Shock absorber replacement? - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series & 8 Series > 7 Series - F01 / F02 / F03 / F04 (2008 - 2015)
The 5th generation F01/F02/F03/F04 BMW 7 Series flagship forum. The redesigned 7 series leads off the BMW Fxx chassis code, offering an 8 speed automatic transmission and all turbocharged engine options.
Old 08-07-2016, 12:25 AM
757series 757series is offline
Mein Auto: 750li
On my 7 series the rear left side sits much lower then the right.. Dealer told me shock absorber needs replacement at a cost of 2800$... Any thoughts or anyone have similar issue ? Thanks ! Brian
Old 08-08-2016, 03:08 PM
MCChuck's Avatar
MCChuck MCChuck is offline
Mein Auto: 2009 750Li
I'd try to get an Indy mechanic to do it.
The rear air spring is ~$1300 from BMW parts store that discounts.
Full list is $1800
I can't imagine its more than 5-6 hour job, plus any reprogramming time.
I'm not a mechanic. YMMV
Good luck
Old 08-10-2016, 02:27 PM
coole65i coole65i is offline
Mein Auto: 2009 F01 SPORT
Holy cow. At that price, depending on how long you want to keep your car, you might want to look into a set of KW coilovers. Depending on the model you have, a FULL set of new struts AND springs will run between $3k - 5k. I swear by KW. They were an AWESOME set when I had my E60.
Old 08-10-2016, 03:05 PM
MCChuck's Avatar
Would probably be a great plan if he wouldn't get an eternal Chassis MIL
Old 11-08-2018, 03:05 PM
Hellzangel Hellzangel is offline
Mein Auto: BmW F01
What did you do fix the issue?
Sent from my ONEPLUS A3003 using Bimmerfest mobile app
Old 11-09-2018, 04:15 AM
Cmhyde72 Cmhyde72 is offline
Mein Auto: 750LI
I just went through the same thing. Replaced both at dealership and it wasn't cheap. Only to find a guy here in Houston that can rebuild them and install them for $750 each.
Old 07-28-2019, 03:32 PM
MarekBMW MarekBMW is offline
Mein Auto: 2015 X5 35d , 2015 740li
Could you please provide name or contact infor to guy that rebuildd them. Thank you.
7series, shock absorber, strut replacement, suspension
