicht_aktiv
PIA_RUECKSETZEN_DEFAULT
aktiv
POI_DETAILS
aktiv
PORTIERUNG
aktiv
RADIO_DAB
nicht_aktiv
RADIO_IBOC
nicht_aktiv
RADIO_SDARS
nicht_aktiv
RADIO_WEATHERBAND
aktiv
RGB_YUV_AUX1
reserved
RPA_CIC
aktiv
RSE_INTERNAL_VIDEO_PLAYBK
wert_255
RVC_CIC
wert_255
SERVICE_MENUE
aktiv
SHUTDOWN_DELAY_TIMER_1
wert_01
SHUTDOWN_DELAY_TIMER_2
wert_01
SIDE_VIEW_CAMERA
wert_255
SMG
aktiv
SPRECHERWAHL1
weiblich
SPRECHERWAHL2
weiblich
SPRECHERWAHL3
weiblich
SYSTEM_GPS_RECEIVER
aktiv
SYSTEM_TTS
aktiv
TDA_ASC_STATUS_CIC
nicht_aktiv
TDA_ATM_ACTIVE_CIC
nicht_aktiv
TDA_BDA_STATUS_CIC
nicht_aktiv
TDA_CFG_SER_ERR_SINK_CIC
aktiv
TDA_DEACTIVATE_STATUS_CIC
aktiv
TDA_HLC_STATUS_CIC
nicht_aktiv
TDA_MSC_STATUS_CIC
nicht_aktiv
TDA_TDC_STATUS_CIC
nicht_aktiv
TELEX
nicht_aktiv
TI_CA_TMC
nicht_aktiv
TI_CA_TPEG
nicht_aktiv
TI_DETOUR_BUTTON_DISABLED
nicht_aktiv
TI_FALLBACK_DISABLED
nicht_aktiv
TI_POPUPS_DISABLED
nicht_aktiv
TI_TMC
nicht_aktiv
TI_TMC_REGIONAL
nicht_aktiv
TI_TPEG
nicht_aktiv
TI_USE_COMBI_DISABLED
nicht_aktiv
TI_VICS
nicht_aktiv
TI_VINFO_SERVICES
nicht_aktiv
TIMER_VOLLBILDKARTE
permanent
TV
wert_255
TVC
wert_255
TVM_VARIANTEN
kein_tvm
USB_AVAILABLE
aktiv
YC_AUX1
reserved
YC_AUX4
reserved
CC_ID_AKTIV_7
aktiv
IGR_HERSTELLER_1A
nicht_aktiv
ISPEECH_TELESERVICE
nicht_aktiv
ASSIST_AKD_SHOW_READ
nicht_aktiv
ASSIST_ECALL_CALL_HANGUP
nicht_aktiv
CDMM_USB_AUDIO_AZ_SEARCH
nicht_aktiv
COMBOX
nicht_aktiv
HIGH_BEAM_ASSISTANT
nicht_aktiv
HVAC_AIRLAMINATION_CODRV
nicht_aktiv
HVAC_AIRLAMINATION_DRV
hvac_high
HVAC_AUTOMATIC_INTENSITY
aktiv
HVAC_CABRIO
aktiv
HVAC_FOND_ACTIVATION
nicht_aktiv
HVAC_INDEPENDENT_AIR
aktiv
HVAC_POPUP_AIRDISTR
aktiv
HVAC_POPUP_AUTO_TOGGLE
aktiv
INTERVAL_LCP_ECHO_REQUEST
value_0
LCP_ECHO_REQUEST
aktiv
NAVI_RNC_MAINMAP_TEXT
permanent
NIGHTVISION_1
nicht_aktiv
ONLINE_BROWSER
nicht_aktiv
PHONEBOOK_PRIORITY_C12
wert_02
ROI_EXTENT_VERTICAL
wert_02
PA_TAGE_REAR_RL_MIRROW
nicht_aktiv
SRR_BLINDHEITSERKENNUNG
aktiv
DECAY_C0A
rse_mid
DELAY_AV_INPUT_DIAG_C0A
rse_mid
HOLDTIME_C0A
rse_mid
KOMP_ENABLE_C0A
rse_mid
POST_GAIN_C0A
rse_mid
SCHWELLE_KHM
rse_mid
SCHWELLE_KL_30_AUDIO_C0A
rse_mid
SCHWELLE_KL_30_VIDEO_C0A
rse_mid
SCHWELLE_KL_31_AUDIO_C0A
rse_mid
SCHWELLE_KL_31_VIDEO_C0A
rse_mid
ONLINE_DAR_TYPE_KORR
dar_us
ALC_OFFSET_LWR_34
wert_31
E3_HORI_BF
wert_01
E3_HORI_FA
wert_01
E3_VERT_BF
wert_01
E3_VERT_FA
wert_01
F_A_ALWR
wert_01
F_ALWR
wert_01
F_SWEG_ALWR
wert_01
GL_ALWR
wert_01
LWR_HEBEL_34
wert_03
MAX_KRUEMM
wert_01
PWM_AN_BLK_H_34
wert_02
PWM_AN_SL_V_AL_1_34
wert_07
PWM_AN_SL_V_FL_1_34
wert_08
PWM_ANSTEUERUNG_RFS_34
wert_01
PWM_PIN_05_62_34
wert_02
R_SWEG_ALWR
wert_01
STRST_MAXDIFF_ALWR
wert_01
T_ALWR_AM
wert_01
T_ALWR_AUS
wert_01
T_ALWR_MKR
wert_01
T_ALWR_NST
wert_01
T_ALWR_SW
wert_01
V_ALWR_AM
wert_01
V_ALWR_AN
wert_01
V_ALWR_AUS
wert_01
V_ALWR_BAB1
wert_01
V_ALWR_BAB2
wert_01
V_HI_AUTOB
wert_01
V_HI_STADT
