Wynís EGR cleaner - Ok for MA sensor?? - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > General BMW Questions
Use this forum to ask general question about the BMW ownership and keep up on the latest BMW news. Direct all model specific questions to model specific forums below.
Old 12-13-2018, 04:01 AM
Stoo1701 Stoo1701 is offline
Mein Auto: 325Ci Se
Hi, wanting to clean my mass air flow sensor, local parts place doesnít have MA sensor cleaner spray but has Wynís EGR cleaner, which does say it can be sued on the sensor. Wanted to double check.. what do you guys think? Anyone used this for this job?
Sent from my iPhone using Bimmerfest mobile app
Old 12-13-2018, 04:10 AM
APLinhares APLinhares is offline
Mein Auto: F10 520d
I don't think so.
They even recommend apply it after MAF, should be for some reason...
Old 12-13-2018, 04:24 AM
Doug Huffman's Avatar
Nuclear engineer
I disbelieve that the MAF can be effectively cleaned. The test would be for a MAF to fail for "implausible indication" and be recovered by this cleaning.
A MAF is two thin film IC resistors, the sensitive one exposed to the intake air stream, and the reference one not exposed to the stream. They are both heated by a bridge circuit current that compares the resultant temperatures. The sensitive element also accumulates oily film that is baked into a thermal insulating insulating varnish.
It is better to meticulously maintain one's engine air filter which FIRST job is to protect the MAF and keep it clean.
Old 12-13-2018, 04:32 AM
Mein Auto: 325Ci Se
Appreciate the input Doug, but as the question suggests, itís a bit late for preventative maintenance.. I am being told by a number of forums that contact cleaner like wd40ís cc is a good spray to clean it out, as a last course before buying a new one for £170+.
Seems MAC sensor cleaner is the same thing as contact cleaner, packaged as a specialist product but identical.. does anyone have any experience using this?
Old 12-13-2018, 04:55 AM
Nuclear engineer
WD-40 cleaner formulation is trivial
Acetone. CAS 67-64-1. 80-90% (Effective ingredient)
Carbon Dioxide. CAS 124-38-9 1-10%. (Propellant)
Heptane. CAS 64742-49-0 142-82-5. <10%
Isopropyl Alcohol (Isopropanol). CAS 67-63-0 1-3%
Old 12-13-2018, 05:28 AM
Mein Auto: F10 520d
You want to use wd40?!
To MAF get sticker or get muddy easier?!
Or You really want to buy a new one?
You could use brake cleanup product's as they have alcohol in his composition. If you like.
Old 12-13-2018, 05:33 AM
Mein Auto: 325Ci Se
WD40 contact cleaner mate, not WD40 ! Residue free...
