Heater always on - Bimmerfest - BMW Forums
Old 10-11-2019, 10:01 PM
Barristerwa Barristerwa is offline
Mein Auto:
Heater always on
So, I recently noticed that my BMW after 30+ minutes of driving the heat, no matter if I have the temperature set to its lowest (60), is letting warm air into the cabin. I have to turn the AC on to cool it down even though its a comfortable 56 degrees F.
Anyone know why this might be the case?
Im thinking about replacing the cabin Microfilter. Im getting a bad smell when I run the AC and perhaps its also contributing to the warm air.
Thx for any help you can offer.
Old 10-12-2019, 03:21 AM
Doug Huffman's Avatar
Doug Huffman Doug Huffman is online now
Nuclear engineer
Your BMW IHKA HVAC must always be on to function as intended and AUTO is the default.
Old 10-12-2019, 04:38 AM
John MS John MS is offline
Mein Auto: 2014 Glacier Silver 328i
If you turn the system off does warm air continue to come in as you drive?
Old 10-12-2019, 05:07 AM
Nuclear engineer
Almost fifty years ago I did an IBEW 4-year apprenticeship, and learned a valuable lesson from a foreman that I did not respect or like. Once I learned the delay between documenting a deficiency and its engineering resolution, I just went directly to the responsible engineering code and they provided the authorized resolution. The foreman instructed me that "a system cannot function properly if it is not allowed to function."
That applies to mechanical systems as well as bureaucratic systems.
The deeper history was that Hyman G. Rickover came to the facility where I worked, years before I was there, and saw a sign in six feet high block letters on the side of a building - ZERO DEFECTS - and his temper exploded. "No human endeavor has zero defects." He started firing at the top GM-18 and all the way down to senior WG. He directed the development of the bureaucratic system above to rapidly identify defects and provide engineered correction. Correction at the management level and at the engineering level.
Old 10-12-2019, 03:44 PM
tex2670's Avatar
tex2670 tex2670 is offline
You Don't Need to Know
Mein Auto: '14 328xi Sport Line
Originally Posted by Barristerwa View Post
So, I recently noticed that my BMW after 30+ minutes of driving the heat, no matter if I have the temperature set to it's lowest (60), is letting warm air into the cabin. I have to turn the AC on to cool it down even though it's a comfortable 56 degrees F.
I'm thinking about replacing the cabin Microfilter. I'm getting a bad smell when I run the AC and perhaps it's also contributing to the warm air.
Did you try turning the wheel in the middle of the dash below the vents from the red side to either the middle or the blue side?
2014 328i xDrive | Black Sapphire / Black Red Dakota | Sport Line | Premium Pkg | Lighting Pkg | Cold Weather Pkg | Driver Assistance | Nav | Sport Automatic Transmission
Old 10-12-2019, 05:18 PM
quackbury's Avatar
quackbury quackbury is offline
///Monkeyazz Duck
Mein Auto: 540i; 428 GC; 340i 6MT
I'm willing to bet you caused the musty gym sock odor by turning off the A/C, am I right?
The ENTIRE system is designed to operate 365 days per year. That includes the A/C function. Even in January in Minnesota when it is -20F outside.
This topic has been discussed on this, and every other BMW model board ad nauseum. Search is your friend.
Current BMW's:
2017 540i MSport
2017 330i Sport
Prior BMW's
2018 340i RWD 6MT MSport
2016 428 GC MSport
2015 X1 35i xDrive
2015 X1 28i xDrive
2014 535i MSport
2014 328i SportWagon
2011 535ix MSport
2011 X5 35D
2008 ///M3 Vert
2008 X5 3.0
2007 X5 3.0
2006 X5 3.0
2006 550iA SP
2003 540iA M-Technic
Old 10-13-2019, 01:07 PM
tex2670's Avatar
It has been. And then BMW updated the software so that when you turn it off, it actually stays OFF when the car is restarted. Why would BMW do this is it's so horrible?
Old 10-13-2019, 03:05 PM
Mein Auto:
Thanks Doug. I appreciate your response.
Old 10-13-2019, 03:08 PM
Mein Auto:
Your suggestion and insight are well received. I did a search first to avoid the standard and well worn reply of doing that and came up empty. I'll try to search better next time. ***x1f609;
heat, heater, hot air, hvac