wert_01
V_LO_AUTOB
wert_01
V_LO_STADT
wert_01
V_MID_LANDSTR
wert_01
V_MIN_KRUEMM
wert_01
V_NSW
wert_01
W_ALWR_EKR
wert_01
W_ALWR_MKR
wert_01
W_ALWR_SW
wert_01
WEG_GERADE
wert_01
Z_ALWR_NST
wert_01
Z_ALWR_SW
wert_01
ZEIT_AUTOB
wert_01
PWM_ANSTEUERUNG_FL_34
wert_02
BERGABANSATZ_05
wert_00
PEAK_THRESHOLD_END_HB
wert_01
PEAK_THRESHOLD_END_LB
wert_01
PEAK_THRESHOLD_HB
wert_01
PEAK_THRESHOLD_LB
wert_01
SRR_SCHWELLWERT_ANPASSUNG
aktiv
STRETCH_THRESHOLD_HB
wert_01
STRETCH_THRESHOLD_LB
wert_01
ONLINE_DAR_TYPE_B
dar_us
BL_POWER_OFF
e6x_88s
BL_POWER_ON
e6x_88s
CHECKSUM_CID_A
e6x_88s
CHECKSUM_RECALC
e6x_88s
DAY_MAX
e6x_88s
DAY_MAX_BRIGHTNESS
e6x_88s
DAY_MIN
e6x_88s
DAY_MIN_BRIGHTNESS
e6x_88s
DIM_DIFF_BIAS
e6x_88s
DIM_DIFF_GAIN
e6x_88s
DIM_DIFF_MAX
e6x_88s
DIM_DIFF_MIN
e6x_88s
DIM_DIFF_THR
e6x_88s
DIM_DOWN_MIN
e6x_88s
DIM_TOLERANZ_ABS
e6x_88s
DIM_TOLERANZ_ALPHA
e6x_88s
DIM_UP_MIN
e6x_88s
ECU_HIGHTMP_CTL_TIME
e6x_88s
ECU_HIGHTMP_THRESH
e6x_88s
FRAME_RATE
e6x_88s
HIGHTMP_X
e6x_88s
HIGHTMP_Y
e6x_88s
NIGHT_MIN
e6x_88s
NIGHT_MIN_BRIGHTNESS
e6x_88s
NO_SIGNAL_BLUE
e6x_88s
NO_SIGNAL_GREEN
e6x_88s
NO_SIGNAL_RED
e6x_88s
NOT_USED_1
e6x_88s
NOT_USED_2
e6x_88s
NOT_USED_3
e6x_88s
NOT_USED_4
e6x_88s
NOT_USED_5
e6x_88s
NOT_USED_7
e6x_88s
NOT_USED6
e6x_88s
OFFSET_MAX
e6x_88s
PARAM_ALPHA
e6x_88s
PARAM_BETA
e6x_88s
PARAM_GAMMA
e6x_88s
PHOTO_X
e6x_88s
PHOTO_Y
e6x_88s
PWM_ADDITIONAL10
e6x_88s
PWM_ADDITIONAL12
e6x_88s
PWM_ADDITIONAL14
e6x_88s
PWM_ADDITIONAL16
e6x_88s
PWM_ADDITIONAL9
e6x_88s
SCALING
e6x_88s
SCREEN_DISPLAY_HENAB
e6x_88s
SCREEN_DISPLAY_VENAB
e6x_88s
SURPRESS_DTC
e6x_88s
T_AD
e6x_88s
T_FE
e6x_88s
T_FESU
e6x_88s
T_KB
e6x_88s
T_NS
e6x_88s
TEMP_THRESHOLD
e6x_88s
TEMP_THRESHOLD_SW
e6x_88s
VOLTAGE_LCD_OFF17
e6x_88s
VOLTAGE_LCD_OFF8
e6x_88s
VOLTAGE_LCD_ON16
e6x_88s
VOLTAGE_LCD_ON9
e6x_88s
WATCHDOG
e6x_88s
TIP_IN_D
wert_02
CAN_WECKEN
wert_01
ENTPRELLZEIT_SENSOREN
wert_01
ERROR_MASK_Z
wert_01
GESCHWINDIGKEITSSCHWELLE1
wert_03
GESCHWINDIGKEITSSCHWELLE2
wert_04
SUCHBEL_PWM_MAX_Z
wert_04
SUCHBEL_PWM_MIN_Z
wert_03
U_MAX_FS_Z
wert_01
U_MIN_FS_Z
wert_01
ZEIT_LANGDRUCK
wert_02
ZEIT_UNWIRKSAM
wert_01
KHV_DREHRICHTUNG_FAS
wert_01
MOTORSTECKERMAPPING
wert_01
KHV_DREHRICHTUNG_BFS
wert_01
SW_I_FAHRWERKVARIANTE_B
wert_16
SW_I_FAHRZEUGVARIANTE_B
wert_16
SW_I_PUMP_LG_ABH
wert_02
SW_I_ZTOTAL0B
wert_07
NOT_SENS_DEF_SN
wert_01
VIDEOMODUL_CCC_B
nicht_aktiv
PDC_FULL
aktiv
AUX3_IN_RSE_RIGHT_SCREEN
wert_255
BAUREIHE_CIC
e64
CBS_VERSION_3_LOWER
aktiv
CDMM_DVD_AOP_AUTOMATIC
nicht_aktiv
COUNTRY
us
DAB_DABFOLLOWING
aktiv
DAYDRIVING_LIGHT
standard
DISPLAY_VARIANTE
breites_display
DOORLOCKING_SEATMEMORY
aktiv
FDS_POPUP_DEACTIVATE
nicht_aktiv
FM_HIGH_CUT
kurve_1
FOLLOWING_DAB_FM
aktiv
GPS_FROM_NAVI
aktiv
GUIDING_KOMBI_HUD
rueko_mit_hud
GYRO_INTERN
aktiv
HDC_CIC
nicht_aktiv
HU_INTERNAL_VIDEO_PLAYBK
wert_51
HVAC_POPUP_SEATCLIMATE
nicht_aktiv
