External Trans Filter - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series & 8 Series > 7 Series - E23 / E32 (1977 - 1994)
Old 06-17-2014, 03:23 PM
chazzonehighlan chazzonehighlan is offline
Mein Auto: 735i
I want to ad an external filter for my E32 auto trans, and I need to know the size for the cooler lines. I removed the nut from an old trans and it fit a 1/2" fitting at the store, but the 1/2" barb I bought was too big.
Thanks,
Old 06-17-2014, 03:54 PM
fidolido fidolido is offline
Mein Auto: 93 525i E34
When buying pipe from a regular store, you need to specify inside (ID) or outside (OD) diameter size. The barb you bought was probably inside diameter.
Old 06-17-2014, 06:34 PM
Mein Auto: 735i
I didn't buy a pipe, I bought a 1/2" flare to barb fitting.
I do know how sizing works.
Now, does anyone have the information I asked for?
Thanks,
Old 06-19-2014, 06:54 PM
m735is m735is is offline
Mein Auto: e23, e32, e34, e39
The new lines I have for my e23 say 12X19 on the hose. I would imagine they would be similar.
Old 06-21-2014, 08:03 PM
TerryY's Avatar
TerryY TerryY is offline
Old Fogey
Mein Auto: BMW '95 840
A bit of a warning. No part on a BMW is Imperial (inch) threaded. Everything is Metric and attempting to screw Imperial fittings into metric will only screw up thread$.
Terry
Woodland Washington
'95 840Ci
'98 740i
'00 Range Rover Vitesse
www.wuffer.net
www.8coupe.com
www.8er.org
Old 06-24-2014, 06:22 AM
Mein Auto: 735i
So...no one has a clue?
Old 06-24-2014, 07:20 AM
TerryY's Avatar
Old Fogey
Find a Local hydraulic hose making shop. They should have any metric fitting that you would need and can make hoses and probably pipe to fit.
Terry
Woodland Washington
'95 840Ci
'98 740i
www.wuffer.net
www.8coupe.com
www.8er.org
Old 06-25-2014, 11:54 AM
BMWFatherFigure's Avatar
Old School
+1 on both TerryY's answers.
Current:
3 x E32 735iL(Alpine White (I6), 750iLBronze Beige (V12) & 730iL Kashmir Beige); E38 735iL (Alpine White); E53 X5 4.4i (Pearl Beige); R50 Cooper; R55 Cooper Clubman (Both Pure Silver). E36 318Ti
Previous:
E21 318i; E23 735i; E30 318i; E32 735iL; E34 535i; E38 730iL & 735iL; E53 4.4i
