eas | BMW Coding: Personalization, Troubleshooting, Retrofits, Updating and MORE! - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > Bimmerfest Regional > Regional Forums > California
California
Old 10-03-2011, 11:16 AM
tom @ eas's Avatar
tom @ eas tom @ eas is offline
european auto source
Mein Auto: BMW
european auto source is proud to be your #1 Southern California coding facility!
Whether its a simple Check Engine lamp or are looking for full retrofit coding - we are your one-stop facility for your programming needs.
Why should you choose eas as your SoCal coding facility?
- Over 10+ years experience in module coding
- Fully Equipped with Autologic Diagnostic Scanner/Programmer
- Autologic Optical Interface (OPS Diagnostic Head)
- Proper Voltage Stabilization maintained with Fronius ACCTIVA Professional Flash (70 Amp)
- Non-biased programming facility, with no fear of warranty rejection. We love horsepower as much has you do!
The Autologic diagnostic tool for BMW vehicles is without doubt the most comprehensive tool to be made available to independent BMW specialists. Autologic BMW is unique in offering full fault code read and re-set, full component activation, electronic control unit procedures, clearing and setting of adaptation values, full coverage of (ECU) control units coding, full programming capability including engine control modules and transmission control modules, adjustment of engine idle, real-time reading of all dynamic data, procedure for engine and immobilizer alignment, procedure for trial substitution of control units and procedure for the fitting of BMW accessories.
The Autologic Optical Interface has been designed to program the CCC-A control units on BMW. Connecting directly to the fibre optic MOST bus, the Autologic Optical Interface is able to communicate with CCC-A, CCC-BO, CCC-ASK, CCC-ANT, ULF TCU and MASK ECUs. The Autologic Optical Interface significantly reduces the time to program these control units and further increases the reliability and recoverability of flash updating these control units.
Power Stabilization
Intelligent battery charging systems are very important given the technology of BMWs. We use the Fronius ACCTIVA Series with Active Inverter technology, the only all-round charger which Autologic recommends.
Coding/Individualization
- Video In Motion (CIC iDrive models only)
- Remove BulbCheck errors (for HID/LED or aftermarket lighting retrofits)
- Windshield Wipers complete full cycle when ignition is shut off
- Remove Ignition/Door gong
- Remove iDrive [ACCEPT] screen
- Remove Seatbelt warning gong for Driver, Passenger or both Driver/Passenger (light remains on dash)
- Unlock doors when key is ejected
- A/C off when Auto Climate is pressed
- Auto Sunroof close when rain is detected
- Open/Close windows with Key FOB
- Open/Close Windows with Comfort Access
- Open/Close Convertible Top with Key FOB
- AutoFolding Mirrors
- Change Low Fuel Warning from 1/4 tank to 1/8 tank
- Remove CityLights (Amber sidemarkers)
- Enable FogLamps with High Beams
- Disable Window Safety Feature (allows windows to continue rolling up while door is open)
- Enable Digital Speedometer in OLED gauge cluster
- Enable/Disable auto-correction for Digital Speedometer/MPG
- Euro SMG Software Updates for e46M3, e60M5, e63 M6 (~5000RPM Launch Control, improved shifting)
- Euro Hazard Lamps (double flash vs US single flash)
- Triple Blink turn signals
- Mirror Curb tilt
- Automatic Door Locking
- Auto Trunk/Tailgate Closing
Retrofit Options
- LCI Haillight Retrofits
- Park Distance Control (PDC) Retrofits
- Halogen Highs enabled with Xenon High Beams
- OEM Alarm Coding
- iDrive CCC-CIC Conversions/Upgrades
- LCI Headlight Retrofits
- FRM3 Module Upgrade/coding
- Sirius Radio Retrofits
- IBOC HD Radio Coding
- Heads Up Display (HUD)
- CD CHanger, iPod/MP3, Dension & mObridge Coding
- Bluetooth
RaceCar/Track Preparation Setups
- Remove TPMS
- Race Seat Coding/Recaro Coding
- EDC Delete (for coilover setups)
- Airbag deletes for vehicles with roll cages
- Remove Headlamp Washer System
CBS Coding
- Flash Programming
- Dealer level ECU Software Coverage
- ECU Trial Substitution
- Quick Test & Quick Clear
- Fault codes timeline report
- CBS: Condition Based Service reset and error correction
- Retrofitting of BMW accessories and extras
- Car/Key Memory Function for personalizing vehicle
Service Options
- Module Troubleshooting
- Reset Adaptions
- Module value Monitoring
- Value Reporting (Fuel Pressure, Ignition Advance, etc)
BMW Dealer-Level Module Updates
- Individual Module Updates, including Engine ECU, TCU/ULF/mULF and iDrive
- MKIV, CCC & iDrive OS updates
and much, much more..............
