99 540 Q's - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series
5 Series
Ask questions and discuss the 5 Series here. If you would like to see all new posts in all the forums, click here.
Old 11-26-2004, 02:17 PM
ara662 ara662 is offline
Mein Auto:
99 540 Q's
I got a 99 540 sport. The certification on it expires on 04/2005. My power stering leaks would that be covered under the warranty? Also how do I reset the Oil indecator. And what are the other two filters under my hood???? Thanks
Old 11-27-2004, 05:16 AM
Sal329 Sal329 is offline
Mein Auto: depends on the day
Power steering leak is covered, two filters under hood are your AC micro filters.
Old 11-29-2004, 07:07 AM
dagoo98's Avatar
dagoo98 dagoo98 is offline
Mein Auto: 2014 BMW 650xi Gran Coupe
need a computer to reset the oil indicator, the dealer should do it for free if its under warranty.
Old 11-29-2004, 07:29 AM
humanoid humanoid is offline
Mein Auto: Dinan 540iA
You can place a wire on pin #7 and on a grounding pin #19 or better yet, ground to your shock tower bolt. Make the connection for about 3-5 seconds and it should reset. I have not tried this but, many fellow enthusiasts have and it works just fine.
Humanoids website.
Old 11-29-2004, 08:28 AM
M.Wong's Avatar
M.Wong M.Wong is offline
E38 E91 (R56 E30 E39)
Mein Auto: The E38
With the ignition off, put a wire between pins 7 and 19. Turn the ignition to position 2, "run." (Do not start the engine.) After just a couple seconds, remove the jumper wire. (If you wait eight to ten seconds, it will do an Inspection reset.)
On my E30 the lights reset without removing the wire, but on the E38 the wire has to come out. The E39 should be like the E38.
M.Wong
E38 2000 740iL Orient Blue
E91 2012 328xiT Alpine White
Passed on to new families:
E30 1987 325i Royal Blue
E39 2003 540i/6 Sterling Gray
R56 2010 Mini Cooper S British Racing Green
Old 11-30-2004, 09:47 AM
GJR's Avatar
GJR GJR is offline
Mein Auto: 2003 530i
Great info-. I'm assuming this should work on my '00 as well...I'll give it a try. Thanks.
Old 11-30-2004, 12:45 PM
GJR's Avatar
GJR GJR is offline
Yes! Works like a charm.
Similar Threads
Aluminum Trim for a '99 540 Cabriolet 5 Series 3 09-06-2004 04:25 AM
Q's for IPODing a 99' CRZY BMW 3 Series & 4 Series 5 08-19-2004 01:54 AM
will 245/40/18 275/35/18 rub in 99 540 spt? ProV1 5 Series 19 03-22-2004 05:04 PM
Installing M5 cluster in 99 540 ALEV8 5 Series 11 10-08-2003 06:12 AM
F/s 99 540 I Sport 6spd $28,500 DANS540I Classifieds 0 06-07-2003 08:55 AM