HVAC_SEATCLIMATE_LED
nicht_aktiv
HVAC_SEATHEAT_DISTR_FOND
nicht_aktiv
HVAC_SEATHEAT_DISTR_FRONT
nicht_aktiv
HVAC_SEATVENTILATION_FOND
nicht_aktiv
HVAC_SEATVENTILATION_FRNT
nicht_aktiv
HYBRID
nicht_aktiv
IBA
nicht_aktiv
IHKA_VARIANTE
keine_ihka
LEGAL_DISCLAIMER_TIME
ld_mit_timeout
M_KEY_SETTINGS
nicht_aktiv
MACRO_FDS
nicht_aktiv
MIC_OVER_MOST
aktiv
MUTE_PIN_BEHAVIOUR
no_function
MUTE_PIN_SOURCE
no_source
NAVI_FUELSTOP_PROPOSAL
nicht_aktiv
NAVI_VARIANTE
us
NIVI_2_OBJ_DETETECTION
nicht_aktiv
PDC_SENSOR_HINTEN
4_sensoren
PDC_SENSOR_VORN
4_sensoren
PERMANENTER_PROFILWECHSEL
aktiv
PHONE_ALL_INC_CALLS_LIST
nicht_aktiv
PHONE_RSE
nicht_aktiv
PHONE_TYPE
tcu_us_sa639
RADIO_COUNTRY
us
SL01_VIDEO
nicht_aktiv
SL02_ES
nicht_aktiv
SL03_IMPORT_EXPORT
nicht_aktiv
SL04_PIA
nicht_aktiv
SL05_KONTAKTE_EDIT
nicht_aktiv
SL06_IBA_1
aktiv
SL07_IBA_2
aktiv
SL08_NUMMEREINGABE
nicht_aktiv
SL09_BT_PAIRING
nicht_aktiv
SL10_ASSIST_PANNENHILFE
nicht_aktiv
SL11_BMW_ONLINE
nicht_aktiv
SL12_BMW_INTERNET
nicht_aktiv
SL13_ZIELEINGABE_SPELLER
nicht_aktiv
SL14_ZIELEINGABE_KARTE
nicht_aktiv
SL15_TRIPPLANER
nicht_aktiv
SL16_NAVI_POI_SUCHE
nicht_aktiv
SL17_ASIA_NAVI_POI
nicht_aktiv
SL18_ASIA_SEARCH
nicht_aktiv
SL19_ASIA_SETTINGS
nicht_aktiv
SL20_RESERVE
nicht_aktiv
SPEEDLOCK_X_KMH_MAX
nicht_aktiv
SPEEDLOCK_X_KMH_MIN
nicht_aktiv
STARTUP
nicht_aktiv
TELEMATIC_INSTANCE_ID
instanceid_0x00
TEMPORAERER_PROFILWECHSEL
aktiv
TI_VINFO
nicht_aktiv
TYPE_OF_FUEL
benzin
VCARD_OVER_MOST_CIC
nicht_aktiv
VERBRAUCH_CIC
mpg_us
VOL_MAX_ON
standard
ANZ_WECKER_BIS_RESET
wert_02
MPM_RESET_BEI_WACH
wert_02
ARBITRATOR_ZUSTAND
wert_02
KLEMME_15B
wert_00
L4_L6_KOMMUNIKATIONSSCHLT
l4_aktiv
DUTY_CYCLE_BUZZER
wert_01
BS_KORREKTUR_INFO
wert_00
FLC_SCHWELLWERT_SATZ_4
wert_01
ZBE_RUEKO
nicht_aktiv
ACOUSTICAL_LOCK_CONFIRM
aktiv
ANTRIEB
nicht_aktiv
CDMM_CHANGER_3
audio_cdc
DAB_BAND
kein_band
EINHEITEN_WEGSTRECKE_3
mls_feet
EMAIL_READ_OUT_BUTTON
nicht_aktiv
ETC
nicht_aktiv
L6_ZBE_ARBITRATOR
nicht_aktiv
LANGUAGE_1_3
english_us
LANGUAGE_10
nicht_aktiv
LANGUAGE_11
nicht_aktiv
LANGUAGE_12
nicht_aktiv
LANGUAGE_2_3
franzoesisch
LANGUAGE_3_3
spanisch
LANGUAGE_4
nicht_aktiv
LANGUAGE_5
nicht_aktiv
LANGUAGE_6
nicht_aktiv
LANGUAGE_7
nicht_aktiv
LANGUAGE_8
nicht_aktiv
LANGUAGE_9
nicht_aktiv
NAVI_KREUZUNGSZOOM
nicht_aktiv
NAVI_PFEILANSICHT
aktiv
OELSTANDSMENUE
aktiv
ONBOARDCOMPUTER_DATE
aktiv
ONLINE_DAR_INDEX_03
dar_1
ONLINE_SERVICES
nicht_aktiv
PHONE_CONFERENCE_CALL
nicht_aktiv
PHONE_RESPONSE_HOLD
nicht_aktiv
PHONE_SMS_READ_OUT_BUTTON
aktiv
RADIO_DAB_VARIANTEN
single_tuner_single_hw
RSE_3
kein_rse
SCHNEEKETTENERKENNUNG
nicht_aktiv
SL21_IBA_3
aktiv
SPEEDLOCK_FREISCHALTMENU
nicht_aktiv
TI_CAT_DEFAULT_CLOSED
aktiv
TI_CAT_DEFAULT_FLOW
aktiv
TI_CAT_DEFAULT_FORECAST
aktiv
TI_CAT_DEFAULT_INCIDENTS
aktiv
TI_CAT_DEFAULT_ONROUTE
aktiv
TI_CAT_DEFAULT_PARK_PUBL
aktiv
TI_CAT_DEFAULT_ROADWORKS
