Pass fog light not working... suggestions? - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 09-20-2019, 06:28 PM
nsguajiro nsguajiro is offline
Mein Auto: '99 328i Convertible
'99 328 convertible
Pass fog light hasn't worked since I bought it. All other lights OK, fuses good, driver fog light works fine. I get 12 volts from bulb connector to chassis. I also checked current and got 300 milliamps, though I'm no elec-chicken and I don't know if current means anything given that the bulb isn't illuminating, though I'm kinda curious to short out the connectors with my meter and see what I get.
I've been told to check for loose grounds, but those wires seem to run all the way back to the fuse box... is there a relevant ground connection I should be looking for? Any other ideas? Thanks.
Old 09-22-2019, 02:44 PM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x3,E30x2, F150
You said you get 12 volts from the bulb socket to chassis ground.....do you get a solid ground (continuity) from the plug to ground? The bulb must have a return path to ground.
Have you tested continuity through the bulb?
Quotes to live by:
Ken Kanne, Silverhill, AL, Bimmerfest Site Moderator
BMW-CCA #441426
1993 325is M3 clone"Ashlyn"; 1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette";1995 318is"Bebe "; 1985 325e "Hazel Ann"
Old 09-22-2019, 06:43 PM
I checked bulb continuity, hot to chassis voltage, and ground connector to chassis continuity.
Possibly also relevant is that my washer fluid motor is also not working.
I did find the Bentley Manual pdf and dl'd that, I haven't had any time to mess with it today, but hopefully that'll give me a better idea of what I'm looking at and what to check.
e36, fog lamps, fog lights
