Hood stuck but cable not broken - Bimmerfest - BMW Forums
Old 03-01-2019, 09:29 AM
jbarb jbarb is offline
Certified humanoid
Mein Auto: 2003 530i E39
Hi all, for the past week I've been having trouble with my hood release. I pull the lever inside the cabin and the hood won't pop. Thankfully the cable has not snapped and if I have someone else pull the lever I'm able to physically pop the hood if I pull at it with a moderate amount of force.
I've tried greasing the hood locks with lithium grease (part 19 on the realoem diagram here http://bimmerboard.com/forums/posts/366665/) but haven't yet gotten to greasing the exposed parts of the cable. The cable is making a squeaky noise when it's pulled. While looking into the locks as the lever is pulled it appears it's not traveling far enough, which makes me think the cables are worn out from PO likely never greasing it.
At this point I'm counting on having to get new cables but I'm wondering if I also need to replace the hood locks? Anything I should look for?
Old 03-01-2019, 10:02 AM
deyrag deyrag is offline
Mein Auto: 1998 528i
What I have found on mine is that the section of cable from the "junction box" to the inside release is ok. It's pretty straight shot so doesn't really bind up. the section from the junction box to the latches however is very stiff. i would suggest lubing or replacing that section to see if it fixes your problem.
Just make sure not to close the hood while the cable is disconnected, that really sucks.
Old 03-01-2019, 12:41 PM
atobe atobe is offline
Mein Auto: 00 528, 01 540
You can try to wd40 or lube up the hood latches. They get crusty with dust and grim and don't move freely. If you decide to change the cables. Make sure to buy BMW OEM. Yes it cost like 2-3x the price but you won't have to do it twice. I learned this lesson the hard way.
Old 03-15-2019, 02:38 PM
Certified humanoid
Yeah, would NOT want that to happen. Might even go so far as to remove the upper parts of the hood locks, just in case...
As stated at the beginning of the thread I already tried greasing it with Lithium grease (and WD40 before that), which sadly didn't work. Thanks for the heads up on the OEM cable though.
I think I'll just have to grab some new cables and see how that goes...
Old 03-15-2019, 02:54 PM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
WD-40 IS NOT a lubricant. It's designed to disperse moisture.
Old 03-15-2019, 03:22 PM
Santaclaus4 Santaclaus4 is offline
Mein Auto: Two 2003 540i Msport's
I think it's basically kerosene.
2003 540i M-sport
If you put cheap parts on your car, you'll soon have a cheap parts car.
The law doesn't determine right from wrong. They are unrelated.
Similar Threads
Hood release cable dhimme1045 X3 E83 (2004 - 2010) 6 11-12-2019 04:16 AM
Replacing front door lock cable on E38 740i Jettamcq General BMW Questions 1 07-24-2018 10:40 AM
Hood stuck closed RomarioB E39 (1997 - 2003) 2 05-05-2018 11:53 PM
Hood cable replacement... string to old one broke, old one pulled all the way through eugeneasaur E60 / E61 (2004 - 2010) 5 04-18-2018 08:42 AM
Replaced hood safety latch and hood won't open e53houtx5 X5 E53 (1999 - 2006) 0 04-16-2018 04:24 PM