aktiv
TI_CAT_DEFAULT_WEATHER
aktiv
TI_CAT_VMAP_CLOSED
nicht_aktiv
TI_CAT_VMAP_FLOW
nicht_aktiv
TI_CAT_VMAP_FORECAST
nicht_aktiv
TI_CAT_VMAP_INCIDENTS
nicht_aktiv
TI_CAT_VMAP_ONROUTE
nicht_aktiv
TI_CAT_VMAP_PARK_PUBL
nicht_aktiv
TI_CAT_VMAP_ROADWORKS
nicht_aktiv
TI_CAT_VMAP_WEATHER
nicht_aktiv
TI_DAB_TMC
nicht_aktiv
TIME_DIST_SAME_PRIO_3
standard
TIME_OUT_GONG_3
standard
VIDEO_NUR_MIT_HANDBREMSE
aktiv
AUDIO_SIGNAL_ROUTING_CIC
standard
MULTICHANNEL_CIC
nicht_aktiv
NOTEPAD_CIC
nicht_aktiv
VOLUME_MAXIMUM_TEL_0D
standard
BT_BEDIENHOERER
nicht_aktiv
CONTACT_LIST
nicht_aktiv
INCOMING_CALL_LIST
nicht_aktiv
MIC2MOST
nicht_aktiv
MULTI_PARTY_CALL
nicht_aktiv
RESPONSE_ON_HOLD
nicht_aktiv
RING_TONE
wert_01
SMS_EIN_AUS
nicht_aktiv
SCHRITTWEITENACHSCHWELLE1
wert_01
SCHRITTWEITENACHSCHWELLE2
wert_04
ABSTAND_KOPPLUNG
aktiv
STILLSTANDSMANAGEMENT
nicht_aktiv
ANGLE_SENSOR_CLOSE
e6x_88s
ANGLE_SENSOR_OPEN
e6x_88s
FLAP_ANGLE
e6x_88s
FLAP_MAX_VELOCITY
e6x_88s
FLAP_START_ACCELERATION
e6x_88s
FLAP_STOP_ACCELERATION
e6x_88s
LOWER_BOUND_ACCEL_CONST
e6x_88s
LOWER_BOUND_ACCEL_START
e6x_88s
LOWER_BOUND_ACCEL_STOP
e6x_88s
MODEL_TYPE_NUMBER
e6x_88s
NOT_USED_8
e6x_88s
TIME_INTERVAL
e6x_88s
TIME_OUT
e6x_88s
TIME_TO_DRIVE
e6x_88s
TMP_COMPENSATE
e6x_88s
UPPER_BOUND_ACCEL_CONST
e6x_88s
UPPER_BOUND_ACCEL_START
e6x_88s
UPPER_BOUND_ACCEL_STOP
e6x_88s
X_AXIS_MOTOR_PWM
e6x_88s
X_AXIS_PHOTO_CORRECT
e6x_88s
Y_AXIS_MOTOR_PWM
e6x_88s
Y_AXIS_PHOTO_CORRECT
e6x_88s
ANZ_WECKER_BIS_RESET_05
wert_01
MPM_RESET_BEI_WACH_05
wert_01
SW_I_FESTUSCFG
wert_01
CHK_MESS_SCHLUSSL_TAILL
aktiv
DUMPER_LEVEL
nicht_aktiv
FONDLOCK_POPUP_TIMESPAN
nicht_aktiv
GETRIEBETYP_CIC
nicht_aktiv
LOGIC7_SYMBOL_C04
aktiv
RUEKO_PU_0308
aktiv
MILANSTEUERUNG_DDE_2
wert_01
PVAR_INNEN_2
wert_03
PVAR_KUPPL_2
wert_03
MILANSTEUERUNG_DDE7X_2
wert_01
VMAX-BEGRENZUNG-N47_2
wert_01
DEF_VERBRAUCH_CCC
mpg
TMC_REGIONAL_C
nicht_aktiv
VERBRAUCH_CCC
mpg
OBD_PFC
wert_00
BT_OBJECT_PUSH
nicht_aktiv
CBS_OFF_AT_KL15OFF
nicht_aktiv
CBS_ON_OFF
aktiv
EMV_WORKAROUND_ON_OFF
nicht_aktiv
AVRCP_VERSION
version_1_0
C14_INBAND_MODEM_TIMER
wert_30
C14_MOST_CHANNEL
most_async_channel
C14_RDU_CONTROL
nicht_aktiv
C14_SIM_IN_TELEMATIK_READ
aktiv
C14_SVR_CONTROL
aktiv
C14_TCU_POWER_SOURCE
kl_30gf
C14_TELEMATIK_ENABLED
aktiv
C14_TELEMATIK_SIM_ENABLED
aktiv
C14_VCARD_OVER_MOST
nicht_aktiv
CAS_UPDATE_TIMER
no_timer
DR_VIA_BUS
via_wsl
MAX_GPRS_TIMER
no_timer
MODELL_TCU
bmw
NEW_MYINFO_LOC
nicht_aktiv
POI_NUMBER_AKD_TYPE
wert_01
TELEMATIC_AUDIO_REPORTING
nicht_aktiv
WAIT_FOR_ZVSTATUS_MAX
30_sec
WAIT_FOR_ZVSTATUS_MIN
04_sec
AKTIV_NIEDERHALTEN
nicht_aktiv
LOGIK_HS
nicht_aktiv
LOGIK_SB
nicht_aktiv
OHNE_FH_ZU_N_VERDECK_AUF
nicht_aktiv
OHNE_FH_ZU_N_VERDECK_ZU
nicht_aktiv
SCHEIBE_NICHT_VERBAUT
nicht_aktiv
SCHEIBEN_ANHEB_OEFF_FBD
nicht_aktiv
SCHEIBEN_ANHEB_OEFF_TAST
aktiv
SCHEIBEN_ANHEB_OEFF_TUER
aktiv
SCHEIBEN_ANHEB_SCHL_FBD
