Rear Window Defroster - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series & 4 Series
3 Series & 4 Series
The BMW 3 Series and 4 Series Forum. If you would like to see all new posts in all the forums, click here.
Old 01-18-2003, 05:19 PM
otto325ci otto325ci is offline
I miss my baby
Mein Auto: 2006 silv 330i sp w/step
I have noticed that it takes about 10-15 minutes for my rear window defroster to actually heat up the window enough to see the condensation burn off. For the duration of that time I can't see out the back window if there is moisture on the outside. Has anyone else had this problem? how long does it take on your cars? I want to take it in but it seems like such a trivial problem. Is there a regulator for the RWDF that can go bad?
Old 01-18-2003, 10:12 PM
tgravo2 tgravo2 is offline
SPF 100 Protection
Mein Auto: 202 X5 M50i
Is it just foggy? Only takes mine probably 5-7 min max.
2020 X5 M50i
2018 M3 - Traded
2002 325i - Long Gone.
Houma, LA
Old 01-19-2003, 10:05 PM
I miss my baby
Foggy...
and condensation on the outside. I don't expect it to clear the water off the back window but thats what mainly keeps the window fogged up. I'll try squeegeeing the back window before i take it in to see if that improves the situation.
Old 01-20-2003, 11:23 AM
AF AF is offline
Here since day one
Mein Auto: 2019 540ix
That does seem a little long if the fog was on the inside but it sounds like the problem is on the outside.
When you drive, doesn't the water bead off the window ?
Have you considered waxing the outside of the rear window so that the water will bead off quickly . . .
Old 01-20-2003, 05:38 PM
machmeter's Avatar
machmeter machmeter is offline
Adolescent On-Call
Mein Auto: 330i
Mine is faster.
Just fogged on inside / outside, between 35-60 degrees, it takes about 1-3 minutes. Haven't tried it on ice, yet.
