645 Won't start - Bimmerfest - BMW Forums
Old 10-03-2010, 03:17 PM
acmc7 acmc7 is offline
Mein Auto: 645 BMW
Unhappy 645 Won't start
My 05' 645 BMW won't start. The engine will crank but won't turn over. Although, the horn will blow, the lights and radio come on, I tried to jump start the battery, thinking it was not charged enough to start the car. It still won't start. The battery indicator in the trunk is black meaning the charge is low, but it still won't jump start. What do you think the problem is?
Old 10-04-2010, 12:08 AM
Jasonau01 Jasonau01 is offline
Mein Auto: BMW 645ci
Even jump start, u need to check what amp is the lead, use thicker lead it should start the car. Change the battery, it should be fine
Old 10-04-2010, 09:27 AM
Giantsfan82's Avatar
Giantsfan82 Giantsfan82 is offline
Mein Auto: 2005 BMW 645CI
It's your battery for sure. Same thing happened to me.
2005 BMW 645CI - 20 Inch ADR Classic - Matte Black Side Fender Grille - Matte Black Front Grille - 20% window tint - Smoked tail lights - ACS Paint - Britalman full catback exhaust system - H&R Lowering Springs - aFe intake - Sprint booster - Ram air induction-Headers - MTEC white Angel Eyes - Two Alpine 12" Type R subwoofers - Rockford Fosgate T10001bd Amp - Escort Passport 9500ix Radar detector .
2005 Mustang Saleen
2005 Cadillac Escalade EXT
2007 BMW F800ST
Old 10-04-2010, 07:54 PM
Mein Auto: 645 BMW
Smile
I found out the problem was the fuel pump, cost $900 dollars parts and labor at the BMW dealership, thank God for the extended warranty, cost $50. I found out with the BMW extended warranty there is a $50 deductible for repairs.
Old 10-04-2010, 07:58 PM
Mein Auto: 645 BMW
Question Brake recall
While they were repairing my fuel pump, I inquired about the Brake recall, As someone else reported on the forum, it is "unofficial" BMW is trying to make sure they have all the parts in stock and then they will send out letters to owners. It will be for All 6 series from 04 to 10.
Old 10-30-2010, 09:44 AM
jeremysm1 jeremysm1 is offline
Mein Auto: '05 BMW 645 Conv.
Can you tell me more about the brake recall? And anyone following this post, what battery should do you recommend putting in? Could I get it from Checker or do I need to go through BMW? Thanks!
Old 10-30-2010, 05:53 PM
vegas645 vegas645 is offline
Mein Auto: 2005 645ci convertible
I just replaced the battery in my 645. First I went to the Dealer and they wanted $500. The SA told me if I went with an aftermarket that it would not operate all the functions. I decided to call his bluff and went to Sams club and got the same specifications as the OEM and had it installed for $86 with a 3 year warranty. I figured hey what the heck if it doesn't work I'm out $86 and I'll get it from the dealer. 2,000 miles later everything is perfect and I didn't even have to get it reprogrammed. The only function that had to be reset was the clock. Some posters on here said they went to Autozone and got there battery for $150. When I did some more investigating I found out that 99.9% of the batteries sold in the US are mass made by Johnson Batteries and sold to the different brands carried by auto parts stores and retail outlets.
Anyways its working for me and I saved $414!! I also put the same Sams Club battery in my wifes 2007 32*i and it is working perfect.
Just a thought......
Old 10-30-2010, 06:03 PM
I know it sounds crazy to put a $86 battery in a $80,000 Sports Car but the car still looks and runs the same.
Old 10-30-2010, 10:03 PM
Battery Replaced by AutoZone not BMW
So...I went to start my car and the battery was dead. So, being 4pm on a Saturday, I decided to locate a battery at an AutoZone (per some of the poster's advice) and found one after a couple calls. I went there and purchased the one for $140 +tax. I was so worried that the electronics were going to stop working or problems arise that I tipped the guy helping me and we jumpered his vehicle's battery to my 645's front engine jumper area while we replaced the battery in the trunk.
Well, so far none of my settings went out and all seems to be working perfectly well. If anything changes for the worst I'll post to let everyone know--but assume that all is good. That's $325 in the pocket for now.
Old 10-31-2010, 06:41 AM
TopDownInFL's Avatar
TopDownInFL TopDownInFL is offline
Mein Auto: 2019 M850i
It's the Brake Booster. I had the problem occur before the recall on my 645. Essentially, the booster enhances the press of the brake pedal to get the car to apply the brakes. When malfuntioning, you have to press REALLY REALLY hard to get just a minor amount of brakes to apply. Could be VERY dangerous if the booster went while driving. Mine died in my driveway.
