Picture & amperage & description of every single fuse & relay in the BMW E39 - Page 3 - Bimmerfest - BMW Forums
Old 08-10-2014, 12:58 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
I found this, so, I would ask the OP whether it's accurate.
- Looking for the Horn Relay Location?
Old 08-11-2014, 11:18 AM
bluebee's Avatar
Today, a user troubleshooting weird electrical problems ran into this:
> E39 (1997 - 2003) > Help with electrical issue please
Originally Posted by vh_supra26 View Post
I have a 99 528i with 101k. I took the car in for a new battery. After that I am having major electrical issue. The car drives fine, but the headlights, A/C & heater, radio, windshield wipers, power seats, gauges, horn, and power window won't work now. I don't even know where to start looking. Did anyone else have the same problem? Thanks
Old 08-22-2014, 10:12 AM
greggo151 greggo151 is offline
Mein Auto: '04 BMW 525i
2001 525iT...I have gone through this whole thread and I still can't figure out where my Auxiliary fan relay is. My box under the air intake has the salmon and the brown relay, but after reading it doesn't sound like either one is correct. My high speed function on my fan has quit. Low speed works, but at certain points the car is heating up at idle because the high speed is not kicking in while the AC is on.
Old 08-22-2014, 10:20 AM
gvelco gvelco is offline
Mein Auto: BMW E39 525i 2002
i wanna know also aux fan relay location.do u have old 3 stage resistor fan?mine is new model.does it matter for relay location??
Old 08-22-2014, 10:51 AM
can someone confirm that 2002 models have 50amp fuse for aux fan behind glove box?searched in my car and found nothing(will post pics in situ).bentley and others say that aux fan is secured with 50amp fuse.
Old 08-22-2014, 05:36 PM
It's there...I took the glove box out and then look up behind the metal plate that the fuse box is connected to above the big plug of wires, and with a light you will catch the glimpse of the two fuses. I had to use my monkey fingers and go over the top with the fuse box open to get them out and back in.
Old 08-22-2014, 06:37 PM
In my 2001 525iT I have this ebox...where is relay K201? Or the Aux. Fan relay? Fuse 75 is in tact.
Old 08-22-2014, 06:57 PM
bluebee's Avatar
You might find what you need in these threads, found by typing /f75 in the bestlinks:
- One users experience diagnosing parasitic dead battery overnight current drain (1) & what's the secret to removing FSU blower motor fuse F76 (1) & where to find the cooling system aux fan fuse F75 (1) (2) (3) (4) (5)
See also:
- How to test the cooling system auxiliary electrical fan (1) & how to replace the aux fan (1) & where is the auxiliary fan fuse F75 (1) & where is the aux fan relay (1)
Old 08-22-2014, 07:36 PM
Tar34 Tar34 is offline
Mein Auto: 525i Touring
I just received this Fuse Housing from BMW and it appears to be incomplete. Is this the way they come through? BMW told me I would have to locate the connectors in the catalog... Say what?? Does anyone know a source of the connectors?
Old 08-22-2014, 10:28 PM
bluebee's Avatar
Given the water damage that car has experienced, I'd google for "marine grade wire crimp terminal connectors" for at least tin-plated copper terminal connectors.
ID:	460165   Click image for larger version
ID:	460166   Click image for larger version
Old 08-23-2014, 03:00 AM
I was looking to find the flat male comb type connectors to complete the box as original. I suppose I could just stack the connections on the posts. Might there be a reason this would not be recommended? Finding wire end connectors is not a problem.
Old 08-25-2014, 01:36 AM
allenwilson33 allenwilson33 is offline
Mein Auto: 02' 525i
It would appear that excessive levels of oxidation on the fuses and connections could be the effect of salt water or damp air, or simply a damp parking area.
If you neglect additional reinforcement in the midst of harsh conditions--even of those conditions are defined by a messy passenger or broken window, for example--the lifespan of the under-seat fuse box will be shortened significantly.
