E-Series Soot and ash levels check on ISTA + - Bimmerfest - BMW Forums
Old 01-19-2020, 05:28 PM
MRAI MRAI is offline
Mein Auto: BMW X5
Hello Everyone.
Could I please know how do I find soot and ash levels for DPF using ISTA +.
I have run, DDE measure value and diagnosis Scan using ECU Functions.
Cannot find soot and ash levels check.
X 5 2007 - 140k. ISTA + 4.10, using K+D-CAN cable.
I have INPA as well.
Thanks in advance.
Old 01-21-2020, 06:15 AM
Marco_R Marco_R is online now
Mein Auto: BMW
Hello.
Have you checked vehicle management / service functions / power train / digital diesel electronics in ISTA?
There should be a menu item to read out the measured values.
Old 01-22-2020, 01:01 AM
Mein Auto: BMW X5
Originally Posted by Marco_R View Post
Hello.
Thanks for the reply.
I have run measured value. Please see attached images.
There are three options
1. General measured values
2. Measured values for air mass system
3. Measured values for rail pressure control
I don't see soot and ash level. Still learning.
Regards
Name:	General Meausred Value.JPG
ID:	879359   Click image for larger version
Name:	Measure Value for Air Mass System.JPG
ID:	879361   Click image for larger version
Name:	Measured Value Rail Pressure.JPG
Old 01-22-2020, 06:12 AM
Mein Auto: BMW
Hello.
Try Control unit tree / DDE / call up ECU functions (shown at the bottom left of the desktop) / Diagnosis scan / Microfilter
Old 01-22-2020, 08:09 AM
Mein Auto: BMW X5
Hello.
I have tried mentioned option too but unfortunately cannot find only selective options
on the same note I saw a video on YouTube and using the same options it showed Soot Mass.
Don't know the reason why is not showing in my installed ISTA? I am using ISTA+ 4.10.
Thanks for help.
Name:	DDE ECU Functions.JPG
ID:	879383   Click image for larger version
Name:	ECU_Soot Mass Menu.JPG
Old 01-22-2020, 10:33 AM
Mein Auto: BMW
Hello.
This function (soot and ash levels) may not be available on the N57. Then I only have Tool32 as a possible solution.
Old 01-23-2020, 12:26 AM
Mein Auto: BMW X5
Hello.
N57 Engine compatibility? Would same ISTA+ version will have those other options for other BMW vehicle?
Will do some finding with Tool32. Cannot find through INPA.
Interested to know what others use to find ash and soot levels? Carly?
Thanks again for your help. Still learning..
Old 01-23-2020, 04:25 AM
Mein Auto: BMW
Yes, it can be assumed that the newer models or rather the new software versions of the DME / DDE in ISTA offer better / further options.
dpf, ista+
