central locking system - Bimmerfest - BMW Forums
Old 06-04-2006, 05:29 PM
dtenorio dtenorio is offline
Mein Auto:
The central locking system has stopped working. My key works, locks and unlocks the door. However, once I'm inside the car I can't lock or unlock the car using the inside button.
Any suggestion where I would begin to diagnosis the problem?
Thank you
Old 06-04-2006, 06:12 PM
alpinewhite325i alpinewhite325i is offline
I love my beautiful wife.
Mein Auto: '01 325i
Thanks for sharing.
'01 325i
5sp
I Love my beautiful wife
moonroof:
Old 06-04-2006, 09:21 PM
Vornado's Avatar
Vornado Vornado is offline
Protect your (lug) nuts
Mein Auto: '97 BMW 328i
Originally Posted by alpinewhite325i
Thanks for sharing.
That was rude. If you dont have anything useful to say, then dont post.
dtenorio: I would suggest taking it to your local dealership.
Old 06-05-2006, 07:03 PM
Mein Auto: '01 325i
You think so?
Obviously you didn't see his post before he edited it.
'01 325i
5sp
moonroof:
Old 06-05-2006, 09:13 PM
Vornado's Avatar
Rodger that.
Old 06-06-2006, 10:52 PM
marco328 marco328 is offline
Mein Auto: 99' 328i (E46)
Unhappy
I also have a problem with my central locking system. It only happens intermittently, like on hot days when left out of garage. Remote won't work, central lock button won't work, not even the door handles. Once the car cools down system works fine. I actually got locked inside my car once. I couldn't open any of the doors. Lucky the windows rolled down so I could climb out the window.
Any suggestions or help would be greatly appreciated.
Marco
Old 06-07-2006, 12:45 AM
Howie Howie is offline
Mein Auto:
I have notice that my central locking has gone funny before. Sometimes the second press on the key which will open all doors stops working. I have to re-lock the car and try again. Weird....
Old 06-12-2006, 10:38 AM
bmwyuen bmwyuen is offline
Mein Auto:
My 330ci also had this problem. I can't unlock the passenger's door when I used my remote to unlock the car. Even, when I drop my passenger, teh passenger door doesn't unlock unless he unlock by the door handle.
I have searched this topic in this forum. It seems to be a fairly common problem.
The only solution is to replace the actuator. I am sure it is expensive to do that.
A lot of guy just wait and see. But that's inconvenient to live up with that.
Can anybody suggest how much it costs to replace the actuator ?
Old 06-12-2006, 10:58 AM
ATLBMW ATLBMW is offline
Mein Auto:
The locking system elecrtronics can be affected by extreme heat and interference from other radio frequency/waves around the car....
Old 06-19-2006, 12:52 PM
indyzhp's Avatar
indyzhp indyzhp is offline
Mein Auto: 1998 540i
I've actually got my car in the dealer today, because I've got an intermittant problem with my door locks. It isn't just one door, it is all of them when it happens. The button on the center console stops working too. I haven't made any connection between hot weather, but it may be the case? Of course the dealer said they didn't find any problem, so who knows if it will get fixed, unless there is some sort of silent bulletin on the matter.
Old 06-20-2006, 10:26 AM
Karen Karen is offline
Mein Auto:
I recently posted because all of my doors were stuck locked including my gas door. Turns out that two days after my locks stopped working my battery went dead. Two days after I replaced the battery the locks starting working again and haven't given me any problem - yet... Anyway, the mechanic said they need full voltage or they won't work at all.
Old 06-20-2006, 08:30 PM
legion legion is offline
Mein Auto:
I have had the same problem with first my passenger side and then my drivers side door not unlocking from the key remote or the center console. Had both actuators replaced by a mechanic but still did not fix the problem. In the end they took it to a BMW dealer who plugged their diagnostic computer into it and said the central locking computer was the problem. They replace it and I havent had any problems since.
Old 04-26-2007, 08:26 AM
MROP3R MROP3R is offline
Mein Auto:
Marco
This is EXACTLY whats happened to me!!! How did you have it fixed???? I thought it was my remote key and bought another $275 key...it obviously wasn't that. People think I'm crazy when I tell them that it only happens when it sits in the HEAT! when I put my car in that garage...no problems. PLEASE HELP!
Shelly
Old 05-07-2007, 10:54 PM
Shelly,
Still haven't solved or figured out the problem. I've been quiet about this because it's been relatively cool. Now with todays hot day, the problem is back. The drivers side door opened only with the key. However, I could not get any of the other doors to unlock with either the central locking button or with the door handles. I guess I wouldn't be so upset but I can't even open the doors with the inside handles with makes it extremely frustrating when I picked up my son from school and he had to climb in through the window. Now that was embarrassing. I'm going to change the battery since it's been a few years since I replaced it before. Maybe (crossing fingers) this will help. I post my findings when I replace the battery and see if anything changes.
Anyone with any suggestions would be helpful. If anyone knows if it's possible to disconnect the locking system so that I could at least use the door handles would be helpful.
Marco
Old 10-05-2019, 10:22 AM
Markinspain2019 Markinspain2019 is offline
Mein Auto:
central locking system stopped working
C/Locking suddenly stopped working, searched the net and suspected the GM5 module relays. I removed the module to check the type of relays and dimensions etc, while the module pcb was out i tappity tap tapped the 4 relays, refitted the module and now the c/l has been working perfectly for 2 days. I hope it continues. If it does, either a relay was stuck or a bad connection on one of the multi pin connectors.
Similar Threads
what are the recalls on 95 e36?? nads12345 E36 (1991 - 1999) 28 11-27-2013 01:10 PM
* M6 * - Press Release from BMW Emission E63 / E64 M6 (2006 - 2010) 6 03-06-2007 08:20 AM
1994 325i 4dr. Central Locking fuse. tmb32v E36 (1991 - 1999) 0 07-03-2005 12:50 AM
Central locking system dca820 3 Series & 4 Series 0 09-21-2003 11:26 AM
