bmw 98 m3 coupe won't start - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 01-02-2020, 07:23 PM
vnadonza vnadonza is offline
Vnadonza98m3
Mein Auto: m3
Need help trouble shoot problem with my 98 M3 coupe. while parking engine suddenly stop running. Try to restart engine won't crank only a slight click. I was able to move by having somebody push car but when I stop and start engine again it will not start. What would cause the engine not to start only slight click from solenoid. any suggestion to fix problem or what cause this problem. Appreciate very much any help.
Thanks, Vnadonza 98M3
Old 01-02-2020, 07:33 PM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x3,E30x2, F150
Battery condition? Get it LOAD TESTED, not just an analyzer quick check.
Quotes to live by:
Ken Kanne, Silverhill, AL, Bimmerfest Site Moderator
BMW-CCA #441426
1993 325is M3 clone"Ashlyn"; 1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette";1995 318is"Bebe "; 1985 325e "Hazel Ann"
Old 01-02-2020, 08:52 PM
Vnadonza98m3
Mein Auto: m3
bmw 98 M3 coupe won't start
Hornhospital thank you very much. I was already charging my battery and has finish putting a new starter yesterday. The problem started after coming from work and parking my car I backing up to straighten my car the engine suddenly stop and won't even crank when I try start again so I have push and it run but after I park and stop I just won't start. Could I have a bad alternator and its not charging my battery. I just start the car and it start. I will check alternator see if its charging the battery when I run it. I can't run it right because I dis assembled a lot of stuff when I change starter and I'm in the process of putting it back together. Thank you very much again for responding you are truly a Bimmerolgist.
Thank you
,Vnadonza 98 M3
Old 01-05-2020, 04:04 AM
spyderg0d spyderg0d is offline
Screamin demon
Mein Auto: 1995 325ic
If the altinator was bad, the car wouldnt continue to run with a dead battery after you push start it.. It seems sporadic in nature
You have a bad connection.
I suggest looking at the engine ground strap. If it becomes loose or bad connection, the battery does not charge while running, and likewise the alternator cannot run the system. And can lead to a stall after the battery is depleted.
