Brake Fluid Reservoir - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > X Series > X1 F48 (2016 - current)
Second generation F48 BMW X1 builds on the success of it's predecessor. Increases in power, interior and cargo space keep it a leader in the small SUV field.
Old 10-10-2019, 06:02 AM
gkski gkski is offline
Mein Auto: 430i xdrive cv
Is there a thread anywhere here that details how to get to the brake fluid reservoir and check brake fluid level?
I have it figured out for my 430; getting the right section of the black plastic cover removed, but it's not as apparent with our X1.
Also, anyone have any idea what the cylindrical areas circled are for?
F48 Engine Bay
Old 10-10-2019, 06:27 AM
Doug Huffman's Avatar
Nuclear engineer
Blue circled areas, shock towers?
Www.NewTIS.info. Search "service"
Old 10-10-2019, 06:38 AM
No. If they are, I don't have any front shocks. These are forward of the actual shock towers that are underneath or to the rear of the black cowling.
These "rings" have nothing in them or above or below them.
Old 10-10-2019, 07:04 AM
Nuclear engineer
"Service" brake fluid
https://www.newtis.info/tisv2/a/en/f...nce/1VnXmDFX4R
Old 10-10-2019, 07:08 AM
Thanks, Doug.
That's a lot of screw plugs. My 430 only had the cover secured by 3.
Old 10-10-2019, 03:47 PM
scottinaz scottinaz is offline
Mein Auto: BMW x1
F48 Engine Bay
The circled areas are for some kind of rubber hood bumpers. BMW put them on the 2016 X1s and then decided they weren't needed I guess? My 2017 looks just the same (empty holes). I've often wondered why they still manufacture the car with them? Just one more dumb thing this company does.
As for the brake fluid, sorry no clue. I'm sure I'll be out of the BMW family before I have to worry about that.
Old 10-11-2019, 01:28 PM
Siread Siread is offline
Mein Auto: 2016 X1
2016. Adjustable hood bumper
Sent from my LG-H931 using Tapatalk
Old 10-11-2019, 01:32 PM
Interesting. Seems like it couldn't have hurt to leave the bumpers in their assembly workflow.
Old 10-11-2019, 03:06 PM
Markst Markst is offline
Mein Auto: BMW 5
For $7.60 you can slam your hood even on the 2017 models!
Interestingly the etk doesn't mention them being removed.
Old 10-11-2019, 05:13 PM
Mein Auto: BMW x1
Well it saved BMW a couple of bucks.My 17 was only listed @ $44700 Ha.
Old 10-15-2019, 10:25 PM
Ridin'Dirty's Avatar
Ridin'Dirty Ridin'Dirty is offline
'17 X1 - Rooster Cruisin'
Mein Auto: '93 "Beemer" R100r
As posted on the "other board":"If you only want to see the level of the fluid, just look thru the bonnet (hood) hinge from the drivers side to see the level ( full; half way, right at the molding seam)".
ID:	868375   Click image for larger version
If you can't fix it, you don't own it.
Old 10-15-2019, 10:34 PM
Yup, FCP Euro has 'em in stock!
Name:	X1 Hood Adjuster.jpg
Old 10-16-2019, 07:00 AM
Any benefit to having these? What is the gain with them installed?
Old 10-16-2019, 07:07 AM
Thanks, that's all I want to be able to do, check the fluid level. Maybe I did not try looking directly from the side. I know on my 430, this cannot be done, rather you have no choice but to remove the shroud.
Old 10-16-2019, 04:14 PM
O.K. I can see enough of the reservoir, I guess, from the side near the hood hinge. Or at least I can tell the fluid is up to the "seam" which I understand is between Min and Max.
Beats having to remove some fasteners to just check a fluid level. Thanks.
Old 10-16-2019, 04:16 PM
O.K. Beats having to remove some fasteners to just check a fluid level. Thanks.
It's just practice for when you have to change out the battery.
Old 10-21-2019, 07:29 AM
Can anyone comment as to the benefit of these hood bumpers? If they serve a purpose, they'd certainly be worth the $7.60
HTML code is Off
