Not charging. Battery could any help me out with this - Bimmerfest - BMW Forums
Old 09-21-2014, 07:29 AM
sca sca is offline
Mein Auto:
I just bought this 98 bmw and the previous owner replace the alternator. But now the car is not charging the battery I was told that theirs a fuse to the voltage regulator but can seem to find it could any one direct me to the right place
Old 09-21-2014, 07:33 AM
sca sca is offline
Mein Auto:
It's a 98 740 IL
Old 09-21-2014, 04:02 PM
TerryY's Avatar
TerryY TerryY is offline
Old Fogey
Mein Auto: BMW '95 840
F22 and F23 in the fuse box under the hood on the passenger side are the Charging circuit fuses.
F22 is the 12 volt to the alternator and F23 are the 12 volts to the light in the dash.
Terry
Woodland Washington
'95 840Ci
'98 740i
'00 Range Rover Vitesse
www.wuffer.net
www.8coupe.com
www.8er.org
Old 09-21-2014, 06:35 PM
sca sca is offline
Mein Auto:
I checked them and they were good but I still have the battery light on and I had the alternator check at a auto parts store and it said that the voltage regulator was off or not working. But they didn't know anything else
Old 09-21-2014, 06:54 PM
TerryY's Avatar
Old Fogey
Either the little connector on the back of the alternator is loose or it is time to change alternators again.
Just changed alternators on the $500 special '98 740i that I just bought. Not all that much fun.
Terry
Woodland Washington
'95 840Ci
'98 740i
www.wuffer.net
www.8coupe.com
www.8er.org
Old 09-21-2014, 07:21 PM
sca sca is offline
Mein Auto:
Ok thanks I will check the connection and see what you think on a alternator from auto zone is it worth it or get it from the dealer
Old 09-21-2014, 07:42 PM
TerryY's Avatar
Old Fogey
If you have a local auto electric shop you might try them first. They may be able to fix yours inexpensively. Otherwise it is all about your pocket book. Auto wrecking yards could be a good choice too.
Mine was lightly used and had been on the shelf in my garage for a while so I have no clue on current prices.
Terry
Woodland Washington
'95 840Ci
'98 740i
www.wuffer.net
www.8coupe.com
www.8er.org
Old 09-21-2014, 08:00 PM
sca sca is offline
Mein Auto:
Ok thanks I will look around
Old 09-22-2014, 03:25 PM
sca sca is offline
Mein Auto:
Do have instructions on how to take the alternator off or step by step
Old 09-22-2014, 07:25 PM
QSilver7's Avatar
QSilver7 QSilver7 is offline
Mein Auto: 2006 X5 4.4/2013 650ix GC
Try a page search at www.e38.org
Q {BMW CCA Member #191509}
2006 E53 X5 4.4i (Sterling Gray) 12/05 mfg date <<~>> 2013 F06 650ix Gran Coupe` (Black Sapphire) 1/13 mfg date
(SOLD)
97 740iL (Arctic Silver) <<~>> 99 540iT (Orient Blue) <<~>> 95 525IT (Alpine White)
https://www.bimmerforums.com/forum/attachment.php?attachmentid=637911&d=1538398374&thumb=1&stc=1
Old 09-22-2014, 08:50 PM
sca sca is offline
Mein Auto:
I took it off and took it in and had it check the alternator is bad. Voltage regulator and diode is bad so I have to get one thank you for the help
HTML code is Off