It is also important to note that automotive hardware is generally made to aviation specifications- not the regular stuff you pick up at the hardware store, hence @Bluebee's recommendation for you to prevent corrosion by strengthening up. If you are going to use anything less, it should only be a holdover. I arbitrarily define 1,000 miles as my duration anytime I have applied a temporary fix.
Old 08-25-2014, 09:00 AM
Thanks Allen.
I'm in the marine industry and work arounds are commonplace. I'm new to BMW OEM part procurement, so I have a learning curve as to what is considered a complete OEM part. Am I too assume it's common to receive equipment with missing parts and no available BMW reference to the missing parts? I understand upgrading components, but missing components in an OEM part with no available reference to complete the part seems odd. Given all the attention to VIN numbers, body specific parts and all the apparent documentation required to procure a specific part, I'm baffled by the seaming lack of information and feigned ignorance of some dealers. I realize it's up to me to establish a bond with a dealer or repair shop and my ignorance doesn't help to complete the circle of trust.
Old 08-27-2014, 09:51 AM
e30ray e30ray is offline
Mein Auto: e30 1986
Can you please tell me what these three wires mean ive herd solid brown is the gorund but not sure about the other ones they go to my fuel pump in my e30
Old 08-27-2014, 11:52 AM
pudl's Avatar
pudl pudl is offline
Mein Auto: E39 530dAT 2001
Solid brown should be ground and in almost all cases it is. Never hurts to check with a multimeter.
Old 08-27-2014, 04:21 PM
Mein Auto: 02' 525i
Um, the blurry picture and angle of the wires make it hard to see what color combinations you're dealing with, not to mention the absence of your car's birthday and model. Will gladly assist with such info
Last edited by allenwilson33; 08-30-2014 at 05:40 AM. Reason: Include quote for context
Old 08-27-2014, 04:23 PM
Mein Auto: 02' 525i
Yes there is sometimes difficulty with these things but dealer and OEM is best for electrical repair. Don't want to end up with more failed systems from OECHIN replacements like I did
Splice and solder is your next step it appears.
Old 08-30-2014, 05:52 AM
Mein Auto: 02' 525i
Learning to wrench on BMW is like {I imagine} learning English as a second language: necessary and useful in many ways, but damn hard to grasp, because there seem to be more exceptions to rules than there are rules to begin with.
Old 09-07-2014, 11:03 AM
bluebee's Avatar
This fuse hint by cn90 today will be useful to those who come here to figure out what fuses to pull to prevent twisted seats:
> E39 (1997 - 2003) > Permanent solution for twisted seat problem?
Originally Posted by cn90 View Post
The permanent solution is Fuse #13.
- Adjust the seat and SW the way you want
- Then remove Fuse #13, just make a note that you did this so later on, if you need to adjust the seat and SW, re-insert Fuse #13.
I removed Fuse #13 4 years ago, and have not had the need to adjust the seat or SW during the last 4 years.
Old 11-23-2014, 11:01 AM
MJB9 MJB9 is offline
Mein Auto: 2002 525i (E39)
Originally Posted by bluebee View Post
I was looking in the bestlinks to help this guy find switched power today:
- > E39 (1997 - 2003) > where would you guys pull switched ignition power for an indash n7 install?
