All BMWs Ista+ download link - no request - Page 4 - Bimmerfest - BMW Forums
Old 11-12-2017, 08:53 AM
Reclaimer's Avatar
Reclaimer Reclaimer is offline
Mein Auto: 2012 E84 x28i
Originally Posted by mvi View Post
Anyone else having issues with 4.08 specifically? I seem to get "Error: The vehicle could not be identified. Please check the access to the vehicle and check whether the testing-analysis-diagnosis has been activated." Details button gives "NET-0015: HOST NOT FOUND" which is kind of strange as I'm using a K+DCAN USB cable. This cable and computer with 4.07 detects the car just fine (X5 2011).
Ediabas settings and so on should be ok, at least worked in 4.07.
Oh, and noticed that the manual mentions selecting Ediabas in ISTA through the VCI Config TAB.. but in 4.08 this seems to have been renamed to "Vehicle Interface". Don't know if this is related or some other change related.. could be just cosmetic.
.m
Every time you change versions, you have to go back and check that settings are configured properly. Just because it worked in 4.07, doesn't mean you don't have to edit the EDIABAS ini file in Rheingold folder of v4.08.
She said that to me once... about being a machine.
Old 11-12-2017, 09:09 AM
Driver30 Driver30 is offline
Mein Auto: E46
Over the torrent it takes 3 days, with a link over Mega it would not be so long ..
Why is it so rare to find the SDP data on the left for the download of Rheingold?
Old 11-12-2017, 09:17 AM
Reclaimer's Avatar
Waiting for 3 days for free stuff is hardship? A download that size, will obviously take time.
It all depends on the good people who actually share this stuff and they are not obligated to.
Old 11-12-2017, 09:25 AM
Mein Auto: E46
I also offer links, sometimes wanted to provide torrents, but unfortunately I have too bad a line.
In other forums I also send links to Rheingold, ETK and other programs.
But many ask for SDP.
If the torrent works, I'll pack in several packages and load that on Mega ..
Old 11-13-2017, 08:37 AM
mvi mvi is offline
Mein Auto: X5 Xdrive30d E70LCI 2011
.m
Ok so I've got rid of the NET-0015 error by copying ediabas.ini from c:\ediabas\bin to c:\rheingold\ediabas\bin but the problem still persists. Only change is that Details button is greyed out and does not give additional info. The original error stays the same
Old 11-13-2017, 04:37 PM
Mein Auto: E46
Version 4.08.13 have a Bug
Old 11-17-2017, 01:19 AM
alfonz alfonz is offline
Mein Auto: BMW E61 530xd
Hello,
Does someone has Czech language files for version 4.04.12?
If not newest full version of ISTA+ (with czech) can be also possibility.
Thanks a lot
Ales
Old 11-27-2017, 05:46 AM
GBNETWORK GBNETWORK is offline
Mein Auto: X5 50iA F85 & M6 E63 V10
I could extract the first 001 7zip file, but for the second 002 or third003 I get the error code CAN NOT OPEN FILE AS ARCHIVE. Any ideas what could be done to fix the issue? Thank you!
Old 12-01-2017, 04:16 AM
f30zoom f30zoom is offline
Mein Auto: F34 330D XDrive
I already have an old running version (3.54.11) is it possible just to update or do I need to completely remove and re install?
Old 12-01-2017, 04:18 AM
Resolved , it was already extracted, all of the 3 big files. ISTA+ is running in my laptop, just need to try the connection to the car now.
Old 12-01-2017, 05:06 AM
mrashton mrashton is offline
Mein Auto: G32 640i GT; F45 218i 2AT
Delete the previous version and copy the new version to the computer. Run the appropriate registry patch files and you'll be good to go.
Old 12-01-2017, 07:11 AM
Almaretto's Avatar
Almaretto Almaretto is offline
Super Moderator
Mein Auto: Test Vehicles
Likely need to update prerequisite software as well. Standalone versions must be replaced. Native installations can update.
Old 12-12-2017, 10:45 AM
Lords Lords is offline
Mein Auto: BMW 316i
Hello everyone,
Can you guide me where I can download SDP Data (PSdz) for ISTA +?
I already searched the entire forum and did not find it.
Thank you so much
Mein Auto: BMW 316i
Hello everyone,
Thank you so much
Old 12-13-2017, 07:40 AM
ShakilM93 ShakilM93 is offline
Mein Auto: 640D
Thank you!
Old 12-23-2017, 01:27 AM
estragos estragos is offline
Mein Auto: BMW F30 320d
Trojan?!
Bitdefender detects a trojan on file ISTAGUI.EXE!!
With the 4.03 version and Kaspersky it was fine.
The new version 4.08 works fine, but if it have a trojan it's better to come back to the old version.
If I start the ISTA without turn off bitdefender, it deletes the file ISTAGUI!
Someone have the same problem?
Merry Christmas for you all...
Old 12-27-2017, 12:59 PM
Olaf1006 Olaf1006 is offline
Mein Auto: F11 520D
Hello
Can i get a link to the last ISTA-D-P and psdzdata?
Thank you very much.
Greetings
Old 12-27-2017, 01:02 PM
Almaretto's Avatar
Super Moderator
Originally Posted by Olaf1006 View Post
Hello
Greetings
Both ISTA+ and PSdZ are self service. You can find the in OP of Sticky Threads.
Old 01-05-2018, 10:00 PM
brattanek brattanek is offline
Mein Auto: 535i
Short hint form my side for W7 SP1 you need install last libraries:
Microsoft .NET Framework 4.6.2 https://www.microsoft.com/pl-PL/down....aspx?id=53344
Visual C++ Redistributable for Visual Studio 2015 https://www.microsoft.com/pl-pl/down....aspx?id=48145
- vc_redist.x64.exe
- vc_redist.x86.exe
Install booth if not you will get error
I run ista in virtualbox in W7 SP1 x64 on macbook air (but this laptop dont have lan port )
Old 01-07-2018, 03:34 AM
Rer67 Rer67 is offline
Mein Auto: 320
Hi, Thank you for the latest Version. Do you have a french Database also?
F31 320D x-drive Pack-M
Old 01-07-2018, 11:06 AM
Applementalist Applementalist is offline
F56 Driver
Mein Auto: Mini Cooper F56
so i have found this here .
There is a new Version 4.09.13 out . Do you have the link ?
Old 01-07-2018, 11:39 AM
Reclaimer's Avatar
WIP. For everyone else having issues and not resolved yet, don't download this version. New version will be up in a day or two.
Old 01-07-2018, 11:52 AM
F56 Driver
so what does that mean ? 4.08 or 4.09 better ?
Almaretto's Avatar
Super Moderator
4.09 is much faster it also fixes kiswb error for basic features.
Old 01-07-2018, 11:53 AM
F56 Driver
ok i will wait for 4.09
