Squeaking noise from under the hood coming to a stop - Bimmerfest - BMW Forums
Old 02-12-2020, 06:47 PM
KrisL's Avatar
KrisL KrisL is offline
Ubergeek
Send a message via AIM to KrisL Send a message via Yahoo to KrisL
Mein Auto: 330i ZHP
'16 328xi.
As the topic says - you can hear the squeal at low speeds. Not related to the brakes being applied.
Video
Any ideas what this is?
Old 02-12-2020, 07:58 PM
AndDown's Avatar
AndDown AndDown is offline
just copacetic!!!
Mein Auto: '16 428i GC
Sounds like belt slippage?
Dan
'01 X5 3.0 AlpWhite
'16 428i GC AlpWhite
'19 230i MSpt AlpWhite
Old 02-16-2020, 09:12 PM
DWG Pauly DWG Pauly is offline
Mein Auto: 2013 335i xdrive Mperf
I had a squeak issue at low speeds and it was resolved upon replacing the hydraulic bushings in the front. Apparently they wear at about 70k. My squeak, however was a bit quieter than yours.
2013 Glacier Silver Metallic 335i Xdrive
///M Performance Package + Bimmercode User
Old 02-18-2020, 10:34 AM
E84F30 E84F30 is offline
Mein Auto:
I have the same problem as OP. The car (2014 x335i) makes the same noise when i let go of the brakes after a traffic stop or at low speed (3-4mph) . It doesn't do it often, but annoying as heck when it does. I took it to the dealership yesterday, they tested out everything and said they couldn't find anything wrong with it. They even test drive it for about 12 miles and of course, damn car didn't make a peep. They did find the control arm bushing to be worn out and leaking. Quoted me $720ish to fix. Is this the same as the Hydraulic bushing? OP, did you figure out a fix? Thanks so much guys.
Old Today, 05:00 PM
Correction...
The squeak is still there. The bushings did NOT fix it.