nicht_aktiv
SCHEIBEN_ANHEB_SCHL_TAST
aktiv
SCHEIBEN_ANHEB_SCHL_TUER
aktiv
SCHEIBEN_KOMPL_OEFF_FBD
aktiv
SCHEIBEN_KOMPL_OEFF_TAST
nicht_aktiv
SCHEIBEN_KOMPL_OEFF_TUER
nicht_aktiv
SCHEIBEN_KOMPL_SCHL_FBD
nicht_aktiv
SCHEIBEN_KOMPL_SCHL_TAST
nicht_aktiv
SCHEIBEN_KOMPL_SCHL_TUER
nicht_aktiv
ZEIT_NACHDRUECKEN_HS
wert_01
ZEIT_NACHDRUECKEN_SB
wert_01
C14_MULTIPLE_CALLS
nicht_aktiv
A2DP_PROFILE
nicht_aktiv
AUDIO_PLAYER_ON_OFF
nicht_aktiv
BASIC_VR_ON_OFF
nicht_aktiv
BT_DATA_SERVICE
nicht_aktiv
BT_MODUL_ON_OFF
nicht_aktiv
DSC_MENUE
aktiv
DSC_OFF_CIC
nicht_aktiv
DUN_PROFILE
aktiv
EINHEITEN_MASTER
hmi
EXTERNAL_CALL_LISTS
nicht_aktiv
FEATURE_DISPLAY
deviceid
MICROPHONE_SENSITIVITY
l4_mic
MODELL_CIC
bmw
MUTE_BUTTON
nicht_aktiv
PAN_PROFILE
nicht_aktiv
PB_DOWNLOAD_PRIORITY
wert_03
PRODUKTLINIE
l6-w
RINGTONE_CIC
bmw
SDARS_IN_EXBOX
exbox
SECURE_SIMPLE_PAIRING
nicht_aktiv
ELV_AUT_FCT
nicht_aktiv
ELV_RESET_FCT
nicht_aktiv
FH_RELEASE_TOP_ZWSTLG
aktiv
PA_LF_PING_TAGE
nicht_aktiv
PA_MAUT_CLOSE_SILENT
aktiv
PA_SEARCH_HK_VORRASTE
nicht_aktiv
PA_SILENT_TO_4TAGE
nicht_aktiv
MOTORISIERUNG_3
wert_01
CCMELDUNG_ABRISS_AHV
cc_04bh
CCMELDUNG_FEHLER_AHM
cc_04bh
CCMELDUNG_VERRIEGEL_AHV
cc_04bh
START_CCM
klemme_15
TYP_AHV_SG
keine_ahv
TDA_CFG_CUST_MOBILE_CIC
aktiv
DWA
aktiv
ENABLE_BC2_AUTORESET
aktiv
EXCL_MULTICHANN_FRONT_DVD
nicht_aktiv
EXCL_MULTICHANNEL_MMC
nicht_aktiv
EXCL_MULTICHANNEL_TV
nicht_aktiv
EXCL_MULTICHANNL_REAR_DVD
nicht_aktiv
FBM_DEFAULT
aktiv
FBM_DETAILED_INFO
aktiv
FBM_ENT
aktiv
FBM_IBA
aktiv
FBM_MENUJUMPS
aktiv
FBM_NAVI
aktiv
FBM_OTHER
aktiv
FBM_SHORT_INFO
aktiv
FBM_TEL
aktiv
FM_BAND_KW
nicht_aktiv
FM_BAND_LW
nicht_aktiv
FM_BAND_MW
aktiv
HUD_DISTANCE_INFO
nicht_aktiv
MACRO_L6_PARKMENU
nicht_aktiv
MOMENTDISTRIBUTION_MENU
nicht_aktiv
RSE_BRIGHTNESS
nicht_aktiv
SOFTWARE_UPDATE_ASSISTANT
nicht_aktiv
BAUART_CIC
cabrio
ROUTEN_ID_GUIDEDTOURS
nicht_aktiv
CDMM_ES_ALBUM_INFO
nicht_aktiv
LANE_CHANGE_WARNING
nicht_aktiv
TDA_CFG_LEVEL3
aktiv
NAD_ALWAYS_ON_14
rs_provisioned
STEERING_WHEEL_SIDE
linkslenker
VR_EQUIPPED_TCU
nicht_aktiv
BT_RECONNECT_FROM_PRIVACY
auto_reconnect
BULK_DELAY_C15
wert_00
DSP_ACOUSTIC_PROFILE_C15
wert_04
SMS_TCU_C15
nicht_aktiv
CC_MEL_POL_BEI_DEF_TFL
nicht_aktiv
CC_MEL_SL_BEI_DEF_RL_BL_2
nicht_aktiv
DISP_ENGDAT_SIG_MONITOR
nicht_aktiv
TORQUE_ENGDAT_SIG_MONITOR
aktiv
UNTERSTEUERSCHWELLE_2
wert_00
PA_HK_2SEARCH
nicht_aktiv
BT_BEDIENHOERER_C12
nicht_aktiv
CONTACT_LIST_C12
nicht_aktiv
DISABLE_NOKIA_WA
nicht_aktiv
INCOMING_CALL_LIST_C12
nicht_aktiv
MULTI_PARTY_CALL_C12
nicht_aktiv
SMS_EIN_AUS_C12
nicht_aktiv
USB_HUB_C13
aktiv
OELWARTUNGSINTERVALL_NEU
wert_01
CIC_MDRIVE
nicht_aktiv
BESCHLEUNIGUNGAKTIV
wert_03
DEFAULT_APPLIKATION
wert_02
VOLUME_MAXIMUM_TEL_0F
standard
API_IPOD_EIN_AUS_CIC
aktiv
API_MTP_EIN_AUS_CIC
aktiv
AVOID_VIGNETTE
nicht_aktiv
BT_PHONE_INSTANCE_ID
wert_00
DEFAULT_DATUM
