93 318i mystery vac hose - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 09-27-2019, 01:51 PM
Bubba14 Bubba14 is offline
Mein Auto: 1993 BMW 318i
In the process of replacing the alternator on this vehicle had to move/disconnect several vac hoses. Now we have one that we can't figure out where it goes. One end of it is connected to the throttle body between the TPS and air inlet tube, the other end goes down from there to somewhere. Can't spot it with a visual, does anyone know the answer to this? M42 motor. Car idles like crap with it disconnected.
Old 09-28-2019, 05:21 PM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x3,E30x2, F150
It goes to the vacuum accumulator, a black plastic cylinder about 3" in diameter. The end pointing up has a recess where the hose connects. There should be a check valve between the manifold and canister.
Quotes to live by:
Ken Kanne, Silverhill, AL, Bimmerfest Site Moderator
BMW-CCA #441426
1993 325is M3 clone"Ashlyn"; 1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette";1995 318is"Bebe "; 1985 325e "Hazel Ann"
Old 09-30-2019, 11:55 AM
Mystery hose
You were correct- found the fitting. Apparently the part the hose connected to is the charcoal canister. But alas, as we were re-connecting the hose we discovered another hose that was attached to it, which is now broken at the hose connector. The canister connecter nipple is fine, but the "vent pipe" connector is toast. New vent pipe is available, but apparently will be a real pain to change. Does the vent pipe, PN 16131181018, extend to the fuel tank as a single unit or is there another connection along the way before the tank area. Or, is there some kind of connector repair kit available to repair the vent line and avoid changing it out?
Old 09-30-2019, 02:00 PM
D'oh, You Kids!
No repair kit that I'm aware of. You could try JB Weld, but that's dodgy on a fitting that's had fuel vapor/oil vapor through it. The vapor return hose isn't one continuous piece. Follow it back and you'll see a joint just before the tank in back.
Quotes to live by:
BMW-CCA #441426
