X5 India Review - Bimmerfest - BMW Forums
The X5 SAV Forum
Old 01-22-2007, 02:57 PM
TropicsX5's Avatar
TropicsX5 TropicsX5 is offline
Mein Auto: Z4 X5 325I
X5 India Review
Athens. To me, it always was a city that surrounded a crumbling mansion atop a hill. And guess what, I was right all along.
What I didn't know was that the capital of Greece which houses 40 per cent of the country's population is surrounded by hills and beautifully paved roads that line the deep blue sea. And another thing that I learnt is that Athenians eat a great deal of cottage cheese and fish and they drive like mad men.
As a result - this too I learnt during this trip - Greece has the highest accident rate amongst European Union countries. Brilliant location then, to launch the new BMW X5.
Actually yes. The weather, during early winter, is bearable and the sun shines despite the chill in the air. Try a Google Earth search and you might see the road that lines the calm Aegean sea and you see the rationale.
With the original X5, BMW created an SUV that could go around corners like a car and they wanted us to experience the new version on these very corners. Lots of corners.
I can handle that all right, as long as I am driving it in a straight line. In such a scenario the new X5 will do a neat 100 kph in 6.5 seconds flat and touch 240 kph. The problem area was the above-mentioned corners.
Powering into one and lifting off a nanosecond late would have meant a shiny new X5 and me taking a nice dip in the blue sea. And did I tell you that the water was cold?
Actually it was not all that bad. With the new X5, it is the first time that BMW has used double wishbone suspension up front. Sports car buffs will know the benefit - more intimacy with tarmac.
Combine that with X-drive (all-wheel drive) that allows a 40:60 split in normal driving conditions and Dynamic Stability Control and lots of 'adaptive' stuff, and the X5 is more or less a car to drive.
A very fast, tall car. Body roll is minimal and turn-ins are precise. Or as precise as it can get with a vehicle that can become a tank if you add turrets to it.
What was hard work though was restraining myself. Burying the throttle was scary and I longed to drive the diesel, which I hoped was more in tune with my ability to drive on those beautiful roads. And let me tell you, the brand new all-aluminium straight-six diesel was a revelation.
This engine features third generation common-rail fuel injection (makes you feel that you were a guinea pig for the first two generations). It develops 235 bhp and 52 kgm of torque between 2000 and 2750 rpm.
That, to you and me, should mean a very flat torque curve that makes the car pleasantly driveable at almost any given engine speed. It does not mean the oil-burner is slow by any standards - it is barely two seconds slower than the V8 petrol and can touch 216 kph when annihilating autobahns.
See, if you needed to reach anywhere any quicker, you would buy an M5, right? Don't know about others, but after driving both these machines I was convinced that it is the diesel that makes sense on Indian roads. And yes, it won't need an oil refinery to run and has more than adequate power.
I drove the X5 to Marathon village from Athens airport (where BMW had put up a nice media centre). I drove it through towns where it dwarfed Smarts which are abundant in Athens, on squares where it was a breeze to pilot, over fast B-roads which required caution since Greek truck drivers looked like they were on a cheese-and-fish diet too, and then drove through a carefully thought-out gravel road.
The gravel stage made me think of the original X5. It was the first time BMW was making an attempt at an SUV and they ensured that they got it right first time around. And that meant an over-engineered marvel.
When the time came to make a replacement, BMW applied the valuable lessons from the first experience and the result is a car that is adequately (and not over) engineered. That means, the indestructibility of the original is replaced with a certain agility that can be best experienced on tarmac.
When the going gets a bit tough, the new X5 will not hesitate in showing its vulnerable side. Fair enough, since almost every owner of the X5 is going to stick to good roads. As if to drive the tarmac point home, the X5 also gets active steering - configured specially for it.
At speeds up to 90 kph the transmission ratio of the steering is very direct and that means you don't have to cross over arms on the steering wheel when you are attacking tight corners. And yes, it helps while parking too. As speeds mount and directional stability becomes more important, the ratio is optimised accordingly.
Making tall vehicles go around corners and tackling tricky terrain is no longer as difficult as it used to be and the X5 benefits from Dynamic Stability Control which incorporates ABS, ASC (automatic stability control), HDC (hill descent control), trailer stability control, dynamic brake control, cornering brake control, ADB (automatic differential brake which acts as a differential lock) and a CFO (control freak officer).
Alright, I made up that last one. Seriously, this car has some brains and it is the first car to use FlexRay high speed data transmission system. Sure, it needed that.
It is difficult to re-engineer and design an interior package that looked absolutely contemporary, right? The new car needed one and BMW has gone ahead and done the honours.
The highlights are the new iDrive controller and an electronic gear selector lever. The new iDrive is more intuitive (really) but I really had trouble understanding the design philosophy of the gear selector. It works well, but the "pistol-grip" unit can't be read when you are trying to flick it to and fro (your palm covers the back-lit surface).
Sure you will get used to it, but if you have to select "drive" in twilight on your first day out with an X5, you ought to be careful. Nit-picking aside, the interior of the new X5 is a comfortable place to spend quality time in. The third row of seats are optional and not exactly meant for adults - but, ahem, like the Audi Q7, it can now be termed a seven-seater.
I normally start a driving impression with the styling of a car and I didn't do that here simply because the new X5 follows the 'why trouble' route. The old X5 was a very successful car and the design brief was to build a car that is wider and longer but one that looked less bulky.
The result, like the new Mini, is derivative, but one that builds on the success of the original. Maybe this is what you do when you create benchmarks and then try to improve them. Surprisingly BMW provided only gun-metal grey cars for test duty (very much a BMW colour) and I really wanted to see one in black or white before passing judgement.
When the drive was over and the X5s were parked en masse they looked splendid. The plastic bit below the kidney-grille is a distraction but the seven surfaces on the bonnet that leads up to it is a flourish and a Bangle trademark.
Add to that the corona rings on the headlamp and a sharply tucked waistline and you can see the design direction for scores of SUVs to follow from Japan in the near future.
The new X5 is a brilliant car that needs to be "lived-in" to appreciate fully. But a spirited drive on Greek roads was a splendid preview indeed.
Old 01-22-2007, 04:16 PM
e60lover's Avatar
e60lover e60lover is offline
Mein Auto: 335i, 535i
Thanks.....
2011 535i- Sophisto Grey/Dark Graphite, cinnamon, dark wood, sport automatic, premium I/II, sport package, convenience package, top/side view cameras, split fold rear seat
2011 335i Coupe M-Sport- Alpine White/Saddle, dark glacier aluminum, premium package, harmon kardon, heated seats, BMW apps
Similar Threads
Range Rover / X5 wmccutcheon X5 E53 (1999 - 2006) 30 08-13-2006 02:39 PM
Own more than 1 X5? suzer X5 E53 (1999 - 2006) 6 02-13-2006 07:52 PM
For the $$ X3 or X5? FireFly X5 E53 (1999 - 2006) 25 01-18-2004 01:33 PM
Why do you guys choose 330i/330Xi instead of X5??? maransm 3 Series & 4 Series 49 09-29-2002 02:54 PM