dd_mm_yyyy
DEFAULT_DRUCK_EINHEIT
bar
DEFAULT_SVS_DIALOG
standard
DEFAULT_TEMPERATUR
celcius
DEFAULT_WEG_EINHEIT
km
DEFAULT_ZEIT_EINHEIT
24h
EINSTELLUNG_MEILEN
mls_us
ENT_VIDEO_VORNE_GESPERRT
nicht_aktiv
FUNCTIONALITY_VIEWER
nicht_aktiv
MAP_SCROLL_3D
nicht_aktiv
NAD_PHONE_INSTANCE_ID
wert_00
NAVI_DEST_EXPORT
nicht_aktiv
NAVI_DEST_IMPORT
nicht_aktiv
NAVI_MYPOI_EXPORT
nicht_aktiv
NAVI_MYPOI_IMPORT
nicht_aktiv
NAVI_ROUTE_RECORD
nicht_aktiv
NAVI_TRIP_EXPORT
nicht_aktiv
NAVI_TRIP_IMPORT
nicht_aktiv
ONLINE_SERVICES_GLS
nicht_aktiv
RDC_SAFETY
nicht_aktiv
SPEEDLIMIT_INFO
nicht_aktiv
C15_CCM_FILTER
wert_03
CHECKBOX_TP
nicht_aktiv
FBM_SELECTION
six_buttons_us
SVS_EIN_AUS_3
nicht_aktiv
PVAR_INNEN_3
wert_03
PVAR_KUPPL_3
wert_03
CONNECTIVITY_SYSTEM_VER
teilenummer
DATACOM_INTERFACE
tcu_mulf
EARLY_VIDEO_LEGALDISCL
kein_ld
ECALL_INSTANCE_ID
wert_01
HDD_ACCESS_VIA_ETHERNET
nicht_aktiv
INBAND_RINGING
nicht_aktiv
NAVI_INFO_INSTANCE_ID
wert_02
PICTURE_ALBUM_ARTS
nicht_aktiv
SDARS_REPLAY_AUTOMATIC
nicht_aktiv
VIDEO_WATCHDOG_NIGHTVISIO
nicht_aktiv
VIDEO_WATCHDOG_REARVIEW
nicht_aktiv
VIDEO_WATCHDOG_SIDEVIEW
nicht_aktiv
VIDEO_WATCHDOG_TOPVIEW
nicht_aktiv
TDA_CFG_AUTO_TRIG_CIC
nicht_aktiv
N_VERZOEGERUNG
wert_02
CDMM_BT_DATABASE
nicht_aktiv
CDMM_USB_COMPOSER_IPOD
disabled
CDMM_USB_COMPOSER_MTP
disabled
CDMM_USB_COVER_ART
nicht_aktiv
DATACOM_TRANSFER
most_high
LANGUAGE_MASTER
nicht_aktiv
SOFTWARE_UPDATE_MANAGER
nicht_aktiv
PHONEBOOK_NAME_DISPL_ORD
last_first
TCU_AUDIO_OVERRIDES_SET1
nicht_aktiv
TCU_AUDIO_OVERRIDES_SET2
nicht_aktiv
TCU_AUDIO_OVERRIDES_SET3
nicht_aktiv
TCU_AUDIO_OVERRIDES_SET4
nicht_aktiv
TCU_AUDIO_OVERRIDES_SET5
nicht_aktiv
TCU_AUDIO_OVERRIDES_SET6
nicht_aktiv
AUX2_VIDEO_MODE
nicht_aktiv
AUDIO_REMOTE_CONTROL
nicht_aktiv
BRAKE_ASSISTENT_3
aktiv
FM_DEEMPHASIS
wert_02
KOMBI_CIC
kombi_high
FBM_DEFAULT_C09
nicht_aktiv
GRACENOTES_ACCESS
most
NAVI_FULL_GUIDINGPOPUP
nicht_aktiv
NAVI_MAP_ARROWVIEW
aktiv
NAVI_SPLIT_GUIDINGPOPUP
aktiv
ONE_SHOT_DEST_INPUT
aktiv
MICROPHONE_0A
no_microphone
TDA_ATM_ACTIVE_CIC_0A
nicht_aktiv
ELV
nicht_aktiv
FBD_NO_LOAD_POS_C06
aktiv
FBD_NO_LOAD_POS_C08
aktiv
EXTERNE_MOST_DIAG
aktiv
CCM_FILTER_C16
wert_03
NAVI_VARIANTE_0A
us
AVOID_VIGNETTE_0A
nicht_aktiv
ECALL_INSTANCE_ID_0A
wert_00
NAVI_INFO_INSTANCE_ID_0A
wert_01
SIDE_VIEW_CAMERA_0A
wert_255
ELV_CCM_NEU
nicht_aktiv
PA_LF_PING_PGS
nicht_aktiv
CONTACT_NUM_HOTLINE_0B
aktiv
CONTACT_NUMBERS_BCALL_0B
aktiv
HVAC_MSA_EFFICIENCY
nicht_aktiv
KOMBIGUIDING_SCHALTBAR
nicht_aktiv
MACRO_PIM
nicht_aktiv
NAVI_ROUTE_STUDY
nicht_aktiv
P_BOOK_NAME_DISPL_ORD
firstname_last
PIM_ADR_VALID
nicht_aktiv
PIM_CROSS_USE
nicht_aktiv
PIM_OVERVIEW
aktiv
PIM_TTS
aktiv
PU_0909
nicht_aktiv
BC_EFF_GESCHW_BEI_KL_R
nicht_aktiv
CAN_OEL_DIENST_ENA
aktiv
CHECK_BLOCK07
e6x_88s
CONTROL_TIMER_1_2
e6x_88s
COR_ANGLE_CLOSE_PWM
e6x_88s
COR_FACT_MAX_CLOSE_PWM
e6x_88s
DUMMY_BLOCK07
