+1 Everywhere edge wear is first resolved with a proper alignment.
Here's a hypothetical; why not align ALWAYS to straight ahead zero toe and vertical camber?
Toe-in compensates for the elasticity of suspension components that would otherwise cause/allow toe-out with its known difficulties. Negative camber compensates for body roll to make the loaded wheel vertical.
Very few of us need all-out track suspensions....don't bother with caster, lads. Much of this is overkill.
Focus on camber, which @ -2.5° or more yields a superb ride you thought was not possible. Combined with better shocks, springs; suspension arms, a delighted grin is yours. More like euphoric. Orgasmic?
Those of you reporting these posts by KMac, please note that they are a site sponsor and thus allowed to post advertising. I'm not crazy about their ginormous post, but they are allowed to post it.
I've heard slight toe-in helps preload the wheel bearings. I imagine if zero toe was set, any clearance in the wheel bearings would cause unstable straught-ahead driving and tire out the driver.
Camber can be modified to match your driving patterns. I had one car where camber was properly set, but the insides of the front tires were wearing. Apparently I didn't do enough cornering. I had to set camber closer to zero.
Can you make the font any bigger? Hard to read from the International Space Station.
Related Threads
BimmerFest BMW Forum
11.4M posts
753.1K members
Since 2001
