FS: M50 ENGINE - 5 SPEED Trans - LSD Rear Diff - So. Cal. - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Classifieds > Parting Out
Parting Out
Old 12-06-2016, 08:01 PM
Slave 2 Slave 2 is offline
I have questions!!
Send a message via AIM to Slave 2 Send a message via Yahoo to Slave 2
Mein Auto: 92 325is & 78 VW Scirocco
Engine:$250.00
M50B25 Engine for sale.
2.5 litre
Non Vanos
280,000+ miles
This was the stock engine that came out of my E36 1992 325is.
It ran fine, just tired.
Excellent base for a rebuild.
Just the block and internals, head, and exhaust.
Pick up only.
I have an engine hoist here for loading.
$250.00
Trans $175.00
*BMW Getrag 5 speed transmission.
Came out of my E36 1992 325is with 280,000+ miles on it.
Worked perfect when it came out.
No linkage.
No clutch.
Just taking up room now.
Needs a steam clean!
Pick up preferred, but can deliver within reason.
$175.00
Diff $425.00
*I had this BMW E36 LSD pack custom built for me with the lowest gear ratio (2.93) and a high breakaway force (62Nm) set up, but won't be using it after all.
It was going into my E36 1992 325is, but it was much too tight for daily use.
It chirps the tires at every turn.
Pefect for Drift Racing, but not a daily driver.
The ratio can be changed by swapping the LSD section into your own diff.
Will need a rear case cover.
The casing does not have the output flanges, and the driveshaft input shaft was torqued down, and then loosened so needs to be reset.
Brand new bearings and brand new clutches in it.
Pick up preferred, but I can deliver within reason.
$425.00
I can't ship these.
All items near L.A. and will be pick-up only.
ID:	583778   Click image for larger version
ID:	583779   Click image for larger version
ID:	583780   Click image for larger version
ID:	583781   Click image for larger version