e6x_88s
LOWER_ANGULAR_VELOCITY
e6x_88s
OFFSET_MIN
e6x_88s
CDMM_USB_AUDIO_DOUBLE_0B
nicht_aktiv
CDMM_VIDEO_C0B
aktiv
NAVI_INFO_INSTANCE_ID_0B
wert_01
PHONE_TYPE_C0B
tcu_us_sa639
PICTURE_ALBUM_ARTS_0B
nicht_aktiv
TI_CA_TPEG_C0B
nicht_aktiv
TI_VINFO_C0B
nicht_aktiv
SW_UPDATE_ASSISTANT
nicht_aktiv
COMFORT_OPENING
nicht_aktiv
HYBRID_EFFICIENCY_GRAPHIC
nicht_aktiv
LANGUAGE_13
nicht_aktiv
LANGUAGE_14
nicht_aktiv
LANGUAGE_15
nicht_aktiv
LANGUAGE_16
nicht_aktiv
MMC_VARIANTE
wert_01
RADIO_AM_LW
aktiv
ALTERNATIV_ROUTEN
aktiv
FM_BAND_LW_0C
nicht_aktiv
GUIDING_TIMING_KM
permanent
GUIDING_TIMING_MLS
permanent
PIM_DRIVING_TEXT_LENGTH
one_page
REMOTE_HMI
nicht_aktiv
TEXTKUERZUNG
aktiv
TVC_WIDTH_0C
wert_01
TYPE_OF_FUEL_0C
alle_kraftstoffe
TDA_ATM_ACTIVE_CIC_0C
nicht_aktiv
TDA_CFG_AUTO_TRIG_CIC_0C
nicht_aktiv
CLIMATE_ACT_ONE_TIMER
nicht_aktiv
MESSAGE_FILTER
nicht_aktiv
NAVI_MYPOI_IMPORT_C0D
nicht_aktiv
ONE_SHOT_DEST_INPUT_C0D
nicht_aktiv
ONLINE_BROWSER_C0D
nicht_aktiv
PDC_DIRECTION
horizontal
TDA_TSR_INSTANCE_ID_C0D
wert_00
DREHZAHLANHEBUNG_2
nicht_aktiv
API_TYPE
none
HUD_ACTIVATION
nicht_aktiv
SINGLE_OR_MULTILINK
multilink
SPEEDLOCK_X_KMH_MAX_C0E
nicht_aktiv
SPEEDLOCK_X_KMH_MIN_C0E
nicht_aktiv
ALARM_LEVEL_Z
wert_03
COUNT_RESET_LEV_1ALARM_Z
wert_03
COUNT_RESET_LEV_2ALARM_Z
wert_03
ERR_BANDW_1ALARM_Z
wert_03
ERR_BANDW_2ALARM_Z
wert_03
MAX_DRIFT_Z
wert_03
A4A
nicht_aktiv
AUDIO_SYSTEM_VAR
default
CDMM_PERSONALRADIO
nicht_aktiv
CDMM_USB_HMI
old
CDMM_USB_POD_BOOK
nicht_aktiv
CDMM_USB_VIDEO
none
COMINGSTREET_KOMBI_HUD
nicht_aktiv
NAVI_3D_MAP_OPTIONS_C0F
nicht_aktiv
ROTATION_WERTE_EINHEITEN
nicht_aktiv
SLEEPDELAY_CLAMP30B_MIN
wert_00
SLEEPDELAY_TIMERVALUE
wert_01
BASIS_KOMBI_MMI_LIST
aktiv
BMAP_JUNCTION_VIEW
aktiv
DAB_STANDARD
nicht_aktiv
DMB_MAX_FRAMERATE
wert_0
DOORLOCKING_AFTER_DRIVING
aktiv
HMI_FUER_DAB_DMB
dab_dmb_radio
HUD_TURNSIGNAL
nicht_aktiv
KOMBI_AR_PRES
nicht_aktiv
PHONEBOOK_NAME_ORD
aktiv
SECONDARY_HFP
nicht_aktiv
SERVICE_HISTORY
nicht_aktiv
WELCOME_LIGHT
aktiv
HINTERE_TUEREN_MINI
nicht_aktiv
OSFG_MSA_NO_KL15_AUTO_OFF
aktiv
TC_KL15_AUTO_OFF_OSFG
nicht_aktiv
TC_NOT_P_NO_KL15_AUTO_OFF
aktiv
TIME_KL15_AUT_OFF_DR_OPEN
wert_01
EXT_MUSIC_MANAGEMENT
aktiv
HUD_ROTATION
nicht_aktiv
JUNCTION_VIEW_HUD
nicht_aktiv
M_DIGITAL_TACHO_EINH
nicht_aktiv
RSE_SERVICE_MESSAGES
nicht_aktiv
TIME_LAG_IDG_CIC
standard
TIME_LAG_IMG_CIC
standard
A4A_REMOTE_APPS
nicht_aktiv
ANZEIGE_FREQ
nicht_aktiv
AUDIO_OFFSET
nicht_aktiv
BRAKE_ASSISTANT_CCM
nicht_aktiv
BRAKE_ASSISTANT_FCW
nicht_aktiv
COLOUR_SWITCH
nicht_aktiv
COLOUR_SWITCH_LINES
nicht_aktiv
DAB_FOLLOWING_CHECKB_HMI
nicht_aktiv
DEBOUNCE_KOMBI_BASIS
defaultwert_50
ECO_ROUTE_TEXT
nicht_aktiv
ENABLE_SW_INFO_REQUEST
cic_high
ENT_CHANNELBUFFER
wert_11
ENT_ITEM_UPDATE_COUNT
wert_1
ENT_MANAGED_CHANNEL
wert_50
ENT_MAX_NUMBER_FAVOURIES
wert_100
ENT_ONLINE
nicht_aktiv
ENT_QUERY_CHANNEL