... when I spied this nice picture of the additional ebox fuses, added for a cooling fan, so I include them below, so it's all in the same spot for others to benefit from easily:
See also:
- Where to find an E39 wiring diagram specific to your model (1) (2) (3) (4) & understanding European wiring diagrams (pdf) & where to find all E39 fuse boxes (1) (2) & adding new fuses & wiring in the engine bay (1) & all about the BMW Glovebox Flashlight Cigarette Lighter Power Adapter (1) (2) (3) & how to install a Valentine or Escort radar detector (1) (2)
HEy Bluebee,
I see my engine bay fuse compartment looks a lot like yours. I see others on here are a lot different, even though same e39. Anyway, I noticed someone before I bought it was definitely in there. and made a mess. There are two relays that should be mounted, but are hanging free (broken plastic). There is also some sort of metal sensor on bottom right that you and I have but others don't. Almost like a water level sensor, or temp sensor (it's metal). My back right water proof rubber gasket by firewall that holds all the wires, wasn't even in right (hanging out), my EF1, etc. fuse section cover is missing, there are two wires oddly taped together (not sure if anything at all but will open up), and there is a cut or broken wire (yellow with blue stripe), that I cannot see anywhere where it would go. I was in there looking to see if anything would be a sign of my ABS issues, or intermittent check brake linings message (which brakes are new, and sensors changed several times, and reset a million times to no avail). Also, one screw holding cover to compartment pulled out the other end, and another one was completely broken off. Jeez.
Anyway, FYI posting for others to see what my fuse box looks like and also to ask if others have those two wires taped together, and more importantly, of others have a mysterious wire missing. I have had NO work done to my car in there since I bought it 2.5 years ago. My ABS and brake sensors both failed many many months apart from one another, and both worked for months after I bought the car. So any broken wires were already there.
Any feedback appreciated.
ID:	477576   Click image for larger version
ID:	477577   Click image for larger version
ID:	477578   Click image for larger version
ID:	477579   Click image for larger version
Old 11-23-2014, 04:14 PM
josemedeiros007 josemedeiros007 is offline
Mein Auto: 1998 528i 4Dr
What did you end up doing on your fuse block, if it were me, I would disconnect all the fuses, and terminals, clean them and the posts with a fine brass wire wheel on a Dremel tool, or cordless drill, then reattach them, and protect it with a coat of Vaseline, or battery terminal protector spray. Soaking the terminals in a baking soda and water solution may also get the corrosion off at the crimp connector, I learned that in high school electronics.
https://www.fcpeuro.com/products/crc...Fc1afgodx5gAqQ
Old 01-03-2015, 09:03 PM
Nervous Nervous is offline
Mein Auto: 01' 330CI 6MT / 00' 540i
I wonder if there is a heated steering wheel relay anywhere on 540?
Old 01-14-2015, 02:12 AM
bluebee's Avatar
For reference, there was an update to the thread today on the three locations of the fuel pump relay (K96) on the various E39s...
- Where is the location of the fuel pump relay K96 (1)
> E39 (1997 - 2003) > Fuel Pump relay in 03 525i
Originally Posted by rdl View Post
Fuel pump relay changed locations over the years.
These are what come in WDS
See also:
- How to test a BMW battery & alternator (1) & the most often recommended diagnostic procedure to test for overnight parasitic battery drain (1) & one user's attempt to locate, describe, and photograph all fuses and relays in the BMW E39 with a picture of every fuse & relay (1) & how to choose a good aftermarket battery (1) and a simple battery replacement DIY (1) & Cn90's explanation of where to get alternator rebuild parts (1) & how to troubleshoot a bad FSU final stage unit (1) and how to build a test jig for your FSR final stage resistor (1) & how to repair solder cracks in your blower motor resistor (1) & how to replace your HVAC blower motor control (1) (E46) & what FSU is the right one to buy based on user experiences (1)
Old 01-29-2015, 08:21 PM
ezaircon4jc's Avatar
ezaircon4jc ezaircon4jc is offline
Mein Auto: 2014 535i M Sport
Blubee......
I've been wading through this thread but can't find what I needed (could be I just missed it!!). Do you know which fuse controls the trunk light in a 2012 535i (F10)? THANKS!!
BTW, your PM box is full......
Old 01-30-2015, 07:51 AM
rdl rdl is offline
Mein Auto: 530i 2003
You'll have more chance of an answer in the F10 forum. This is forum focused on the E39, designed about 20 years before the F10.
Regards
RDL
