How Good is the A/C? - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > X Series > X5 G05 (2018 - Current)
G05 BMW X5 produced between 2018 to Current. Discuss the G05 X5 with other BMW owners here.
Old 05-24-2020, 09:42 AM
SuzyQ SuzyQ is offline
Mein Auto: 2017 BMW 540i
I am two months away from the end of my lease for my 2017 540i. It's been a great car with one exception. The air conditioning is the weakest of any car that I have ever driven in my entire life (three consecutive Lexus models prior). I'm in SE Texas and it is miserable unless you have it on max A/C and then it's just incredibly loud.
I am now looking at the 2020 X5. Are there any complaints with the A/C in this model?
Old 05-24-2020, 09:58 AM
Doug Huffman's Avatar
Nuclear engineer
The performance test is the same as for your 2017 540i. I'll post them both for you, gimme a minute or two ...
newTIS.infobeta
Home / BMW G30 540i Sedan / Repair Manuals and Technical Data / 64 Heating and air conditioning / 64 50 Air conditioning, check / 64 50 ... A/C performance test
https://www.newtis.info/tisv2/a/en/g...check/GbGkqA9N
newTIS.infobeta
Home / BMW G05 X5 xDrive50i SAV / Repair Manuals and Technical Data / 64 Heating and air conditioning / 64 50 Air conditioning, check / 64 50 ... A/C performance test
Old 05-24-2020, 10:28 AM
Ugh. Thanks... I think?
I know on the G30 forums back when I purchased my car, people were speculating that the inefficiency of the A/C was due to the slant of the windshield, and people were tinting them (I could have the details a bit skewed on that - it's been a while).
It's a serious deal-breaker for me. I guess I'll ask if I can hold on to an X5 for a few hours and test it out in our heat.
newTIS.infobeta
newTIS.infobeta
Old 05-24-2020, 10:41 AM
Nuclear engineer
You will probably be happier with something other than a BMW, perhaps a Suburban or a navigator.
The BMW IHKA HVAC is not inefficient but it is sophisticated beyond American experience.
Mine works fine including my trips to the South, to South Carolina, and Florida, and Texas, and the desert Southwest. The HVAC controls are occasionally momentarily changed as when we get off the ferry after a half-hour with the engine off and the windshield is fogged on the inside and frozen spray on the outside, but back to AUTO and default settings within five minutes.
Old 05-24-2020, 11:17 AM
It's something that I think was a G30 issue from what I recall, not an overall BMW issue. I have a friend who had a 2015 X5 and I never noticed anything odd about the AC in it and I was in it quite often for work. I just wanted to make sure that whatever they changed in the 2017 540i wasn't carried over into the X5's as well.
Old 05-24-2020, 11:37 AM
Nuclear engineer
Thanks for the suggestion to read up on G30 / G12 IHKA.
Old 05-24-2020, 11:59 AM
I just spoke to a friend who has a 2019 X5 and she told me she has the same complaint about the AC. I guess I either live with it or move on to something else.
Old 05-24-2020, 12:31 PM
Nuclear engineer
As I said, I believe that you will be happier with something else. Best wishes.
Old 05-24-2020, 03:33 PM
TheTurtleBoy TheTurtleBoy is online now
Mein Auto: 2019 X5 40i
It sounds like she does not have her AC adjusted correctly. The AC is very strong/cold, actually the coldest I, and many others, have ever experienced. More than likely she does not have the upper air flow adjusted to be cold (given that she actually has the AC turned on although I have spoken with people who have not). Many folks do not realize that this needs to be done on order for the coldest air to blow from the upper vents.
Name:	Screen Shot 2020-05-24 at 4.32.37 PM.png
Old 05-24-2020, 06:42 PM
jadnashuanh jadnashuanh is online now
Mein Auto: 535ix-drive GT; i3 BEV
Even in auto, the fan control is more of an aggressiveness control than directly adjusting the fan. Try moving it higher in increments after you've made sure the upper vent temperature control is right for you.
Jim DeBruycker
Old 05-24-2020, 07:01 PM
In addition you can also hit the Max AC button, that will put frost on your nose in no time.
Old 05-25-2020, 06:37 PM
I test drove a 2020 today and the AC was way better than my G30, so much so, that we pulled the trigger. Out with the 2017 graphite gray 540i and in with the 2020 graphite gray X5 40i.
Old 05-25-2020, 07:00 PM
Congratulations. Good luck, enjoy and be safe.
Old 05-28-2020, 12:23 PM
Sonny184 Sonny184 is offline
Mein Auto: 2020 X5
I fought the the A/C in my 2017 540i for three years. There is day & night difference with the A/C in the 2020 X5. No matter what the data says, the user experience is very much improved.
2020 X5 40i Tanzanite Blue II
2020 X5 40i Mineral White
2017 540i Bluestone (retired)
2018 X3 M40i Glacier Silver Metallic (retired)
2016 X3 Black Sapphire Metallic (retired)
2014 535i (Mineral White) retired
2014 X3 (retired)
2011 535i (retired)
Old 05-28-2020, 02:09 PM
Stans Stans is offline
Mein Auto:
Ac
The problem is with the tubing layout. The left most vent does not get enough air flow even with the fan on high. Other people are correct in that you need to use the AC menu to set the air flow at max. This will be noisy for a while but if you use the recirculating function you can lower the blower to half way and the car will remain cold. I live in Florida and found this method works
Old 06-02-2020, 02:40 PM
I've had my X5 a week today and you're right - night and day difference. I find myself having to turn the temp up in the X5.