Models Supported
1 Series: E81 / E82 / E87 / E88
3 Series: E90 / E91 / E92 / E93 / E46 / E36
5 Series: F10 / F11 / E60 / E61 / E39
5 GT: F07
6 Series: E63 / E64
7 Series: F01 / F02 / F03 / E65 / E66 /E67 / E68
X Series: X6 ( E71 / E72) X5 ( E70 / E53) X3 (E83) X1 (E84)
Z Series: Z4 (E89 / E86 / E85) Z3 (E36/7/8) Z8 (E52)
M Series: M3/M5/M6 / X5 M / X6 M / Z4 M / Z3 M
Contact Details
Retail Location/ Installation Center:
Come check out our 8000 square foot facility in Anaheim, CA. We install everything we sell.
Address:
4015 E. Leaverton Court
Anaheim, CA 92807
Hours of Operations:
Mon - Fri: 9am to 5pm (PST)
Sat - Sun: Closed
Contact Info:
Phone: 866.669.0705
Email: [email protected]
Website: http://www.europeanautosource.com
Available options vary among specific BMWs year, model and Vehicle Order (VO). Please feel free to contact me directly via phone, email or PM if you should have any questions and I will be happy to assist.
Old 10-14-2011, 01:49 PM
eas eas is offline
Past Sponsor
Mein Auto: BMW
We have time slots available. Give us a call to schedule your service appointment!
Old 11-10-2011, 02:22 PM
eas eas is offline
Past Sponsor
Mein Auto: BMW
We have a few openings available tomorrow and for the following week for coding! Give us a call to set up an appointment
Old 11-29-2011, 09:37 AM
eas eas is offline
Past Sponsor
Mein Auto: BMW
A few slots open these upcoming weeks. Call today and let us code your car!!
Old 12-22-2011, 03:29 PM
eas eas is offline
Past Sponsor
Mein Auto: BMW
Get the options you want coded today!!!
Old 01-03-2012, 11:43 PM
ard ard is offline
Resident Curmudgeon
What do you guys charge to enable Sirius using the FSC code? 2011 X5 w/ CIC (no hardware needed)
Thx
Alignment here: The Definitive Alignment Thread
OE is Original Equipment aka 'BMW Original Parts' aka 'What you buy at the BMW dealer with a BMW label'
OEM is Original Equipment Manufacturer... EITHER the company that made the OE part or.... A part this is identical to the OE part, but is sold by the OEM under their own label
OEM is not what BMW sells
http://www.bimmerzone.com/category/T...ricks_OEM.html
https://www.turnermotorsport.com/t-OEvsOEM
Old 01-04-2012, 09:04 AM
tom @ eas's Avatar
Mein Auto: BMW
Thx
FSC code activation might be best left to the dealership as the code needs to be purchased directly through BMW. We can do it, but it will require 2 trips (read/write).
Old 01-10-2012, 04:13 PM
eas eas is offline
Past Sponsor
Mein Auto: BMW
Personalize, Troubleshooting, Retrofits, Updating and MORE!
Call us now to set up an appointment to get coding done.
Old 01-20-2012, 03:04 PM
eas eas is offline
Past Sponsor
Mein Auto: BMW
Make your BMW your own...
Contact us to set up an appointment to get Personalization, Coding, Troubleshooting, Retrofits, Updates and MORE!!!!
