Morning startup - Bimmerfest - BMW Forums
Old 05-31-2019, 07:21 AM
chitown312 chitown312 is offline
Mein Auto: 2011 x5 v8 M adapative
Morning startup
What causes your engine to shake more than usual during the morning startup even if it isn't that cold outside?
I've experienced this in my N63 a little but have also heard this from my friend who has the newer B58 engine and a 2016 X5 inline 6. We had a couple high mileage 2014 E46 3.0 inlines in our day and those remained balanced even during cold climate winter start ups.
e46 330ci, sport package. (sold)
e70 N63, M adaptive suspension.
Old 06-02-2019, 08:40 AM
B4_685 B4_685 is offline
Mein Auto:
Morning startup
Any more details? - any work done to the car/mileage/unusual noises/smoke - bit hard to diagnose without a but more info...
Edit - spark plugs changed at all? Has the car had all the recalls done?
N63 E70 X5 2012
Old 06-02-2019, 10:34 AM
edycol edycol is offline
Mein Auto: X5 35d (traded in)
Something is wrong with mixture IMO or spark plugs. B58 had some issues in the beginning. It is 2016, first tear of B58, there are usually infant issues at that stage.
Sent from my iPhone using Tapatalk
Old 06-02-2019, 02:20 PM
ard ard is offline
Resident Curmudgeon
Hook up an OBD reader and monitor the real time display of closed/open loop...does it smooth out when it clicks over to 'closed loop'?
Alignment here: The Definitive Alignment Thread
OE is Original Equipment aka 'BMW Original Parts' aka 'What you buy at the BMW dealer with a BMW label'
OEM is Original Equipment Manufacturer... EITHER the company that made the OE part or.... A part this is identical to the OE part, but is sold by the OEM under their own label
OEM is not what BMW sells
http://www.bimmerzone.com/category/T...ricks_OEM.html
https://www.turnermotorsport.com/t-OEvsOEM
Old 06-02-2019, 02:35 PM
Doug Huffman's Avatar
Nuclear engineer
Motor mounts controlled hard or soft?
Engine mount control
The controllable engine mounts are switched to "hard" or "soft" corresponding to operating conditions.
Function
The pressure converter connects the engine mounts to the vacuum supply. When the DDE control unit activates the pressure converter, the pressure converter responds by applying vacuum to the engine mounts.
The engine mounts are switched to their soft setting at:
- low speeds (under around 60 kph) and
- below engine speeds that are dependent on the coolant temperature (the engine speeds are between 1000 rpm and 1200 rpm)
Whether the engine mounts respond to activation by switching to their hard or soft settings depends on the model series:
E65, E6x, E7x: hard.
E46, E53, E83, E9x: soft.
Fault handling
If a defect occurs in the activation of the pressure converter, a fault is stored.
The engine mount control is switched off faults occur to the following functions:
- Coolant temperature sensor signal.
- Message error speed.
Old 06-02-2019, 06:19 PM
ard ard is offline
Resident Curmudgeon
...how to take a $35 part and make it a $350 part....
Old 06-03-2019, 02:04 PM
Function
Fault handling
I had no idea controllable engine mounts existed. My take is they are soft under low rpm(potentially cold start) conditions and then they harden up when at speed to stiffen the motor. I guess the industry thinks we need to complicate the motor mount for the sake of limiting vibrations. As with all add ons it's good until you need it replaced one day.
Old 06-03-2019, 02:14 PM
Nuclear engineer
I have particularly enjoyed having to learn all of the new systems in my X5 35d, some of which I had not heard of before. I had studied Woodward / Mach Effect reactionless space propulsion before I discovered our piezoelectric injectors that use a different implementation of the the same technology.
