engine oil reset not possible - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series & 8 Series > 7 Series - F01 / F02 / F03 / F04 (2008 - 2015)
The 5th generation F01/F02/F03/F04 BMW 7 Series flagship forum. The redesigned 7 series leads off the BMW Fxx chassis code, offering an 8 speed automatic transmission and all turbocharged engine options.
Old 05-29-2016, 04:26 PM
Abdullah2016 Abdullah2016 is offline
Mein Auto: BMW 2009 750Li
Hello,
I have changed my oil and tried to reset the signal but I could not , I have driven my car more than 650 km up to now since last oil change , I keep trying to reset and every time I got this message saying " engine oil reset not possible ", I have tried this many times without any success. how do I solve this problem, am I doing it wrong? below some photos that I shot , please help.
Name:	oil reset not.jpg
ID:	565137   Click image for larger version
ID:	565138   Click image for larger version
ID:	565139   Click image for larger version
ID:	565140   Click image for larger version
Old 05-29-2016, 05:52 PM
paprmkr's Avatar
paprmkr paprmkr is offline
Mein Auto: 2010 BMW 750Li
i used the dash cluster to reset all my service. google it and will show you how. i know you have to add the last five digits of VIN to get the unlocking number when asked.
this might not be it but recall
1- ignition on (not engine)
2- keep the mile reset on left corner of cluster pressed until asked to enter the number(vin total number)
3- then click until you get to the oil service
4- press and keeping pressing the left button again until reset
better check on google thats what i did for oil, brakes etc...
Old 05-30-2016, 07:07 AM
Hi everybody,
Paprmkr thank you so much for your fast reply, I know the procedure and I came to the last step but when I try to reset , it will not reset , there may be some thing wrong or the way I did it incorrect.
I forgot to put this photo.
Name:	Engine oil rest not possible.jpg
Old 05-30-2016, 12:13 PM
paprmkr's Avatar
was it due for oil change? maybe the counter has to be low enough to reset. sometimes i buy my oil then have shop change it for $20. they have this tool to reset via OBD. maybe that is what you need.
Old 05-30-2016, 04:37 PM
joeyrs416 joeyrs416 is offline
2009 750i
Mein Auto: 2009 750i
I think if you just wait until the cbs updates something like the brake service, it will have a number against the oil service. At that point, you can reset it. That happened to me quite a few times and I just ended up manually recording my oil changes which I do every 6 months. I know it is annoying to see that yellow glow when you start the car but again if you wait a few weeks, you'll get a chance to reset it.
2009 750i Imperial Blue Metallic, Style 253 Wheels
Old 03-14-2017, 12:26 PM
TXSTYLE's Avatar
TXSTYLE TXSTYLE is offline
The Entertainment Guru
Send a message via Yahoo to TXSTYLE
Mein Auto: 750i (F01)
Question
Originally Posted by Abdullah2016 View Post
Hi everybody,
Bump***
I just performed an oil change and I get the same notification when I access this Menu as well. *Oil Reset Impossible*
What's odd is that in iDrive shows all systems OK but it also shows "Unable to determine Oil Level"
https://i.imgur.com/YdmhJBM.jpg
Old 03-14-2017, 08:22 PM
wjjklj's Avatar
wjjklj wjjklj is offline
Mein Auto: 2013 BMW M5
This is a software glitch. You will need to get software reset.
Old 03-15-2017, 08:44 AM
TXSTYLE's Avatar
Thanks wjj. Do you know if coding can correct or dealer specific software?
Sent from my LGLS992 using Bimmerfest mobile app
Old 03-15-2017, 02:00 PM
keeble keeble is offline
Mein Auto: 328i Wagon, Dodge Diesel
If you have low mileage, it may be the oil condition sensor in the oil pan. If you have more than 180,000 miles (300,000km) there's a similar thread on e90post with the service bulletin addressing the problem on high mileage BMWs (FUB-FUB-FB-121402-A09 CBS Engine Oil Service. It calls out performing SCBS_6006 engine oil deactivation literaaly deactivates the CBS engine oil service display in the instrument panel.
Old 03-15-2017, 09:41 PM
wjjklj's Avatar
Marcus- I had to have my dealer update the software.....coding didn't work.
Old 03-16-2017, 10:34 AM
TXSTYLE's Avatar
57k miles
thanks for the reply.
TXSTYLE's Avatar
Old 03-17-2017, 02:24 PM
firefox firefox is offline
TXSTYLE, I had this error the other day and could not reset the oil through the normal procedure. I tried doing it through my Carly Wifi Adapter and it worked. Maybe we can meet up sometime and we can give it a shot.
Old 03-18-2017, 09:38 AM
TXSTYLE's Avatar
Absolutely! PM sent...
Old 03-25-2017, 08:34 PM
Well, it appears that I was able to reset TXSTYLE's oil using the Carly app. Hope that it doesn't come back.
I got to say, that car is clean beyond belief. I'll need to spend tomorrow cleaning my car.
Old 03-25-2017, 10:13 PM
TXSTYLE's Avatar
Thank you my friend for helping me with that. Great app! Nice meeting you.
Old 03-26-2017, 07:15 PM
wjjklj's Avatar
Nice job helping a long term member. Marcus does ride clean for sure!
Old 03-27-2017, 08:46 AM
TXSTYLE's Avatar
Thx bro!
Old 04-02-2018, 02:43 PM
Dkozicz Dkozicz is offline
Mein Auto: 2009 750LI
Hello fellow BIMMERS!!! I am New new...and i have the same issue with the error message in the dash screen. What steps do i need to take to reset the service on the oil sensor? 2009 750li 115,000 miles... LOVE THIS CAR!! Any advice will be followed promptly. Thank you guys.
Old 04-03-2018, 06:15 AM
Cmhyde72 Cmhyde72 is offline
Mein Auto: 750LI
I had same issue. had to get the scanner hooked up to reset it. Thankfully a friend of mine did it for me. It was driving me nuts.
Old 04-03-2018, 06:45 AM
@Cmhyde, what kind of scanner arr you talking about? I have an obd 2 scanner but i dont think it can reset the oil service indicator. Let me know.
Old 08-10-2019, 04:28 AM
hnajee hnajee is offline
Mein Auto:
@Abdullah2016.
I live in Jeddah and want to do regular 100K maintenance and will appreciate your assistance. hnajeeATgmailDOTcom
Old 09-19-2019, 06:58 AM
voxsam voxsam is offline
Mein Auto: X5
Originally Posted by hnajee View Post
@Abdullah2016.
Go to any work shop there is one close to car show aljohara