Nick / TopDownInFL (sans the "top down")
2019 M850i
Previous Bimmers:
2017 540i
2012 650i Coupe
2008 650i Convertible
2004 645Ci Convertible - Reverse Sensors / Reverse Camera
2005 545i Sedan
2003 330Ci Convertible
2001 330Ci Coupe
1998 323i Convertible
1995 318i Sedan
Old 11-01-2010, 01:14 AM
spegase spegase is offline
Mein Auto: 645Ci Cabrio
have you a e64 or e63 ?
* BMW E64 645Ci MT6, 2004, Black Matte *
http://www.youtube.com/watch?v=PftXV1V5L8k
- BMW E46 328Ci MT5, 1999, Black Metallic
Old 11-01-2010, 06:54 AM
whitedesigns whitedesigns is offline
Break booster was replaced/repaired on my car. I noticed that it took LOTS of pressure on the brake pedal to stop the car. Repaired under original warranty.
Old 11-01-2010, 07:06 AM
tampamark tampamark is offline
Mein Auto: 650 Sold - '12 Jaguar XK
Ah, the beauty of the internet, it debunks the mystique in OEM parts.
It is a battery and it is a car. Certain items in your vehicle are not luxury brand specific. Glass, mirrors, rims, tires, battery, the list could go on. Besides, it seems that a good portion of the folks on this board bought their car used for $45k or less. In that case it is just a $45k car.
Old 11-02-2010, 07:30 PM
has247 has247 is offline
Mein Auto: 645
Question wont start
my car stopped turning on i put the key all lights navi radio work no noise when trying to spark the starter i dont know if its electric or battery .....i even tried to jump start no good .got a hand car wash b4 all this mess: . it s a 2005 645ci 70k miles . before i take it to the dealer anyone have the same issue ...
Old 11-03-2010, 03:39 PM
So, did you figure out what is causing the problem with your starting issue? As a follow up with my battery issue--its been 4 days and nothing seems wrong with the car after replacing the battery with an Autozone battery.
Old 07-31-2019, 07:08 PM
Eric100 Eric100 is offline
Mein Auto: 05 645ci bmw
Hello, i have an 05 645 bmw, im having a problem , crank but no star i had the fuel pump replaced ,new bmw batterie & registered , new crank sensor, alternator. Early in the morning will fire up w/np..8hrs after work np..have to fuel up with car running.replaced ivp...under hood...starter motor ok,...
Old 07-31-2019, 09:00 PM
HerbP HerbP is offline
Super Moderator
Mein Auto: 05 645Ci, 14 750 M-Sport
Change your IVM module that is located in the DME box under the passenger cabin filter. This can be purchased online or at the local BMW dealer. Your cost while be around 120.00, & the dealers stock them due to the failure rate.
Old 08-01-2019, 12:01 AM
I changed the box under the air filter box, crank sensor, new programes bmw batterie, new fuel pump, alternator, all fuses and relays good.starter turning over.randomly wont start..car haa to sit for awhile then itll turn over.any suggestions?
Old 08-01-2019, 08:59 PM
Super Moderator
Are you talking about the box with around 8 fuses in it? Have you measured the battery voltage to make sure it is above 12 volts, the car will not run properly with less. The next item would probably be to try syncing the DME & CAS.
Old 08-02-2019, 04:52 AM
Yes the black box with the fuses (IVM). how much will it cost to sync the dme, also my idrive displays batterie high drain.Early in the morning itll stsrt with no problems , and after work...but if iwas to drive to the store, go in and come out, like 10mins , then the same crap will happen, it will have to sit for 25 -35mins.
Old 08-02-2019, 07:11 PM
Super Moderator
Your problem sounds more like a battery, or alternator issue. After the car has had some wait time for the battery to recover, the voltage on the battery recovers. I would have your battery & alternator tested to see if they are ok? When you have your no start problem, raise the hood & measure the battery voltage at the jump terminal. With the engine off, ignition switched on, & the headlights on, measure the battery voltage. The voltage should be above above 12 volts with the engine off, & 14.12 volts with the engine running. If your battery voltage is low, try charging your battery to see if that helps?
Have you added any aftermarket parts that put a drain on the battery? If you have, it might be your problem?
Old 08-02-2019, 08:24 PM
As i mentioned in my first post ,i have a brand new bnw batterie and programed to the car....brand new alternator....sometimes i have to jump start it , and while keeping it cranking..itll turn over....monday im taking it to my mechanic, i have a feeling that there maybe a short in the starter, my parking lights doesnt stay on....it go out after 30 seconds,which surpose to stay on when i turn on the lights to position 2....
Old 08-03-2019, 07:48 PM
Super Moderator
A new battery does not mean it is properly charged. If you are having to jump start the car, charge your battery!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!11
Old 08-05-2019, 04:18 AM
Mulchman's Avatar
Mulchman Mulchman is offline
Mein Auto: '07 650i
Check your ground straps to the starter and motor. Check my recent post about fuel purge valves.
'14 X6 i50 - Deep Sea Blue Matallic
'07 650i Coupe - Black Sapphire Metallic
'11 328i Sedan - Alpine White