wert_50
ENT_TEMPORARY_CHANNEL
wert_100
HEADLIGHT_SETTING
nicht_aktiv
HELLIGKEIT_AMBILIGHT
nicht_aktiv
LANGUAGE_UPDATE
nicht_aktiv
M_DIGITAL_TACHO
aktiv
MAX_VOL_STEP_RSE
standard_39h
MDRIVE_CONFIG
1_menu
MDRIVE_RUEKO
nicht_aktiv
MMI_STATISTIK
nicht_aktiv
MODE_HARDKEY
radio_cd
NANP_FORMAT
aktiv
NAVI_POI_ONLINE_SEARCH
browser
NAVI_POSITION_MENU
nicht_aktiv
OELSTAND_OENS
nicht_aktiv
SERVICE_HISTORY_WHO
default
SPEECH_2_TEXT
nicht_aktiv
TERMINAL_UI
nicht_aktiv
VOL_MAX_ON_RSE
standard_19h
BRAKE_ASSISTANT_CONF
nicht_aktiv
DATUMSFORMAT_AR_ASIA
nicht_aktiv
ENABLE_SW_INFO_REQUEST_14
nicht_aktiv
FBM_NO_TOUCHSENSOR
nicht_aktiv
SLEEPDELAY_CLAMP30B_MIN_2
wert_ff
SLEEPDELAY_TIMERVALUE_2
wert_1e
ABS_REG_ENABLE
e60
BEV
nicht_aktiv
CONNECTED_DRIVE
nicht_aktiv
ECO_FDS_POPUP
nicht_aktiv
ECO_LIMIT
nicht_aktiv
ECO_MODE
nicht_aktiv
ECO_MODE_CONF
nicht_aktiv
ECO_ROUTE
nicht_aktiv
ECO_TIPPS
aktiv
EFF_DYN_FORECAST_HYB
na
EFF_DYN_SPORT_CID
nicht_aktiv
EFF_DYN_SPORT_UNIT
nicht_aktiv
EFF_DYN_SYS_CID
nicht_aktiv
ENT_HUDRIVE_INSTALLED
aktiv
EXTENDED_CC_MESSAGES
aktiv
FDS_NAMING_MODE
bis_0711
HIGH_END_AUDIO_MENUE
kein_menue
HIST_BEV_CONSUMP
nicht_aktiv
HIST_BEV_CONSUMP_SCALE_1
50
HIST_BEV_CONSUMP_SCALE_2
5
HIST_BEV_CONSUMP_SCALE_3
10
HIST_BEV_RECUP_SCALE_1
20
HIST_BEV_RECUP_SCALE_2
20
HIST_BEV_RECUP_SCALE_3
30
HIST_CONSUMP_AVERAGE
kein_wert
HIST_FDS_MODE_COLOR
nicht_aktiv
HIST_FDS_MODE_NAME
nicht_aktiv
HIST_GAS_CONSUMP
nicht_aktiv
HIST_GAS_CONSUMP_SCALE_1
na
HIST_GAS_CONSUMP_SCALE_2
na
HIST_GAS_CONSUMP_SCALE_3
na
HIST_GAS_CONSUMP_SCALE_4
na
HIST_HYB_CONSUMP
nicht_aktiv
HIST_HYB_CONSUMP_SCALE_1
nicht_belegt
HIST_HYB_CONSUMP_SCALE_2
nicht_belegt
HIST_HYB_CONSUMP_SCALE_3
nicht_belegt
HIST_HYB_CONSUMP_SWITCH
nicht_aktiv
HIST_ZOOM
nicht_aktiv
MAXGLOBALREMOTECOMMANDS
v20
MAXLOCALREMOTECOMMANDS
v0
ONLINE_BROWSER_LIVE
nicht_aktiv
PHONEBOOK_CACHING
nicht_aktiv
RR_SPEZ_KLZ
nicht_aktiv
SETTINGS_DOORLOCKING
aktiv
SETTINGS_HOMELIGHT_PERIOD
aktiv
SETTINGS_INFO_DISPLAY
nicht_aktiv
SETTINGS_LIMIT
aktiv
SETTINGS_SPIRITOFECSTASY
nicht_aktiv
SETTINGS_TIP_BLINKING
aktiv
SETTINGS_TOURIST_LIGHT
nicht_aktiv
SETTINGS_TRACTION
aktiv
TDA_CFG_BDA_REMOTE_HELP
aktiv
TPEG_TAP
nicht_aktiv
TRAVEL_BC
aktiv
SL_BEI_KZL_AKTIV
nicht_aktiv
A4A_LEGAL_DISCLAIMER
nicht_aktiv
ASD_CIC
ls_diag_on
CBS_MOBIGUAR_LIFELONG
nicht_aktiv
CONFIG_INDEX
config_index_4
DAC
none
DPAS_INDEX
dpas_4
EFF_DYN_SAILING
nicht_aktiv
FAS_INSZENIERUNG
nicht_aktiv
GATEWAYTABLE
l6_mue
GEZIELTES_ANLEUCHTEN
nicht_aktiv
HIST_Y_SCALE_STEP_1
000
HIST_Y_SCALE_STEP_2
000
HIST_Y_SCALE_STEP_3
000
HIST_Y_SCALE_STEP_4
000
HIST_Y_SCALE_STEP_5
000
HIST_Y_SCALE_STEP_6
000
PERSONEN_WARNUNG
nicht_aktiv
SWT_ARABIC
nicht_aktiv
TIMESTAMP_DISPLAY
nicht_aktiv
VANITY_DIALLING_EIN_AUS
nicht_aktiv
VOICE_LANGUAGE_RR_US
nicht_aktiv
ZBE_LOW
nicht_aktiv
HK_V_VER_MODUS
modus_00
TC_MSA_IGNORE_ENG_RUN
nicht_aktiv
