Strange Noise - Bimmerfest - BMW Forums
Old 12-14-2019, 08:41 AM
J306TD J306TD is online now
Mein Auto: 335i ActiveHybrid3
Strange Noise
When I unlock the car after its sat over night or for a few hours. It makes like a creaking noise that sounds similar to a stuck starter motor. I don't get in the car this is just when you unlock it. It drives fine no issues.
Any ideas?
Sent from my SM-G960F using Tapatalk
Old 12-14-2019, 09:13 AM
El_Quandro El_Quandro is offline
Mein Auto: F30 335IAX
is it not the fuel pump that is building up pressure (priming)?
I have something similar that last for 5 seconds or so
Old 12-14-2019, 10:16 AM
Strange Noise
Old 12-14-2019, 12:21 PM
This is the sound I am hearing when unlocking
E90 not F30 I know but sound is the same
This guy has the same problem as you I think
https://www.e90post.com/forums/showthread.php?t=1116989
Again E92 not a F30
Any codes on the car?
Old 12-14-2019, 01:02 PM
Bottom video definitely sounds like mine. I hope it's nothing major. Will check for codes in the morning
Old 12-15-2019, 03:51 AM
No codes ...hmmm. Have emailed BMW UK about this as it seems US guys have a warranty on these
Old 12-15-2019, 04:35 PM
attycda attycda is offline
Mein Auto:
I'm virtually positive that the top video in post #4 is the fuel pump. I've been dealing with one on a 328. Fortunately it's not my car, and they had already made the decision to replace the fuel pump before I got involved. The designs are not that dissimilar. I replaced the fuel pump, replaced fuses, replaced at the fuel injector relay (last two being cheap), and I believe I finally have the problem identified.
The way I understand it, and it appears to be showing in your video, is that when you click the remote to unlock the car, (turn the key to accessory in older models) a fuel pump electronic module called the EPK sends a signal to the fuel pump which causes it to run for a few seconds in order to have pressured fuel in the fuel injectors for start-up.
In every video that has talked about the fuel pump, part of the diagnosis (basic mechanic not code use obviously) of the fuel pump is to listen for it to make that sound. It's absence says that the pump isn't working. On all the models that I've seen, the fuel pump is under the passenger side rear seat so to that end, when it's a model like yours, you stand by the passenger's side rear door when you unlock the car to listen for the sound. It's quiet evident in your quiet garage.
I have no idea what the sound is in the second video. It could be an evolving fuel pump issue or it might be something else that is activated at the same time.
I would have no reason to believe that the sound in the first video leads to the 2nd.
Old 01-08-2020, 02:06 AM
Car has been looked at by local dealer. It is the valvetronic motor that has gone
